View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16z6 parts question
- B16A Upgrades
- radiator hoses?
- Would a stock ecu and dsm 450's cause 3000+ idle when cold
- Car dies randomly when I stop
- car wont start
- Starter problems
- DOHC ZC Swap.. obd1-odb0? converstion??
- Codes 14 and 17 '99 Civic
- z6 and y8 vtec solenoids the same?
- error code 12 EGR on a d16z6??
- 1996 civic lx. Pushing coolant into overflow?? help
- 2000 civic ex with d16z6/y8 head
- D16y8 pm7 pistons
- 95 civic EX overheating/leaking near water pump
- Gutting the back
- overheating above 50 mph or uphill (highway). I already searched
- what gains?
- HELP! Foglight Switch Wiring
- DIY Vtec indicator light (revamped)
- EG coupe vs. hatchback quarter panel
- GSR exhaust on a B16A
- 99 Civic LX leaking coolant out of overflow
- V band exhaust tubing and universal mufflers
- del sol hydraulic steering rack compatibility
- DIY d16y8 rebuilt
- Tried starting car with timing "off" would this bend vavles ?
- Sabatoge?
- Bad Sputtering Help
- purge valve
- Driver side window doesn't always work!
- Another TDC Thread
- ek radiator support
- ebay MLS head gasket
- Swap
- EJ6 BlackBanditCoupe
- 92 Civic VX daily driver build
- del sol vtec cluster harness, what others fit?
- Cv joint pops out of passenger side axle
- distributor timing
- Where Do You Recommend I Look?
- Bad fuel/air pick up after high rpms.
- side skirts 92
- Car struggles to start. Ignition switch?
- NED HELP ASAP TORQUE SEQUENCE D16y8/ d series ASAP!
- Engine/transmission question.
- 95/96 swap?
- HID fogs plug help
- mystery connector anyone know where it goes
- distributor issues need advice
- 95 Civic DX clutch switch pushing pad broke off. How can I install new one?
- AC condenser question
- Temperature gauge different from scanner coolant temperature reading - 97 Civic HX
- 99 Civic SI Alternater problem?
- Window problem
- Complete Engine and transaxle Mount kit?
- ek civic
- PLEASE HELP!! COOLING ISSUE
- fender and hood gap
- A/C Compressor grinding/clunking when clutch engaged...
- 95 ej1 b16a swap
- Injector pulse..
- Rear console cigarette lighter in EG?
- Extending Wires B-series swap
- 00 civic ex wireing question! need asap
- b16a2 head with b18c block, stock hp #'s???
- 99 civic si tachometer help plz.
- 1992 honda civic LX, d16z6 swap.
- High Output Alternator Strange Behavior
- 2000 civic si, block shot, should I repalace with b16a2 or b18c or b20 vtec
- Snapped my bleeder bolt right off!!!
- Civic EH9 fluid changing period
- Clutch Choices.....
- Tachometer help - 99 eg8
- Engine Knocking - May be my worst summer.
- Civic dx Hatchback 1998 bolt on motors ?
- 94 hatch - struggles to start in morning, sluggish, cuts off while driving
- throttle cable replacement
- Help with a 93 4dr B18 build.
- My acceleration is hessitating
- Need help car revs to 3000 grand at idle an than drops
- Vtec only kicks sometimes need help!
- what all is needed for auto to manual window conversion.
- Ecu plugs cut off, Now I need a new harness but I need help
- B20b Hytech Rep Header A/C Friendly
- Block/Head questions.
- 99-00 hatchback rear seats into 96-98 don't fit?
- different quarter panels?
- what cams wont require a tune
- major tire blow out story (ELCTRICAL ISSUE OMG)
- shorter gears for my y8 transmission
- CEL on and then off?
- HELP!! SiR Eg coupe..
- Engine Swap & Exhuast Question
- Need some guidance with tb and mani
- knocking noise
- front shock replacement 98 civic
- Convert 92-95 civic diagnostic port to OBD II.
- D16Z6 block notching
- Is this head any good
- 99 Civic Ex Coupe Front end vibration and warped front right rotor
- 94 EG Coupe AC smells funky
- Help please eg8 dohc zc - electrical problems
- Child seats in EK9 *HELP*
- radiator or other problem
- Check engine on engine brake
- 2000 EX Coupe EJ8 Throttle Body Questions
- Fully built b16 head tips PLZZZZ need help on biuld
- COOLING SYSTEM PROBLEM?
- AC Bracket / Bolt Mount
- Car won't start, replaced fuel pump and filter.
- 93 ex d series tranny question.
- 99 ej8 wont turn over
- ECU grounds
- are d16y8 and d16y7 dizzy the same???
- 98 Civic Dx (Vibration)
- Driver Door "L -Switch" switch broken-Needs help
- Change out your lighter for usb port
- 1994 civic d16z6. Swap help!!
- bushing confusion moog k200120 beck arnley 101-4510 picture
- BrakeLights/Horn Fuse (15) keeps blowing 98 Civic
- Timing belt tensioner on a 1995 civic d14b7
- 95Civic abs
- subrame problems??
- Roof Trim/Molding for EJ8
- help with rpm
- Red conversion ??
