View Full Version : Honda Civic / Del Sol (1992 - 2000)
- HELP Cranks but No Start civic 96 ex
- 95 del sol vtec-e, ECU problems
- 94 Honda Civic Smoking?
- Just ordered 15x7 +10 offset for my em1
- I/M nut keeps spining and spining.
- 1992 sway bars
- b16a2 running rich
- 97 civic LX suspension
- problem, change cvt to manual
- battery light
- Bad miss; stutter; hiccup
- CTR suspension opinions
- APEXi WS2 Exhaust and ASR
- GSR rear disc swap question/s
- Thowing code 22.
- D16Y8 Idle Problem
- Acura 1.6EL 2000 front brake pad and rotor
- Water outlet housing removal ?
- fuel pump fuse keeps blowing (ek hatch)
- Change radiator fluid...car won't start now and has a frozen crank...
- 99 civic suspension
- Electrical Issue with Turn Signal
- Car wouldnt start jump started it and died again
- Power windows and door lock issues
- AC Evap Cleaning doubts
- H22 EG build thread
- Door handle bushing
- weird grinding noise while under high load
- Interior Electrical problem need help
- battery light comes on after changing new alternator
- High picth metallic whine after having work done on car...
- L/side halfshaft install issues
- Z6 engine not running after multiple repairs check it out!
- Quick question about a stripped out shifter?
- need help 1993 del sol injectors not firing
- door locks wont lock
- simple swap wiring harness confusion
- 2000 si grill ?
- 95 civic coupe EX wiring gremlins
- 92 civic hatch front clip
- 97 Civic Auto Trans issues
- P0505 IACV Malfunction need help, tried everything.
- Outer Handle Rod Bushing Part number
- Idle Problem
- Cold Startup Problems 93 Del Sol
- B18c1 over heating plz help
- under wiper cowl foam flap?
- Last production for the del sol......Puzzled question????!
- 98 LX automatic transmission issues
- Del Sol starting issue
- Rear seats for ej8
- which grade gas
- heater/ac problems
- $500 Headache 92 Civic LX Swapped WONT START
- Coolant leak
- d15b multimatic rev limit
- D15b vtec block with y7 head?
- Fix for no brake power assist below freezing
- Use car without drivers side lower engine mount?
- how do you attach the ek door panel inserts back on
- D15B1 smoking issue
- No Spark, I've done all the tests
- Do I need a new mechanic?
- 1993 del sol si, won't start.
- After MAP pinout test question
- brand new input shaft bearing making noise
- 00 Civic EX won't start after replacing starter - I don't even know what to try next
- 93 del sol Build
- 96 hatch/Jdm b18c (R) - what A/C Compressor?
- need some help
- Transmission guys HELP B4RA
- 1994 Civic LX 1.5 engine is studdering and jumping and now wont start. PLEASE HELP!
- cutting out like a brick wall @ 2300rpm
- JDM F20B vs JDM K20A
- car runs amazing in cold weather but not in hot?
- Heater fan just quit
- speedometer problem
- 94 Honda Civic DX will not start
- My car just died?
- replacing clutch over holiday, no clutch alignment tool
- Rear Fog light problem.
- 00 Ek gsr swap No high idle at cold start? Iacv, Ecu
- 95 civic cranks consistently but doest start
- Running lean in cyl#1 ?(spark plug pics).
- D16 vs Swap
- GSR: Engine "bogs down" in VTEC, fuel cut off?
- Best fuel rail in the market?
- Knocking on deceleration
- Honda B18b block with B16 vtec head problem!
- 98 Civic DX hatch ignition system broken. help?
- 98 Civic P1298, P0500, P0135, 20V+
- White smoke help!
- EDM aux lights on Del sol?
- d16y7 block jdm d15b non-vtec head
- 2 Early 90s Hatches, 1 Restoration, 0 Idea Which Way To Go
- 1993 Honda Civic Si Stuttering Problem
- 98 civic ICM
- 96 civic smog issue
- 1994 civic hatch build up
- 98 civic - lights and radio turn off and on
- 1998 EX Loss of Power on Low RPMs, Good Idle
- Help with installing trunk latch
- HELP! Severe leak under distributor!!!
- Could intake cause cylinder 3 misfire - I'm so sorry, but let me ask again.
- DA integra spring & shocks on EG ?
- Freon(?) help
- 93 Del sol start and die
- Anyone that owns a del sol can be a hero
- Obd2 to Obd1--Do I need both ECUs?
- 96 and 00 d16y7 intake mainfolds
- Some jackoff hit my car - any sources for parts?
- Brake swap. Ran into a snag. 99 dx hatch
- Will d15b7 crankshaft fit in a d16y8?
- Do all / any obd1 92-95 civic and obd1 94-95 integra FITV's interchange?
- 93 del sol Si - fuel pump won't prime
- CEL misfire issue EM1
- Exhaust fitment question 1995 Hatchback model
- D swap
- Mid engine swap
- Alternator issue -- 3P wire harness/4P alternator
- 97 civic LX magnaflow 2.25 bad gas?
- Are All Speedometers From All Custers The Same 1993 Honda Civic del Sol
- EG front bumper side hook (help me find these)
- Jumpy speedometer: VSS or cluster?
- ekb16 swap questions, wiring priority
- I have fuel and spark won't start
- AMH Stamp on B16: Anyone know what it means?
