View Full Version : Honda Civic / Del Sol (1992 - 2000)
- d16y7 block d16y8 head
- Who's rockin stock struts???
- wanna go with a b18b, but what about the hydro clutch? What's involved?
- WTF is up with my clutch
- Tranny Conversion Question
- H22 powered Civic with 5stud (JDM Integra) conversion 'Driveshaft Question'
- what seats to get in my red eg hatchy?
- In need of parts...
- How to tell what TB I have laying around.
- Urethane Bushings?
- type r suspension
- HEY WIERD clicking sound from engine PLEASE help!
- please some host my video of a delsol
- Gauge pod??
- gsr O2 censor question?
- D16Z6 vtec engagement? Which rpm?
- Limited Slip Diff
- Autometer warning light
- Civic Gas Mileage
- Found some great info but is it true.. Turbo b16 or Turbo b18b
- What airbox do I need?
- GRRR... Rear lip burnt by exhaust. What to do?
- What makes a D15B7 and a D15B2 different (other than the years they were produced)?
- need some info..please (cam gears)
- header install...need help
- reusing rings?????????????????????????????????????????
- EG guys who has oem JDM 4-1 header...b18/b16 swaps
- Help ! temperture problem
- Anyone got their civic si stolen lately in NY?
- any one ever replace their windshield?
- lots of air but no HP
- Do 94's have airbags?
- EG JDM D15B throttle cable question
- st rear swaybar install???
- Anyone got templates for a B16 port and polish?
- CEL code 91
- B16 throttle body in a D16 intake manifold
- Is this a possible spun bearing?
- Which Wire Harness OBD1 or OBD2??????
- Idling in higher rev
- Need sum parts help wit my honda civic lx sedan 2000
- just picked up a sol...
- Where to buy axles? For 99-00 Si
- B16 in to EG
- difference between 99 si and 00 si
- more hatchs in one color than the other?
- WENT TO SPARK RACING>>> VerY PLEASED
- Where can I find a windshield washer?
- Brake Bleed sequence (EK)
- will gsr fuel regulator work on civic ex
- got in a wreck. should i try this?
- another IACV just a quick question
- Question on TWO Bottom Tranny Bracket
- how important is fpr for sohc spraying 65 shot
- help with steering wheel.
- Spotting: Silver Hatch on 309 N, had HT sticker in rear side window
- civic sir ecu error codes need help !!!
- wut should i do
- D16Z6 with PM3 pistons, what static compression??????
- Spring Help PLEASE>>
- OBX coilover dampers
- my eg civic cluster...help.. (searched)
- axles in a 94 civic!!
- 93 CIVIC CODE 17
- Heat Shields
- car wont start
- A/C question
- Replacing the cams!!!!
- dc sports lower tie bar
- Are there any bad things about the 99-00 Si?
- can some1 pm usdm420 4 me
- Charging system problems
- Looking for a turbo kit that would fit the JDM K20a
- fitting ABS
- anyone got a worthless EG gage cluster?
- How big is the collector on the dc header 4-1 for sohc?
- gauge cluster?
- I want your opinion!
- A/C help
- 2000 civic SI stereo in EG
- Yet another CEL question
- air not working. need help
- 00 civic si cd player in 96-98 civic?
- ?? 4 MOD OR ADMIN ??
- fitment issues with rs*r exmag?
- FS: Zex Cam and Springs for D-series
- is there any other hardware to use to put a lip on *PIC
- EK front bumper removal
- Please help! I need good site for ITR Pistons and vaulve springs!
- instrument cluster
- Allow myself to introduce myself...
- checking ECU codes prob. SRS flashes, check engine light doesnt???
- wiring question
- new to engine swap need help
- code 71
- Del Sol?
- Is this a good deal or what?
- Can I swap B16A into a 96 hatch???
- gasoline POURING out of cylinders!!!!! WTF!!!!!
- vtec porblems
- Engine, ECU name .... Help !!
- D16
- D16Y7----Help---
- New to Honda's need some advice from expierienced Honda Tuners
- Rear eg6 stabilizer bar on eh3 (eg5)
- s 2000 moter
- smog test?
