View Full Version : Honda Civic / Del Sol (1992 - 2000)
- will older gauge clusters work with my 96 civic ex?
- VTM Signal?
- OBD2 SOHC distributer connecting to an OBD2 LS motor
- OBX products?
- HX O2 sensor
- Bogging EH2 w/ B18B1
- need soem help guys fpr problem
- dc header melt tha a/c pipe now not workin...
- my 98 EK story
- 96-98 EK CUPHOLDER --> 99-00 EK?
- Question about valve cover?
- SHE NEEDS LOVE TOO
- What suspension set up would I need for my 95 Hb Dx?
- d series trans adaptor kit to f/h series???
- rings for srp pistons
- Idle problems, and perhaps Main Relay?
- which flywheel....ACT, Spoon or Fidanza??
- what turbo to use???
- What can cause my ground Vtec Solenoid to melt
- b16a for a 4 door eg
- skunk 2 coilovers
- electric doors
- need help on b16a3 IACV = idle problem! cleaned but stiill...
- the higher the offset, the nearer to the car's body the wheel is?
- f/s omni power camber kit
- From what engine? Dizzy question
- Handling Q?
- Pic Request: Integra Clusters in 92-95 Civics
- help 99 dx hatch exh mani
- speakers dont work
- Common Problem with minor rough idle?
- where do i find wings west side skirts for my eg?
- sawpping gsr cluster into ek. need help asap
- GSR SEATS
- leather GSR front & rear seats into a 93 DX hatch.
- '93 Civic... What A/C system? R12 or R134?
- any sellers?
- coilover top hat
- Squeeking noise
- Where is my oil going- D15
- AEM EMS OBDII Question...
- ls swap price
- window rattling noise?!?! 92 gsr eg
- Throttle Body .
- A/C problems....!?
- engine ping under heavy load. HELP!!
- ID this throttle body
- p72 in b16?
- where to find type r swap.
- good cruising rpm
- Anyone have any extra ground control tools they wanna donate?
- Where to find......
- intake resonator (yes i have searched)
- No honk with keyless entry system on 99 Civic EX Coupe
- 96 Civic Air Conditioning Installed. Help
- where can I find the diagram for fuses
- UK civic hatckback engine swap (confused! plz help)
- temp gauge overheating
- how do you remove these pieces?
- help to get rid of sticky stuff off mirror..
- jdm d15b valve cover.
- Help with an oil leak!!
- integra air intake on a d series engine...
- JDM B16 Fuel Problem
- b series valve spring removal
- 93 si hatch
- HOW TO TELL THE DIFFERENCE BETWEEN A B16 AND A B18C5 HEAD
- exhuast is better
- For sale- 2000 Honda Civic Hatchback
- pistons?
- looking for 92 hatch fenders??????????
- shifting problems 93hb b16a2
- Just Got a Greddy Turbo Kit for D'series, What is it worth???
- WHAT DO I DO!?
- CTR crank pulley to run or not to run ?
- Starting up right after shutdown
- I need a CARFAX Pronto
- CTR Cam Dyno's
- How about these Headers?
- what are the voltage outputs of sensors in bay
- Filter on throttle body??
- Rear Disc brake conversion (question)
- 92-95 civic 2dr/3rd shaved door heyhole
- Huge Timing Question Need HELP!!!!
- Yes or NO
- What Magnaflow Exhaust Are You Using??????
- Clutch noise
- Greddy Cat Back Exhaust..
- y8 intake man. worth the money?
- concerns of swap
- Code 22 - Will not go away!!! Please Help.
- stroker kit cylinder head??
- Intake for my 98 Civic
- obd engine question
- OBD1 B18B swap into OBD2 Civic EX
- how to tighten AC belt
- HELP! Are 99-00 Civic Si and 96-00 Civic EX coupe midpipes the same?
- ITR cams in a b16
- b16 hydro tranny on a obd1 b16a?
- How-to GSR Cluster in EG. (Couple things people left out)
- d16y7 better boosted than mini-me?
- anyone selling a affordable turbo kit for a b18a1 engine
- how much anti-freeze in a civic Rad?
- what type of head
- d16y8 t-stat housing...
- Recommended mechanics for timing belt changes in New York/New Jersey
- EG SI vs. non-SI
- Need help ASAP, rod knocking? oil pump going out? d16z6
- Will a non-vtec 97 Civic distributor work properly on a Vtec 98 Civic EX?
- Installing transmission-How?
- will this fit
- Converison on 92-95 front end
- passing inspection
- b16a into ek-9? will it be worth it?
- errr, where do i put in gear oil?
- Obd 2.5 to Obd1 Jumper Harness
- b20 oil pan on b16a? will it fit?
- Shooting Spark Plug
- ef springs on my 99 SI??
- need any info on p73 ecu!?!?!
- help, EG civic fuel problems
- LS wheels?? color
- OPINION ON LOWERING JOB
- Does this sound normal to you? My oil "burn" rate...
