View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Test Pipe CEL
- 98 hatch brake light out
- good suspension
- 2000 Civic DX transmission issues?
- 92-95 Civic JDM power folding mirrors Wire layout help!
- 97 GSR in my 95 hatchback DX..Wiring harness??
- Camgear question
- 94 Civic ex wont start
- How do I depin this cabin connector?
- Car stalls after reaching operating temp
- quick help please?
- power sterring question!!
- Need Some H22 Guidance
- D15b into cx- tech questions
- High NO (PPM) Failed CA Smog
- Broken Valve Cover Bolts/Engine Swap?
- gsr motor parts help
- Coolant sensor locations D-16y7 block
- automatic ek throwing cel codes
- 94 del sol idle issue HELP
- is my shift linkage ruining my tranny
- d16y7 help.
- Air Conditioning help
- radio HELP!!!
- What exhaust should i get for my 00 Si?
- 96 y7 rpm troubles
- 94 civic gsr just got worse
- What size is the knock sensor in MM? 20 ish?
- Wiseco Pistons
- Electrical problem, 99 ex
- speedo calculator
- Ek Power Outlet 12V-10A
- eg civic starts then dies, need some help
- Car makes noise when i start it up. help.
- oil leaking from cam gear cover
- injectors
- Is any1 familiar with what kind of intake
- JDM Console Conversions
- A Starter Issue perhaps?
- Direct Fit Highflow Cat. Fitment
- what motor oil do u recommend
- Cruise Control Help
- Blox Racing Full Coilovers
- parking lights inop in ej?
- is this a custome color
- CAN U PLEASE TELL ME where to buy a cheap GSR swap for my EK?
- d16y8 head with boost cam.
- Quick HID question
- motor boggin when push on gas...advice plz
- Piston removal Help!?
- Desperately need some help with idle issues
- pressure plate bolts
- broke the fuel line that comes from tank
- 92 - 95 body parts info
- what year
- throttlebody gains??????
- 1995 Ej1 Build thread =D
- Help with JDM seat install
- d16y7 to d16y8 swap help
- Evap Purge joint?
- D series to B series wiring problems
- What does this thing on the fuel tank do
- back seat help
- Car dies when AC gets turned on.
- 94 b18c1
- air assist solenoid valve
- need someone to help me tune my ecu with chrome!!
- How much is this 94 VX hatch worth???
- oil pump question!!!
- Totaled civic with Swap dealing with Insurance
- Is all B-series the same???
- sohc manifold
- cruise control help
- EK spoon spoiler??
- Output shaft seals..
- ek AIR CONDITIONING!!!
- Some electrical problems with my 98 civic please help
- 95 civic dx low idle help
- cat converter/ test pipe help
- is this motor a good deal?
- cleaning valves
- E-brake cable Interchangability?
- EM1 armrest on 97 cx? SEARCHED
- Installing 04 si seats into 95 civic need help!!!
- b18b1 idles down when clutch is pushed in
- i made a mess of my b16
- 97 civic ex low fuel light not working
- Help me find a thread from a few days ago with pics of a supposedly dead model
- 99 Si / GSR swapped, VTEC AND ECT PROBLEMS!
- test pipe in need of help.
- b16 overheating problem
- NEED HELP car throwing code 20
- anyone running or heard of j swaps?
- Good Nitrous Kit for my N/A GSR
- how to reff a 00 gsr motor into a 00 civic EX
- heater problem
- replacing cap and rotor in 2000 si
- 97 d6y7 overheating questions.
- Syndacate
- What to buy when building your DD car?
- Pistons Rods and Rings
- battery question??
- thread removed
- breather filter question and intake help
- what kinda hp will my civic make?
- What is so bad about turbos from ebay
- My EG suspension set up
- chipping ecu
- Electrical Help
- questions on turbo build on d16y8
- turbo issues Would like some opinions
- Noise In Tranny- Lost of Power What can it be?
- Code P0141, Need help with this one
- obd2a engine harness help, manual or automatic
- Ignition switch part # for EG?
- 1999 ex with a big hole in the block
- 97 CX hatchback idling issue.
- s2000 seats.
- 94 civic dx oil press problem...please help!!!
- B18C1 dipstick question
- Caming my B16A3
- HELP ASAP.... Horn issue
- Help: EK civic A/C
- ECU help b16a
- Rear passenger side parking light not working. brake light does.
- Can someone tell me what delsol exhaust this is?
- Skunk2 Ball Joints On Ebay Camber Kit
- 2000 Honda Civic SI HELP!!!
- OVERHEATING AND FAN PROBLEMS
- another swap problem(h22a4)...need help!!!!
