View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Water pump confusion
- Honda civic D16y7 swap to what?
- del sol in need of rear frame work :(
- b16 d16z6
- 00 Em1 requires starting fluid to start but runs fine after.
- Changed trans now axle pops out? Eg
- what cluster is this?
- Strange tail light issue and question.
- part number
- My EG Hatch
- Bad or clogged injector ??
- Post mount question!
- 94 civic LX delay start
- Spun a rod bearing... Now what?
- How should I cover this hole
- civic won't start - no spark
- what steering rack?
- what altenator can I use on my 99 civic with a d16 to put out more power?
- Intake suggestions, and questions...98 Civic Sedan DX!
- Reconnecting D series trans to motor
- 92 civic power doors harness diagram needed...
- Wierd idle after radiator busted???
- 98 Civic ex with b18b1 no spark need help!!!
- 95 honda civic dx fuel pump problems
- 93 civic leaking coolant on passenger floor and white smoke in exhaust
- auto to manual/rywire harness/reverse lights questions?
- Mini me,,
- civic and integra alternator brackets
- 00 em1 having issues, please help!!
- transmission problem need help!
- 2000 1.8 VTI speaker upgrade??
- How do the weep holes on a water pump work?
- 95 civic h22a swap breaking axles
- Signs of a Clutch Wearing Out
- H&R ultra lows or??
- shift lever from 98 civic on em1?
- My first EG hatch build.
- what brand headlights are these?
- 97 Civic - problems with heater, locks, wiper washer, and dash lights
- My EJ9 Civic
- B20 eg waisting too much gas!!!
- Can I put a D16y7 swap in a 92 civic?
- my first eg
- Thorough guide on hardwiring 92' fuel pump?
- Crank Pulley Question D16Z6
- Strange noise when backing up / rattling noise when driving
- check engine codes
- any how to mini me threads? y7 to y8?
- My car sputters slightly on take off, any ideas?
- OBD1 SOHC ZC in a 93 civic dx
- good deal?
- 98 dx no start issues
- 00 Civic smogging problem and ecu trouble - o2, htr, cat and evap are on monitor
- troubleshooting several issues. want this thing running safely
- B16 Tranny Trouble, HELP!
- D15b7 Rocker Arm Assembly Removal - welded to head
- Donut bushing woes
- Broken Bolt Removal from Rocker Arm Assembly
- EG build!!
- vtec conversion questions
- Integra 2dr back seat in a 00 civic coupe?
- 1996 hatch lsvtec won't stay running help!
- linear solenoid
- smoothest and most wire tucked bay on ek
- 95 civic need help. Posting for a friend
- which slave cylinder to buy
- clutch pedal question. (video)
- Help needed h22 hatch runs crapy
- EM1 window seals
- Intermittent loss of acceleration/power
- Big wire harness problem when swapping OBD1 D16Z6 into 97 civic/d16y7
- Quick cluster question
- Del Sol VTEC intake
- Interior green plug on harness got wet. Code p1382 now
- tire size with fat fives
- EM1 parking brake trouble
- Why does our 94 Civic still overheat after replacing the thermostat and radiator?
- Help with Apexi Tachometer Decs !!!
- Tires?
- Help identifying leftover bolt on 98 civic ex
- Symptoms of a clogged exhaust.
- ac control lights
- Car wont start after changing heater hose?
- update on shaking del sol swap
- 98 civic motor swap questions
- HELP!! my del is sol is leaking brake fluid
- What kind of rims are these ?
- Check Engine light comes on after misfire
- Manual says to apply silicone grease to LCA bushings?
- 1995 b16 civic help!
- AEM Fuel Rail Banjo bolt/nut help!!
- Belt replacement 99 civic sedan
- Relocating fuse box to the trunk?
- Willl removing the driver side airbag disable the passenger side?
- 94 Civic - CEL and low, rough and unstable idle
- trunk wiring harness
- HOW could i tell if my 96 ek ex coupe had keyless door entry or not ?
- 00 civic sohc getting trans codes (P0715 740 730) but shifts fine
- Del Sol B16a covers road in thick white smoke from tail pipe - Blown head gasket?
- Would catch can on d15b7 get more mileage and keep it cleaner?
- 94 Civic - need help reading CEL code
- CA speeding ticket in my hatch 45mph in a 0mph
- 97 civic moonroof panel problem
- civic lx stock - tryna make it more powerful
- eg hatch wheel fitment
- 93 civic d16z6 Cv joint - EX and Si the same?
- Disk brake dust shields. With or without ??
- Clutch Engage Point Help
- 95 civic ex ignition switch issues
- 92 civic cx Intake suggestions
- 94 civic check engine light not working anymore?
- my car sounds like a wookie
- Help with DD purchase!
- 93 Del Sol - no power to anything
- do they make aftermarket doors?
- tranny sealing?
- Please comment on my exhaust set up for my EM1
- Will stock airbox from 93 2.2l accord fit 95 civic?
- How to make VTEC crossover louder on UK MB6 B18C4?
- 92 Civic CX Won't Start - fuel pump primes, has spark, but not CEL codes
- ZC motor - broken rocker arm
- Lowered em1 - header clearance issues
- Did I blow up my motor? 99 Si Turbo
- Coil sleeve/ring things on Eibach Springs?
- replica ferio spoiler
- B18C into 6th gen coupe.
- where am I gonna get E-brake cables?
- 1994 Honda Accod Check Engine/ABS Light Help Please
- no gas response
- Radiator steaming and fan doesn't seem to be turning on
- 93 SI (dimmer switch part #?)
