View Full Version : Honda Civic / Del Sol (1992 - 2000)
- gsr head and b16 block
- Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions
- convert p06 to vtec is it possible?????
- si eg help!!!
- fuel filter
- groning noises and metal chinging noises - ek hatch
- spoon style rims
- IACV, FITV, and gas mileage :( help me and I'll love u 4ever
- 97 HB w/ b16a2 CEL #9 out of the blue?!
- Blinker not workin.......
- Service thing on cluster
- Inserting a mesh grill.
- heat wrap
- Early signs of the wearing out clutch?
- denso o2 sensor?
- My 1998 EK hatch w/B16b Spoon, Bride, Takata, Cusco etc etc
- need help with alternator problem...
- clicking on start up?
- performance exhaust and header on gsr
- 10w-30 in Si instead of 5w-30?
- Just did GSR swap and tranny side axle is 2 inch short??? CONFUSED!!!!
- antenna
- Raido problems
- Plz Check my work Wireing !!!!!
- will an oem exhaust from the cat back fit an ej8???
- Brakes???? Please help
- signs of detonation... how bad?
- What the hell, no clutch pedal pressure?? I'm now a foot soldier
- need vtec diagram
- replacing dizzy seal
- strut torque specs
- Code 16 On B16 swap
- JDM GSR p72 ecu pinout for knock sensor
- skunk 2 chiped p28 ecu on a b16 tranny w/ type r motor...
- wheel bearing and axle repair for 93 dx
- HELP!!!
- over heating
- brakes
- Need ideas for wheels!
- 95 civic ?s
- lowered car today. Left and right height is different?
- after swap, rev limiter is set to 4 grand
- em1 power windows
- hi new member from singapore
- 94 EG hatch or 98 EK Coupe EX?
- O2 questions on d15b into vx swap??
- Canadian Civic Differences???
- Is there a way to mod the fog light to be brighter on a eh2?
- 96 civic wanting 99-00 look alike??
- HEY AM NEW
- foglight cracked
- Dyno Tuning Around Iowa/ Minnesota
- **Engine check light: fuel supply system problem**
- what would be faster?
- healthy b16a3????
- Cheapest Lug Nuts??
- Importing EK from the States to Canada (swapped engine)
- 1.5L head swap???
- seat rails
- 95 civic eg coupe front lip poll
- CRANK, but no start situation
- Hondata
- Vtec pressure switch
- anyone knows a good hid company for a civic hatch 99
- Are these authentic OEM parts?
- Searched entire service manual... Help!
- attn eg h22 owners
- cam?
- Identifiying camshafts
- air cond??? problem
- is this true or not
- radiator? aluminum?
- Help with my 2000 DX
- how can I hook up my boost controller with no t fitting on the turbo??
- Spark plug wire fitment
- Crank Position Sensor CEL being thrown....??? HELP!
- looking for a p8r head!!!
- D16y7 wire diagram needed!!!!
- bah..engine wont even turn over
- what is the best headlights for EJ8??
- Few things not wrking after interior swap
- Race Motors
- what is going on!!!
- HELP: Getting BAR, need to convert the EVAP system
- Dust gets into my eg6 civic 92-95 anyone?
- Introductory thnx and I thnk I gotta good deal
- h22a or f20b
- need quick help
- Question what type of Tranny to use on a ls engine
- Radiator Hose Questions
- Under dash clips, anyone know where they trace back to ?
- Question for z6 owners
- trq specs?
- d16y8 oil pan swap info
- My muffler installed wrong? Swaybar wont fit..
- Anyone with PIAA H3 bulbs and OEM fogs?
- OBDI VTEC solenoid on OBDII b series motor?
- sway bar ?
- how would i put power windows and locks
- 92 civic lx
- Sunroof problems
- eg b16 swap a/c problem
- Lexan Covers?
- XS POWER TURBOS
- eBay headlights on Del Sol?
- Car not starting after a few weeks?
- Is this an es tuning polished muffler?
- Strong vibrations at 7k+ rpm felt from my shifter...
- civic front speakers
- civic momo wheel
- Alt. belt noise
- DIY: Manual oil pressure gauge install
- EK fog lights
- side markers. stanley.
- D16 turbo? info please.
- D16y8 or D16z6 Tranny?
- What mount to buy for swap
- gasket question
- Del Sol windshield seal; Dealership or glass company
- BAD BUY....
- brake help
- which swap is better for my sol?
- rear speaker help
- mugen valve cover
- LSD help.......
- y8 dizzy fit on z6 head?
