View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what does a timing belt kit cost for a B16?
- Stupid Question But Help Me Out...
- HELP: T fitting from oil pressure sensor broke off
- Need to find out the correct mm socket size for spindle/driveaxle nut...
- Need some help here. Shift linkage question.
- d series header weight dc 4-2-1 1pc vs. oem 2pc
- xtd cltch intall got a problem i think HELPPP
- ek sidemarker
- idle problem
- 99-00 SI and 94-01 Tranny Bracket question
- Need help with b16a2 swap
- how to get a rhd car imported
- turbo kit
- vtec-e
- Replacing oil pump?
- passing CA smog with ITR pistons in a b18b?
- tire ?
- Master cylinder change-out, any tips on bleeding?
- IAC coolant lines go where?
- electrical malfunction
- Del Sol inside door handles needed!
- help me save this ek!
- Weird issue with H22 swap, reoccuring code 9.
- h22 eg6 which axles do I need?
- amber cd player lighting?
- Custom Interior carpet work in Bay Area?
- will the seats fit
- Help. Could this be bad?
- 94 Civic Vtec interference head
- What is this line on my LCA?
- ******DelSoL Roof Top4Sale*******
- stupid question about b and d series
- bouncing idle after manifold swap, need help ASAP
- Gauges in climate control location? anyone?
- blowing out of valve cover...
- best p28 chip for b16a2 swap.....
- Tranny Identification!! PLEASE HELP!
- Z6 vs Y8
- Totaled my EK hatch, need advice
- y7/y8 mini code 14 after putting p28 ecu in? why!
- Transmission Evaluation
- Failed smog
- rpm problem?
- Light knocking not bearings. HELP!!
- headlight problem....please help asap
- tail light questions?
- CTR piston on B16a2...
- how do i put side moldings in a 92 civic?
- Easiest way to remove cam gears?
- B20
- front brake system
- CAR wont start ???????-dash swap-
- Auto to Manual: Can't start car and other problems. Help me get back on the road!
- help needed to change the valve stem seals
- jdm b16 crank sensor?
- PROBLEM PLEASE HELP!!!
- how safe is this? searched
- Help! HID Projector won't fit in 98 Civic
- Removing Resonator
- Fiberglass doors
- valve cover corner bolt socket size
- 92-95 civic hatch with k20a3 motor?
- Hello from Spain!!!
- plz dont flame i need a qwick answer k20a3, 1000 dollars worth it?
- Bored GSR TB on D-series?
- 1993 civic dx auto radiator
- engine bay smoking?
- questions about lower arm stablizer bar
- Clear Headlights
- Can't Get Caliper Bracket Bolt Off
- tranny leak
- Civic 98 hatchback rear strut bar
- Need help!! Searched!! Obd2 Distibutor On Obd1 Harness.
- BRAKE HELP!!!!!!!!!!
- 96-00 coupe exhaust on 92-95 hatch
- Integra side mouldings
- Point me in the right direction. How to install LS in an EG.
- final drive compatibility
- Trouble code 43 Fuel system (DTC 43)
- ek4 navigation (to anyone who has/had it)
- H22 IN EG MAKING RATTLING NOISE AROUND TIMING BELT AREA AFTER REVING
- transmission needs a brak after a couple hundred miles?
- turboing stock b16
- drag/street EK hatch civic!
- more mini me questions *sigh*
- EK's with no side moldings?
- resistor box continuance?
- Ecu Chips
- Question about wheel lug nut sizes on Civics
- motor mounts are they different from auto to manual
- Quickie question!
- any one know what head light bulb a 93 civic hatch takes???
- best throttle body
- Header Glow Problems
- weigh ins (searched and sounds a lil weird)
- Need help with identifying item
- my "maintenance needed" thing faded from green to red??
- Licence plate mounting question!!!!HELP
- obd0 to obd1 dizzy problem, i searched.
- swap help?
- Which ACT Clutch KIT for H22 swap?
- vtec bogging
- Need help with timing light question. ASAP!!!
- will EG front lca fit EK?
- 89civic w/ d16z6
- D16A6 alternator and crank pulley
- ST sway bar endlink L brackets?
- 95 civic coupe hood same as sedan????
- Diagram?
- Timing.. HELP PLEASE!!
- b series cable trannys
- NEED SHELL!!
- Pulsing lights
- after to auto to manual cant start .. errr ..
- d16 high compression pistons website
- battery light flashes ,car bogs until 3grand,battery dies
- who's got a borla muffler?
- EG to 2000 front end conversion? *Searched*
- ELD disabled, but still getting ELD code
- signal problem
- my alarm lights
- searched. crank bolt size for 2k D series
- front lip interchangability... 99-00 on 96-98?
- can I use other models hoods for my 97 Civic?
