View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Rear headrest
- horn problem
- 92-95 ex/si turbo in 95 lx
- I know this is no ones favorite... Stolen
- 92 Hatch. Idle jump when heat is on. Not another iacv question.
- d16y7 vs d16y8 Help Me out.
- car wont start
- Typical price of a B18B?
- It runs but don't move
- speed sensor
- parking brake cable (seized?)
- Engine Swap
- Brake hardline compatability
- Brake Issue-Noise & FR wheel locking up
- n1 exhaust
- rear disc conversion on ek hatch questions
- suspension set up question for my 99 civic coupe
- Need help with B16 LSD Install.......
- Del Sol w/ B16 Exhaust Question
- 97 DX problem
- iacv valve prob and yes i serched already
- Oem clutch or f1 racing clutch
- s2000 AP2 cluster installation
- eg swap axels on 00 si
- Question- Needs for K24 into 96 civic sedan
- hiden gas filler kit
- fuel rail?
- Need help with friends MISSING 96 turbo civic
- Best place to buy Vtec solenoid gaket?
- civic hatch
- 93 civic hb turbo?
- d15z1 head gasket on d16y8??
- Looking to buy 1995 Euro Civic 1.4i
- y8 head and z6 block???'s Help me out.
- 2000 Civic Distributor on 1997 Civic
- roll cage question.
- HELP! Metal grinding when i turn the key
- scratches inside cylinder head
- Engine knock
- 95 civic project...first time tuner...major help needed
- INFO and TIPS on replaceing ENTIRE STEERING COLUMN after THEFT!
- What do i need for b20/vtec conversion *searched*
- Need Help, My Eg is Not Blowing any Air when i turn on Climate Control
- water coming from exhaust
- 4 dr to 2dr exhaust?
- car squeaks and sound like metal grinding while driving
- fuel pressure question
- Stupid head gasket question
- Looking for advice on my 93 dx hatch
- Information on HX and VX models
- h2b questions
- how good is yellowkoni/grndcntrl set-up??
- Brand new jdm ek fender for sale
- high performance engine builder Q
- Rear motor mount braket
- what are these called/used for?
- EG Inner Fender Lining
- Name This Part!
- engine tuner
- Ground control, shocks, suspension...
- frozzen ice in motor
- -----need help please?-----
- Question about eh-eg trim models
- Help...my car will not start...but I know it is fuel related.
- Installing Lower fog lights on DEL SOL HELP..
- Steering noise
- help with EGSI B18C1 swap
- EK front lower control arms on my EG?
- Stock drive axles
- EG Sedan Front Bumper Question??
- Honda civic makes deep and lound noises
- New Build
- weird idle....
- picking up problems..!
- Wiring Harness Troubles
- cluster problems
- Shipping a car. What company did you use, why, what's the cheapest out there
- the club "tire claw"
- motor swap
- I Found This Amazing Money Savings Loophole!
- Si wheel question
- axles? help please
- B16 Block with GSR head blowing blue smoke
- Question about RPM and Speed
- Should I sell my B20 vtec and go H2b?
- timing on civic
- Push start button
- Wiring diagrams
- OBD 1 to USB cable
- msd 6a box wit a msd blaster 2 ignition external
- very important!!!!!
- How to Fit 99-00 Rear Mud Flaps / Guards on 96-98 Coupe?
- New here
- rod knock/bearing
- 94 civic dx problems
- H22 mounts for eg?
- tips on painting door handles?
- Why do all my valves chatter?
- How to tell the condition of the timing belt/when it's been changed last?
- New here young kid, Project question
- Can't find stock sway bar size for eg6
- Brake Lines, need help finding them.
- Brake Booster!?!?!?!
- 95 civic ex help missing ecu
- d16y8 crank swap
- 97' Civiv EX Airbag Deployment
- 1998 Civic Wiper Problem
- Wheels for my 99 sir
- Do i have a P28?
- New H22 Build
- LS swap into 98 civic hatch wiring help.
- EG FERIO Part Numbers - Help -
- Gsr swap in ej1 need help please !!
- wire tuck help
- Nrg vs. Works Bell
- Need help, car idles from 1k-3k back and fourth.
- TDC Sensor 8
- Keeping the factory horn while removing SRS
- Wire Tuck(Help)
- rotas
- Help verifying Venom Cam Gear Y8 / Z6 ?
- help d16y8 swap
- Help .im getting nutz- Cel code 43 / P28
- 93 civic blown motor
- more horse power?
