View Full Version : Honda Civic / Del Sol (1992 - 2000)
- CIVIC Window Glass Channel Clip - Which Glue ?
- td84u dizzy in a b16a2
- Suggestions for affordable Ek cluster swap??
- What grille is that?
- i need tranny codes...
- b18c5 usdm trouble codes P1259
- ej8 mudflaps / mudguards question
- 1994 honda civic eg type r swap? help
- EM1 header sound
- 95 to 98 civic manual speed sensor interchangeable??
- Em1 as first Honda?
- Headlight Problem?
- 97 civic ex window and door replacement
- Vtec not engaging ( ectune)
- 1997 hatch options/help engine/trans
- Rounded Timing tensioner bolt
- 1995 Civic Sedan EX with Four wheel disc ABS
- Fog Light Switch Light Not Functioning
- need help with ctr power folding mirrors!!
- 96 Civic EX - transmission amd power steering questions
- PLEASE help ! civic shakes really bad when turning right
- How to replace exhaust manifold gasket? Minor exhaust leak after removing 'pipe A'
- Any one know the 93 civic oem trunk board measurements?
- Vibration In Front End- Need Suggestions
- Rattling exhaust
- will a 97 ex ac fit in a 97 del sol si?
- Car shuts off when coming to a stop?!
- Wiring '96-'98 fog lights to headlight switch?
- 95 EX will push start but runs horrible...
- Creaking clutch pedal
- cold intake question!
- Can anyone let me borrow their eg stock axle back??
- d15b8 boltons for better mpg
- 95 civic dx 200k+ maintenance
- 96 Civic/d16y8 engine - no spark and VTEC CEL code
- Not the starter or battery or alternator...
- y8 head on z6 block quick ??
- just bought a 2000 civic ex - want a single cam but not sure which one
- 96 civic stalls when you hit the gas pedal
- 97 civic ex no start
- ej8 intake resonator question
- How replace my stock del sol seats (black with red stripe) with racing seats?
- My GSR Build - Please Comment/Assist/Share Knowledge
- Ticking noise when accelerating?
- 2000 civic Si - How do I identify my tranny?
- My 93 civic hatch manual wont start but i can pop start it?
- 1994 dx pulsing lights?
- 1993 civic header/o2 sensor question
- ebay EK square fog light - Does anyone know how to mount the brackets?
- Crazy Oil Consumption - B16a2
- 99 Si Front end Pop/Knocking Noise??
- New battery - what brand?
- 97 civic dx - Why does gas meter in cluster change when making turns?
- Suspension help - rattling/knocking sounds when going over bumps
- 92-95 p30 ecu -- What cars does this ecu come out of?
- HELP with 95 civic sedan, headlights and corner lights
- car started shaking need help might be steering rack
- need help asap
- AC and power steering diagram DelSol Help
- 1997 Honda Civic BAD GAS MILEAGE HELP!!!!
- no vtec engagement after cam install
- Where can I buy civic 99-00 oem hood bra?
- exhaust/resonator question
- Honda civic 99-00 question help
- 99 Si: Is there vacuum lines on the bottom of the engine?
- 97 civic wont start
- d16y7 blown head gasket
- eg coupe wont start? cant figure it out!
- im using a 96 hatch harness and i need repin the iat plug to fit a b18c
- do i need evap canister?
- No Compression on Two Cylinders
- EL console in eg
- My '97 CX build
- Ek acting weird after cleaning iacv
- manual window problem
- Cracked manifold affect O2 sensor?
- Rear Defroster Broken Connection
- 99 Turbo civic steering problem?
- '97 cx hatch climate control lights going off
- Mini Me questions
- Rad hoses with a b-swap radiator?
- what engines fit in ej8?
- 2000 Honda Civic Si weird popping under accel or release clutch
- Water leak issue
- 99 Civic Ex D16y8 to d15b obd1 help with vacuum lines
- Replaced 2 ex. valves and have a question
- 2000 Civic Si City light Slot headlights
- 2000 Civic Si tweeter doesn't work - replace with OEM or aftermarket?
- Valve adjustment b16a2 question
- 97 civic was misfiring and now stopped running
- B16a3 knock sensor?? obd1
- occasional reverse grind?
- Need help installing my prop valve.
- RIGHT SIDE HEADLIGHT LOW
- DIY S2k Cluster Into EG * HAS VIDEO*
- Oil getting into intake??
- white smoke, power loss, no compression :(
- Connecting rod location help
- What is this sound?? (video)
- D16A Swap in 1995 Civic, Not Starting...HELP!!!
- Burned out bulb? Answer to question "what type of bulb do I buy for my car?"
- Need help with cluster lights flickering and srs light flickering???
- BMW 3 Series seat swap in coupe?
- hard start, new battery
- 97 Civic LX Radiator Fan wont come on
- 94 Civic auto to manual conversion - special mounts needed?
- Prop Valve really required?
- Del sol clutch problem
- Start Up Issues
- Del Sol Hood Stuck Closed
- A/C Heater Blower Stop working
- 1993 Civic Speedometer Problems
- What can I do to get a little extra out of a d15b7 overhaul
- Confused about wheel bearings
- 2000 civic si b16/gsr idle issues and hard start
- Pacesetter 88-1422 on a dx hatchback
- What cat do I need for my civic ej6?
- Dynomax VT or Yonaka exhausts?
- Best Way to Remove Subframe LCA Bolts?
- CEL code 14 only with the service jumper conected
- Vinyl/interior question.
