A/C Vents blowing desintegrated foam
I have a 2000 LX D16y7 Civic Sedan and it began to blow pieces of foam (sometimes just the dust from it desintegrating) out from the A/C vents. I'd like to replace those foam sealers but have no Idea how and what are those P/N or the name of that particular part.
The A/C works like a charm, just this foam pieces that are pissing me off.
Need a little help.
Need a little help.
Re: A/C Vents blowing desintegrated foam
I'm interested in the answer too. My Civics have been shooting disintegrating foam gasket from the vents for years. I did not see replacement gasket material for the heater unit sold at Majestic Honda.
Might it be the inner or outer seal for the evaporator:
http://www.hondaautomotiveparts.com/...IT&vinsrch=yes
I kind of knew WHAT was the foam, but have no Idea HOW do i dismantle the centerconsole to replace it. Or even how to get to the evaporator or whatsoever.
Does anyone knows any DIY for that ? It's a 6th Gen.
Anybody re-foamed these pieces successfully? I have the heater box torn apart and all of the foam is disentegrated on everything. I want to clean the pieces and re-foam where necessary before re-installing. Has anyone tried this? I can see the indentation around the edges of the flap where the panels sink into it. I would assume I can just re-foam the edges? with self adhesive foam found at Lowes etc...Just wondering if anyone has attempted this and what foam was used and where?
Thanks, Matthew
Thanks, Matthew
Thanks, Matthew
Thanks, Matthew
Anyways, I replaced the foam on the heater box vents with white 1/4" self adhesive foam weather stripping from Home Depot.
Can be seen in this post here:
https://honda-tech.com/forums/honda-.../#post51148987
Or in more detail here:
https://honda-tech.com/forums/honda-.../#post50967413
I have not refoamed the panels inside the heater box though. That may require a high temp foam as at least two of the flap panels sit right on the heater core itself.
Thanks for the reply! In my logic, the less threads floating around about a topic, makes it easier for someone searching in the future to find an answer and this thread kept popping up at the top of my searches. I will create threads from now on if that is the proper thing to do!
H-t is a special forum. Its different.
This....----^^^
It took me a long time to wrap my head around this.
Here's the explanation just as an FYI.
Honda-Tech has been around over a decade, possibly over 2 decades....
Now imagine (especially in it's prime) 1 thread per issue, thousands of different cars and people in one megathread about that issue.
After about page 3 or 4 of 255 you'd likely call it quits and re-ask. Then everyone returns with, it's in this megathread, the answer is there.
If the site didn't expect to outlive all of us, the normal forum logic would apply. But when it's longevity surpasses most people's dedication, it makes sense to separate threads into individual instances (cars/people) and reference other threads with like issues.
I hope that helps clarify why H-T is different from most other forums.
