View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Interior Stinks!!!
- questions about elevation, please help!
- '87 si needs help!?!
- Help car wont start, cranks and get spark
- P28 Help
- OT: maybe SSR type X's
- Which ECU guys?
- strut bars
- some new crap for my eg
- OBDII emissions
- bolt in roll bars
- Which Cold air intake? or custom
- This was on my front door step when I got home......
- Ek hatch DX/CX engine - which engine?
- japanese spec zc into 92-95 civic?
- 5G Hatch and suspension/GSR brake question
- intake help??
- harnesses are less safe than regular safety belts?
- Y8 head?
- can civc exhaust cause power lose on H22?
- suspension compatiblity??
- Need some help for my home projects!!!
- For anyone wondering about smog check with OBD II to I...
- rear main seal installation? anybody personally do this?
- Question on A-sports inner fender bar.
- Will NSX calipers fit on stock 00 Si\SiR Rotors?
- just thought i'd share a cool video
- Anyone know where I might be able to find the new Racing Hart rims?
- Gettin new motor! what to check and change out?
- I Deleted the "How to Avoid Theft" Thread That Was Just Here...
- TPS sensor
- Endlinks.
- Integra SIR Strut Bar fit '96 EK Hatch?
- All you people from Nj
- Anyone have the upper part of the interior black?
- So I am kinda new here...
- How to remove back seat & rear panels from Eg hatch?
- question? has anyone on here bought from tornactive the 98-00 hb lip?
- At what speed do you shift your DX?
- How do you remove the sideskirts on a 92-95 Civic?
- help w/jdm cluster
- OT: music affects the way we drive.
- Best online place to buy Benen products?
- spoon progressive spring question ?
- JDM header Bracket
- does anyone have the pin out for an eg2 and eg6?
- quick question
- build up and swap pics, 56k-nope
- Type-R Tube Vs. Comptech
- how many
- tire rubbing
- axles are a breeze...
- Best daily driven trany for LS in 93 Hatch
- EF SiR Brakes on EG
- Miles Per Gallon b16a jdm
- Vin number and CArfax Help please...!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Anyone have an extra stock Eg front lip??
- i need help with vtec wiring for d15b
- what would happen if..... H22 question
- How much is a brand new B16a2 S4 tranny from the dealer?
- TODA SPEC C's or Skunk2 Stage III's
- Rims for My Civic
- Installing CF Duckbill on EG
- Post your GREEN EG hatches here!!!!
- Post Your 99-00 Hatch Pictures!
- what is this called and how much $????
- price for OEM 98 ek hb sideskirts?
- h22a or b16a2
- How to get loans for auto...
- People who have 96+ civic ex coupes i KNOW you have this problem too!
- Glove Box question
- I think something is wrong please help!!!!
- why can some cars be started without pushin in the clutch and some cant?
- Can i Put a 16V head on my 8V CX block?
- i need valves for an 96 Sohc Vtec head..
- Where to go????
- B16 turbo question
- new ACT (XACT) flywheels
- can't figure out a motor damn it
- great del sol to fix up!!
- got some new parts.. jdm stunna y0
- Carbon fiber lips / hoods / spoilers???
- look at whats going on in the FI section
- Must Sell 1996 HOnda Civic
- d16z6 vs d15b
- Removing cluster needles on EG
- weird idle can i get some help?
- Bumper brace removal question on 96-98
- civic Type R tb size
- Fair price to mount wheels / tires & balance?
- KYB AGX settings???
- NE1 ever do a JDM RHD conversion!
- pics of my car
- Tach
- Civic pics for you
- How did you mount your AEM EMS?
- b18b wiring!
- wanted
- finally in the 12's
- i have no brake pedal after new pads!!??
- Del Sol
- Anyone have a 92-95 hatch with swap for sale??? I have 10k! someone help me out!
- camber kits?
- Replacing front right fender
- interior question
- I am getting a code 54 Crank speed fluctuation
- will wheels rub after camber kit install?
- lowering questions??
- HID guys...???
- SOHC performance...
- video of my whip
- help real fast
- B18 or B20
- why are my plugs wet?
- Help????? How in the world am I going to get this door open ATTN:everybody
- O2 Sensor Interchangeability....
- What is needed?
- Transition pics of my car and an ITR suspension question.
- GSR brakes on civic dx
- Temp. of ECU? Hard Question!!!
- Lowering 01 civic
- mini me swap
- Does EK Side Skirts Fits EG Civic?
- Need Help, my dash guages stopped working. fuse problem?
- Does the crank pulley on the d-series have a key way?
- Need some info
- noise from the rear
- A LS rear sway into a civic????????
- fender flares?
- brake problems.....help!
- do i need a 98 or 99 radiator support?
- need ya's help...