- zc bottom end with z6 head
- wiring diagram 6th gen folding mirrors!
- rear brakes
- thread locked
- d16y7ecu and y8 ecu the same? as of wiring slots?
- whats up guys
- why would you want to get rid of vtec?????????
- How to change brake shoes?
- Quick help! NRG engine damper mounting question
- Bolts for del sol lip
- Got pictures of my car. Need your advice on rims. Thanks.
- Will a 99-00 SiR/B16A2 header (for you US peeps, SI) fit on a GSR/B18C
- B18C trade for h22a ?
- 93 civic with integra dash
- Car will not start (this is a different story)
- bumper pole install on an eg6
- increase power
- Ported head and losing water in the redaitor
- The Gas Thread
- LS-VTEC CONV. (RESPOND HONDA-TECH)
- 94 - 01 Integra 4 Door Rear Seat in to 96 - 00 Civic Coupe
- Crazy Exhaust Question?
- OBD2a ecu tach signal
- How big a job is it to fit a B18C engine into a crx del sol?
- Difference between hydro, cable and electronic transmissions
- 4 Door Type-R Rear Seats in a 2000 Coupe? How to fit??
- Which ECU?
- transporting an engine in a civic?
- k24a4 in a hatch.
- Plug in block...
- White EG owners!
- please someone help me Iacv problems.
- engine light code?
- Quick GSR Manifold wire question (which goes to IAB and IAC)
- how to change clutch fluid ....and bleed system
- trying to put JDM B18a in to 92 civic
- 99-00 Civic SI rear engine mount???
- Mugen radiator cap on a Fluidyne...
- RIGID strut bars or Cusco?
- Clutches
- j's racing eg wing or spoon wing????
- Carbon Fiber?
- D15B7 engine harness work with D16Z6?
- brake fitment question.
- lights dime down
- Where to purchase SOHC VTEC decals?
- what does bump mean????
- A/C compressor
- compression tester issues
- do i need to compress skunk2 lowering springs? (rear)
- need to find this part so i can order online...b series cable tranny
- Title on the EK shell
- EK9 JDM SiR/SiR II / TypeR Brake Upgades
- WTB: P30 EDM ECU
- help, O2 sensor wiring to ecu
- D16 Idle Problem (Searched to no answer)
- Now my car won't start anymore...
- b16a questions. injector and how to get more HP?
- type r ecu
- cel test??
- carbon fiber hood, will it pop open?
- trunk shocks?
- 92-95 civic hood half bra
- Is this problem cuz the clutch slave cylinder???
- Throwing code 91 help
- HONDA-TECH (RESPONSE TO TOPIC)
- ecu problems
- What Pistons?
- JDM D15 Fuel Rails?
- HELP!!! which header to order
- mid rpm range...bog down need help
- What else do i need for a b series swap?
- instructions for installing ek foglights.
- Does anyone know if a 99-00 civic SI muffler will fit on the ex coupe ?
- removing seats
- Door handle question
- something wrong
- ek9 for sell 3900 or trade??
- SI rear setup on DX..should I upgrade my front brake setup as well?
- 96-98 EK civic square Fog light install... HELP.
- need some advice
- thinking about h22 in my 99 ex coupe
- h22a c98 coupe all motor questoin
- c/r calculator link
- B20vtec in a 94 civic to turbo or to supercharge?
- Twinloop replica mufflers...EG HATCH fitment?
- Fan wont turn on.
- 5 bolt hub question
- What is the color of Honda ATF?
- CLIP ON side moldings question for EG hatchback
- Could code 43 cause misfire at middle to high rpms?
- ABS on 98 Civic EX????
- mini-me bouncing idle and rev limit
- suspension clicking..dont know where is from
- 20mpg :(
- Car wont start help please
- 95 civic ex running wied, pulsing
- i got a question
- hx wheels on eg with gsr brake swap
- Another Overheating problem....HELP!!!
- '95 Civic DX Hatchback Swap from '93 Integra RS?
- Steering wheel question.
- daytime running lights
- check engine light MAP sensor
- air fuel guage install help
- tranny problems. d16z6
- best trans for a z6
- trying to manually wire power/ground for a radio
- need help (searched)
- B18 Nonvtec motor, What head should I put on it?
- Best Intake
- Y8 ecu
- Raising the Shift Boot
- pic requested 99-00 si cluster
- How much FREON r12 to add - 1993 civic dx
- EK exhaust ?
- water pump differences question...plz help!
- CTR HEADLIGHTS
- map sensor prb.
- wat kind of ecu should i use?
- looking for independent mechanic in Eastern Massachusetts
- com
- jdm spark plug VS usdm spark plugs. difference?
- VTEC System Malfunction
- idle air problem in 98civic w/ 00' sohc
- check engine light? p1259 help!!
