View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Temperature needle problem.
- engine wiring harness HELP
- 93 lx front sway bar question
- Tweeters in 96-98 Civic
- b20 tc
- What is a good way to tell if your buying a HIGH MILE JDM MOTOR from a shop????
- headers help!!
- 1992-2000 Civic stock muffler anyone??????$$$
- Mugen Big Brakes
- which cams are better??
- foggy/ oxidized headlights
- SOHC Vtec Transmission
- Can a d16 mani fit on a d15?
- question about tein springs ride height.
- not a civic topic
- any difference?
- sir bumper with moldings?
- trunk lid - not sure what model trim body or year it is for
- turbocharging an engine
- obd1 to obd2?
- Knock sensor? Need to pass NJ inspection GSR swap in 98 Ex!!!!
- How do you hook up GSR IM Butterflies?
- b16 tranny question.
- Trial Status - Buy/Sell
- Can Anyone identify this fender?
- d series worth it
- 99 conversion question??
- tranny help
- SHOCKS?
- Borrow Muffler to Pass Noise Test?????
- 2000 CIVIC SI INTAKE ARM QUESTION
- Install Front Camber?
- 96 Civic Heat Shield
- oilpressure gauge?
- eg k swap axel prob please help asap
- question about axle compatibility between 92-95s and 96-00s...
- How do i install coilovers
- ysk-1
- help with check engine b16a3
- Will power steering fluid shoot everywhere!?!?
- HX oxygen sensor help
- overheating while driving(mostly in the 15 minutes of cold start)
- 1997 dx w/ b16a swap ----> which crankshaft/harmonic balancer should i use?
- b16 swap in 99 ex
- F22B DOCH Swap
- I WANT TO BUY SOMETHING IN THE MARKET PLACE BUT I AM ON "TRIAL"???
- Best Windshield Wipers??
- Cel wont turn off
- b16 flywheel
- B16A Idle Problem
- VTEC and ECU ????
- IAT ISSUE WITH GSR SWAP
- alternator question.
- reinstalling e-brake question (ej)
- has anyone had problems after instaling a BLox, Skunk2 ext... Intake Manifold ???
- DIY windshield wiper lowering
- Best brand Battery?
- civic tail lights
- NEED HELP!!! Brakes and Wheel!
- Strange shut off problem here.....anyone have this happen?
- Best Exhaust for Turbo B18?? Any help?
- p80?
- whats more affective???? CTR intake camshaft Or Blox intake Manifold??? for the bucks $$$$ help anyo
- Manual/auto swap-Oil pan brackets?
- how to make a duplicate key?
- fuel and spark but car won't start....?????
- clutch
- tie rod? wheel balancing?
- i need help! engine stutter at low throttle pressure
- Which donut gasket?
- chipping my p28 question
- Just bought a 99 civic si
- z6 plug gap
- b16a tranny problems. Need some help.
- OBD2 to OBD1 harness.
- speedometor and radio freaking out
- How to tell the year.
- One high beam won't go on?
- WHICH TRANNY SHOULD I USE FOR MY 2000 JDM B16?
- IS THERE A SQUAD FOR EJ1/EJ2's ??
- exhaust questions for a b16
- D16y8 consuming a LOT of oil
- Idol problem with my 97 del sol
- going boost!!!
- B18C w/ P73 ECU Type-R O2 Sensor Wired Wrong.
- 2000jdm b16.... what tranny to use??
- HELP!!!!!!!!!!
- Honda B Series Synchromesh rings
- ls/v tec
- Retarded question. Oil in D15b7
- New (to me) Civic EX questions
- Need confirmation. D16Y5 head onto D16Y7 block.
- few civic problems
- obd2 gsr engine harness in 98 ex?
- Help!! CEL comes on and D4 blinks
- 92-95 civic front bumper intake scoupe for fog light hole. Who makes it ?
- Compression Test/Leak Down Test on swap
- b16 swap
- has anyone ever used a Holley CatBack on their civic
- wats a good tranny for my d16z6 ??
- Help with EJ foglights
- My first tear down. Tell me what you think!!
- stuck...y7 to y8 mani... iacv not resonding
- EK/EG K20A Project
- help! speed control sensor
- 98 civic door locks
- engine oil
- 98 Civic EX door panel
- I Need a New header and exaust HELP!!!!!!!!
- Royal Purple Synchromax (and temporary use of RP 10W-30)
- Can't get cam gears off. HELP!
- D15B question
- B16a2 map sensor wiring diagram needed,help...
- obd2a or obd2b 96 civic ex coupe
- How much should/would you pay for a '96 civic?
