View Full Version : Honda Civic / Del Sol (1992 - 2000)
- d15b zc!! HELP! interchangable stuff? what are the benefits!
- Doing ITR SWAP! Need HELP!!
- spring rates for valve springs
- Motor year????????????
- Best Nitrous Kit
- I need to find these gauges....
- Lookin for sound clips (TwinLoop on Bs)
- compression test question.
- b18c swap in del sol smoke a prelude?
- Coil Overs & Shocks....
- Anyone want to help me out with my logic here? (Car Selling & Future Project)
- SOHC "mini me " turbo
- How to prevent the slammed hatch rattiling problem???
- gauge question, i did search....
- How do you plug JDM motors on US cars??
- How to tell if you got a real Spoon CF wing
- First time posting my car
- What's this car worth?
- Hey guys I'm back!!!!
- vaccum noise in motor
- Turbo fuel suggestions....kinda URGENT!
- Tein SS on 92 VX
- Carbon Fiber Hatchs and others
- Brand new Circuit 8's rusting?!
- would my axle fit on eg?
- 2000 DX & Si Grills
- What motor should i swap?
- 1999 EX Quick Question
- After VAFC install, Im throwing a CEL??
- Check engine light, CODE 80
- OT:Picked up a 94 DX beater
- GB on Carbon Rear Hatches for EG, EK, DC... SIGN UP HERE!!!
- Crashed GSR burnt to hell. Need opinions!
- shifter and linkage question
- just did my ls swap and i'm hittin fuel cut at 5600....
- 99-00 si
- JB WELD hold a shifter stabilizer together?
- is it me or...
- My clock resets to 1:00
- help!!!!! D16y8 vtec
- Civic Si Resale Value and Pricing
- weird noise from motor...please help
- 99-00 Si endlinks a problem with 22mm sway........
- recaro rails
- D16z6 fuel Pressure with I/H/E
- shit...got keyed today
- Still getting a code 8
- 2003 Civic LX
- Question on lowering my civic
- loose steering.....
- gas reading problem
- Cruise control removal (2000 si)
- water light?? help
- b16a powered sand rail?
- B18b
- my 92 cx hatch..is this a good trade?
- ACT 6 puck sprung break-in period?
- 1992 Civic CX Hatchback
- Big water spot on headliner on 00 hatch?
- turbo the way to go?
- werid 4 door
- could use a little help check this out
- Does anyone know where I can find. . .
- JDM Power Folding Mirrors wiring HELP??
- help with motor swap
- EG RAG TOP
- 94 Prelude Brake conversion?
- airbag problem
- pics of my EG
- What's it mean when your rotor wobbles?
- custom piping or full cat ?
- Hondata VS Apexi V-AFC???
- piping and muffler question
- Ignition wire??
- need valve lash specs
- Front passenger side viberation and hard pull to the right.
- steering wheel install??? cant find thread for nothing?????
- friend's car picture
- Need Help????
- Are all EG Civic front seats compatible?
- ? ? Tire size question ? ?
- 1995 Civic EX w/ JR Supercharger Need Help!
- recommendations on where to buy your CF wing for eg.
- are all 5th gen civic hoods the same?
- Options,suggestions,thoughts on new shocks for my 93 delsol si.
- 02 sensor
- ABS problem
- 99 si doors on 98 hatch,what harness?
- Obd-1 ZC ques
- how to install Shifter Bushing ?
- Rear lower strut bar vs Rear lower tie bar
- 99 d16y8 intake manifold
- vibration in the left front
- grrr i need to vent! CA freeways suck! (mod: you can move this if you feel it is in the wrong forum)
- CD Player Relocated
- 1/4 times
- motor mounts for a D16y8
- auto JDM GSR??
- itr b-pipe on ek ??????
- jun or toda?
- question ill probally get flamed for.
- who makes body kits for the 4dr eg?
- piping with stock muffler??......gain or loss?????
- dash wiring (i have searched)
- S20 Tranny? What is it out of...?
- Swapping d series engine, having problem with few things, need help.
- zc single cam?
- Bodykit?
- car dies shortly after starting
- Tech people help me out here...
- how much for my car?
- Are both black wires on the o2 grounds?
- 1993 civic dx and 2000 civic si front/rear brakes?
- I got in a wreck, I need advice
- Need help NOW! Type R header fitment!
- Whats this going 2 cost me??
- Poor Gas Mileage
- got fix-it ticket for my exhaust in CA.... some questions
- ls/vtec
- AEM ITR 3inch CAI or AEM v2 CAI
- Quick guesstimate, fender replace/repaint
- skunk2 spring rate?
- Turbo Civic in Knoxville???
- VIS carbon fiber hood
- fuel pressure under 40 psi
- how to remove lower part of rear seat
- how many of you are lowered on stock struts?
- How to paint my rims black?
- 2003 Civic EX stereo
- my car pictures. Good bad?