- Bride seats bracket?
- titling issue PLEASE READ
- 2010 si seats in eg??
- what is an ES kit?
- 93 SI hatchback build ideas. d16z6
- Help! 99 Civic with JDM GSR won't turn over...
- D15b7 engine build
- Mechanical timing verification? *pics*
- d16y8 auto transmission with a y5 engine is it possible?
- 98 Civic wont start
- Popping noise in exhaust?
- 1996 coupe build
- Where i can get Civic Ferio ViRs ECU?? HELP!!
- 93 civic dx - where I can get stock body panels?
- 99 civic dx cranks but wont start, need ideas?
- Upgrading master cylinders??
- Help!!! 92~95 civic pillar antenna
- (Help!) What tires should i get?
- Del Sol driver's vent
- Signs of a bad water pump?
- brake problems 0.0
- delsol/lsv swap is shaking
- B16 hesitation/sputtering at low rpms (>1700rpm)
- D16Z6 w/ hx intake and ecu what have i made!!!!!
- first ej6 build
- d16y8 NGK blues on b16a2?
- upper control arm install
- Si Power Mirrors on DX Hatch(99)
- EG OBD1 ECU P06 connector pinouts in Helms or where?
- 99 lx 4door - problem with ek3 power folding mirrors
- honda civic rear disc conversion wheel bearing
- 94 civic radiator fan doesn't run
- Weird noise from fuel tank area?
- new to the honda scene
- Iacv placement question
- Replacing starter and battery to fuse box wire.
- defrost mode not working ej1
- 22 Mpg with 96 Civic Dx Automatic??
- Dyno of 94 Civic with 191-whp bolt-on USDM gsr motor
- 4 point harness with stock seats
- Keyless Entry 97 Civic
- Skill testing questions about GRRRRRR fuel pump!!
- 98 civic cranks no start
- how do i take the banjo nut out of the fuel rail?
- Aluminum flywheel
- Yet another EK build thread
- 94-97 DC cluster into 98 ej8
- 96 Civic CX cluster swap - extra green connector?
- 97 Civic EX Won't Start
- 94 civic ex automatic - questions about swapping in a D16Y5 engine
- 00 si/boosted b16a swap - got fuel got compression got spark, Wont start
- 95 Civic EX -- Is the FITV going bad?
- 94 Civic EX stalled - no spark
- differences between 97 civic proportion valve and 00 civic si
- 96 Civic LX - ball joint just spins not allowing me to tighten it
- 98 Civic LX auto - Is 29 mpg on highway normal?
- 94 shift linkage
- 95 civic DX/z6 swap - hard to start and CEL codes 6, 10, and 19
- Y8 auto to z6 manual swap, please help
- ep3 seats in a eg, how to
- Replace trunk lid or body shop?
- 94 hatch cx brake swap help!!
- still having a brake light issue.
- 94 civic build!!! leave feedback
- obd1 vs obd2
- 1996 Hatch K24/20 project
- 96 Civic door panel removal from rear door that won't open?
- Can I swap my d16y8 head with any other d-series head?
- 00 Civic EX - Transmission D4 code 16 (Linear Solenoid)
- 95 civic will not start - water on passenger side floor
- 94 civic - eBay racing seat installation and bracket issues (pictures!)
- 97 Civic speaker wiring - how get wire through door grommet?
- my 95 civics back tire is toed out bad
- 92 Civic not starting - fuse 24 keeps blowing
- 98 Civic...need to get some stuff rewired..Dome light, CD player, chime, power lock
- Is a 97 Civic HX (EJ7) Coupe Worth Fixing Up??????
- 1995 civic ex 1.5 v-tec distributor problem
- 94 EG coupe auto to manual build.
- 92 Civic DX with stalling/starting problems - Main Relay issues? Help
- D15B Vtec - Oil eater and blue smoke
- letters stamped on cams need info.
- D16z6 build
- 98 Civic CX/D16Y5 swap - TCM/TCU and wire harness questions
- 98 Civic DX - B16a3 Swap Issues
- Clutch replacement info
- Si floor harness tail light conversion to 96-99 Ek hatch
- Should i get a universal or direct fit cat to fit my setup?
- 92 hatch shaking thumping vibration during driving
- chassis harness question
- new head gasket, now there's no spark?
- new to the forum!
- Possible head gasket trouble, or...?
- Cam an rack swap on a d16y5 need help
- Russell Brake Lines Help
- white crow bumper.... and need help....
- 1996 civic overheating! need help
- How do I fix this rear bracket?
- Weird RPM Shifting Problem
- Dome light won't come on as doors are opened
- Beginings of big brake upgrade on eg from integra
- Yes it's Another No Start Problem
- Heater problems
- material suggestion for making tire cover
- 97 Civic Wiper/Washer - fluid sprays but wipers don't activate
- Which headlights to go with?
- Obd1 gsr swap tick
- oil and coolant mixing
- 1996 Honda Civic Dx gas tank size?
- Brake Light constantly on
- Noisy Front End
- weird misfire
- Honda Civic dx 92, timingbelt broke and had a mechanic replace with water pump today.
- 94 Del Sol Si - Any bolt ons for more power and/or torque?
- Rotor not spinning
- Took my car to the carwash, what do you guys think?
- wierd steering noise??
- High Idle HC - Failed Emissions
- ACT PRESSURE PLATE ?
- b16a really high idle then cuts off