- y7 block with a6 head
- steering column bolt!
- ok to drive car with ac belt on and no ac lines?
- 6x9's into EG Hatch (already searched, no luck.)
- smoke/steam from exhaust
- fish eyes!!
- exhaust question????
- b16 Question
- Calling All Emissions Specialists - high NOx, and yes I did my research
- Brake Fluid Leaking... Rear Drums the cause?
- CAMS
- how do i know im not overthrowing my clutch?
- quick question
- BUY PARST WHERE?/internals
- BDL Fuel rail on Victor X manifold
- Quick ? bout an air pipe!!
- carbon fiber hood
- is there anything specail about an ex slave cyclinder?
- electric window conversion
- si cluster questiion
- jdm b16 swap
- Overhead while driving
- Saying 'Hi' (didn't see intro thread)
- JDM fog light installation
- manual to auto?
- Fuel injectors?? would they do this if switched?
- front tow hitch installation
- Quite a bit of help!
- new used engine not running right
- b16 head
- Audio Console ?
- gsr swap wont start, please help.
- are all b series shift linkage the same?
- looking for ep3 seats and steering wheel...
- i need a new header and exaust help!!!
- Buddy Club Spec II Exhaust Question
- 2000 jdm b16 swap
- tires
- headlights on 99 civic ex
- 99 Civic EX Fuse Problem...Please Help
- Cylinder Head Question
- b20z swap.
- JRSC for D16 for $750 with 440 rc injectors worth it? And would my Stage 2 cam or stock cam?
- Little help on looking at a local hatch....
- ITR Retainers Vs. B16 retainers
- "00" civic Si for sale
- Car won't start on first try - takes a few tries
- redline on VX help
- 99' civic fogs
- ep3 seats?
- crome tuned fuel issue
- b16 swap running like PooP!!! Help
- 2000 Honda Civic Si for sell,can't post in classified yet sorry..GOOD DEAL!!
- ls vtec
- Autolock?? Anyone had there car stolen with one on??
- Car idle problem
- DIY VOLTMETER
- jdm b16
- 195/60-R14
- TRADE!!
- stock ls crank
- sway bar/endlink question
- Good deals on tires?
- WHY CANT I POST ANYTHING IN THE MARKETPLACE?????
- coilover fitment?
- 94 civic cranks but doesn't start. Need help.
- Need a Helms service manual for my civic!!!
- does any1 know how to keep sidemarkers on
- CIVIC HIGH REV
- b16
- sparco seats
- what seats will work?
- help pulling codes
- Requesting: EK hatchback with hitch
- Is it possible to turn off a CEL with one o2 sensor
- EK9 Wire Diagrams
- jdm b16a
- Another story on stolen rims,actully just one SI rim!! SOCAL cops suck..
- Some forum help.
- Oh No! Car broken! Sometimes it starts, sometimes it doesn't
- How does the door lock stay in the door handle?
- 92-95 Civic Main Relay problem possibly?
- Has anyone tried this with a d15b?!?!?
- Blew my Diff, Where can I buy a new OEM one?
- h22 died
- EK OEM bumper plugs
- which OEM axel backs fit what civics?
- K SERIES SWAP A/C INSTALLATION
- abs problems =\
- running rich
- ecu help (i searched)
- How the heck do I remove my ECU?
- starter issue...
- humming sound coming out from cam gear
- NEEd help!
- LED Bulbs
- A/C and Power steering, will taking them out do anything?
- GOOD STORY ABOUT STOLEN RIMS
- freakin fish eye!!!
- Radiator
- i just want to be 100% sure on this
- What can I do to save my car?
- how much?
- car sputter after fuel rail install....help..
- d16y7????
- distributor & cap
- what oem replacement steering wheel fits egs
- OMG help
- no tranny fluid = louder tranny?
- Auto to Manual Swap Won't Start...Ideas?
- 93 civic boost project
- Tuning, I didn't get that far
- trann y
- Help car burning oil
- alarm factory power locks
- will this work?
- del sol carpet in ek hatch
- lsv stumbles when gasing it
- Lx civic fuel light?!
- b16 white smoke
- Cali State Ref need help
- From B16A to B18C1 (jdm)OBD1 what do I need??
- Ecu question...
- d16z6 tranny!!!
- need top of a/c dryer/receiver pictures to see whats missing..
- civic
- turbo ek civic 7 psi
- Spring rates
- about how much will it cost to convert my auto. 94 civic to manual?
- timing belt shaking
- how do i order bearings??
- EG6 brakes
- want to install a/c
- Is this a Si lip or Si styled/type R styled
