View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Just Curious
- Honda Tech
- HELP: Replacing Front Wheel Bearings?
- tire questions
- Suspension opinions...
- Carsound cat install....sort of
- greddy turbo on a del sol si?
- how do i take off the plastic piece around the steering wheel?
- 99 Si motor into EG
- So how to tell if VTEC is working??
- Body Kit install. References?? Site help??
- Clutch slipping???
- wat are the differences in spark plugs
- High-Beam Bulbs in Low-Beam Sockets: work on civics?
- Full Koni coilover?!
- Any OG Civic Honda-Tech.com members out here?
- B16a or B20b into my 97 hatch?
- Wiring power windows and locks on a 99dx...any guides?
- d15b? anyone know anything bout it?
- Where to buy a CF duckbill from?
- kumho 712's or Falken azenis??
- Where can I get the PPG spray paint cans in factory colors?
- Is it possible to fit a RSX steering wheel into a EG?
- doesa anyone have a ex motor laying around??
- LS...CRV distributor
- water leaking on the floor board of my sol
- pics of my car with my new camera :)
- got the swap in, here's pics... and pics of the other good stuff
- Will stock rails from civic seats fit on the s2000 seats?
- ROTA Wheels
- what to do to hit 13's within the next month????
- who got ITR seats on a civic?
- YOUR thoughts on a Del Sol
- Anyone with some ROTA attack picks in a White EK
- hybrid d series?
- Pics of my 2k2 SiR
- will these fit 95civic ex??
- how many people have you fit in your hatch?
- how to read a ecu code on a 93 hatch?
- Does anyone own a 2002 civic ex?
- Real spoon wing Carbon Fiber
- ball joint
- JDM tuner sites...
- My Damage
- 6" drop.....is it even possible!?
- Please help me!!
- HELP !!Car wont turn off after taking the key out.
- Removing Rear Tray... Lining by rear window????
- finally bought myself an eg!!!
- mysterious rubber burning smell....
- Need help from the pros
- Benen rear tie and ITR sway....
- squeek from suspension???
- help! she won't start
- Tranny Questions
- performance brake pads (any recommendations)
- OBX Coilovers = Skunk2 Coilovers
- 99-00 Si Suspension...Pics needed!
- cam gears worth it?
- HOW can i TEll the real spoon from fake CF WING
- Changing out my axle.
- where to hide my Monster Tach. I dont want ppl to see it outside
- Smokes a little after starting in engine bay, black sut spitting out of exhaust, irratic idle
- 92-95 Civic Si wiring diagram wanted.
- what kinda spark plugs on a ls?
- ticket?????
- Where can I buy the cf Spoon duckbill wing for my EG?
- Finally pictures of my car(56K beware)
- Synthetic vs. Non-synthetic Transmission fluid
- Got Hit By A Fockin Ricer(Car Accident) ! ! ! ! ! !
- turbo boost
- size does matter!!!
- Will an ITR stock exhaust fot EJ Coupe??
- New Si...
- engine/ecu harness
- what should i do?
- itr in b16
- b20 questions
- motor swap or turbo on 93 del sol si vtec?
- EX motor
- ticket question
- CTR/ITR Shift Boot
- OT-I got an interesting letter from the cops today:-(
- Just bought a 90 Civic Hatch...Need help with brakes...
- Wierd whistling noise......help!
- a6 pistons in z6 engine
- HELP! There's a sqweak coming from the engine.
- WTF is b18c6???
- Has anyone ever broke or faced a problem with ground controls?
- DelSol Purchase, which best for turbo setup? (Searched)
- Si Rims?
- Thermal Exhausts
- Front Lip!!!!!!!!!
- Best 195\50\15 All Weather Tire for my hatch...
- skunk2 coilover install help..
- Differeneces in Brand Names
- Help! D-series valve adjustment (Dist. Rotor?)
- I need A 92-95 HB side skirt...
- NEED HELP!!!!! for some reason it wont come off!
- Which one do i get?
- CEL... FUN!!!
- itr valves, valve springs, and retainers
- HELP, In need of VTECH SOLENOID From 96 + Civic
- How to pull studs out of gsr intake manifold?
- Help...wiring..what's this
- Y1 synchros...
- everyones thoughts on a LSvtec
- How light are CF hoods?
- Socal meet
- how much are EG6 wings?
- camber on a 00 si
- 94 d16z6 Spark Plug Wire installation?
- Anyone using ctr pistons with eagle rods???
- nsx calipers on eg6???
- e-brake is stuck
- Back from Palmdale...
- happy Fathers Day
- Does anyone know the color code for Electron blue pear?
- any help
- anyone got ex motor laying around??
- My first run since mounting on my new Falken Azenis Tires
- OC Folk there is a lunch meet tomorrow
- Need opinions. . .
