View Full Version : Honda Civic / Del Sol (1992 - 2000)
- my b18c3 motor....
- stock exhaust with no resonator
- Can't remove key!!!
- Ek Sunroof?
- Fiberglass Dash Install...
- Tranny housing removal, still unclear
- EG w/ b16 swap wants to retain power steering??
- 96-98 Square Foglights
- D16Z6 Install Progress
- Integra dash people HELP!!!
- What to do with a 98 Civic DX Hatch...
- where can i get a catalytic converter for my 95 civic vx?
- fuel question
- Did a Search, Brothers Auto car wont move!
- how to change light switch???
- Fuel Delivery for turbo
- GSR brakes...what year is what?
- Searched: Speaker vibrates.
- are the 92-00 pressure plate clutch and flywheels the same?
- anyone tried defcon racing PHENOLIC INSULATING SPACER??
- Where Is The ECT?
- Interior Code K (Dark Gray) for '97 Civic Coupe: Classy Gray or Excel Charcoal?
- need help with gc/koni installation!
- Brake pedal return spring help ASAP
- Rear swaybar mount holes on EG
- Good deal?
- What setting for turbo d16z6?
- rip in gsr front knuckles gasket?
- obd 1 - obd 2 SMOG QUESTION "HELP"!!!
- Possible Transmission Problems
- DC headers
- EK Civic Coupe vs. DC2 Integra - chassis, autox
- Question about Engine Trouble with a 2000 Civic Si Turbo
- HELP HELP HELP
- Custom Endlinks for Type R rear and 99-00 civic SI sway bar (56k wait >2 min)
- how to install a d16z6 intake manifold to a d15b7(cx)
- ARP Head Studs vs OEM Head Bolts
- Where could I search to find a EG shell?
- my hood won't open again!!! NEED HELP
- launching a auto ex
- Which is Worse?...
- HELP A/C wiring digram for 96-98 civic
- Do EK and EG's have the same rotors?
- Car cranks but won't start over? WTF?
- torx speck for front lug nutz?
- TPS voltage at .45 at idle, but no higher than 2.0 at WOT...any ideas why?
- WHAT lug nuts for my new 99 SI RIMS
- Where can I find a Mugen replica lip?
- MY Ball joints are stuck! HElp me set them FREE!!
- Flat spots in powerband after B18C Swap.
- Engine not getting Fuel
- A couple Q's, braking/steering.
- Clutch Squeek?
- taking out a/c
- EG h22a hybrid vtec problems
- CD PLAYER INSTALL HELP
- shipping on hondaautomotiveparts.com??
- how do you undo wiring harness clips?? need help ASAP!!
- lost a bolton my camber kit.... okay to drive?
- Si Tranny Swap!!
- passenger side airbag box/lid thingy... i need one
- EG vs. EK SOHC Driver Side mount
- p28 obd1 question. EVERYONE PLZ LOOK
- Ebay...?
- o2 sensor question...
- Adjusting B&M Command Fuel Flow
- Angular Momentum Engine Spin
- Motor swag questions
- door panels after integra civic dash conversion
- Can't get the bottom alternator bolt out!help please
- thoughts on this camber kit
- Slanted Exhaust Question
- Searched... SRR Coilovers on EK? Review?1st hand Exp?
- Will a skunk2 D16z6 camshaft maybe fit a D15z6?
- just got my gsr swap what do i look for. . .
- wtf another little problem
- Timming Belt Question
- starter problem
- front upper strut tower bar for 96+ civic dx
- Car parked in gear overnight and no clutch fluid next morning?
- mini me idle
- drum breaks on my coupe
- what is a good tranny for the d16z6
- suspension questions
- Those electronic goodies
- Smog question to you Arizona guys
- Cable tranny codes
- Building a hybrid tranny
- NO0b question .HOW TO USE TORK WRENCH
- regular or super?
- car wont start, state inspection in 3 days...please help me
- brake line flaring
- break question searched
- I need a ecu!
- 15.871 Stock Si, Good or Bad time??
- Brake pad question
- Where to find Gauge Pods
- JDM Cluster backlighting brightness issues
- Cracked Exhaust Manifold!!! help!
- difficulty of vafc install?
- which part do i need?
- 04 civic... where to start.
- remove these stitches
- cfs light
- 04 ex gauge cluster into an ek??what would be needed?
- radio reception?
- All you SOHC soliders.....
- How many have ran into this type of problem changing a clutch. Bolts breaking??
- JDM ITR front brake upgrade on EG hatch?
- Everyone go to sears
- LCA problem please help
- New Goodies
- Help with swap....D16Z6
- I need the CORRECT engine specs please!
- can i do a jdm 5 lug swap w/ d series motor.
- buying a 03/04 hybrid
- disc brake pads
- Does anyone have a wiring diagram for power folding mirrors for EK's?
- b16b in a 93 hatch
- b16b vtec help
- Need brake help please - Wilwood brakes
- Struts rub springs...wtf?Camber?
