View Full Version : Honda Civic / Del Sol (1992 - 2000)
- question about v-tec controler
- ARP studs...new head gasket oil everywhere??????
- wheel offset for NSX brake calipers?
- it this even worth my time, a cheap mod that tis!
- **WANTED** Vids of B18C type-R swaps
- wat type of engine
- Help modding a d16z6 on a budget.
- explain to me
- I'm new here on HT... Great place!
- PCP headlamps vs. TYC headlamps
- open header or close header
- Need Helping Passing Smog
- difference between auto/manual d16z6
- 3rd Gear Scratches...
- in need of a shocks and springs change diy...someone help!
- spoon style side mirrors?
- clutch problems
- ls/vtec oil squirter?
- Front bumper swap
- K20 swap into EG?? whats needed..??
- Removing spotlights on 99 EK?
- 96-00 hatch owners with ligh gray interior...
- how fast??
- Suggest a Camber kit for my EG
- A/C vents + inner door panel parts
- EK strut bar help
- Codes 19 and 21
- Weight differences between bubblebacks / hatchbacks / coupes?
- Chipped ECU
- YS1?
- eg with a b series axle question
- k20a3 in a 92 eg cx civic?
- z6 into a 94
- h&r springs on my civic? which?
- WHICH SPRING SHOULD I DO?
- quick shift linkage assembly picture request.
- Hbrace on ebay?
- Need H-T help again, my cars popping and im throwin a code now
- D15Z1(VX) flywheel on a Z6 possible?
- winterizing my civic
- [FAQ] Y8 Oil starvation ?
- Buying a car with a swap w/o papers - advice
- d15 to d16 vtec head swap
- b16 in eg, what kind of mounts??
- how soon should I cange my oil after switching to synthetic?
- 2000civic dx ECU. what is it called?
- Honda civic ecu obd2 codes ?
- Dome Light Fuse Problem, but interior lighting SUCCESS!
- tach into a 96 CX hatch
- Has anyone dealt with Japan Star Motor recently?
- EX automatic transmission numbers in ink ?
- EG Predicament. OEM fog lights clash with bottom corner license plate.
- Civic Type-R Headlights
- People with lowered Civic - HELP
- nice JDM EK's post up pics
- Whats the Wise Decision for my 94 ex
- Gauge Clusters For 91 civic
- What trannys are possible for a b18b ls swap?
- hasport motor mount install b16 in 93 coupe
- Where can you find usdm Si motor
- need help with gauges
- EK: Auto To Manual + B16 = what tranny mount to use?
- new to the site
- Do you Really Need a Knock Sensor??
- HELP!!!!!!!!!!!!
- b18b1 or b16a2
- Thinking about buying '99 EX sedan in 5-speed for my girl?
- engine mount question...
- Hedman header
- Lights dimming???interior and headlight???
- looking for 98 civic rear bumper (sivler)
- cusco cages..u got one?
- Have you seen this intake!?
- Looking to sleeve my block?
- Swaping an engine into a 92-95 coupe frame - how much to get it to beat an 02 wrx?
- steering wheel
- possible dumb question about intakes.
- Need help quick
- EG CX owners... cigarette outlet??
- Axles....Help!!!
- is it worth it?
- New Clutch? B Series?
- Vaccum Diagram Chart?
- Gsr 92 Hatch Swap
- 1998 Civic.... Is this correct operation of the locks?
- Idea for rear hatch INTERIOR LIGHT, check this out...
- electrical help, alternator acting wierd.
- Gauge PODS
- d16y8 intake manifold removal question - searched
- Just got done with my b18c, having problems, need help
- Burnt out cat...loss of power
- K20 in to eg6 (step by step how to)
- cranking noise from left side suspension....
- help with cluch
- Machine work needed!
- HELP!!!!! EK Civic Type R Lip. I cannot find this particular type r lip......
- h22 skunk2 manifold?
- Help CEL code 41
- Tranny swap
- **n00b question** ECU?
- 1991 Civic EX trunk latch won't close
- So how hard is the sway bar install on my EG?
- Short Shifters
- Break pads need replacing?
- Power window options in DX
- Smog CA Referee Question
- tranny question
- 2005 Civic LX Intake question
- vin decoding
- Valve/spark plug cover bolt broke....
- Question about projector headlamps
- need lots of help....
- 92-95 CTR side skirts?
- question on ecu!
- ECU
- Where could i get door panel inserts like in this pic?
- new head on ls motor
- something doesnt feel right
- 96-00 EX intake and exhaust Mani...
- how to switch the climate control
- pivot vtec controller?????
- 1997 civic bought all hooked up
- What muffler can u use when cat back are illegal in ur city?
- sohc swap
- Will coilovers made for an ITR fit a 96+ EK hatch with CTR 5lug suspension and brakes?????
- How do I repair these small dents?
- dizzy help
- Need Advice: Buying 97 EK with Salvage/Rebuilt Title.
