View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Possible causes for too much toe
- mileage
- B18B jdm What should i change out on the motor before i drop it in the car.
- '00 GSR
- can i put a 99-00 front on a 96-98 front??
- Was there ever a stock cd player in 92-95 civics
- A Good Chip?
- Car wont start help!
- Timing affecting performance/starting
- 3 Trouble codes, P1298, P0135, P0141
- DIY Cluster. What do you guys think?
- i need the mounting bolts for valve cover d16z6
- oversized valves or standard
- 92-95 Civic JDM Gauge Cluster help
- Vtec controller
- anyone know the name of that gold color on 03/04 civics?
- d16y8 governer?
- 93 honda hatch and the hatch rattles when on bumpy road any ideas
- Where can i get a spoon style carbonfiber wing for my Ek?
- 1992 Si Hatchback *STOLEN* Reward for info - Oklahoma City Area
- small asian weiner's
- can't reach redline with mw mini-me swap?
- omni power coilovers
- Rear camber correction
- eric gardner
- Budget Shocks?
- 1995 eagle talon tsi fwd
- CARFAX help please
- Advan Offset
- What is the best way to increase acceleration
- Question on A/C
- Where to get Power Door Lock Conversion for 92 HB?
- weapon r header for 00 civic si b series..worth 200 shipped$?
- bad rod or crank?
- Throwing a 10 (IAT) on my 2000 Si - what can that cause?
- i need help!
- 93 civic MOST HP??????
- HELP!! 93 si blown? / swap q's
- EF suspension on EG
- Post your EK hatch roll bars please.
- Need help with a problem with my D16y7....Honda-"Techers" please have a look....
- converting the front end to ek
- radio code
- Bseries IM
- Engine prep?
- Hi, new user looking for help.
- clunking when taking car out of gear
- CEL due to bad o2?
- where is fuse for fan?
- tranny problems
- Question about motor mounts
- Question
- who makes fiber glass race pieces for EG's
- 94 Hatch Front U joint
- Follow up on this so called dumb thread
- alternator or dizzy??? any other possibilities
- 97 Civic EX Oil Pan Issue
- Rattle when I turn and take off
- Anyone know all the places oil can leak from back of block?
- looking at a del sol... reliable?
- b20 vtec
- field sfc wiring diagram
- Check Engine Light Help
- 94 Civic Hatchback Speakers
- How to look for engine damage
- Side Skirt Question
- About to swap, but something's been cut. What is it?
- lightweight flywheel question
- Sticky seatbelt retractor?
- PLEASE HELP ! broken parts ..
- Del Sol exhaust fit 96+ coupes?
- Will '03 15x6 Si rims fit ok on my 92 Hatch?
- ASIAN TRANNY
- Suspension noise?
- 2k EX antenna replacement, can't get wire down the pillard.
- COMPRESSION VS. VALVE ADJ..
- K Series?
- Question on spinning mass (wheels) and wheel width
- easiest way to put a timing belt on?
- post pics of nice eg's coupes and hatches!
- civic eg 4 door vision ambers?
- are cat converters compatible for both EG civics and tegs??
- Convert JDM cluster kmh to mph.. explaination inside
- Easiest Way to Pull Out Car Stereo from 92-95 Civic
- honda lifetime warranty ?
- problems with getting rear drum back on a civic cx
- 100,000 d16z6 or buy d15b
- How can i do this?
- HELP!! newbie project! need info from the PROS
- Just installed Hondata IM gasket car runs like crap
- 92 Si...Rear wheel bearing making THIS noise???!?!?!???
- QUICK INSURANCE QUESTION PLEASE LOOK!!!!!!
- blown headgasket - how do i know what to replace?
- RAaaaaaaahhhhhh Stupid TDC Issues! JDM D15B
- Car fax for me please
- HELP! oil burning question
- GSR swap into 92 EG NO SPARK
- tuner shops in Iowa
- I need help with tire and rim size!
- how much is a 92-95 civic nowadays ?
- Need part advice for brake conversion to 4-wheel disc
- Lowering springs for a 2000 4-door civic...
- H22 in EG Prices
- Proper spark plug gap on JDM D15B?
- D series exhaust manifolds?
- Winter Storage EG GSR
- Vibration over 70 mph
- Supercharge Turbo
- Timing belt broke, what do do next?
- Tranny Re-designed???
- Compression???
- broke the rack?
- Weight difference?
- Autozone CAI
- EG engine transport
- How much would a complete swap (labor) be for a b16?
- help with a b16 tranny
- Knock Sensor?? HELP!
- primary o2 not functioning no CEL either, misfire?!?
- 95 cx hatch....weight question.
- cheap b18b's and d15b's!!!
- OBD1 Scan tool HELP!
- The better of the two?
