View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16 Engine Mods
- 92 civic signals and clock not working
- Leaking roof rails? Water woes.
- Highway braking - Warped OEM Rotors
- Clutch lines clogged?
- 00 Civic EX - Knock sensor Check Engine Light
- Main Relay for a 93 del sol m/t
- 95 Civic - HVAC controls sticking and popping out of dash
- Intake Gasket Leak
- My 1995 EX got stolen... [NM]
- 1995 civic Canada mfg, Japanese rear lca's?
- No Crank when Hot
- 95 civic cranks but won't start
- Heater blower not working
- Engine Will not rev Past 4000 rpm. '95 Civic EX
- D16 all motor/full build
- What RPM for a 99 Civic Condenser Fan?
- Engine Shut off and Start Issues 98' Civic
- Low compression misfire
- replaced neutral safety switch - engine won't start, key stuck, can't change gears
- are civic and del sol door window universal?
- Fog light issue some please help 95 civic!
- Cannot Find A Name For This Part?
- Which sway bars should I look for?
- Auto Transmission Failure? Power to Wheels Intermittent.
- EK door panel...trying to fit it back on.
- External ignition coil not grounded on negative side?
- Are they the same! Non-v eg hatch's and del sols
- del sol no key for tires help!!
- Del Sol Seat Swap?
- Key Issues
- '98 LX - Sound from trans in neutral or when wrapping out 1st/2nd gear. Bearing?
- Need help - 95 Civic Coupe
- C-Pillar Bar Install
- Y5/Y8 hybrid; what's the right fuel pressure?
- Del Sol Suspension Compatibility
- revlimiter at 5500 WTF???
- Transmission Needs Replacement
- Question about crank position sensor
- D16y8 surging idle
- Honda Civic 1996 lx overheating
- What ecu can I get for a 93 del sol ?
- Rebuilding b16a2
- D16Z6 Weak spark, no voltage to ICM, Jumping TACH
- B16a2 SWAP into 96 Civic
- D16y7 with z6 head issues
- Adjusting base idle
- Car not starting
- D16z6 very mild build in mind would like to get some thoughts
- 92 LX 5 speed project
- tire rod
- Headers for EM1
- B16a2 no spark help!
- what dizzy for y8(p2j-6) head on obd1?
- Where to find a duel throttle pullies, one for cruise one for gas cable?
- Need Help!!! 99 Civic Ex at misfire and slow acceleration
- Need help on Amber lighting on cluster
- OBD2b d16y8 swap into OBD2a Civic
- 93 honda del sol s d15b7, fuel tank
- Radiator size question
- Civic Trunk Release into Del Sol
- D16 Dies when given gas only in gear
- Random no start. Is this a main relay problem?
- Grinding noise and clunks... what is going on here?
- Car cranks but won't start
- Fire Damage repairable?
- Buying a EJ Hatch, what to look out for?
- 93 civic shifting odd?
- Any ideas on how to remove belt-driven crank pulley, please?
- Does a B16B CTR engine and tranny come with that one-piece transmission stiffener?
- Need help gaining mor hp on y8
- Head gasket testing need some help
- d16y8 swap into 91 Civic - Overheating slightly
- Hood Latch not working
- Urgent - spark plug nut broke off!!!
- eg6 back seat bar
- Clutch Help
- Gsr build
- primary o2 sensor help
- d16z6 exhaust tone.
- died an wont start
- I have tree fiddy for a nitrous kit, what to do?
- B16 oil light flickering issue
- d15 help
- Let's play find the oil leak...
- Eg8 won't start please help
- Crank, No Start + Loose Timing Belt. Replace Tensioner?
- How can i delete vtec, and have it on at all times
- No speedo and cooling fan
- Pulley help
- Anyone use K&W fiber head gasket repair?
- obd1 scanning adapter
- 97 Del Sol SI SMELLS LIKE GAS BADDD
- 1st feels like 3rd
- more timing issues
- valve adjustment
- Swapping a D16Y8 crankshaft with a z6
- 1997 Civic EX Coupe Trunk Leak
- I want to do an engine swap
- Missing Door Harness?
- Engine identification issue
- Deciding on chassis parts ,Extended ball joints, tie rods, upper control arm, bushing
- 97 HX overheating
- Wobbly shifter
- Del sol radio cover.
- Problem with A/C system
- Front end rattle EM1
- Seat Swap Combinations
- Civic ex 1999 gurgling engine noise
- 1996 honda civic windows stop working
- '98 LX - A/C not working
- '95 Civic auto trans /d15z1 with p06-1 ecu. And it runs
- Smells like fuel.
- 95eg timing/smog issues
- 2000 DX won't start
- 95 hatch. Crank, No Start
- ecu sticker missing
- Overheating help!!!!
- New here!! 1997 Honda Civic HX EGR code (problems)
- overheating
- 93 Del Sol Si (d16z6) sputtering... Please Help!
- 1993 Honda Civic idle problems
- Won't start
- IAT wire configuration.
- how to put my honda civic 1998 in Valet mode?
- How to remove the engine harness?
- 96-00 Honda civic d-series Upper front motor mount are the manual and automatic same?