- Is it worth $2400?
- DC2 integra Rear Seats Into EG?
- exedy clutch question
- 97 ek hatch w/jdm dc2 frontend?
- question about a v-tec civic motor
- any one have d16 jdm lsd tranny???????
- 96-98 Si
- h22a swap into my eg6, axle problems!! please HELPPPP!!
- d16y8 obd2 versus d15 dx obd1. what is the difference?
- Tire size
- Question on HX tranny
- solenoid
- Interior Light Problem - Bugging Me!!!
- need autometer gauges oil press boost air fuel
- Hasport mounts
- Need tunning on my LS/VTEC.....someone help me.
- oem side skirt???
- Engine shuts off, and comes back on while driving
- itr rear seat clarification!!
- Buying Front LCA need advice
- motor swap
- Gsr Q's
- obd adapter harness
- Koni Yellows on a del sol
- 100% water?
- Will em1 suspension fit on a 92-95 coupe?
- hood scoop..........
- d16y8 swap in a 93 del sol - need some advice
- honda Civic CX A/C
- Wow, I'm kinda dumb.
- Fuse question
- R_status AKA ANTHONY LA IS A SCAMMER AND A THEIF
- post thoes tan cars.
- Disc Brake swap question...
- ls/vtec help
- Longest 5th Gear?
- Spring Compressor
- 99 civic ex header
- cooling system/ thermostat help
- will leather gsr seats fit in my 99 dx
- HID's... ??
- Surging Idle and TPS Solved?
- what do you guys recommend on my build? k24a1
- What problem am I having?
- obd2 b18b in an eg... what's the best ecu???
- EK picture thread????
- car push starts but doesn't start with key?
- AC in a 92 civic lx
- canadians need an asnwer about your mirrors
- OPTION FUSE???
- Could Main relay cause low compression numbers ???
- fuel injector relay
- ITR oem cd player
- preloading suspension bushings
- gsr swap
- mini me question
- need help car keeps dieing!!!!!!
- B16a swap using a D16y8 harness
- Tranny Question
- how come the lights on my cluster dont work
- tranny stuck
- d16y7 compression test
- d15b7/d16z6 head mini me problem
- h22 swap
- carpet?
- 3stage vtec
- usdm d16z6 vs. jdm d15b
- what can i do to make my civic look nicer or faster
- Throwout Bearing - D16y7 motor & Suspension question for a EJ6
- Problem with gsr in 95 ex
- Mass smoke and code 21 after head gasket change..
- 1992 Hatch
- VSS help needed
- bumper beam hook orientation
- i am about to replace my b series tranny but is the oem flywheel worth of replacing ?
- HH2 CIVIC IDDLE PROBLEMS..PLEAS HELP.
- Help: Clutch noises in neutral.
- Websites for replacment parts?
- My Ek.
- CTR Front end
- Map sensor 92 Civic si swap B16 Help plz
- need a part number or exploded view
- BAR'ing B16A2 swap w/ GSR tranny
- my friends car burns ECU's.
- 1996 Civic DX, D16Z6 headswap, CEL 4 CKP
- Wha else could i do to my car
- RIGHT HAND DRIVE 2000 SI
- What's the difference (EX, DX, LX)?
- Civic making noise while turning....new axles
- manual to power windows
- rhd eg k series???
- b18b hp gain
- green plug near ecu
- Where can i find an antenna cover??
- Vin Location
- 97 EK with GSR swap ECU problems.
- Quick question about tig and mig welding....
- HP ?
- Need Wire color for Blower motor on a 94 Civic CX
- Distributor help obd2 car now to obd1
- Aluminium drum question
- ICC_Texas need help
- EP3 Seats in 00 Si - Pan Swap Possible?
- CTR interior Question ?
- act 6 puck question?
- green injectors?
- gauge help guys
- b16 turbo ?
- car makes noise around turns.....
- Paying tickets off when after selling / buying a car
- OBD2 RC Injectors?
- harness and shift link problems
- suspension woes (00 civic ex coupe)
- Honda Civic 99 D16Y7 Is It Ground? or is It ECU?
- Msg n trial status
- Rear disc brakes for my 99ek
- I need a wiring diagram for Civic 00 EX
- Cant post?
- Will Mazda/Subaru/Mitsubishi Exhaust Bushings fit on a Honda?
- Recomended upgrades for 97Hatch w/ITR Motor?
- does a 92-95 civic steering wheel fit a 96-00 civic???
- wet or dry shot
- Distributor-less