- HELP!! How can I tell my fuel pump is bad?
- still looking for 13's in the GSR hatch..
- h22a axels?
- SRS light
- skip to my lou...under acceleration?
- Wanted: manifold for civic 94 si turbo
- Sea Foamed the Hatch today..
- need help installing oil catch can?
- rpm's?
- Type R seats in a EK9
- Power+Plus Manifold
- b16a2 swap in my 96 ex civic problems please help
- help!!! swap eg dash to an integ...
- Hub Removal Help...
- Interesting gauge idea...
- suspension question ??
- Has anybody had any problems with HCP mount kits?
- Drop questions
- Best way to fix this?
- EK hatch rear suspension problem??
- Keyless Entry Stopped Working
- DIY sidemarker?
- jdm itr front lca question
- airbag block off tray for EH2?
- Question on a future project...
- catalytic converter o2 bung hole - what size in diameter? PLS HELP!
- Help with charge pipe
- JDM D15B 5-wire VX to 1-wire O2 Conversion
- Rear left suspension or alignment problem
- h22 in to a 94 coupe
- POWER STEERING in VX,CX
- EK with b18b hood clearence issues?
- ECU/Radio Fuse keeps blowing, even when not using anything??
- my turbo ls v-tec is not running proper. someone please help me
- What kind of sway bars fit the eg?
- fuel/main relay question
- My FRAME LOCK REVIEW!!!
- Diagnose my idle problem! (not IACV, FITV, no vaccum leaks)
- Need help! What should I do? obd0 b16 for sale/ CRX Si Shell for sale.
- Best way to loosen axle nut?
- at and mt throttle bodies
- Possible Ebay Scammer: Opionions?
- What Diffrent Interior will Fit into My 93 civic?
- My LS/VTEC project.
- best motor for a hatch
- how does oil get in the engine?
- 2 suspension questions
- axles and shift linkage for swap???
- help cant find the airbag module for 02 civic si....
- How to remove headunit... searched.
- need advice
- Where Can i get the key for my cam gear?????????
- Tranmission Parts Interchangeability?????
- C-pillar bar on a 00 Si possible?
- iight... i got a question jdm d15b vs mini me swap
- Clutch Going out??
- 9 psi to a Bone Stock B16??
- thinking about a KAMIKAZE
- ek hatch swap info???
- out of the 1500's whats the best ??
- what mount is this?
- Somebody please help, LS engine problems, noob but searched
- Axel problem?
- Stock motor?
- Weird Problem with hatch, need assistance!!
- valve job
- Where Is the Water Coming From?
- header?
- Anybody selling these items 4 a 95 civic dx
- I need help with a choosing a turbo
- installing a tach on a DX
- Installing Lowering Springs in a EG hatch
- Will a 92-95 coupe b-pipe and muffler fit a 92 DX hatch?
- Civic 91 Driver floor
- 2000 Civic Hatchback Rear Wiper
- Air/Fuel and Ratio gauge
- no spark
- Jacked EJ
- Info for upgrading to power mirrors?
- ek wire diagram
- 92-95 coilovers on 99
- 2000 civic question
- Transmission trouble shooting.... Help Please?????
- Lowering my eg
- Greddy Evo ?s
- 2 O2 sensor with an ODBI ECU
- 2000 si dash wiring in 93 civic ex
- HELP! EK stuff
- Rear LCA compatibility and availability question!
- How to remove seat brackets from stock seats.
- RIMS?
- I need a quiet exhaust for 92-95 hatch
- Car won't start.
- need car fax before sunday
- d16 intake manifold on a d14...
- need help with my field vtec controller
- Is there really a difference.....HondaMTF vs. 10w30
- help my car stutters
- mini me question
- 95 Del Sol S Lower Stut bars
- b20a swap to 96 civic
- Need help fast
- 93 civic front end conversion questions
- where can i get a c- pillar bar for eg
- Strange interior lighting problem on 93 Del Sol
- wanna buy racing seats
- How much hp does a stock 98 civic LX have
- Now that timing is in factory spec, accel. is slower?
- Key gets stuck in Ignition!!! Please help!!!
- Vafc Wiring Harness Question
- Sparco Seat
- something seems fishy
- Lowered Civic heading into the winter - need help
- Where is the cheapest place to buy a front lip from?
- auto cluster in maual dx hatch
- Adjusting your clutch for a 95 Civic Dx
- can't downshift to 2nd...is my tranny busted?
- autometer civic hatch 96-00 apillar pod
- No Spark
- A couple of questions dealing with my tranny (I think thats the problem)
- obd-1 distributer
- ctr pistons in a ls block???
- Tranny needed now..........
- center jack point ruined
- tranny problems
- Showoff your EG here! **Unofficial Thread**
- Touch up paint
