View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Remote Starter Questions for 2000 Civic ex
- headlight allignment trouble
- K SERIES EG COUPE 4/S
- auto to manual-- shit not covered
- very poorly swapped b16a2 eg
- Wrong ECU / severe missing?
- 92 civic. light warning sound. I'm tierd of having to carry jumper cables. are you?
- Knock sensor
- ok so suzuki vitara pistons are done for
- camshaft for non-vtech d16y7
- Idle Problem in my EK
- vin number location
- sohc zc vtec 92-95
- grease clogged in the sensor from the fuel pump!?
- OPINIONS NEEDED! Broken Axle, intermediate shaft? PLEASE HELP!
- what is the best tranny?
- Rust... Cheapest way to fix in 93 civic
- What is this? PICS INSIDE!
- okay so where do all you guys get your tranny parts??
- 92 hatch Dx disk conversion **NEED HELP**
- Can't find something...
- Fuel pump won't work and i'm not getting any spark???
- TPS Question
- What to do with 7-8 grand
- Del Sol or Civic?
- Nitrous!! help
- should i just disconnect my airbag?
- Helpppppppppp
- What can it be?!?!?!?!
- Can I keep my passenger airbag when I disconnect the drivers side?
- Ebay projector lights ....any good? Will my HID kit still be bright?
- Rev limiter
- shortest SITTING short shifter?
- taking apart steering wheel
- EG/Del Sol Owners I have a question!!
- Buying first civic!
- Would i need to sleeve
- Injector plugging order
- Boostin my D16Y8
- cv axle stuck
- humming noise when the lights are on and then it get greater when the fans come on???
- newbie question..header??
- What Are The Rarest EG/EK OEM USDM Parts?
- ecu question
- New Car.....HOLLA
- can anyone identify what this plug is for?
- plx m300.... capacitors?
- new B16 engine swap wont start easy and when it does it barely runs
- axle into tranny question...?
- Running too rich
- rear disc brake swap..oddball question
- C.A.R.B. legal stainless steel headers??
- price of JDM b16 block "Built"
- Fuel air metering
- changing 93 civic dash colour!!
- spoon/mugen chips
- NGK G-POWER PLUGS
- HELP!! Need info on h22 swap!!
- dsm injectors????
- need help on my cluster
- cv joints/ front end work
- Sidemarker Help!!!!! ASAP!!!!
- ZC DOHC
- Possible igniter problem?
- Dash lights dimmed after pedal swap? 00 civic
- how do you route fitv and iacv lines?
- Catalytic Converter - What cat do I need?!?
- Integra lca's on a del sol?
- F'n hubs!?!
- ek mudflaps.... tech advice needed
- steering lock
- ZC DOHC
- best ecu
- ITR 4x114 brakes, vs USDM teg brakes?
- Engine Coolant Temperature Sensor Location
- Even more suspension questions/preferences
- ecu
- carbon fiber lip
- Too much oil?
- 1998 acura 1.6 EL interchangeability?
- d15b7 crank/overhaul/power???
- Should i trade
- failed california smog test...
- inner tie rod?
- h23 or ls motor? if you could help me out thanks
- vss help please!!!
- header question..???
- Head Gaskets
- Mixing oil
- Engine Problems need help ASAP
- upgrading brakes, MC/BB question
- how to install my vtec selenoid
- Cheap, but good windshield wipers?
- 1996 civic EJ6.... No bodykit, but i need front bumper for fog lights, which one?
- z6 alternator on b18b1?
- need info on a h2b kit for an ek
- Question about fitment with these wheels/tires..
- Looking for axel seals from acura, cant find what I need.
- nitrogen Vs. Air in tires
- F22 or F23 swap question
- Would bad suspension cause this?
- quick question.....
- New cam, odd problem.
- Car wont start after valve lash
- what to do with 8 grand
- How to replace alternator on 93 Civic?
- Help KNOCK?????
- jdm swap?
- Help!!! Steering Wheel Column Cover Removal on 1995 Civic DX MT
- lower control arms
- 96-98 a/c compressor will it fit my 99 civic
- has anyone tried the new Skunk2 LCA?
- ****Trying to figure out what parts to order. Please help.****
- transmission questions
- Heat still not working any other ideas??
- help starting out
- DIY Headlight Haze...wet sanding... Only on outside of headlight or inside too?
- 92-95 civic
- jdm 5 lug axles + d series
- i think my distributor is bad?
