View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16z6 sputtering and back firing
- ••• Chipped ECU burning more fuel?? •••
- 99 Civic low compression on one cylinder
- Throwout Bearing or Input Shaft Bearing?
- Help with my ac condensor.. Can i use any civic condensor if my system is using r12?
- D16 Valve Cover bolt broken in head
- Help needed 99 civic keeps shutting down
- gutting dx eg doors & puttin lexan???
- P0133 code need help
- Need help with low/ rough idle
- Crank Pulley Torque..Now or Later?
- need help installing OE integra gsr shifter on civic EG.
- D15b in a 99 civic
- GSR Leather seat into a EJ Coupe
- Wheel alignment locations?
- hood issues. diffrent than normal
- P84 Ecu help
- Valve cover cutting question B series
- D16y7 to y8 Mini-Me Swap
- jdm d 15 swap what ecu do i need
- where can i get longer exhaust hangers?
- B16A Idle probs + others
- Ac with a b series
- need help car smoking with new exhaust
- 95 B16: Need Help With ECT sensor Part #
- Oil pan gasket leak
- ??? DO EM1 REAR SEATS FIT IN AN EK HATCH ??
- cam tdc???
- need help starting H22 Swap what do i need from Prelude
- need help going crazy lower hose cold,fan dont come on
- aftermarket windsheild and oem window trimmings fit??
- 00 dx power window conversion help!!!!!
- Question about B series T-brackets for a B18 swap into an EK!!
- 93 civic d15b vtec / vtec-e
- my y7 NA build
- need help asap on del sol in cali!!!!!!!!!!!
- Help! 99 Civic stalls while driving!
- knock sensor on y7?
- dang ac blew a hardline anyone know .......
- silly question/quick answer (code16)
- Shift Linkage Disconnect to Pull Tranny
- HELP! A/C Tensioner Reassembly, needing advice.
- Part number?
- D15b7: CEL codes 9 & 10 with video
- 1993 civic ex single cam starting issues
- 99 civic si boost suggestions
- A/c help!
- EGR block off Plate question
- Will Rear mud guards fit 99-00 civic with oem rear lip?
- Antenna malfunction
- Should I replace the wheel bearings? Tiny bit of play..
- do you lose power with a d15 block under a d16 vtec head
- Wheel bolt pattern on civic
- I need help with inside handle
- D15B7 running lean
- 1998 civic hx hydrolocked how much can I get for this?
- Random misfire P1339
- extra plug
- Del sol Roof rack
- Best way to jam flywheel without flywheel tool.
- gsr rear seats
- d16y5 tranny on a d15b motor
- 95 civic Front Lower control arm question.
- Not A Tech Question but...
- Power to Manual Steering Rack!?!?!?!?
- help ... motor question ..
- Where is my accumulator located? 92 civic
- fluids for B18c1
- obd2a to obd1 jumper help
- Low Idle, Sometimes Stalls
- Trans Hitting frame
- omni clutch master cylinder
- lsvtec starting problem question
- 94 civic has no power at low rpm's!
- b16a motor problems
- delsol b swap
- 00' front end on 97 civic???
- stock obd2 gsr throwing code 22
- ***STOLEN: 2000 HONDA CIVIC CX*** (WI)
- Broken Bolt, Royally Screwed.
- problems with fuel pump priming
- Intermittent hesitation on accel
- Question about swapping motors??
- how to choose correct rod/main bearings?
- tunning ign and afr
- Problem with OBD II scan tool
- 2 dead cylinders when car is cold??
- B18B Motor Swap Del Sol S
- jdm b16a bad idle
- rhd help!
- Y8 Head on Y5 block?
- 92-00 civic and 94-01 integra trailing arm bushing the same?
- Is it possible to relocate Ignitor module?
- >>>OFFICIAL EJ1 THREAD<<<
- Clutch and Flywheel Bolts
- my rpm's are going crazy
- Where to get real EGR rear visor for ej1?
- D16z6 major problems
- GSR transmission no reverse?
- limp mode or no????
- Removing the Driverside mount 98 civic ex coupe
- P30 B16A3 question
- D16Z6 Tranny wont shift into gear
- mini me help!!!
- rota slipstreams key lock....
- Del Sol boost gauge.
- Car bogs with A/C on, runs fine with it off.
- NEED HELP! EK is dead
- help with brake pedel noise
- Failed oil pump? Need help
- Wheel Vibration on Highway
- '96 Ignition timing out of range?
- Ek 4 door
- Loose ECT sensor connector
- what do i need to swap in a b18b1
- Best si/type r lip replica
- to those who have swapped h22's in a eg
- putting in a GSR Mani
- 97 Civic DX Hatchback Trailer Hitch
- Blower only works on high
- 1994 civic speedometer issue.
- bent rear hatch henge on my 93 civic hatchback ?
