View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b18 swap
- Reseting computer?
- What can i use for a gasket
- Fs. delsol parts
- Question about VAFC and no its not "WHAT SETTINGS SHOULD I RUN FOR BETTER VTEC"
- Happy Thanksgiving-not to be...
- Trial Membership
- manual steering rack in power steering car
- "H-Brace".....Does it work?
- CRX Si Tranny Vs EG EX/Si Tranny
- jdm headlights and side marker wiring q's
- Bad iddle problem
- catalytic converter emptying
- looking into a b16
- thought this would be helpfull for u ppl
- Timing Belt Area Noise @ 1500rpm
- Best place to get an aftermarket front bumper that will ship?
- D16 Needs Help!
- Trouble with VAFC-II in 2k Si
- Radiator Fan Question
- knocking/clicking sound from my rear left....
- What lube to use?
- J Walker Lip Kit
- Header install - - - Safe?
- vented cf hoods?
- Removal of EG Hatch rear bumper??
- OBD2 p2p vtec wiring
- need help on choosing comfortable seats
- 10sec civic full interior street tires, 9sec on slicks...sick!!!
- battery keeps dying...
- LUG PATTERN
- bar
- Best all motor engine?
- A/C belt installation on a 96 hatch
- EF, EG, EK, EP... but....
- Anyone thats put an EG tranny on an EK motor help....
- Integra seats in EG
- phoenix peeps please lookout for
- Pic reqest:EK with 5Zigen FN01R-C
- shift linkage
- j's racing intake
- automatic seat belt stopped working
- LSD SLOW YOU DOWN??
- Boost or no boost???
- EG radio reception/signal crappy?
- test
- good wheel offset for eg?
- Omni coilover settings?
- changing z6 head to y8 head and compression also 9.2 to 9.8 hp difference?
- !!!oem wheel offset question!!!
- Friend wrecked my hatch last night...
- what does it take to allow a p06 to enable vtec?
- Idle adjustment screw location on EJ1?
- Which is really better?
- HELP! Car won't start
- Anyone with a 96+ hatch got a trunk leak, too?
- i blew up my single cam
- rocking seats
- EX Header from DC sports for my 1996 CX Hatch
- Side Draft Intake for 1996 CX Hatch
- Guage Cluster w/tach for 1996 CX Hatch
- Non Vtec to Vtec swap (wiring)
- Help with Si Cluster. (Tach Not working) SEARCHED
- 14b boost question?
- anyone know how to reset SRS? 00 si
- squeaky loud sound
- Anyone with a > How To: EK Civic Power Window/Lock/Mirror Conversion?
- Quick A/C question?
- headlight out
- Battery is constantly being Drained....... Plz help
- need a starter!!
- Tie rod end question..2000 civic ..threads are all messed up will a 92 cx swap?
- water temp?????
- Will I Rub Tire Size
- cx to ex brake swap
- exhaust problem?
- trowing code 22? WTF??
- What are some good light rims for a 4dr civic
- b20 crvtec into 92 vx civic
- code 22 but i dont have a vtec engine?.
- tein ss coilovers
- 93 del sol si
- pulley question
- Questions about b16b ECU....
- ATTN UTAH H-T MEMBERES STOLEN CAR
- ITR MC/Brake Booster OR Teg MC/Brake Booster on 4 corner Teg Brakes?
- Rear Strut Tower bar.....is it the same for a coupe and hatch?
- Getting d16y7 block...but it has surface rust on engine
- Stock Sway Bar Sizes
- Installed OBX Cam in my MiniMe ;)
- Stock intake question???????
- can i run a jdm solenoid?
- JDM Clutser Conversion
- Sticky gas pedal
- Swapped B16 from DX Civic to EX Civic..Speedo working w/ RPMs??? HELP!
- any one ever bought any thing form sportcompactonly.com?
- Pictures of your dropped EG hatch w/ specs?
- which eg's come with black dash?
- which eg amber corners to get?
- Prolly the only ? post thats never been posted.
- what is the different between si hatch and gsr moonroof ?
- EK fuel pump/relay problem
- clutch pedal spring
- Civic Si Front Conversion on del Sol.
- Hmotorsonline Question
- Del Sol VTEC brake upgrads?
- my civic dropped
- What intake is best?
- got in a wreck -_-
- z6 head
- Will stock radiator fan work with fluidyne radiator?
- B16 SIR II swap into EG civic?
- B18c Pistons in a B16 Block???
- 99 civic si ?
- 4 door ITR rear seats in EK
- Need Help Quick Eg Coupe B16 or Eg Hatch z6
- shifter install no lithium grease
- DO DC2 REAR SEATS FIT IN A EG?
- Fake AEM intake with pic
- 94 Civic Cx Rear Drums Problem
- Skunk2 front control arms V.S Ingalls "P" shaped camber kits
- Difference(s) between the s2000 and Honda Insight steering wheel?
- Need new muffler
- snapped a bolt.
- ECU ODB2 Question
- Who would win?