- 95 Civic Engine Swap/Smog Question.
- Engine and Transaxle question.
- Possible spun bearing??
- Brake Clicking issue
- High idle upon start up
- skunk2 or rmf headers
- Distributor question on a d series.
- 1997 Civic SRS Reset - blinks three times after reset procedure
- 99 civic si
- WONT SHIFT OUT OF PARK & NO BRAKE LIGHTS
- 97 civic hx having problems not sure what to do?!? Please help
- B18 block / B16 head HELP! please
- 95 hatch spare tire lid
- 92' civic LX sedan build, Project Sleeping Beauty
- 96 civic ex coupe vtec. bad distributor?
- A newbie 99 si build
- Retro fitting a Civic - glove box light or low fuel light?
- Best brake rotors
- Civic D16y7 Auto Throttle Body VS 5 Speed
- Engine specs
- Unexpected Engine Problem
- new rear brakes, e-brake issue?
- Factory emblems a problem.
- ignition timing once again..... smog is my enemy
- suspension improvement
- 2001 ITR Trans. gear lockout?
- Front lip installation
- 97 Civic missing when warm
- new to the forums - 95' DX sedan auto
- Manual rack suggestions
- civic oil pan (gasket)
- Engine turns over, no spark
- 99 D16y8 IM on 96 D16y8 head
- 95 Civic A/C Blew fuse, killed fan... Tried a few things, still hot air.
- Del sol rear window not working, in need of help.
- ZC Vtec parts
- limp mode mystere
- two part question high idle and collision
- ac blows warm at idle, colder with rpm
- 98 civic ex vs 00 civic ex wire harness
- Best brakes for 2000 civic
- Which ecu to use for my eg auto D16z6!!!
- 2000 front subframe
- d15b 3 stage vtec -- Im Astonished !!!!! WTF
- Unknown sensors/connectors
- D15b Injector Size
- Cheapest way to fix cracked exhaust manifold?
- Unfused ECU?!
- Civic EX coupe vs Civic Si coupe
- OEM axles
- need to get out of limp mode
- Just got another Del Sol
- D16A6 Block Questions
- 98 civic dx hatch interior help
- 5th Gen Coupe Collapsible Mirrors Compatible with 6th Gen Coupe?
- Bone Stock EG CX : removed distributor , messed up ignition timing help!
- custom exhaust on my 94 eg coupe.
- Window washer jets need replacing. 99 dx
- Motor oil VS Manual Transmission Fluid (MTF)
- HELP!! CAR OVERHEATING AGAIN!!
- 93 Del Sol Door change
- Fuel Gauge problems. JUMPY
- obd2a engine harness and ecu in a obd2b car
- 98 Civic LX won't start
- Distributor O ring replacement.
- Need help Plz! Noise under hood. No CEL's I'm stumped..
- b16a2 / gsr turbo HELP!!!!!!!
- 96 00 civic window fix? unhappy
- diffrent head better mpg?
- ls vtec loud clicking
- Crank Sensor question
- chasebays eg harness in ej8?
- Loss of power after hard run
- Civic Hatch 94 - With GSR Motor (Speed Sensor Issues)
- 96 LX sedan front spindle on a 99 EX will it work
- Headgasket?
- 94 ej1 probs, Clutch pedal won't come all the way back
- Gears too far to the left?!
- Cornfield EM1 Find in Ohio. Should I save it?
- 95 civic randomly won't start - no elec.
- Engine With Knocking Noise.
- HELP Identify these Headlights
- new to honda-tech
- Engine rpm fluctuates when accelerate
- 1992 Honda Civic AC not cold enough! Blowing 70 degrees.
- Integra rear sway bar bushing mod for Civic
- skunk 2 cams noisy/valves/tensioner
- Bogging RPM Driving, Hesitation When Accelerating
- BONE STOCK 98 EX COUPE. Need suggestions!!!!
- Odb2 honda del sol harness into obd1 civic hatch
- VSS?-1993 Honda Civic
- 93 Honda Civic Timing belt
- Your ownership experience?
- 92 eg will not start or crank
- Wiring harness ID
- HELP Identify Sparco seats & which rails to use!
- Rear Teg Sway bar problem
- what kind of seats are these ?
- ignition issue
- 98 Civic DX Heater Blower Motor not running.
- Another Power Window problem...
- Coupes N' Kids... Opinions needed
- Oem injector upgrade
- a/c lines from a ek civic match a jdm sir2 b16a compressor?
- Vtec Solenoid cracked.
- SRS Code 72?????please help
- Best way to fit prelude recaros in ek civic
- d16z6 bronze valve guides daily driven turbo??????
- wiring harness help!
- rear disk conversion
- compatible with del sol
- 93 civic hatch wont turn over, everything dead.
- Speed Sensor?
- Injectors not working? 97 del Sol SI
- facelift conversion
- Carburetor to efi
- How many bolts?
- No code, but severe hesitation, once a day or 2
- Weird Cel
- 98 civic ex auto rpms bogging & hestation to move off quick while driving
- Help idle issue. Yea i know right. Help
- what sealant to use for water leak
- BYS LIP
