View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Certi-fit fender price?
- 2000 honda civic sedan driver door window slowww
- Audio system in 97 del sol
- Figuring out what rear disk brakes are on my Eg?
- manual transmission fluid, oil, oil filter questions...
- Back after 7 years! Need help with idle problem.
- d16y8 chipped ecu problem plz help!!
- injector size
- Searched: econoline o2 sensor for honda
- will d16z6 start on a non-vtec dizzy
- 96 Del Sol driver door won't unlock or open
- How To- Install Air conditioning into a Non A/c Del Sol or EG
- S2000 Steering wheel into an EG or Del sol
- CV Axle Boot?
- Can 87 gas damage a cat converter.....
- b18b1 in a 99 EM1 questions
- Help with EK POWER FOLDING MIRROR!!!!
- 93 Civic 4dr electrical issue
- swap problem
- Automatic transmission, loose first , then fourth after its warm ?
- turn signal doesn't work after car got stolen
- vtec issue
- JDM Integra Type R steering wheel in eg - airbag connector problem
- Is there any way to check codes without jumper pigtail?
- Picking up a b16a swap.. Question Obd0 to 2
- Where to get a new carpet for my 97 del sol vtec?
- Oil leak.. any suggestions?
- what pistons?
- Oxygen Sensor Wiring - '93 Hatch
- 96 Civic Temp Guage problem.
- Anybody have input on new TB?
- rear disk conversion on 93 LX
- OBD1 Code 41 Heated oxygen sensor heater
- What u think? My mini me build so far
- buddy club spec 2 exhaust?? sound problems..
- can some one run a vin for me? pls & thx
- 2000 Honda Civic EX 115,000 Miles
- 1999 ex b18c civic not starting!!!
- b16a w/ ls tranny - should i go b16 or gsr ?
- RSX seats fit in 00 Civic?
- Steering rack guide screw How To "tighten" guide
- Question for true "builders"...
- WDPfreak's EG Sedan: Project "feri-yo"
- RIP PROJECT LAFONDA!!
- d15b problem
- Dizzy swaps
- tps Sensor help needed!!!!!!
- JUst finish Swapping, and DIzzy has No spark!
- 92-00 civic d16/d15 5 speed tranny
- HELP: f20 or k20a in civic del sol!
- New here :-) 93 Civic with speedo and transmission problems
- Maximum muffler length on 00 civic.
- Eg door panels?
- pcv valve on d16y8
- Wiring iacv for y7y8 mini me, need help
- Broke my valvecover bolt need help
- Headlift cause heat not to work??
- teg calipers on cx civic knuckles?
- d16z6 timing belt, water pump, tensioner and seals replacement recommendation
- Need help b18c1 to d16y8
- maybe a dumb question (flame suit)
- del sol died and now won't start
- 00 civic ex unable to time properly.
- 92 hatch, MILANO RED JACKED!! :(.... carolina tag # ILANBOI
- Mobil1 0w30 Advanced Fuel Economy
- 93 Civic Dx Integra Brake Conv Gone Wrong|help
- Vx motor / p07
- p07 ecu ??
- Ex coupe braking problem :(
- 92 EG. CAR TURNS OFF AND WONT START BACK UP AFTER CAR IS AT NORMAL RUNNING TEMP.
- rough idle/gas smell
- B16b ecu on a b16a2?
- 97 civic coupe with b18 swap need a few questions answered.
- 96 Civic with FTPS code and no power
- No clutch start ?
- Nasty grinding the first 10 seconds after start up.
- EK Gsr seats?
- relay? ecu
- How to get more power out of my 99 si
- half rad/fan problem
- del sol trunk problems
- Will 99 civic header/exhaust fit on my 98 civic?
- Snapped fuel rail bolt
- Power window is 'jumping'
- transmission leak??? idk
- Starting problems?
- Windshield wiper fluid kit?
- 00 ek smell
- my car died =/ can it be the fuel pump?
- Shift Knob
- 99 Honda Civic EX Coupe wont pass state ref
- 93 Del Sol Vtec Solenoid Question
- 93 civic 1.5 NO SPARK NO FUEL
- obd2 powersource
- 1997dx civic
- Help on D16 build
- 6th gen windshield molding
- My ZC 1997 p2a parts gathering
- GSR Tranny noise
- 95 civic ex. my plans need advise!!!!! Losing coolant
- Rear Disk Conversion
- LS VTEC SWAP PROBLEM!
- Violent jerking while car in motion
- over heating issues please help
- Stripped lugnut on an extended stud. pics*
- B16 out of a Delsol whats the engine stamp
- MY CAR WONT START!
- idling up and down between 1k and 3k rpms
- Rear Wheel Bearing replacement help
- water tempreture guage problems!! help!!!
- Replacing exhaust - possible part numbers?
- Buying a used d16z6 head
- B20 vtec leaking oil from dizzy
- 92 dx hatch possibly bad dizzy help!
- No sound to speakers
- d16z6 vss help please
- 98 civic drum brake creak, not squeal...
- ebay spoon style spoiler compared to others
- DIY: How to test for spark and to troubleshoot spark problems
- cheapest place to order OEM 96-00 EK window visors?
- Need help changing my injectors!
