View Full Version : Honda Civic / Del Sol (1992 - 2000)
- clean "ctr" ek
- Paint code for 97 Honda civic ex coupe??
- Whats YAG stamped on tranny
- what is standard fuel pressure to run on B18c1?
- need help on deciding on parts
- Please Help. Grill Question on 96-98 Hatch
- fuel pressure at 65
- 04 Honda Wiring Diagrams
- need parts ct 92-95 coupe
- Power numbers?
- Ideal offset for wheels on 2000 civic coupe
- ctr black center console into em1 ?
- Two problems with my EG! Strange noises.
- I need some rims!!!!
- charcoal canister removal.....
- Going turbo on my d16z6
- spark plug wiring (correct)?
- lets name that tranny!
- 93 Si specs
- will my d16y8 obd2 harness work with a b16a3?
- 96-00 DX Power steering swap
- heatercore problem...
- Hey all
- DX cluster changed out for CX cluster w/ tach, tach no workie-please help w/ pics.
- problem starting
- Length and Width of Cat Converter
- which swap?
- filling the frame with foam.
- b15b7 in a vx(someone put it in there)
- 1/4 mile times in a ek with a itr motor?
- what is this single cam dual vtec? anyone know
- what color wires to hook up vtec GSR?
- Which Seat for me?
- Bypass Valve
- How much for ITR suspension?
- anyone done '92 headlights on del sol?
- B16A (si-r) or B18C ??? help!
- car runs better with CEL on
- Del sol + Body Kit = Rice?
- High Pressure Radiator Caps
- ctr gauge cluster
- D/FW honda forums
- washing engine bay question?
- Radiator Support Removal?
- Are Idle Air Control Valves interchangeable????
- Opinions wanted
- Emissions/Fuel Question B18C1
- clutch stuck to the floor again
- carb legal cold air intakes????????
- damn thieves
- omni upper control arm question before install
- Throwing code 20...
- de-ricing my '99 si!!!!
- I need some good suggestions on some cheap LSDs
- b16A Bar'd Question (EVAP)
- $900 93 del sol?
- anyone know how or where to get this mod?
- sorry to the original jdmfreak
- HondaAtomotiveParts safe?
- rpm problem...(searched)
- Messed up idle!!!Need Help!!!
- no spark on my JDM b18c in my 95 coupe....help!!!!!!!!
- gsr on a 92 si
- check engine codes
- Wow, Im gonna need some money...
- what color wheels?
- flip-flop trunk conversion
- Del Sol Dash
- best coil overs under 200 dollars for a eg civic coupe?
- Blinkers not shutting off after turning
- Headlight adjustment on 2000 Civic
- Strange, intermittent idle problem. '95 JDM H22 in '92 civic hatch. Please help me.
- cruse control buttons and aftermarket wheel.??
- Hello all
- Austin TX, when and where.
- 4 wire o2 sensor help
- Shifter bushings?
- Orange Turning Signal Bulbs
- what should i run
- iv search and still need help
- Ticket for intake?
- Possible engine swap for a 99 civic lx (California).
- clacking sound when car warms up
- compressor?
- p28 ecu with b16
- Door lock swap..
- Lip Fitment Problem
- what is the difference between the stock 99 si ecu and the b16b ecu
- cv shaft hagning out of transmission!!!
- Power Steering Pulley Wobbling
- ringing noise???
- timing
- mounts???searched. need quick answer
- 96 honda accord sedan ex 5 speed
- b series question
- fuel pump wont come on
- Clutch Performance Inc.
- air bag test
- h22 in a 92-95 dx
- I get static shock everytime I get out of my car....ideas?
- header help
- 96 to 99 civic climate control.
- code 10-IAT sensor
- 95 Civic Frame
- YOUR WIRE HARNESS PROBLEMS SOLVED
- DIZZY part # TD 80U/TD-98U
- Does the OEM 96-98 black paint match the 99-00 ?
- what 2.5in cat backs are there
- FS: B. Widow rear 4 96-00 civic HB/ free sideskirts...
- another radiators question!
- make your steelies shine
- Prothane Motor Mount Inserts
- bad gas milage
- plzz help
- do you have a 99-00 SI???
- 97 lx w/ b18c wiring issues.
- TRADE: hydro b16 tranny for ls tranny
- turn signal problem
- ambers that actually fit?
- How can i find out if my B-series is legit or not???
- question on a swap
- 95 civic check engine light code 9 and 12
- Rear lip question.
- HELP!!..Not even honda can fix this thing! Please help me out..Let me know what you think...
- Stock 00 hatch with fireball N1?
- hearing a noise
- Authentic Honda nose bra del sol
- Timing belt
- another h22 civic problem
- yeah yeah yeah i searched...megan products
- bumper trim pics
- can i use a p30 ecu for my b16a swap
- K20 or GSR?