- sooooo confused need some advice
- head bolt size
- Del Sol Rear speaker panel questions
- CTR camber kits vs stock camber kits
- Nasty metal grinding noise - PLEASE HELP!!
- D15B8 on JDM D15B VTI motor
- MY CAR WAS STOLEN!!!!!! PLEASE HELP!!!!!
- Weird shift linkage in my EM1
- no check engine light
- Who is running ATS FD w/o LSD?
- www.JDMcustoms.com - What are your experiences?
- Del Sol antenna
- state reffed smog question for 92 eg with b18b swap(HELP)
- B20-Vtec
- How to on lowering spring
- question on my 00 si headlights
- 92 eg boosting HELP E-manage
- Del Sol Stock exhaust question need some help
- emission test fail help
- Tranny has no neutral!!! (I know it does but I can't find it)
- Help my car wont go in gear **UPDATE**
- Car won't start Agian. Searched. weird symptoms bad ECU?
- throtle cable
- fluids for swap
- 95 GSR oil?
- VAFC controller diagram?
- Skunk2 Short Shifter Questions
- Can anyone figure out what my problem is?
- sealing my vision replica corners
- need help on 95 civic!!!
- Fuel Filter
- FORSALE/TRADE 93 Hatch (very very very clean in the NoVA area)
- exhaust manifold problem!!
- Megan header question
- Lowering spring / shock recommendations - eg with 16 inch rims & 50 series tire
- Low Oil Affect VTEC..??
- vtec wiring problems, bad ecu?
- what kind of #'s
- car cover
- NEED HELP BEFORE NOPI. Chirping Tranny
- 92 Si, had to offset coilovers to make height even??!
- Which clutch should i go for.... ACT or Exedy for b16?
- dashboard fitting
- Custom 2.5 piping with ES Muffler too loud
- honda service manual crx del sol
- Help identify this o2 sensor
- all eg hatches....lets see your rear strut bars!
- del Sol Master Cylinder
- Pic Request: EG's w/ aftermarket fog lights
- Ignition
- D16y sohc turbo kit, will it fit a dohc jdm b16a....if you've attempted this, i need your help???
- why doesnt vtec work
- please help, d15b sohc vtec
- Honda charge alot for changing an axle?
- civic 92-95 front conversion
- how much lower does a rear lip go, exhaust wise?
- removing a/c from del sol
- Trouble-Shoot
- Turbo guys question. Safe boost levels??
- Cracked windshield!!! need an estimate price on fixing!!!
- thin side moldings
- what to do first to my engine? b18a1
- EGs/EJs with bumpers cut out for large front mount intercoolers.
- Teg turbo ki in SI?
- Cubic feet of a 1995 Honda Civic DX?
- tach got stolen and now i have no running lights!!!
- WALBRO FUEL PUM PROBLEMS
- help with p28 ecu chip
- 93 CIVIC EX CLUSTER BULB SIZES?
- Fuel Pump Question. . .
- Need help separating tranny housing
- Opinion on this turbo kit
- LOOKING FOR
- 99dc2 struts on 00si?
- ANyone ever heard of the d16y8 being a two stage vtec at 4400 and 5000 rpms?
- My new eg8 furniture from japan
- Horn on 99SI
- 04/05 UKDM CIVIC TYPE R REAR SEATS
- I have a question i need answered
- knocking sound when motor under load
- What kind of coilovers are these?
- Civic/Delsol exhaust compatibility
- Safe revving??
- EK engine swap question
- Wiring Diagram
- 97 Civic - speedo is jumpy
- 1993 civic front lower control arm question
- cams for b16a
- uurg e-break light doesnt go out
- plugs look okay?
- '97 EX - Wiper arm "clunks"
- Help taking off my wheel ?
- cars
- Need help w/ crank question on SOHC ASAP
- can you pull codes with jumper off of obd2 gsr??
- Do Any of You Run Non-Reclinable Bucket Seats For Daily Driving?
- Lightweight transaxle for Electric Vehicle
- Cat Convertor Help
- Cost of roll cages
- Is 2 1/4 to 3inch too big?
- need help to remove ebrake lines
- probs after install 16"
- built motor and forgot little thingy PLEASE HELP
- 95 cx won't start
- HELP! Rear view Mirror!!!
- Radiator fitment issues!!! Need help
- power locks doesnt' work after power windows/lock conversion
- code 43, fuel supply system, what does it mean?
- How often are you supposed to change your fluids?
- Omni Clutch Master review w/ pics
- b16 cel
- Swap A/C Help
- MY SPEEDOMETER IS NOT WORKING
- Ebrake Cable is locking rear drum - how do I get the drum cap off?
- Rear section fitment question
- Acceleration Problem
- wanted axle back apexi n1 for 2000 civic si
- Questions regarding replacing RF axle assembly in 95 Coupe EX - And part source?
- How do you shorten the brake booster pushrod length?
- AC COMPRESSOR
- I NEED MY A/C TO WORK
- axle question
- Stuttering on takeoff
- 99-00 si side skirts on an eg
- high beam dash light
- 6061 T-6 aluminum ebay