- scraping noise?
- My 95 DX is running hot
- Switching from a cable GSR trans to Hydraulic B16 trans..few ?'s
- bogging then pull issue with d15z1
- Squealing from rack and pinion
- junkyard b18b???
- Ignition problem car won't start need help
- chip on sleeve block
- 15-20 min. idle thermo goes past middle
- 2000 Honda Civic EX Coupe OEM Shock Replacement
- vtec engage problem
- Priming oil pump
- car dies at idle sometimes. possible fuel pump??
- side markers
- EG to Ls Swap ECU help
- 93 del sol trans fluid check question.
- d15b7 ecu on ls swap
- Quick question about Apexi ws2
- D16a6 cam in a D15z4
- 99 Si - How many O2 sensors?
- Y7 OR Y5
- hard to start del sol
- car dies while driving
- power window issues
- K20 EK HATCH
- cfk bypass,cell 41,23,54,65, h22 in a 97 coupe
- 96 honda civc ex, need help with engine
- P30-a00 or p30-900
- Need directions on how to wire in a b16a in a 98 civic ex
- So where do I start? ('00 Si content)
- 98 civic carb legal headers????
- Anyone know where to get the gen specific road race door markers?
- 96 LX D16Y7 auto to D16Z6 manual - Transmission mount woes
- car starts no idle??
- [DIY] OEM JDM/EDM 1992-95 Honda Civic Low Fuel Indicator Retrofit
- 92-95 EG OEM FRONT LIP ON A 93 DEL SOL. HELP PLEASE!
- EG/EF Rear Leather Seats
- 92 hatch with ZC swap
- which oxygen sensor will fit a d15b delsol
- stock asr brace with stock ex swaybar
- Replaced auto transmission fluid with Honda's new DW-1, observations.
- Fuse 31 keeps blowing
- My First EG build in memory of my little bro (Turbodcx)
- B16b swap
- timing belt fitment question????
- hatch gutted weight?
- rear seat removal of em1
- 95 civic sedan child anchor retrofit ideas?
- 5 lug conversion kit
- Need help!How to install a keyless entry onto my 98 Honda Civic LX
- 95 civic ex common issue or not? Sunroof only opens partially
- d15b
- Ek seats in del sol
- si climate control and ex climate control
- EK Orange Signal lights!
- B20 valve spring compressor?
- RHD B series shifter on LFD shift linkage
- 95 Civic EX hesitates and speedometer doesn't work
- clutch safety switch???
- eg b16 no fire
- LSvtec wont start
- Ek's have window leaks from factory?
- New EM1 help
- Automatic HX head swap question
- 00 Civic EX with 255K,rod bearing advice
- 2000 civic SI bumper support
- 94 eg hatch, Solid SRS light, how do i turn it off??
- i_Shift's 96 Hatch build thread (High comp Low Boost) 56k = ANGERY
- CEL Codes
- Hatch Doesn't Open!
- Anyone have this exhaust on their ek sedan?
- need help changing rear rotors on 93 civic
- Coasting fuel delivery
- Best Suspension for under $1200?
- RPM's bouncing after warm up
- Aftermarket cats vs OEM
- Feels like its hitting a wall
- Somebody with an EM1, need your help
- temp gauge not working
- 96' Ex wont pass 63 mph? Plz help!
- butterfly valve on intake mani gsr swap help
- fuel pump and cel problem
- PCV valve hose????
- Wiper motor question
- camber and suspension ?s
- 96-98 sir replica lip install
- Noise at 3k rpm only when car is driving
- Lsvtec timing help and how to set cams to TDC if using aftermarket cam gears
- B18c1 Swap only revs to 7k Help please!
- my little f swap dilemma
- pros and cons of a stripped down civic
- Starting, running issues
- Window molding and windshield trim??
- Engine Removal Help
- need help with spark and fuel pump problem
- 99 Si revs all the way up
- Type R Rebuild - The Good, The Bad, The Ugly
- Intercooler pipes for 95 civic
- broken bleeder bolt
- Removed a pump on washer fluid resevoir now horn doesnt work
- installed tein basic dampers.... something went wrong
- do they make carbon fiber windshield wipers nozzle
- LOW idle after cleaning IACV???
- wont idle/rough idle on cold start
- My EJ6 build thread - 99civicB20V
- B16 Intake manifold question
- How often do D-series oil pumps fail
- automatic transmission hole cover?
- Will an EG hub fit on an EK?
- 2nd cylinder plug wire not staying on valve cover
- b16a2 wont stay running...
- Installing rear suspension only question
- Disable airbag before cluster swap?
- New distributor info for LS/B20 swap into '99 - '00 Civics
- help with mini me swap please..y7/y8
- help on choosing a head gasket
- Em1 external antenna question...
- Multiple help issues.
- Intermittent Not Start until engine rolled and low idle
- Oil question
- Civic 95, Fuel pump/main relay/g101 issue
- Long Shifting and persistent CEL code 19
- ????? b16a converted to obd2 into 2000 em1
- Erratic RPM help
- 98 D18y8 build
- delsol HELP!!!
- pic request 6th gen hatch quarter window area
- D15b7 jdm cam
- Del Sol interior door panel all wet, help?