- roof removale and installation
- Ball Joints
- does anyone know the spring rates for the ApexI N1 coilovers for an EH2/Eg6?
- 96 civic coupe
- eg and integra brake question
- obd2 engine d16y7 replacing d15b out of a 92 dx sedan
- mushy brake pedal
- OEM cat diameter?
- Water Temperature Sensor, Wheres it at??
- Del Sol Weight...
- Help 2000 Si V2 Intake Install!
- rear disc brake conversion
- 92 eg hatch with swap, Ran Out Of Gas, tired to start didnt.... got some gas.... NOW WONT START....
- Limp Mode, SEARCHED (Pics Inside)
- gauge cluster swap=no cluster light? searched...
- the 06 si...your opinions and criticisms
- mini me
- Differnces between D15 and D16..
- vise grip vs the wrench..
- Bent steering knuckle? Easy to replace? Do i need to?
- Transmission questions???????
- hey what body kit is this for the delsol
- question on distrubutor
- ???? on rc injectors for my civic..
- civic shakes!
- 93 sedan motor prices
- weird whistling noise..
- Resurfacing Flywheel?
- No 3rd gear ??????
- mini me with auto trans.
- 6th Gen civic projector headlights? not the triple beam crap
- how to install tps?
- A6, Z6, or Y8 crank?
- 99-00 power window problems
- Rubber sealant, for the gap between cowl and windshield
- itr 5 lug conversion with itr BB/MC on EG, which prop valve do I need?
- Advice for my Daily Driver please
- Man I Need Help Bad!
- Warning: Aftermarket Steering wheels and Insurance
- H22 in civic coupe
- Do RSX seats sit as high or higher then stock seats??
- 1993 Civic EX Torque Converter ?
- lx specs?
- h22 and b16 weights differences ?
- Automatically locking doors?
- ef struts on an ek
- Civic stalls once warmed up...
- All 92-95 antennas retract to the antenna plate?
- Passenger airbag removal in a 98 civic
- t1R b-pipe and spoon N1
- need help with shifter.
- Brakes on my civic
- Idle problem on crx..... HELP!
- Does anyones center console get real real real real hot?
- exhaust leak problem...need help asap
- s80 what tranny is that?
- GSR F/B Brake conv. Which Prop?MC/BB?
- Valve adjustment tool
- Headlight Help!!
- Greddy Civic si turbo kit- Smog legal?
- B16A2
- what exactly does a retrofit headlight consist of *searched*
- WTB: Need 2 pass emissions! Stock ecu,VIRGIN, bla, bla
- MSD 6AL QUESTION...... and help...
- 98 front
- what are these wires for in the door panels
- Integra 2 Civic spring swap drop question
- 92-95 eg exhaust fit 00 civic?
- Anyone know if D16z6 vtec head will work on the EF D15 Dual POINT?
- stupid problem...damn dome light
- VTEC VTEC VTEC
- need some info on a 4dr dx
- 96 DX HATCH**Guage lights**DO NOT WORK
- OBD I motor in OBD II car
- need help on my 97 civic!!! motor mounts.
- Are there any front strut tower bars that will have proper clearance in a H22 Civic?
- anyone with similar setup?(curious to know what times i will throw down)
- D16Y7 ecu swap
- Oxygen/Heat Sensor
- ????STOCK WEIGHT 94 del sol si????
- Overheating issues... Searched but still confused
- need fellow ht'ers opinion
- what is a good price to replace my clutch
- anybody with a haynes manual
- What could be causing this monster of a smoke screen?
- My 97' HX coupe
- D16Y8 INTAKE MANIFOLD OR D16Z6 OR J SPEC ZC WHICH IS BETTER
- EG window visors
- shaking when breaking
- 97 ek
- I think my clutch went? :(
- Idle Surging, I believe its a bad tps...read on...
- 93 turbo, having to get refered because of ticket.
- how long can you go with valves tapping?
- modifying a d16y4 engine
- Clicking sound when taking off normally, Tie Rods or axles?
- d16y4
- dough! comp. took a dump ,but....
- VTEC problem-- please help
- Bought a 96 ek hatch. A/c not working Help!!!! im in miami !!!!!!
- Clutch Problems
- D16Y8 Auto to B16A 5SPD Mounts
- 99 Civic
- Si conversion?
- Do you guys think this will be totaled?
- h22a in eg - axle rubbing fork on passenger side
- Selling items
- Eibach / Sachs shocks
- RPM wont pass 2500
- like fried chicken
- repairing the "stillgood" civic
- Looking for Front Clip for 2002-2005 Civic Si or......
- Opinion/preference on what swap
- need help choosing catback exhaust
- window regulator questions!
- D16Z6 WHP
- D16A, anyone herd of one?