- looking for apexi S AFC-II Manual
- 1st gen b16 into 93 civic...
- WS exhaust- will a coupe catback fit a hatch
- help idenify this oil pan!
- Whats the difference between VTEC and VTEC-E solenoids?
- west coast – how much does a decent eg go for
- sohc skunk2 intake mani info
- question about headgasket and timing belt
- short shifter
- Caps Lock R Stuck y0!
- Used Japenese Engines?? Any Good?
- Main Relay or distributor? Help, new civic owner.
- tapped b16 ?
- Help? How to remove steering wheel?
- What clear coat do i use?
- Eibach Sportlines of H&R Sports Suspension
- what bhp n/a?
- 92-95 Civic corner lens, and map light bulb size?
- And again.......brake question, yes I searched :D.
- HELP Speedometer not Reading
- ITR cluster into a 96-00 civic direct swap??
- SWAY BAR WORTH IT?
- Civic ?'s
- k20/k24 head
- 03 si seats
- Ideal fuel settings with fields vtec controller
- I plan on buying 16" OEM rims. How does that affect my driving, if it does at all? Also, best tires
- has anyone ever put a 01' civic motor d17a2 in a 95 honda civic?
- Now that I have my CF hood. I have a few questions.
- Installed my air horns directly to factory horn wiring and.........
- Vacuum lines don't seem right
- search down b16 into 96 civic
- Squealing noise from starter
- help
- will these tires rub?
- happy thanksgiving everyone (free food so eat all u can)
- compression test
- 96-98 4DR Taillight to 99-00 4DR Taillight?
- obd0 to obd2 intake manifold swap
- squealing when turning problem, any help?
- What does everyone think?
- Search function is down..... quick question...
- will a 96-98 SiR lip fit an EG sedan?
- Anybody know the belt size for the AEM PS Pulley?
- p28 vs p08
- Front End
- Problems with car, please help! (turbo LS in EG)
- integra brakes search server down
- cat-conv bolt sizes
- High idle?
- looking for someone near Seattle to tune hondata in my EG for $$$
- d16a6 cam in a y7??
- 92-95 EG (cx) with sidemoldings???
- car wont idle correctly
- timeline of my civic
- Stupid Question.. Are all B series engines the same size, just different boring?
- Intercooler Piping
- window track lube
- HEY GUYS HAPPY THANKSGIVING!!
- ??? OEM Wheel Offset for 92-95 EG ????
- Baked headlights?
- 92 honda civic cx wire vtec to vafc.
- LS Swap... what is needed????
- NEED major help with ba16a in 92 eg
- Should I be using teflon tape when connecting brake lines/components??
- wheel stud question
- wheel hop question
- Civic Type S
- LCA compatibility? suspension swap ?'s
- H22 from my 94 accord to my 92 civic hatch
- Are all auto parts stores closed today??
- TSUDO N1 AND OBX CATBACK EXHAUST OWNERS CLICK HERE... GOT SOME QUESTIONS
- full carbon fiber race seat???
- SPOON N1 setup questions
- Steering lock screws
- Help me light my cluster :)
- Integra type r springs&shocks combo on ek
- New bie here just saying whats up
- how the heck do i...
- Help with linkage 94 civic si about to swap 2000 b16a2
- 94 Civic Radio Problem
- Fog Light installation
- 93 civic hatchback rear speaker brackets HELP!!!!!
- How do You connect vtec solenoid
- quick question
- motor mounts
- Matrix Fog light help.... 92 civic dx..
- Smog Registration Early - California
- compresion calculater
- has any tried the h beam for the civic from ebay
- will a thinner head gasket raise hp? cometic or stock y8
- REAR LCA BUSHING...
- will 4dr eg civic disc brakes fit .......
- any oe got a light del sol. PICS??
- Cam seal D16Y8 ?
- help check engine lights on, cylinder misfire and fuel system is lean
- Fuel managment for 10 PSI B18B
- Do 99 Civic si's come with oem floormats with "Si" on them?
- differences in front LCAs
- D16Y5 Engine Oil Dipstick Interchange
- Question: Anyone have the Apex-i N1 Vs. CTR rear lip issue on their 96-00 Civics?
- GC Coilovers Question
- Dome Light Help
- Dumb lugnut question...
- car bogged then ....wont start again
- 98 Civic lx
- What fuel should i use?"
- Yellow/Green wire to ICM (ignitor control module) does pulse. Why?
- Blew my radiator... sucks...
- D16Y8 cam seal ?
- Grippy tires
- Cylinder 2 Misfire out of F'in no where? How?
- does anyone here put synthetic oil in there stock civic engines?
- Vss problem
- D16y8 into an HX
- autozone fried my ecu
- Strength of Oil Pan
- WANTED - 92-95 Civic Hatch
- Timing belt sloppy on exhaust side?
- [FAQ] How-To: Removal and Installation of a Distributor O-Ring.
- center console help!
- surging
- sway bar question
- What's better for RODS!