- Won't turn over after stalling.
- Considering a civic, need advice
- Driver side front wheel making squeaky sound...
- Seibon carbon fiber fenders
- OBDI GSR suttering/lagging low rpm
- Del Sol oil leak
- 50 ignition fuse keeps blowing! help!
- Possible 2000 Si purchase.
- D4 light blinking and hard shifting
- EM1 Si Restore
- civic HX - when and under what conditions does it go into the Lean Burn mode?
- psi for hx wheels?
- Wiring a radiator fan switch back to stock
- 99 Civic - distributor rotor screw length and size?
- OBD0 B16a in a 4dr 98 civic.. NEED HELP!!! DIES WEN I GIVE IT GAS!!
- 94 honda civic car bogging down while driving
- engine swap want to upgrade?
- 93 ej coupe shaking problem
- EK Door Inserts Done the RIGHT Way
- 95 civic vx b18b swap no fuel! help!
- can't figure out idle problems on 98 civic!
- 95 civic lx speedometer problems
- srs light 95 civic ex
- D16Y2 To D16Z6
- engine mounts
- Stiff First Gear?
- Brake Bleed Question
- Where To Buy A New Vtec Valve??
- Power Windows
- 00 Si problems after engine jumped time
- Cold weather whirring D16Z6
- EG no start one click help!!! idk whats wrong
- Torontojdm???
- Power Steering Hose Disaster
- looking for the right civic.... suggestions?
- Code 1337 & CKF Bypass Method
- tail light poles switched? wiring?
- 1999 Honda Civic DX Tac
- Sloppy Steering
- A/C Only works when in motion?
- 1998 Honda Civic LX Motor Choice?
- obd2 to obd1 question
- Questions about 97 civic with y8 head.
- Mini-me/5sp swap. wont start. help?
- Knock Sensor Issues(EM1)....Help!
- d16y8 block with d16z6 head
- B16b port n polish
- Replaced Instrument cluster, fuel and temp not working?
- Annoying High-Pitched TV Squeal-Like Sound, Occurs Only when A/C is On
- Having engine problems...PLEASE HELP!!
- 95 civic ex has fuel, spark, compression, and is in time but wont run
- need a carfax TONIGHT --- plz
- Ej/eg nose mask question
- water leaks in 98 ej6 hatch - foggy windows and water in the spare tire area
- Car slightly jerking when keeping constant throttle?
- Swap bottom half of door panel on EM1..??
- 96 ek hatch w/b18b swap sputters untill I floor it??
- loud thump while turning
- 1999 CIVIC CLUTCH PROBLEMS
- recaro seats
- losing coolant, overheating, Help me!
- 4th gear grind
- 1997 civic tranny swap???
- Electrical issue Please help!
- Ground Control Spring Identification
- 92 Civic Hatch Wiring Problems
- Need Help 98 honda civic lx
- Cooling System Rebuild(?)
- 2000 EM1 dash ligh fuse
- EG9 ferio wing/spoiler
- Why on earth are my control arms different?
- Civic Front End Alignment Specs
- Name that engine noise: Knock, slap, clap?? Audio Included.
- 92 Civic Hatchback DX - brake lights won't turn on
- drivability issue with b16a 2000 civic
- 97 civic hatch reverse light plug
- What did I do wrong? White smoke after head gasket fix?
- Correct K&N Air Filter for an EK with B16a?
- IACV Questions and a few others
- EM1 Five lug Conversion questions
- 2000 Honda Civic hood fit
- Ckf bypass fail on b20 need help
- del sol s d15 wont stop over heating
- My EM1 dilemma...
- 95 civic lx roof rack
- Expanding FM frequency on Gathers GXC-7108SFW
- 1337 CEL
- Coil Spring (2000 Civic LX) - is there a trick to getting it to stay on the coil?
- alternator over-charge...UGHH!!
- converting to obd1 chip/tune
- z6 sputters on cold start only
- Brian Crower cams?
- any recommendations on a good priced seam sealer for interior leaks??
- Ek swap almost done but small problems
- Monroe Quick Strut vs. KYB Strut Plus or any other suggestions?
- 2000 civic ex taillight problem
- Skunk2 coilovers question.
- B18c5 into EK throttle cable problem
- Function 7 Lca.?
- help!!!!!!! transmission problem
- Help!!! 93 civic hatch
- H22a Ek coupe Shifting Problems
- 1996 civic hatch exhaust-- HELP!
- 96-98 civic auto trans difference between ex vtec and dx non vtec?
- CA smog issues
- Need New Distributor
- D16Y7 Tensioning Problems / Excessive Deflection? *Pics*
- 92 Honda Civic si project car
- 1996 Honda civic Question
- 98 Civic EX B18C1 swap
- si/gsr strut bar question
- D15B7 into 97 Civic HX. need clarification on O2 sensor wiring
- How to Read Bolt Measurements?
- My heater won't work and my radiator fan won't spin!!
- Rear disc swap question
- z6 block with y7 head...timing, part numbers wrong?
- MAP TPS Poor Fuel Economy
- 92 civic b16a hesitating (low rpm)
- Lights won't turn on in my Eg ?!
- 94 ex engine code
- 99-00 CX sub frame
- Burning smell when flooring it? brown tinted coolent?
- 94 honda power steering rack