- Lower control arms
- Finally decided to sell my car. Thanks for all the help.
- Honda Power!
- 96civic dx d15b swap i need help
- spark plugs?
- noise in tranny help!!!!
- What should I do with my Frost White EH2???
- What size bulbs are 96-00 Civics
- o2 sensors
- Needs Help with question
- For all the guys storing there cars for the snowy winter weather
- Trim line for 92-95 sedans
- Testing for a bad ECU...
- Where to get USDM B16
- '98 Civic EX Shifting Problems
- Will a 93 Si LCA fit on a CX?
- IACV on 2000 b16
- day 4 & 5 of getting my car repainted...again...
- How to take off Stock CX wing on hatchback??
- what header can i use
- 5th gen hatch BOGGS after driving for about 1/2 hour.
- DYNO DAY!!!!
- need some details on suspension please
- blue smoke when i get on it hard?
- Cone style intake in stock SOHC VTEC (D16Y8) airbox?
- Underdrive crank pulley with stock belts?
- '92 Civic steering/suspension woes!
- Screeching noise on start.
- Front Sway Bar Installed
- Is she dead ? pls help
- The adventures of the grocery getter
- Sellin my bubble...$5000..You wont be dissappointed
- homemade dyi cold air
- rsr springs?
- RE: 88 & 89 EF Master Cylinder
- grrrr
- HX looking for swap
- pics of my hatch 56k warning
- AirDynamic/MMR Racing Seat Write-up
- can i drill a hole in bottum of headlight to reduce water inside?
- Need Assistance on allignment specs.
- The Best swap for what I want from my car The hardest decision ever
- my swap is done and i'm damn excited about it
- Auto Tranny FLuid and Chassis code questions
- Kaminari USA body kit fog light ?
- [FAQ] Complete DIY How To: Timing Belt/Water Pump Change on a D16Z6 - lots of pics!
- Does Lokar Motorsports make the G-BAR System for EG hatch
- How do you change the 02 sensors on a 98 civic ex? And does anyone have used ones?
- VX block worth makin a mini-me??
- intermittent wiper delay box, where?
- Does any one else have next racing seats
- Look what I found... just like b20z CF seats!
- Change your VTEC Engagement??
- What other OEM Honda exhausts will fit a 96lx sedan?
- top fuel
- About to buy a swap.. Quick question
- gsr hatch
- 99-00 rear drum to disc conv.
- Have a brand new timing belt and waterpump for my 96 civic ex... what else will it fit?
- Why are Del Sol rotors smaller in front?
- need to find out what other cars these alloys will fit on
- Buying an Si, have questions.
- Choice of cars...
- S H A V E D D O O R S ! ! ! ! ! !
- I need help converting 3 wire IAC to 2 wire IAC
- mtec white lights?
- Rattle on my d16y8 (headers/trans.)
- rattle on my d16y8
- Power>Manual Steering,EK Related
- problem with my engine...
- Loud annoying Squeaking belt noise......
- help...!! parts number....
- d16z6 clutch question
- si gauge cluster color?
- fs civic si parts
- sohc vtec decal
- Fuckin Bitc @$$ thieves tried taking my car
- TestingWaters: Midori Green Hatch
- Ferrari vs. civic
- 10 w 40 in tranny
- Sup I am new Noob to the HOnda world
- Roll cage specs?
- camera mount with 95civic seats ::mad::
- You knew it was gonna happen, but you hoped it wouldnt...
- What ECU to run?
- Civic strut bar in a del sol
- 94 Civic DX and Compatibility
- 2000 GSR in 95 hatch, tall shifter....
- 9000 grand mis-shift....
- car won't turn over but push starts
- CAI B18B EG
- Civic coupe not in japan ?
- Motor Swap
- d15b vs. d16a6, p29 pistons....
- oval es exhasut rattle at low rpms, need help
- Any put hood/fenders/bumper on in OWN driveway??
- sunroof wont pop up
- gc/blues OR nuespeed race/agx??
- Hondata S100
- GReddy Evo Exhaust Vs. RS-R Ex Mag Exhaust
- $3,500 into a honda?
- code 14 help?
- Anyone knows any good shops around southern cali. im looking for a motor swap.
- C95 Civic For sale...$6000 or best offer
- Good Price on Apexi GT header...
- integra radiator in a eg??
- 5th Gen gsr swap mount Q.?
- Transmission fluid = REGUALR OIL !?
- 14 second coupe with d16z6
- How much does it cost to use a civic?
- skunk2 install help
- n e 1 know a web site for cars' stock performance
- b18a swapped 93 cx-fuel probs! too much fuel-engine flooding=car won't start
- aftermarket seats and seat belts
- motor swap....before after trip?
- need help quick
- Thanks to you honda-tech guys, a guy and his firebird got owned.
- shift linkage problem.
- best setting of field vtec controller for JDM B18C
- LS cai into EG coupe
