View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 1999 Honda Civic LX 4 Door Exhaust Help
- 99lx sedan headlight bulbs
- Help Code #20
- What wire disconects the 4 ways ...??
- trailing arm bushings.....they dont fit
- 96 need help auto to fice speed swap asap please
- Clicking noises when turning
- b18b1 not starting when engine is cold
- NEED HELP HOOKING UP AUTOMETER GAUGES!!!
- All red del sol seats !
- 96 EX 4 door: no power locks/windows
- H23 motor swap help
- !!!!!NEED HELP QUICK!!!!!
- Evaluate my build, be my critic. d16-t
- Radiator Cap Question-need help!
- B16B swap!
- DC Sport Header
- Seat Railing for 95 civic lx
- Fuel line removal diagram
- rpm's
- knock sensor plug in
- how do i unlock power from my d16y8 cheap n easy??
- comparison between honda motors???
- a few fuel pump kill switch questions
- Question about sir lip install
- timing belt advice and such, please help me out
- Drove in a flood & failed smog.
- Which 36MM wheel bearing so i get for my 5 lug?
- d16 transmission mount help
- troubleshooting noise on 99 civic dx hatch
- Need Help
- Just got my 93 EG hatch, but what engine should i drop?
- want to hire someone to wire up vtec
- ebrake thread? Where to find?
- Horn Wiring for quick release?
- rpm reading wrong help
- I need Help / advice on what size exhaust piping to run.
- my throw out bearing needs replacing
- I need a write up on how to replace front and rear cam seals for a '98 civic SOHC
- Integra Rear End Question
- d16y7 more power
- B18b1 0bd1 swap into my 98 hatch
- h22 swapped civic won't start HELP
- Ebp rear lip on 96 civic sedan?
- NEED HELP ON SEATS!!
- Installed new Inatake manifold now I have 4 CEL!!!
- 92 hatch alternator problems
- PLEASE HELP! Calling All Coilover Experts******
- tri-y big tube fitment question
- Machine shop to line hone cam caps!
- question injectors
- foldingside mirrors diagram for ek
- why the difference in DX prop valves for 2dr/3dr vs 4 dr?
- HELP WITH EXHAUST FITMENT
- HELPPPP pllzzz
- got a pair of raybrig oem foglights
- this car is getting me mad need help
- Newbie here!
- Problems with my 95 ex coupe
- EG Sunroof sticking
- GC Top Hats + SKUNK2 Shocks/Springs???
- b20 wont stay on need ideas
- EG rearview Mirror REMOVAL HELP!
- What do you use your cup holder for?
- Car still not starting???
- red eg coupe with a black trunk?
- 99-OO EM1 weight difference
- crx ksports on my ek
- 92 Hatch interior swap
- help with fuse question?
- 94 delsol
- 96 dx coupe 2000 si tail lights
- ..Ej1 Parts Questions..
- 96 hatch power door window conversion
- 1994 Civic Crank But No Start
- **Stolen** 93' Civic Hatchback
- HELP: HOOD LATCH WIRE FELL OFF
- help rebuilding b18c1 motor?
- New Distributor and TDC
- if i drop the car?
- Speedometer Not Working
- car wont start?'
- Del Sol Will not turn over
- Please Help Me Find a Code - 94 Honda Civic LX
- Running boost while having high compression pistons
- HELP!! WIRING HARNESS PROBLEM
- Fuel efficient ?
- motorbike cluster
- 92 civic hatch will not rev above about 2500
- need help:gauge cluster wont light up
- brake comparison
- EK hatch wiring harness question
- brake upgrade?
- front knuckles and axles
- does any body know the part number for integra transmission bolts?
- b16 DIFF Question
- Seat Swap Questions... Thank you
- EG Seat Rail Swap
- Rear Disc Brake Conversion
- I need a pic of a b16a2 connector
- t belt issue
- Help with harnesses for 99-00 hatchback to PW and PL conversion
- help with lca ball joint castle nut. (98civic)
- window sill
- ek grill issues ?
- EK swap question
- Do b16 and gsr trans use same starter?
- conventional oil to synthetic oil issues
- LS.....WHAT??????????
- Intermitent Vtec, VERY odd
- AWD civic possible?
- s2k cluster into my 96 ek hatch..
- need help with em1 fog lights>>
- ECu's/Emissions
- 96-98 EK3 VTi Climate Control in my 98 Civic EX
- Fuel issue need help
- Help! Water leaking from timing covers
- 92 cx blowing fuse, short somewhere i know
- Civic 2000 paint valve cover
- Car is overheating randomly wtf!!
- Rear disc conversion...what brake hose do I need?
- Bad rear wheel bearing?
- Help Diagnose This Weird Buzzing Noise!