- Nippon wheels spoon lookalikes.. what do you think?
- fuse box diagram for ek
- putting dc2 door panels in a eg hatch
- JDM Lighting Questions?
- Which rear swaybar for EK Civic?
- Jumping idle while stopped.
- im too lazy and have no jack... exhaust size question
- Help with race car.
- WANTED: Interior
- Good muffler shop around Greenville, SC?
- injector wires in the harness. which one is which??
- Two different frost whites?
- new to the forums
- Failed Emission HELP!!!
- Just picked up a b18b for a 98 civic check it out, and let me know what else i need
- Wheel and Suspension for Del Sol
- What to do with a civic LX sedan(2002) performance-wise
- [FAQ] How To: Fit EG Coupe bumper on Sedan
- Tein SS Coilovers - After Install ?
- Is THIS an acceptable way to add wires to the ECU connector?
- Need some info about a b16a1 swap into 92-95 hatch
- where do i need a gasket?
- [FAQ] Sway bar theory
- itr radiator?
- Looking to buy an ek off of ebay
- mini me ?
- what does this mean....
- ::installing a rear sway bar with stock EG LCAs???
- Manual rack conversion (universal joint issue)
- What rod bearings do I need??
- EK door panels on EG
- Keeping ABS on EK with rear drum when swapping to 5 lug conversion?
- changing rotors and pads...
- I got owned!!!!! Bad Luck Day!
- which one to tap on the o2 sensor
- Help!! DC2 Non-SRS wheel into EG Hatch
- drag race project car
- Tranny wont Shift Into First......
- mike nice in this forum got in bad car accident
- another a/c qeastions
- any one have a b16b
- Auto to manual conversions
- How do you install Cold-Air Intake?
- what "T" for mech. oil pressure gauge
- help me out...
- IM gaskets
- LOOK OUT and BE CAUTIOUS Bay Area
- need help with tranny removal : gsr swap
- link to the honda casting codes???
- can any1 tell me how much, it will cost?
- Ground control coilovers spring rates?
- ek hybrid help please
- What side skirt is this?
- 99-00 si driver side bracket?
- eg6 right hand drive .. what to look for?
- Car overheating any ideas.
- This Happen today :(
- need info on installing a itr rear sway bar on ej1 coupe
- is this legit?
- Eg Gsr Swap AC Question PLEASE HELP!
- ignition switch
- OB2 codes
- code 41?
- 99 Civic Cracked exhaust manifold -- best replacement?
- New guy about to buy a Civic...
- cruise control vacuum
- question about turn signal bulb on 97 cx
- Burning oil????
- S2000 seats in del sol
- Gas mileage with H22?
- which head would you use?
- del sol swap
- HA Sport Cable to Hydraulic Conversion...replacement parts?
- HELP!!! what ecu is this
- Will these wheels fit my car?
- Disc Brake Conversion Help
- 25$ Cold air intake??
- How to: Prepare the car for a k20a , k20a2 , k24a motor swap
- Need help with a part number
- ITR BRAKE CONVERSION... we all know how to do the fronts, but what about the REAR?!!!
- GOOD LORD! Is there an Iron fist in here or what!?!
- What do the sponcers think of the LOCK people out power here.
- suspension tech
- 98 Civic LX Clutch?
- O2 sensor problems, searched already
- Auto B16a3.....question...
- 02 SI motor in a ek hb???
- suspension tragedy thread..
- carz resonator vs cherry bomb
- jdm zc 1.6 vtec header
- zc swap
- Del Sol Radiator
- Please Help: Need OBD1 Penout (showing ALL connection discriptions)
- What do you guys think
- Rear Upper Hatch spoiler for 97 EK..
- anybody running stoptech brake lines?
- Used Parts Guy
- Radiator Catch Can??????LOOK
- 96 Civic Ex Check Engine light with code P0171 (Fuel System too lean)
- spoon calipers
- what msd cap do i get??
- rear lca's
- JDM EG6 rear sway bar diameter
- A P73 ECU for my 2000 si
- new catback fume
- Opening taillights...
- inconsistency with fuel gauge
- Please, need MAJOR suspension help
- Will chipping my p28 on my d15b make me go faster?
- What is the difference in 92-95 and 96-00 civic suspension?
- 95 integra shocks/springs into an ek?
- help w/ my mini me!!!!!!!!!!!!!!
- Coilovers with standard shocks
- B16 sirII swap EG, what header??
- I NEED HELP!
- cable tranny with obd1 from obd0? need guidence.
- is there such thing D15B Vtec - e
- speedo messed up...any suggestions
- [FAQ] What Should I do to my Civic First?
- AEM Fuel filter in a 92 CX
- Climate Control Problems
- Should i jump on this deal ?
- finished my rear disc brake conversion.
- B18c5 in 94' civic.....wiring problems?
- Need some help... can't decode CEL
- my rear sway bar moves right and left. anyone knows why??
- how to install an eg audio console.
- Car Wont Turn Over