- need help with exhaust for my hatchback!!!!!
- installed my SI rear sway bar...
- Force induction help
- What are my options? Swap engine or modify current one?
- H22a in a GSR swapable in Civic?
- eg6 carbon fiber hatch
- SVPsohcturbo pics
- Help on how to keep wheels
- earth/groundwires?
- si sohc 1.6 / Y8 merge (need help)
- Issue with ignition or clutch switch maybe?
- What wheels?
- what size are city light bulbs of '99 ek9?
- Those who are running a Field SFC-VTEC controller
- '02 Civic Fuel warning
- EG Civic 15x6.5, Is proper offset +38 or +45.
- Question for SLAMMED guys...
- got questions on porting..
- AZ eg owners meet recap/new page to whore on!!
- Finally picked up some rims...gotta few questions....
- proper way to install a MC brace on EK
- got my sir guage cluster from osaka today.
- Crankshaft Replace
- Starting Problem
- b 16 into a 95 coupe ex any one who knows a good shop
- i got a 96 SOHC Vtec head , i need the valves though. anyone know where to get them cheap??
- I got a SOHC VTEC head from a 96 civic, will it bolt on to my 93 CX block? what do i need?
- Brake Upgrade
- crv swap??????????????????/
- A/C bracket??
- Power steering installation?
- what about aem intakes?
- 205/45/16 What's the Best Tire?
- Major problem with exhaust need help!
- ## Do 215/45/16 Falken Azenis rub on 92-95 civics'? ##
- front lip...need help...pics inside
- 1st car..yes im a noob
- Newbie... kinda
- three hundred and fifty dolars for WHAT?!?!?!?!?
- DeLsoL Ebrake Qs
- New windows.
- Need Brakepads ASAP *Revised*
- What fluids to drain doing engine swap?
- EK = ?
- 99 Ek, and b18c1 wiring prob
- where to get b16 knock sensor online?
- another civic stolen in NOVA.. look out everyone
- DelSol removable top
- where i can find an online helms manual for a 92-95 civic?
- they stole my rims
- thinking bout buyin suspension techniques front and rear sway bar for 5th gen hatch
- Axles question
- A new guy with some questions
- y8 in a dx auto?ASAP
- Any of you EK guys formerly an Integra owner? Do you regret the change? Why or why not?
- CTR cams or Spoon Sports race cams???
- gsr swap almost done. prob with vtec.
- NEED HELP (IAC)valve adjustment
- Which Head is Better?
- BOV simulator...WTF??
- stock stereo installation problem!
- If a EG6 is a hatchback, what is the coupes code?
- Help With Amber Gauges...
- stock fuel pressure for a 92 DX?
- all motor...look!
- To trade or not to trade?
- 95 gsr suspension parts on 92 cx hatch? everything basically the same?
- Nova Cars
- 5G interior colors
- swap
- recaro brackets for the civic
- motor got water IN IT******!
- Car won't start after pulling my head
- How do you Make JDM RHD power windos be LHD controllable?
- just got my gsr rims
- Question
- Anybody have pics of 4 door EGs with removed side moldings?
- turbo or all-motor?????
- should i sell the hatch???
- possible water thru intake?!??! help
- How to polish glass on a 95 cx hatch?
- anyone near kopiague?
- very early rev limit!!!!!
- WTB: Anyone KNow where to get Factory Fog Lights for 99+00 Civic, If you have em or know where to g
- HELP ME!!!! I am having major tire problems
- How to convert my car to NON-Power steering
- Short Shifter
- LS vtec
- Anyone have a JDM eg b16a cat?
- I am being forced to sell my car :( But I am being given a teal green one.
- BrakePads!.. NEED HELP ASAP!
- ATTN: ATL vandals!!! Grrr
- "please read" need help guys "please read"
- 92-95 Duckbill suggestions?
- I got my Spoon wheels today!!!
- Electronic cutout
- throttle body ?
- H22 EK Handleing?
- anyone have experience with these exhausts?
- doing a swap i encountered a problem...
- thats all she wrote
- Which engine for swap... B16a2 or B18c1
- lightest performance tires...
- Looking for lightweight & deepdish WHEELS
- Help with Vtec and my SOHC swap
- Squeaking car.
- OT newbie problems
- Turbo Delsol Question
- Please help , been ripped off by Del Ruiz from Portland , Oregon
- what kinda HP and 1/4times are the coupes pushin around here
- What Rear Lower Tie Bar will fit under Type R Sway Bar with Beaks kit????(PIC inside)
- Best 99-00 hatch to buy??
- Vtec conversion??
- REmoving Climate Control BulbS??
- d15 injectors
- How long does it take to become a full member?
- Auto to manual swap guide is up.
- d16z6 injector install question