- Honda Civic Del Sol SI with rusted quarter panels
- Del Sol Si Proportioning Valve
- how to reduce torque steer
- 95 civic not getting spark
- Ac compressor stalled car
- Clutch slipping when engine is warm
- Power window issues?
- questions on d16z6 mini me
- What do you guys think about fixing large rusted areas with fiberglass?
- Help with B18C build - silicone hose kits?
- Noisie clutch
- Is there an Accord RonJ?
- EK pick up speed slow
- Engine cuts out for split second
- Will stock rear lower control bushings fit on to aftermarket lower control arms?
- IACV on 97 LX
- 94 EX SEDAN a/c cold but barely blows
- CIVIC SWAP
- Civic coupe 99 rear suspension squeak
- Shaking at first gear
- Civic Coupe Steering and Camber issue
- HELP! How to install manual fan switch
- 1994 civic ex - best suspension?
- 1996 Civic - stick shift only goes in circles
- Vtec solenoid - how do I tell if it isn't working properly?
- D16y7 exhaust
- 99 civic hatch semi rebuild thread
- build question arp head studs
- 95eg brake issues
- D16y8 Bogging
- CEL 67 - cat conv
- 94 civic fuel issue
- Curious about crankshaft pulleys
- Door outer weatherstrip
- Choking up/losing power on freeway.
- Drilling holes larger in distributor
- EH1 rear wheel bearing - how free?
- Lost motion assembly from a y8 in a z6
- D16z6 moderate performance build
- Transtop help
- Car gets sluggish on Gear 3
- 96 Civic Accessory Power Relay
- Honda Ek4 (B16a2 Rebuild Questions)
- Driver Door Not Locking
- 2000 Civic, dash lights not working.
- 2000 Honda Civic EX gearbox/shifting
- 93 honda del sol door hinge problem
- INCREASED ride height on Koni Yellows/HR OE sports??
- Power Locks Not Working, Windows, sunroof 1996 civic ex coupe
- Del Sol stance advice.
- b18b1 swap into a 93 eg coupe
- Fuel Gauge DIY Help (I used search)
- stock 1995 Civic VX: EGR repairable?
- Reverse problem
- Need Help on Cruise Controller Not Working
- Delsol shift linkage
- stalling issues
- Need help, engine starting issues after replacement
- is it worth it to rebuild fully rebuild a 98 civic
- 95 Civic - code 23 or codes 20 and 3?
- low rpm
- Yonaka exhaust rattle noise
- 93' Civic - AC Recharge - R12 to R134a Retrofit?
- front tires uneven wear
- OBD issues
- 1994 Civic Si Not Revving Past 6k
- intermittent spedo
- Big Brake back to stock
- 94 Civic d13b2 stutters in 3rd and 4th under heavy acceleration
- 93 del sol gauge lights wont come on
- 98 civic ex ej8 build si clone
- Car wont start...
- Heater Hoses HELP!
- 98 civic y8/y7 minime stalls when coming to stip
- Fuse 43 keeps blowing !!
- Mini-me d16y7 to z6
- Engine Model number and ECU details
- 99 Honda Civic - Code P0141
- Distributor rotor fell off, now low compression???
- CTR defrost switch wiring
- Help With Speed Sensor
- Replacing head on 96 civic DX need help
- '98 LX tach doesn't work, easy to replace tach? Or what clusters fit?
- Air,fuel,spark no-start condition
- 1998 Civic EX Mods
- Can you rebuild EK/EJ starter?
- Brake/rotor problems
- how many miles on your starter/alternator?
- Fuse that won't start the car?
- Correct Exhaust Gasket Exh. Manf to Pipe
- My EG8 Build
- Are all the d series driveshafts identical?
- 97 Civic Won't Start and Shift Lock
- 96 civic cabin filter retrofit
- 99 EX overheating - many details inside
- Stripped bolt hole, what helicoil kit?
- Noise then smoke after second timing belt change - AC compressor issue?
- Cranks won't start
- EM1 Mods?
- EK Rear Bumper Bar Bolt Hole Spacing
- Engine mounts !!
- 95 Civic Engine Bay Harness HELP!!
- Please help SRS always stays on 1999 EK3
- 99 EK B series conversion, how do I retain AC and PS!
- EG OEM Front Lip Compatibility
- Honda Civic EX D16Y8 Service Manual
- 97 sol won't start,
- Pleae help! Timing belt tensioner installed incorrectly?
- B16a gear box shift freely in gear still?
- Replacing ignition lock cylinder - pin too big
- 225,000 miles too many for Head Gasket?
- P1509 fast bouncing idle
- 1999 Si b16a2 timing belt replacement help...?
- Car Wont Start
- Can anyone identify this part?
- Broken speedo/odometer?
- Found broken plastic round cap/plug under driver side dash 93 VX
- 0 compression? 150 0 150 150 what is this?
- Questions about a 1997 Del Sol VTEC with a different motor
- 2000 Honda Civic woodruff key orientation
- Obd2a or Obd2b?
- plastic headlight lens
- No spark issue...Tried everything!!