- d16z trubo
- how much is this car worth??
- '95 Civic Disk Brake Conversion
- trick to fix exhaust rattle.
- where to unload old tranny fluid?
- h22 hatch with jdm headlights
- HELP: 96 civic hb with 97 ls swap wiring problem located in st paul mn
- Looking for a certain thread. "Perfect Female"
- help on going turbo?
- Help, knocking motor
- Will these parts work?
- Dam Thieves : (
- Pretty dumb question but..a short ram intake only screams in the high rpms and is quiet in the lows?
- cluster wiring diagram
- Need help with Valve Cover Bolt!
- Did Mugen make a carbon EG bonnet?
- civic vx wring harness question
- Ok don't tell me to search because it won't be found...what does a 98 hatch GSR run 1/4 mile stock?
- shift linkage problems.
- Part # needed please help
- Problem a friend is having with his B16 Motor (please help) ANYONE With Motor Knowledge!
- H22A JDM axles on a 96 honda civic coupe
- H4 Harness Help..
- Quick upper control arm question
- squeaking Clutch pedal. Please help me out here
- 99 -00' Si Strut Bar on a 97' Ex
- HELP CAR IDLE HIGH!!!
- Distributor advance
- difference between d blocks?
- ZC DOHC
- h22/ek harness
- mods on a b16a2
- need to choose one seat..put ur o2 here <---
- Mail order parts ?
- Anyone ordered a motor from Passwordjdm.com???
- Car running on 3 cyclinders?
- misfire CEL's
- d16y8 manifold swap, question about spring/coil on tb?
- Valve Adjustment - Cost?
- Camshaft Question?????????
- b20 swap into 97 civic dx coupe?
- problems with shifter
- 4 wire o2 sensor
- Help: 40/40 Prop Valve Install onto EG/EJ
- what suspension for civic?
- Fiberglassing a whole EX dash...removal???????
- Vacuum leaks/idle adjust screw. Check this out
- Power from cx
- Vaccum pressure dropped, what should it be at?
- Honda Access door visor (how too)
- Looking for Civic in Montreal
- Those of you with Manual Door locks, how could you make the door locks open....
- Spark Plug and Wires Post
- Apexi N1 routing
- what the heck! Handling newbish question
- Input on best brake pads!
- 2003 civic cluth
- OBD 0 to OBD 1 conversion on 91 civic dx
- Show me your 99-00 Civic Si with projector headlight...
- Question regarding seat bolts
- Fixing / Replacing a snapped door hinge on a Del Sol ?
- F22b
- Anyone using a 4pt h-brace
- Honda Civic 92 - Air Condition problem
- Turbo civic gets ripped by my talon...
- What exact part could be damaged?
- Brake Swap!!! *** Already Searched *** Need your help!!!
- White pearl 99 honda civic HB Stolen 11/18/04 between 1am and 6am
- exhaust on 99 a door
- Mustang Replacement Radiators !
- [FAQ] Sea Foam.. worked for me. many pics.. 56K maybe on a good day.
- How to remove interior Radio Trim piece..
- 97 Civic DX Motor Swap
- Important question!!!
- Quick question on 96-00 side mirrors
- valve adjustment
- y7/78 mini-me question, using stock ecu
- I need a practical car that wont cost a lot of gas. preferably an older civic. what should i get?
- taking apart an aftermarket headlight?!
- Tein S-tech Vs. Progress
- Quick question for ek owners.
- Question from Europe / Tuning
- memory fab intake aka bling fake J's
- Tach problems???? need help ASAP!
- Motor Swap/ Emission Question
- Cold Radiator Hose
- Engine harness D16y8
- CAI quieter than a shortram?
- How much does camber and toe effect steering?
- Can I use old throttle body??
- b18b1 club. if you have a 92-95 civic with the LS swap. come in!
- LS Motor only gives 20 MPG. Input needed.
- Turn signals
- ca smog motor swap question
- USDM type R tranny for 5 lug
- clutchmasters ?'s
- DX with EX D16Z6 motor
- b16 turbo or all motor GSR?
- Cleaning up ENGINE BAY, any tips???
- mods
- Is the N1 angled???
- Buddy Club Racing Spec Damper..???
- Oil light flickering RIGHT as I start my car.
- Manual Tranny HELP!!
- New exhaust advice
- camber and lowering
- Will I be able to pass EMISSIONS????
- Help me choose a wrap for my ride...tire advice needed (specific inquiry)
- Hid system
- Proprotioning Valve?
- DA to EG
- Tire question???
- please help!!!
- Help with civic
- will turbo fit wit a/c in eg on gsr?
- I need help with ecu problem
- What is a EG8
- ECU code 21 (VTEC solenoid), why why why!?
- where can i get and civic hatch type-r?
- WHAT DO YOU THINK?
- Should I get a Skunk2 Cat Back Exhaust?
- need help with my account. please