- need a\c help 98 ek cx HELP!!!!
- Lag?? please help 1st and 2nd lag.
- a/c drains battery
- 2000 civic ex gutless acceleration
- Fuse box gives power to my car's frame
- Where do I buy a distributor for a JDM D15b? Also, is this P28 in pic socketed?
- Want my car to run need help, electrical
- 1995 Civic Si - Different Trim Level?
- Upgrade larger 91 civic ex master cylinder?
- Acceleration problem
- Del Sol roof leaking!
- Can't put into gear?
- plexiglass sunroof fix, ideas?
- 96 Civic No instrument lights
- main relay does not click! not bad relay
- Ignition Question? EM1 Stolen
- AC question
- Rear endlinks are annoying! Help
- Possible Blown Headgasket? Coolant Overflow Dilemma
- Help with Interior for EG Hatch
- EK mirrors fit with EJ1?
- Radiator Fan Staying On When Car Off
- b16a cel light
- 2000 Civic Si Gauge cluster and Climate control light dont work!
- 2000 civic clutch pissing me off!!!!
- 95 EJ2 rywire engine harness through firewall
- My 94 Civic Cx hatchback build
- Noticed a little drip of oil and now it's gone
- EK - Will Bride Low Max Rails bolt onto my DC5 Recaro Seats?
- 98 civic - bad idle for ~30 seconds after start up
- What to rebuild?
- 2000 Honda Civic rough shifting
- Speedometer bouncing, battery light, squealing & more
- 97 civic - auto tranny shift hesitation from 2nd to 3rd
- 93 Civic Si/B16a swap - Running rich and engine rpms rise but no acceleration
- installing a new slim fan
- in need of a d15 or d16 engine
- Very low Idle**have done all the checks**
- Where do I buy a replacement engine for a 2000 Civic EX?
- 92 to 95 coupe trunk on a sedan?
- 1998 honda civic ex
- CP sensor & Knock sensor.. Important?
- 36mm 5lug on ek automatic need help please
- Where does this plug go? 99 civic Si
- axle to half shaft wobble
- installing ek9 headlights
- b16 turbo?
- Radiator trouble
- 93 del sol w/ gsr swap . cutting out / sputters at high speed
- Hi guys
- Weird Clutch Noise?
- first attemp at clutch job, need help
- Hatchback trunk pre-wired for speakers?
- What's considered good compression???????
- my car doesnt start
- Suggestion on B16 N/A Del Sol Exhaust
- excessive blowback?
- new post for no run 94 honda civic no fuel pump
- D16Y7 oil pan torque spec
- OBD1 92-95 jdm b16a swap into OBD2 2000 si - Will it run?
- '92 Civic Hatch tailgate question.
- Timeings jumping helpppppp
- Replaced the oil seal on distributor and now engine won't start
- Disgusting Grinding Noise... Please advise...
- Changing D15z4 to D15Y engine (help need)
- need help changing bulps
- Throttle Body Question
- 92 VX tranny/clutch whine?
- Misfire on cylinders 2 and 4
- Odomiter stoped
- Degreaser did this to my engine! How to fix?? *PICS*
- Sensors?
- b16a2. obd2 to obd1 help
- help swapping a 96 civic steering column into a 95 vx
- B16 Knocking Noise!!
- SI Engine Harness Diagram
- speedometer stuck at 30
- Running light issue
- D.I.Y EDM / JDM EK Rear bumper fog with OEM Switch
- Eg POWER WINDOWS. WITH INTEGRA HARNESS. HELLP
- DIY z6 clutch replacement help?
- 98 Civic - any gearboxes I could put on to help with acceleration?
- who knows this wing? (pic inside)
- NGK Spark Plug Wires - Which Part #??
- Is it worth swapping auto to manual?
- 95 civic lx leaks hot air and...
- Project GreenGo: ALL Motor K24 midori ek buid
- no start
- d16y8(97 civic ex) starting problems
- 94 Del sol build!
- My First Car/1993 Honda Civic Si Build
- tanabe exhaust
- inner fender splash guard ebay same as oem?
- Over Extended Inner CV Joint. Boot still good - Will Not go back in. Help!!!
- Check light went off
- gasing leads to dead engine.need help!
- Attempting a wire tuck (issues)
- Manual chipped p28 throwing code 19.. Yes it's a MANUAL ecu
- 92 civic front bumper
- 95 hatch b18ba/b16 ls-vtec. What ECU should i use?
- problem with my d16z6
- Wiring disaster
- is it ok to removal the plastic liner in your wheel well?
- ported head
- axle nut
- Mirror replacement? Will this work?
- 2000 Honda civic ex, need advice for certain problems! Please help!
- JDM D15B Vtec combustion issue?
- 1992 Honda Civic Hatchback reverse light issues.
- After Market Cam Gears and CTR Pulley Pass Ref??
- 92-96 prelude seat installation
- 3 inch exhaust for eg hatch
- EG Exhaust Question
- b16a starting up problem
- 97 Civic EX - code 14
- Anybody ever use these torque mounts?
- head light problem
- why does my car smell after driving fast
- D16Z6 Engine Rebuild "Bearing Help Please"
- Motor will fire up and immediately die, Tach and Speedo flutter
- obd1 or obd2?
- Young&Broke Build
- Exhuast/Hearder set up????????
- oil light after head gasket replaced
- Surging idle & limp mode ( code wont read) b16
- 2000 EX coupe misfire
- EG Sedan rear window fix?
- Difference between 2000 SI rims and 2003 ex rims?