- Piston manufacturers
- thrust washers d16y8
- 00 si Tranny problem
- just need to know
- 4 wire O2 install into cx now iac problems
- Whats Needed To Run Nitrous?
- How do I make my car look like this?
- need help on my eg3
- Best Tranny For D15b all motor
- 96 EX 2dr, CV problem perhaps?
- 1994 Si stock, original owner, 205k, what's it worth?
- 99 civic ex rear brake light problem
- hesitation in auto
- Lug nut just spins
- D15b7 in a 96 dx???HELP!!
- pic for 96-98 civic full nose mask
- I am changeing bushings
- Build for Nitrous+pics+questions
- If I buy new black headlamps, can I transfer over my HID lights?
- What are my brake upgrade possiblities?
- Hatch won't open... 2000 Civic
- just got a 95 hatch. Have a few questions.
- HELP! Fuel pump constantly priming - flooding my engine
- nitrous??
- The Beginning: 1995 EG Hatch Build. 56k BE AFRAID!!
- 93 Civic taillights problem
- need color code
- Ignition Switch ?- PLZ HELP
- selling my 97 civic $3000 obo
- hubcap fitment question for civic
- cluster
- 2000 civic starting issue
- 2001 si cluster into EG
- Reply with improve gas mileages
- Brakes?
- Whats a control module
- Need help with d16z6 d16 swap, Is it ok to use a p05 for a bit?
- quick question about head studs.
- need help - engine build for my eg
- 1999 civic no spark
- headers questions?
- << 00 Civic fog light problem - only driver side is working >>
- turn signals
- Honda/Import Meet..... GA
- Which Arp rod bolts do you use on b16? Pr3 rods
- Why does my damn idle fluctuate?
- Question about Del Sol floor mats
- 00 civic EX p505 code IAC help
- d16z6 turbo build
- boggin
- transmission help
- Help 96 ek hatch w/jdm H22
- need an idea to fix my fuse problem
- I think I'm missing some side skirt pieces. 00 SI
- Best spark plugs for my HX?
- want to buy.......does anyone have 92-95 civic Coupe Flormats ???
- 1997 Auto tranny question
- learning about my del
- 99 civic
- turbo help
- tranny sucks!
- 99' civic si headlight problem!!!!!!
- lookin to start a team
- help with my parking lights
- del sol suspension
- p75 obd1 or p06
- Help: Car Pull's left and right
- help: b16 bugging out
- D16Y7 into 96 EX won't start... Tricky...
- Need some help
- 99-00 dx manual ecu?
- Steering knuckle repair
- b18b into 94 hatch high idle and no bottom end power
- Steering wheel on the del sol?? S2000? EP3?
- 5 lug on del sol?
- What Power Steering bracket do I need? (SOHC)
- Help please, b16a2 cam seal replacement
- Just wondering about nitrous and turbo
- Help with OIL CHANGE 2000 civic ex
- Spec Stage 3 Clutch Kit
- Does GSR seats fit EK?
- D4 gear indicator doesn't work???
- what do i need to put a 00' ex motor into del sol
- WANTED: zeal spoiler for ek
- 93 civic ex .....pic included
- clean my engine
- Test-Pipe question
- Brake pedal on the floor! help!
- Attention ca swappers have bar/ref question
- radiator support fix
- SRS light on - Passenger side
- Really low idle?
- New Swap wont start *vid inside*
- p28? what ecu?
- service engine soon light
- 92 civic cx timing? sensors? ecu? not running right!
- URGENT!!!! Prop Valve Leaking!
- wheels
- How do I remove heater control unit in a 98 civic?
- help 97 ex shell,00 ex motor questions
- still no spark
- inner fender
- engine dies on its own
- Rebuilding ls/vtec Need some advice?
- 93 DX BATTERY LIGHT??...help please
- Whistling!!!
- rear disc conversion on my del sol
- H2b?
- what you guys think about ma car???
- 00 Civic Ex couple of problems
- A/C recirculation switch not working..
- ECU question?
- Possible computer problem??? PLEASE HELP
- Machine shop questions for y7
- whats the best way to do an oil flush
- Advice on turbo setup in my b18 94civ
- auto to manual help!!!!!
- D16y8 heed help!!
- d16 dizzy install
- Alterntor Help?
- Quick question.... Code 20.
- Boosted EM1 CELS P0170 & P0172
- aem fuel rail questions
- aem bypass or ebay bypass????
