View Full Version : Honda Civic / Del Sol (1992 - 2000)
- stock pipping
- How To:Fix for excessive vibration from Avid torque mounts
- rattle can similar to stock
- 99-00 Headlights, need some good knockoffs
- Fuel Sending Unit....plz help
- HID Opinions?
- D16Y7 TB Size?
- questions about rsx type S muffler and customizing it.
- Integra Brake swap, horrible pedal feel?
- b16 red line 7500
- Quck Fuel Pump Question.
- Brake switch: Auto to manual swap
- 4-1 header?
- quick oil question
- Starter problem
- transmission mount question...
- Just picked up an oem ITR intake manifold, but...
- what is this thing
- 96-00 coupe exhaust system on a 96-00 sedan?
- Help! 2000 Civic Si 1.6l DOHC vtec, Skunk2 Intake manifold and 70mm throttle body high idle . .
- TRANNY ACTING UP HELP !!!!
- Pic Request... www.Passwordjdm.com Fender!
- removing a ebay chip from my p30
- Spraying a stock B16a2 - Is it safe, who's done it?
- b16 valve adjustments.
- 9 hatch, CEL, diagnostic plug???
- Shop Adjusted idle too 2GRAND for IACV being broke..need help to adjust back down need help ASAP
- !PLEASE HELP TIMING BELT WALK!
- HELP!!!!
- NEED HELP ON FRONT LIP
- 95 Civic EX Cold Starting Problem.
- Alternator
- Transmission Q for 2000 SI civic
- 95dx-->94ex doors
- Helpme out. Fusebox, now with pictors!
- still no start
- Where to buy female plug end for IAT wire on '97 LX?
- 95 Civic Si (possible) For Sale Opinions Wanted
- shift linkage help
- b series crank puley washers fit a deseries?
- b series throttle body on d series on skunk2 pro series intake mani
- Car is taching out soon as you turn the key.
- Owners manual PDF?
- header clearance in eg
- *Looking For* Sparco harness instructions
- 92-95 civic A/C block off plate??? part number???
- stock civic muffler dimensions
- B series guide...HELP!!!
- relay, right side of fuse box eg
- looking for some replies! mini visor!
- Rear LCA Bolts
- DYI: Remove TPS (throttle position sensor)
- would OEM ITR intake manifold with B16A SiR2 Throttle body work ?
- big problem - 99 si with 98-01 JDM type r - from H MOTORS - CEL problem
- SiR master cylinder into Si?
- I BLEW A HOLE IN MY BLOCK> WEIRD SITUATION THO! HELP!
- Another one taken
- JDM DC2 type r seats
- Head Light Alignment ?
- Del sol dash
- DEL SOL FR PASS SIDE FENDER!!
- Spark Plug Gasket
- LMA Question
- fuel pump
- clutch issues.
- ek hatchback sway bar..help!!!
- Just did my wire tuck. What do you guys think?
- d16z6 water pump on a d16y7
- skunk 2 vs type r intake manifold?
- skunk 2 intake manifold question
- Throttle body question?????
- 97 civic type-r rear lip.. help..!!!!
- Valve Cover Gasket Torque
- swap it and forget it...
- Muffler for my car
- should i get a bra or a bug reflecter shield (plastic ones) for my ek
- cant pass emissions any help?
- Looking to build my b16
- wiring vtec
- b20b??
- B16 head ?
- last motor and now new motor...thermostat wont open??
- b20b turbo in ek swap finished, car wont start
- Teg brakes with steelies.
- 98 Civic: How do you remove power window switch from driver door?
- How much Psi?
- CAR SHUTTING OFF??!!
- Removing front stock speakers in a 98 Sedan...
- where to buy ish for tune-up?
- When it's cold car won't start
- What motor is better for my 1995 Civic Si.
- quick question
- Location of headlight relay?96 ek coupe
- Looking for Qutie exhaust 3inch
- gsr sway bars on eg civic
- Apex-i turbo timer for sale
- Hi need help with b20vtec oil line kit. Plz help ty
- Wrong forum
- Grinding 2nd
- Brake Dust Shields
- ebay products
- write up on how to remove b seris head
- B16 boosted vs GSR boosted
- my car bogs out
- Cold Air Intake or Short Ram
- Problems with IAT Sensor - B16A
- can someone get me a part number? or at least help me identify the part i need!? lol
- 94 honda civic steering problems any suggestions? please help
- need help w/ pedal or throttle cable... thanx ht
- Need help/suggestions on front end vibration
- Heater Circuit Malfunction
- delsol poll
- ITR suspension into 92-95 civic
- o2 sensor plug location???
- Delsol or EK shell South Fl.
- d series shortblock?
- Finding the ECU error codes
- 91 CRX.. what should I do with it?
- i have pics
- problem with the es bushings
- idol problems
- A unique fuel problem: Gasoline is flowing out of the throttle body!
- cant find wiring for d series...
- Blown headgasket?