- Whats up.
- what would you pay?
- changed fuel pump but car still won't start
- another b20 in eg timing issue -need input
- New DelSol, New here, New problems
- NEED HELP BAD asap....
- My 97 Civic DX build thread
- 97 dx intake manifold help
- suspension help!
- i need your help pls
- T3/T4 downpipe on a 14b?
- need help tranny s1 and t bracket ASAP PLS!
- act cluth kit
- Erratic RPM at 3000
- Make $20 fast if you have a chasebays brake tuck EG/delsol
- vtec not always working
- Dash Lights = Car won't start?
- Fuel pump Removal Question Del Sol
- what would cause my back tire to wear on the inside?
- lug studs/spindle
- Starting problem; sitting for a week and now wont crank?
- D16 block differences
- Built B20 Vtec Idle problem...HELP!!!!!!
- needs for B16 swap
- MAP sensor wiring diagram
- Replacing cam seal/plug
- p28 chiped for d15z1 is it possible
- Climate Control Lights Brighter?
- 93 ex with d16y7
- Great discount on parts...must see
- sub dash ac removal.
- Mini Me Question
- si rear disc conv on a 98 civic ex coupe!
- Replaced struts several months ago and now squeeky noise
- difference between "jdm style" and oem(JDM)
- GSR swap into 97 Del Sol
- Eg lug nut/studs question
- Question: Swap a D16Y8 to D15B (D15z7)
- ek civic, electrical trouble
- Help?
- Swapping Axle back exhausts - Spoon/Apexi
- Waterpump info and symptons
- Washer fluid sensor (96-2000 canadian civic)
- Changing out timing belt and have questions on cam and crank seals?
- Is OEM just as good as Genuine Honda Parts?
- removing driver side door panel help
- No spark, we checked everything it seems
- New Guy with a A/C question
- Cheapest place online to get timing kit??
- HI!!!!
- car keeps dying
- will ef springs fit eg
- Bad compression test results NEED HELP PLEASE
- MSD hook up em1 (distibutor)
- D16
- Are there clips on the front bumper/side panel that hold it?
- ek black interior?
- Repairing bent rim?
- radiator issue.
- Civic ECT issue
- a different style fog light 99 00
- How Many Times Have You ...
- Flywheel Weight
- Which differential bearings?
- RHD
- 98 civic 4dr question
- 93 delsol
- Engien runs fine until I hit Vtec then it cut's off!????!!
- Confirmation: Bent Igniter Coil Spring
- What is my car worth
- Ongoing CEL problem EG z6
- Newly bought Civic wat should i do?!
- Worn oem lugnut studs on my sol. Extended lugnuts help.
- Looking for a good solid motor on the cheap
- 68mm blox racing throttle body question
- EG with ls swap throttle cable question
- can't find hole in firewall
- 95 DX crank pulley install
- One piece fiberglass front end
- Need help. How to tell civic mounts apart.
- EG hatch front hood fit inside the car?
- 98 civic SOHC build?
- Swap or Exterior?
- d15z1
- Quick Question On ek wipers???
- cable gears in hyrdo?
- Anyone from bakersfield, Need to borrow Headers
- honda del sol wiring?
- d16y8
- cd player from 00si into 95 coupe question
- so... I am putting a d17a2 in my 95 coupe
- unknown coilovers
- gonna be going to junk yard soon need some adivse/help
- 98 civic wants to put 2000 civic front bumper
- 99 si burnin oil?
- h22 hatch 2.5L turbo?
- 93 civic lx no brake pedal
- converting to obd1?
- Kill Switches
- Pulling hair out....
- HELP! auto to manual on 93 DelSol
- hey guys need help??????
- Price for swap in k20 vs b18c5 vs b16b
- Smallest size wheel for spare on 99 civic si
- Need EJ1 Inspiration :)
- Civic bigger wheels
- Check engine light during 5k+ rpms
- ls/vtec options
- 1994 Honda Civic CX problem, read on.
- BAR a 97 ls in 93 civic Si?
- Does 1999's bumper fit 1997's civic?
- radiator exploded/coolant spewed over motor/car start drives then dies
- broken rod bearing
- IAT=WTF, BS, POS
- 98 ek hatch problems
- 2000 civic si, CEL codes 17 and 22
- ek climate control?
- Prices for EK's so high?
- Types of Axles for H22 Swapped civics?????
- help....si misfire
- HELP CAN U JUST ANSWER ME DIS QUESION
- 1996 civic battery drainage
- Starting problem INFO INSIDE
- help?
- B16 DelSol... Civic and Integra intake designs?
- 1998 Honda Civic EX timing and engine leak question(s)?
- Distributor cap bolts/screws help!!