- SKunk2 Camber kit 95 EG, Steering has mind of it's own....
- shift linkage off of tranny..
- engine noise
- Exedy and Fadanza on EM1
- You wont believe what just happened
- where to buy liscense plate hole filler??
- stroking a d15b7...
- b18a swap questions really quick before it goes in
- poor mans stroker?
- Ex Wiring Harness 2 Fan Switches?????????
- HOW TO REMOVE PIN STRIPE????
- vtec not working!!!!!
- new brakes wont turn ?
- crower vs. vtec
- Don't pump gas on May 15th
- Black housing Ek headlights
- My B18b swap with a hydro GSR tranny
- NEED KNOCK SENSOR HELP ASAP
- distributor woes
- vabration when accelerating
- Help With Clutch
- Will a eg hatch hood fit on a eg coupe..
- type r chassis VS civic chassis
- 94 Civic DX won't start.
- NEED HELP FAST!!!
- SRS wire spool compatibility
- A/F ratio and tuning
- d15b8 with D16 z6 heads.
- D16Y7 Turbo.. Installation
- cd player problems
- firewall access?
- DX to EX guage cluster.
- vtec killer cams
- roller rockers
- NOOB: rear end suspension
- ECT Sensor Question
- is HMO reliable?
- EG cluster issues
- Is there a diffrence in the front shocks on a 99-00 civic??????
- koni yellows
- Need some radio help
- B18C wiring info.
- Z6 or Y8
- JDM?
- EM1/B16A owners, chime in
- 92-95 Civic Half-Nose bra
- B16 WITH GSR CAMS
- z6 swap
- here come the problems
- Dont Pump Gas on may 15
- Save two nice Del Sol's from the crusher
- Rear brakes only squeal in reverse
- B20 Swap
- ecu code 20 and first and second o2 heaters??
- idling problem.
- Problem when revving.
- SOHC turbo. Hondata Wont rev over 3000 NO BOOST?
- Need an O2 sensor wiring guru....
- is a 98 4doors civic sports with b18(i believe) worth of buying? why is it sooo cheap? can it be tun
- Need help, ecu prices
- Will this type r emblem work?
- Continuing issue with leakage.
- car wont hold idle on cold start
- b16 compression test results??
- MAP sensor Question???
- Quick ???????
- Trouble with reverse!!!
- Engine Wiring Harness Jumper
- does a b-sereis short shifter fit a d-series linkage??
- drianing air from cooling system
- Clutch is Going Out
- Problem after valve lash
- Whats a 2000 Si B16A2 worth?
- over heating help asap please
- EG Squad
- ******SOHC obd2 engine harness;will it fit a DOHC obd2 motor****
- code 6 and 21
- 99/00 tails on 97 EK...Help!
- Undecided...and all together not sure
- Clutch kit?
- teg rear seat
- 99-00 civic coupe??
- Timing Advance?
- fog lights
- Im stumped..............
- clean title vs rebuilt title????? Any problems
- blue paint on my valve spring
- How much to add A/C?
- 95 civic coupe, which engine will fit
- what gearbox will fit 1.6vtech dohc
- Reprogram Honda remote for 1997 Civic anthitheft system
- gsr bottom end for 1000?
- Need to rethread the thick bolt for front seat - anyone knows what size to use??
- ac trouble
- Torque Specs?????????????
- h&r springs
- running a z6 with y8 accessories
- I have some crappy luck lately with my em1 (idling issue)
- Will a 94-01 RS/LS/GS header fit 97 Del Sol Vtec?
- Website?
- wheel bearing bad
- Door locks help
- cranks out in the civic
- acura interior in to a 94 coupe
- CARFAX
- 6000K vs 8000K HID for EJ6
- Bad idle with d15b
- rebuilt motor burning oil!!??
- 95 civic turn signals and cluster
- PCV Valve
- No start
- where to get rear wiper delete?
- Apexi WS2 and Boost....
- climate control dont work>?
- What should i do to my d15b?
- Smoke from underneath the manifold?
- Ring set,little help required please
- possible to down agrdae a b-series vtec motor to a non vtec. For a goof of course
- ROB BERING HELP
- Fuel Pressure problems
- what's the best LCA for EK?
- Would a '98 harness work on a '99 Si?
- Getting the right Cat
- ran turbo car in rain with no filter. now it sounds funny
- b16 into eg question
- Vibration When Braking *yes, I used search, please read*
- top drivers side motor mount
- oxygen sensor?
- d16 engine over heating
