View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Problem with 97 Civic HX
- how to swap a dohc vtec into a sohc vtec?
- Best Lighten Flywheel for LSD tranny????
- help choosing springs..
- B16 LSD Trans For Jackson Racing Supercharger
- How to take off driver side door panel on a 98 Civic?
- correct tire size for 16" slips on 98 civic coupe
- How do u remove the rear seats on a 4 door EK?
- SHould i RUn the Sandwich for Oil or the T in back of the Block?
- THen why dus CRX & Civics Pre-'92 have a pic of cars topic not us??
- EG Speedometer Problem Searched
- Which suspension forks are identical to 99-00 Si (SiR Canada) Coupe?
- car cranks but wont start, died on the road
- Brake swap - soft pedal
- Tailight harness wiring...????
- $12,999 too much for a Laguna Seca Blue EM1?
- Car will not redline in 3rd gear. wtf?
- Difference Between Automatic and manual steering column?
- short shifter
- throwong code 7
- Shop Manuals
- My Car Produces Oil!!!
- dohc vtec del sol a/c compressor bracket
- 97 EX fuse diagram
- del sol ac bracket bolts for swap
- Clutch Chatter Prob.
- lookin for tranny conversion advice:
- Not sure how to fix enging codes
- New Intake & Check engine light too...plz help-:searched:
- ok throttle prob
- Eg cluster removal question.
- Honda Problems
- How much would you pay....
- KYB Agx's....?
- Tranny noise.....noise record included
- question to user w/ bright white head light bulb in their eg
- CEL 24 OBDI (possibly)
- '97 Civic or '94 Accord?
- Honda accessories VANCOUVER BC
- need tint
- problems with power windows
- h22a swap turbo for sale
- 95 civic ex coupe... great deal.
- black smoke
- Valve spring compressor?
- what do you guys suggest for a cheaper exhust for d16z6
- Compression test
- smelling weird
- Hondata Help!!!
- Brake lines: OEM vs Aftermarket.
- Finding oil leak source?
- Help me choose a HID kit
- ek foglight problem 96-98 99-00
- H22 swap in dx ek hatch
- BLUE NEONS INSIDE A CAR
- Learning Swaps
- RICE turbo k20
- B16 hondata s200, what ecu?
- solution to my door lock question
- 97 EX Seats into a '92 Hatch?
- POST SOME PICS OF YOUR CARS!!! LETS SEE SOME CARS!!!!!
- EX Brakes question.....brake gurus..come on it!!!
- wat kinda tires should i get?
- NEED HELP TRANNY 92-95 QUESTION
- Performance Upgrades
- brave move, results not to pretty (JDM CTR MIRRORS)
- will 92-95civic springs fit 96-00civic?
- Mcgards or Rays? or possibly other lug nuts
- optional audio console
- installing a short shifter...
- civic si bulbs in our EG climate contro???
- differences between jdm b16 and usdm b16?
- b16 tranny problems...
- installing a b16
- Pricing on an ECU???
- Question about idle...
- What oem steering wheel for my hatch?????
- arm rest for a 93 dx
- Just Bought My First Honda and i dont know whats under the hood
- how accurate is the stock tach?
- safe to use p05 (civic cx) ecu on jdm d15b motor?
- Look at what this nice motorcyclist did to me !!!!!!!!!!!
- standard conversion wiring
- Radiator fan fuse keeps blowing, any ideas why?
- Exhaust shop piping
- Is it possible to convert a honda engine into diesel?
- How to make a 97lx faster?
- 96 Civic DX auto to manual
- clutch install
- titanium resonator
- H22 EG axle problems!!
- header question (searched)
- stock b16a2 head flow?
- Help needed on 95 Civic Prob.
- HP quotes?
- someone busted my window, wheres a good place to get new glass?
- tranny problem 99 LS in 95 coupe
- 92-95 civic dx stock exhaust piping diameter
- car wont start main relay????
- DOHC ZC Swap
- AC Blows fuse
- Angel Eyes 95 Civic
- Hi flow cat
- Distributor Help
- sparco seats in an ek
- o2 sensor problem
- Swap Question
- CAN SOHC vtec solenoid fit DOHC motors?????
- rsx front seats lower or higher than civic seats? (searched)
- Need help with engine light?
- Possible hydro lock???
- longshot but worth it i guess
- changing out igniter
- Lining up motor mounts for droppin' engine in
- gsr into 00 civic ex wiring ???
- What do you think of this clutch?
- I keep popping my speedo fuse?????
- whats a car like this worth??
- jdm teg sir-g to an eh. whats needed?
- Driver side window help
- clutch problem.....what is it?
- y8 Headgasket question
- Tach Jumping
- will this tranny work with my d16y7???
- Anyone rewire horn completely with Momo and Hella?
- Need help to find our where sputtering is starting
- ek maplight bulb
- Throwing codes and need help!