- Nakayama Cold Air Intake Questions
- will this work(cheap climate control)
- Adjusting Headlight beams
- Valve cover gasket
- Are ITR or CTR cams worht while to install in a B16A2
- help-> last bolt on y8 Intake Manifold!
- del sol seats in a 97 civic
- what year GSR's are OBDI or OBDII
- who hates black widows
- Anyone have experience with damaged rims from tire installation?
- Anybody know if I could buy coilover sleeves?
- removal of crank pulley
- what kind of clutch?
- Long term Turbo use
- Ordering from American Racing
- Import Showoff Ciel Kit
- Si Springs
- attn: sinister my homie raced ur homie lets see the outcome
- HX wheels on 5th gen Si, fitment problem?
- nipponpower.com?reliable or not?
- Eibach Pro-Kit springs for 96 civic
- EG shells anybody?
- ruff ride?car not smooth??
- What tranny code is s40/1905743?
- Timing belt on a B16A
- who has a shift light on their cluster??
- 98 Civic ECU
- will si grill fit 96-98 civic
- D16Y7 Engine
- Tires........
- Help! Cruise not working, brake lights not working, blown fuse!
- Tighten the timing belt
- Del sol of miata????
- will 49del rims fit on a 91 accord??
- D16Y7 gear ratios?
- License question.........
- turbo civic for sale, 11 seconds on half boost
- First Florida 8 second honda?? could it be?
- So-Cal Weekly Meets??
- Spoon Lower Tie Bar
- I hit this pothole tonight.
- Falken Azenis in the wet
- 92-95 Civic Ex Tranny Code
- Pics of "Rollcages" in '92-'95 Civic HB?
- Upped the boost on my SOHC VTEC! Dyno results....
- Forum for 2k2 Si/SiR hatch owners!
- Occasional 5500 RPM launches in 99ex ok on stock clutch?
- need suggestions...
- which chip is best for h22 running off a p28
- Print Out Guages
- is this real or a scam??
- 5th gen. w/jdm ITR exhaust questions
- 160 mph! wow, what cajones!
- will a dc 4-1...
- Air Conditioner Problem
- flywheel
- REAL QUICK! A/C question... fitment...
- Antisway Bar on EX
- H22 on the CX will smoke the Corvette?
- Replacing Wheel Studs
- Vafc anybody having troble with them???
- BUILD A D16Y7 As strong as can beeeeeeeeeeeeeeeee
- check this ish out
- Tuning involved with JDM header?
- power
- Calling All H22A Owners
- which mounts??
- lightweight flywheel for the B16A2...who makes one?
- should i upgrade my radiator?
- a little OT..but I need some help..
- DC Header (YES, I've searched) 4-2-1 vs. 4-1
- timing belt/crank shaft pulley...
- If you like F&F and drag racing then this is for you..
- Need help with Skunk2 coils and Koni Yellows
- Brake Q
- 99 Si seats or 92-95 Si hatch seats in coupe?
- Does Japan Hates On Us?
- whats the dimension of the HX wheels?
- NEED to buy: Iceman Air Force System
- What cams are the best?
- Sideskirts for a 93 ex coupe?
- 99si fit in 2k EX?
- 92 civic si code 2. what is it
- Times for a 93 Ex?
- Does anyone know how to relocate/adjust exhaust?
- What should I get....from Japan?
- Short shifter saw
- wiring rader to lighter
- Power door locks
- anyone seen/have pics of
- back for a vacation
- del sol pwr door locks
- cigarette lighter for gauge power
- JDM scmooey
- Skunk2 manifold people what throttle body are you using?
- 94-01 Integra seats in my 92-95 hatch?
- what TB to put on my B16A in my 93 DX HB?
- revved to 8600 on my gsr motor, shoud i worry?
- Gonna try something new: Pick/submit your overall favorite coil over.
- SoCal BBQ and tech lecture by Oscar Jackson June 30th
- SoCal Meet w/ tech lecture by Oscar Jackson June 30th
- freon ac
- Cargo Cover Sliding
- K&N Filters is looking for All Honda Civics 1990-up for Cold-Air Intake Development!
- questions on itr shocks+springs?
- 1/4 Mile Time Estimate!
- need electrical help
- question about my Carsound cat
- going to get a del sol
- Projector Headlights
- Who Ones that Black eh2 with.....
- Importing My Car
- Need something new..
- New honda......................
- i got a question for all of you......
- to those with del sols..
- COOLIN PROBS!!!!!!!!!!!
- Could someone please run a carfax report for me?
- Good Cam gears
- Anyone here have a d15 non vtec w/ a cam gear?
- CD for Eg's
- ATTN: los angeles eg non-si owners
- Which Tranny to buy for d16z6 turbo and possibly nitrous in the future
- sol owners, how do i get wires thru to the trunk for stereo????
- help with 99-00 si ecu code #73
- how much for AC into '94 CX w/o AC
- tool kit