- EK power window conversion trouble need help from Monicle and others
- PCV valve question! please help :)
- engine missing
- Fuel Lines!!!
- My EJ build up...
- looking for b16
- ac delete duct
- Tranny brace/bracket
- Ways to fix/clean windshield nozzles.
- HondamanXxX?!??!?!?!?
- 92-95 civic hatchback rear sway bar end links. need help!!
- jdm rim vs copy -OFFICIAL PICTURE THREAD!
- 99 Civic Si - wont start
- dash swap question...searched
- built b16a not running like it should
- !!!!Cel problem please help!!!!!
- Wierd smell..
- Proper break in method
- buddy club spec II
- jdm b16 map sensor in 93 dx
- Help! with a 94 civic wiper relay
- So i read the engine swap quide
- Help urgent!
- Idle at 3k and throws TPS code(7) replaced it same thing. Any suggestions?
- Are these ITR cams? ive done my research and i think they are...
- B20 w/ ctr pistons & rods
- Gauge cluster is in kilometers, will this affect smog?
- vtec controller buddy club (vcon) write-up
- Will an ek trunk lid fit on an eg
- Blueish tint smoke?
- 1 wire o2 sensor d16z6
- single cam swap help
- ball joint help
- upper cntrl arm?
- putting car on jack stands help
- Idling like a V8
- 2 quick questions: ECU swap question and rims question.
- Break in
- Just need some Opions plz!
- Need help with an EM1 Wiring harness...
- i Have a Question
- Anyone know of a diy for cutting fog light holes?
- E.K steering wheel
- how to make power?
- Headlights are not ocming on turn signal bulbs are.
- Iam New on the best Forum
- Shift Linkage
- radiator fan will not turn on.
- GSR Misfires on Idle 95 Civic OBD1 Stock P72 Chip No Tune
- motor wont stay on
- jdm itr piston on b18b1
- 15's or 16's
- Momo Steering Wheel ??'s
- Does upper control arm affect ride height?
- Civic Ignition 96 DX body
- car got stolen!!! :(
- Brake pads and rotors
- D series Valve Retainers
- cleaning filters
- 92 civic Cx wiring help
- Header for 97 Cx, how do I prevent CEL?
- Knocking
- WHich color wires
- Secondary o2 help!
- battery relocation - charging problem
- need help on arp head stud!!
- Adding coolant..
- Smoke from the radiator before full warmup.
- OBD2 chassis and OBD1 motor ?
- Lower control arm - Front...reinstall issues.
- do i need the prelude carriers if i fit prelude calipers to my ek 4
- I hit a metal plate now my car sounds funny :( ! help
- Please Help! a/c installation with b-series motor in a 96 DX hatch???????
- Whats Good Boys and Girls! I Finaly register to honda-tech!
- D-series question
- What kind of full coil over shocks does everyone use?
- H2B vs K20a2 into EK
- Setting up my first turbo build Need help from you guys, thanks
- Bad IDLE Y7 W/ Y8 Mani, Opinion/Help?
- Completely random...no first or second gear
- boosting d16y7 need help
- ECU Problems
- Del Sol - Aftermarket Fog Lights
- D series non-vtec heads - how to tell them apart from casting
- having problems with my swap
- Help: Which timing belt for D16y7 block with D16z6 Head? Already Searched & FAQ
- del sol transmission
- New hatch from nj
- Can i swap parts
- Help with ITR swaybar (pics included)
- b16a2 engine rebuild kit
- broken door panel! replacement!
- '98 Civic Timing belt/water pump
- Hey guys! New here and looking to pick up a Civic in the future.
- D16 Turbo vs B18B?
- MAP SENSOR PROBLEM..
- ej6 aluminum hood
- 99 civc brakes
- GSR Intake Manifold on B16?
- Ground or alternator whine noise type..confused
- 98 ex gauge cluster into 98 civic cx
- b16 ob1 b16 ob2
- CAI water protection
- frozen axle nut
- Gsr swap
- Are omni valves good quality/product?
- rebuilding clutch plate...
- Idle problems! Help please! b18b in ek
- Another poor mans type r question
- Advice needed for a D16Z6 turbo project
- itr tranny v.s b16 tranny
- will Carsound(magnaflow) high flow cat on EM1 pass smog???
- jdm d15b timing belt question
- Will a 92-95 Civic Rear Lip fit a 93-97 Del Sol Rear Bumper???
- Will a 99-00 Si Front Lip fit on a 93-97 Del Sol Front Lip???
- Civic brake issuess
- most power out of a sohc
- Rev Hard Greddy HKS Turbonetics??? What's a good turbokit???
- +33 offset
- need vacuume and wiring help
- B16a2 into EJ, mounts?
- y8 into 95 eg help
- Clearing up information about dust shields (type r 4 lug brake setup).
- Acura 1.6 el 99 (luxate Civic) CEL problem #16, #18 witch not exist,#54,#61 NEED HELP, Got A Video o
- cx rotors.
- i got a question