- Five Bolt Conversion, ITR to an EG6, but how do you distinct ITR 5 Bolt Conversion?
- DIY: delsol seats in to 92-00 civic
- ARP Head bolt Question?
- vei engine code and tuning
- B16A engine model 1998?
- eg si help
- weighed the coupe today
- D16Z6 Somebody knows the HP of this engine
- [FAQ] Hood Weights
- i have to go see the bar ref for my exhaust help!!
- SI muffler vs. DX muffler
- energy suspension master bushing set(searched)
- Need to know of any Philadelphia area shops
- HOW MUCH do you know abourt RESISTORS
- Emissions in UTAH.
- Need diagram from service manual 97 DX timing belt housing
- A few problems with my headlights
- Carbon Fiber Can You Re-Clear coat?
- what do we all think of the AEBS Typhoon intake manifold?
- main relay, igniter honda civic 1990
- springs loose when i jack up car???
- best head on d series
- Fuel Pump wiring question
- Finding Engine Information..
- racing seats???
- Tachometer Install Problem
- balljoint question
- Where can I find Ate Super Blue?
- Bosch Platinum spark plugs 4227
- IDLE ????
- Y can't I post in other sections?
- 98 Honda Civic CX hatchback too much to fix?
- CAR STOLEN, NEED INFO
- WTB, d series tranny for a 96 del sol, i know its in wrong place but its urgent,
- OBD1 DOHC ZC & D16Z6 Comparison
- Is It worth the trouble?
- Tint
- CEL code 61
- Bit of a rough idle on my 94 civic....any ideas?
- Question on where to find cheap mesh grille material
- europeian civic wants to come to america
- To all Ek hatch owners HELP!!!!
- Canadian Tuner Sites Please
- Recaro Seat question
- 00 si front bumper on a 99ek hatch
- 150 MPG?!?! Horrible gas mileage?! im lost
- GSR Front Spindle HELP!
- fuse help!
- how do you guys put your lips on?
- steering wheel shakes violently
- Will a b18b1 oil pan fit a b18c1 ?
- Del Sol Roof Rubber Seals
- Built motor on stock muffler question's...
- *CTR SRS steering wheel help*
- paint choices for wheels
- ek door handles on eg
- How much does a d16z6 weigh with no tranny, just the bare engine?
- 99 civic SI timing belt???
- A HOW NOT TO on Crank Pulley advice
- A/C install in my 93 Si
- Skunky Cam Business
- Who knows the D15B?
- Wheel Noise???
- help me dicide on this trade
- Do they make a silencer for the magnaflow catback exhaust system??
- right hand drive ek?
- Match exhaust to car or engine??
- Dual Core Radiator question..
- Distributor Pinout Help B20b into a 00 Civic Dx
- OK fixed clutch....still a problem?
- Anyone have 97 EX FUSE DIAGRAM (searched already)
- Danbury, CT -- obd1 ECU chipping/tuning
- Help with the 3 Bar Map sensor?!?!?
- if the ecu is throwing a code will vtec engage?
- a 1990 honda civic dx radiator
- B18b auto
- help car knocking on passenger side
- Car runs wierd cold, please help
- got a newb ? about carsound cats...
- Tire question for my Eg?
- Exhaust questions. NOT a pic request
- problem # 1,000
- AEM V2 cold air intake
- rear camber shim kit install on 96-00 civic
- Decent Shocks...
- REBUILT AND RUNNING PIG RICH
- re
- Is this legal in Ca.
- Almost there! i swear i used search.... TACH RPM WIRE!?!!@
- Transferring Transmission
- Please help DIY Wiring Power folding mirrors
- Replacing Headlight Bulbs on a 94' Civic
- Rear main seal
- Misfiring at low rpms????
- Newbie here! Need your help!
- Civic backfiring & stalling. speedometer going crazy.
- ARE THESE ALLOWED
- Light-Weight Wheel Suggustions, I've been waiting months, grr....
- 2000 Si B18c5 Swap FOR SALE
- Hi everybody lookn for info
- Need help finding IAT
- Cam markings in JDM B16A
- Tail light FUSE for 97 ex (searched)
- Whats the problem with my car??? help!
- How do I install an Autometer electrical Water Temp. gauge? No instructions...
- Over heating, help
- civic drive cycle?
- Modifying Mount Bracket, Need Help!!
- 99 Civic SE/VP Radio Code??
- Should I pick up this engine ?? is it a good deal ?
- What would you like to see more/less of in the EG+ Forum?
- need help 99 LS in 95 ex
- sum ting wong
- HEY GUYS HOWS THE WEATHER OUT IN TEXAS
- d16z6 or dohc non-vtec zc...
- ITR cams for B16A
- Blinker stopped blinking
- 92-95 4 door carbon lips??
- codes for civic 00?
- Big brakes with 15/16 master cylinder on an EG Civic?
- Transmission Jack