- Steering wheel alignment issue
- boostin a z6
- valve adjustment
- obd2b to obd1 conversion problems
- power steering pump toast? 99 civic
- b16a civic throttle check engine light
- hid bulb type
- ***BEFORE AND AFTER TURBO CIVIC VIDEOS***
- Gonna drop a motor in need to be sure of a few things
- pacesetter exhaust, good or bad?
- HELP... engine dies when rpms drop hard
- Video-Test Run on my first swap special thanks to h-t members
- Part number for starter cut relay (PIC included)?
- need advice... head swap on jdm d15b
- Help me identify this water leak in my EH3
- Shift linkage
- 97civic d16y7 with y8 head oil pressure light flickers on sometimes at stopping..
- volk rays on ek hatch
- Best thing to use for cleaning a Block
- jdm b16a cams vs usa GSR cams?
- del sol wont start need help
- Power FOLDING MIRRORS With Terets
- can i put a vtec head on a d16y7?
- Put JDM D15B VTEC into EK Need Help.
- Harness behind intake manifold
- auto to manual 97 civic parts list please
- D16Y8 engine removal?
- hose location
- Civic '96 Dash Lights don't work, but parking Lights work
- Rear quarter panel removal
- 94 civic with LS swap issues :/
- b18b1 burns oil assistance needed
- 97 integra guage cluster
- car runs hot after 10 minutes
- B18C piston rings?!
- maintenance light
- Integra front LCA's fit EK?
- car not starting. anybody have any inputs?
- P32 Intake manifold, anyone heard of it?
- EG 4dr door panel question
- 95 civic dx starting problems. sometimes start sometimes no?
- dont kno which spring goes were?
- Rear Disc Conversion Question
- D16y8 build ideas...
- Will I run into issues? Disk to drum.
- Issue with short throw and shift linkage 92 eg b16
- Just finished motor swap; engine acts weird at cold starts
- guage cluster from integra in civic
- A gallon of brake fluid later...
- lookin to boost my ls/vtec lookin for some good parts?
- z6 intake
- Best bang for buck motor swap?
- New suspension: Is the front riding too high?
- Still Chasing Problem with A/c Compressor Clutch
- Tire play help
- Low idle during the day.
- HIDs for EG
- 97 Civic LX lose power when cold start up
- Rattling Noise...
- hi
- 93 civic, misfiring during heavy acceleration, died on me.
- CEL 6
- Manual tranny fluid replacement
- Help B16a in 93 Civic
- n/a build recomendations
- best clutch for b18b1
- whoosing sound
- How to replace drive axle?
- problem with 96 civic b20 boosted
- Ef starter
- Civic Radiator Leak
- Coolant bursts on cranking
- Help removing broken bolt!?!?!
- speed sensor
- Need some Quick help
- LS Vtec Issues...Please Help Out!!
- problem with civic starting revs to 3500 rpm
- will bushings from a 96-98 civic fit a 99-00 civic si
- 92 eg hatch with b16 trans problems
- G-Force Peformance Chip 60 HP increase?!
- My cars pulling a lot of air
- 96 Hatch: What's it worth?
- 92 del sol si: name these plugs
- What all is interchangeable on d series motors...
- NSX powered MidRear Eg?
- steering wheel question
- Will the trans work d series
- Weird issue, Blowing Igniters with AEM V2
- CEL Question With Picture/Video
- 94 del sol dohc vtec fuel injection timing
- How the Hell do i lower my adj. Coilovers??
- 98 civic HX need some help for a B18C type r swap
- 94 DX Ignition wiring mess. Please help.
- Post Rebuild Issues...need help
- 92 Civic with air conditioning problem
- transmission/clutch question
- electronic speedo calibrator
- Items attached to the radiator support
- adding performance?
- 1996 Civic w/ B18C Type R swap. No vtec, limits at 6600 rpm, idles at 100 rpm if cold
- si replica lip?
- has anyone ever warped an intake manifold?
- Blew my engine looking for something new.ideas?
- ALTERNATOR & BATTERY PROBLEMS - B16 swapped eg hatch! Help!
- Creaking when turning the wheel at low speed?
- Need Help Figuring out: DIY 5 Lug Conversion
- help PLEASE FUEL SENDING UNIT
- Ls Swapped Civic 95
- Valve Lash Doubt
- HELP: Car high idle, Backfire, No power!!
- car starter going badd??
- Poor acceleration / Bogging issue
- 1996 hatch light ?ion
- D series build
- Rear wheel lag...
- b16 wont stay running because of IACV?
- 1996 Civic VTI -- immobilizer problem
- Fuel Pump or Ignition Control?
- del sol block swap help
- b18 b non vtec, turbo setups good or no?
- EK cluster in EG questions.
- What is full mark on oil dipstick?
- obd2a engine into 99 coupe
- EG No headlamps! Help.
- Clutch installation problem. $10 Paypal'd to whoever pinpoints it!
- Ek9 exhaust?
- 97 civic b18 swap lumpy idle
- Black smoke from b16a2