- crower,bisimoto, or supertech valve springs?
- What tranny do i have?
- cracking or creaking noise...tie rods? or bushings?
- b16a Tranny plate cover... help...
- Fuel gauge functioning oddly?
- 94 civic sedan window assmbly
- D16 Build
- which one is the vtec seal?
- NEED ADVICE FOR EK 4 DR
- power steering???
- Motor head low in oil
- Window Regulator Spring
- Looking to do a cheap swap.! b16a?
- b20 swap wiring problems and other issues
- rear main seal
- Type R EJ shuttering?
- 94 civic dx gsr swap low redline....
- reverse light is dead
- Possible alarm??
- 1993 civic si hatch, Severe electrical issue
- AC question
- Problem with car, please help
- Doing the clutch on my z6....
- Line hanging from gas tank, need advice please!
- how to remove ac line need help asap
- 98 DX Hatch Swap Exhaust
- weird overheating problem(cant find anyone else with this problem)
- Question about shift knob
- 92 civic LX engine code help.
- Speed sensor, do I have Denso or non-denso?
- Car Won't Start/Dizzy Not Firing
- need help on my b20b ek
- Clicking after headwork
- Custom Plates For My 2 Civic's???
- d16z6 del sol idle problems
- Power locks and windows acting funny
- 99 Civic LX oxygen sensor need help
- 1994 Honda civic VX
- Will Tein SPR01-010950 Springs fit my sedan?
- Reffing a OBDII '99 GSR into OBDI EG
- Could the cause be hot weather?
- Adding factory keyless remote. What is needed?
- Which is the radio fuse?
- H-Motors - Still a reputable engine supplier?
- CV or Wheel Bearing?
- del sol intercooler
- Help with A/C while driving
- GSR blades on 97 civic ex
- brake prop valve help
- cam seal leak
- probally dumb questions but i have to ask
- DEL SOL WIRING HARNESS HELP
- Trying to Find where thie PLUG goes? 93 civic coupe
- Crank Pulley got Loose, Crankshaft Damaged
- Drivers side window help
- Need Help finding a battery tie down for a Optima yellow top in a 2000 civic
- 98 ek dies out sometimes! HELP.
- del sol sir d15b dilema
- DC cluster in a ek. OMG!
- A Few Swap questions mini me
- What should i do?
- Car is making scraping sounds from under
- GSR swap...Suspension???
- Cosmetic Civic Upgrades
- Do I already have an LS 5th gear??
- what trans in a 95 EJ1 AUTOMATIC
- acceleration vibration.
- car doesn't start
- Dash light help
- b16a2 hose diagrams
- 2000 Civic EX catalytic converter...
- Car hits VTEC falls on it's face tuning issue or timing issue?
- I broke the valve inside the VTEC solenoid, need suggestions
- timming belt & water pump?
- d16z6 engine problem. any help would be great!
- Window Regulator Handle
- Passenger brake light out
- new here, wats up, whats this intake mani off of
- Problems with my tach
- Honda Civic 95 Coupe Jam/Stuck doors
- TURBOCHARGED D16Z6 QUESTION!!
- Not turning off the AC when turning off the car?
- Cant explain issue (H22 EG)
- Weird high idle issue
- ckf sensor not letting my car start.
- Ek3 PFM wiring diagram
- idle issue
- Tips and/or tricks to set timing???
- JDM EK9 Type-R Interior Trim Colour Code?
- Speedometer/Odometer Don't Work
- need suggestions for resonators
- Rear torsion mount bolts..
- 92 b-16a swap wit bad emission's
- emissions on 99 civic si NEED HELP
- TPS sensor help
- Engine Swap ?
- 98 civic ex starting issue, Need Help ....
- 94 del sol b16 smoking and high idle
- What are causes of NOT idling?
- Oil got in the water jacket around the cylinders while removing the head
- Small electric problem!
- ANy one in LA Parting out an si or type r?
- EG hatch leaking NEAR the rear window..??
- the GOVERMENT is paying for my smog :)
- Car Died in the Middle of the Road
- need new seats or rails?!
- HMOTORSONLINE.COM: 40,000 Miles ONLY??
- Hello I am new hereabouts!
- Need help on motor set up
- Should I use STP Fuel Injector & Carb cleaner in my Civic?
- EK Fog Light Wiring Pics
- noob exhaust question!!!?
- turbo em1 vs turbo tc-t question
- mini-me ?
- crower 2 cam question
- Lost my keys!
- y8 head on z6 block timing and headgasket
- Can't remove tranaxle after all bolts removed, what now?
- I can't take off my Tensioner bolt!
- 1996 Civic Coupe. (First Car)