- re-threading ball joint
- B16a2 w/cable tans into an ek
- Where can i get the Edelbrock Performer X?
- what is this part called? 92-95 civic coupe!
- bull locking lugnuts
- come on... i know someone wants this...
- Beaks Kit took a sh`t on me...
- WTB: 99-00 HB stock taillights (OR area)
- lmao dynoed my car today.....
- stupid CEL question
- Fiber Images CF Hood... Questions...
- Buying a 96 DX hatch with a quick question..
- Whats all these Apexi ABC-AFCs?
- ARC Intake Box
- I wanna see pics/ instructions of your home made intakes.
- "mini-me" swap D15B7 leftover heads.
- PLEASE HELP ME idle is messed up plus gauges/turn signals wont work!!
- d16 Clutch/tranny proplem proplem
- 92-95 DOHC ZC....whaddya know about it?
- stock airbox ?
- Teamrice.org. hatches. Vids inside
- HELP WITH SPRINGS!!
- ***TRouble Shooting- EG JDM interior (rear seats)
- DIY Black housing headlight question ALLMODA plz help
- Got my swap done!!!!!
- What is a SRS light for? and what does it mean?
- building an engine
- whats a H23 in a EG run?
- showoff your EG+ hatch's........no comments just pics so everybody can see
- ECU crap?? SOHC guru's come help!
- dohc vtec valve cover bolt into b18b head?
- will an LS dizzy work on a B16A2?
- anyone use exospeed cams?????
- All Indicators on Instrument Panel Stopped Working
- 99-00 civic SI / 97 integra GSR
- headlight aiming
- Toe Problem. Toe kit fix it?
- Baby Steps? Whats next?
- What does a bad cv joint sound like
- would the o2 make the ecu red line at 7500
- JDM Civic Question
- clutch is stuck to the floor
- am i thinking correct with these wheels?
- DEL SOL CARBON FIBER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- limp mode? after obd2a-obd1 conversion need help!
- help reading parts diagram
- How To: Si swaybar on your civic.
- what do i have to do to my engine to run my turbo at 29 psi
- NGK Wires?? Where to get...
- 6th Gen Front Swaybar install question
- help..my radio stopped working!!!!!!!!
- Custom exhaust So Cal
- factory seat reskinning???
- Type R cams + Edelbroch Turbo = ?
- seat question...not a repost......
- wobbly wobble
- VIS carbonfiber hood review...
- new shoes
- Any place to rewrap seats for cheap in Orange County?
- engine swap ?
- Rotor Rotor
- Springs or Coil-overs: Give me YOUR opinion!
- dc2 a/c fan fit in an eg? (searched already)
- Batfa Japan
- Surface rust need help
- can anyone help me out on this
- anyone recognize where this bolt is from?
- Good website to purchase some rims.
- o2 sensor..new or used?
- carbon fiber hood
- hondata installed, but dumping fuel like mad!
- K26 Turbo??? Have you got one???
- SWAP QUESTIONS!!! PLEASE HELP ME OUT!!!!!
- going fast or down long hills in neutral bad ?
- Ricer CTR Key question
- EVERYONE!! YOU MUST SEE THIS!!
- 92-95 lip.. i am trying to find out what type it is....take a look please
- little tach prob.
- 4 wire to 1 wire O2 help....
- HELP: Looking for Used Honda Parts
- eBay seller: gtmotorsport3 aka Tad Huang
- full tank of gas = sagging rear?
- Please help me out about my fuses!?
- newbie with a question
- Wheres That Guy who sells the carbon fiber hoods?
- b18c5 build plans - gasket questions and suggestions please
- NITROUS when is it legal?
- i need a 97 del sol front bumper!!
- lowering stock??
- Swaybars?? which one to get??
- WANTED!!! stanley side markers for an eg6???
- Anyone with an Eg from Thailand?
- where to buy mount inserts??
- 94-97 teg console fit in a eg hatch?
- drove into puddle. need help!!
- checking for codes on a del sol?
- is it my tranny or cluch
- SOHC VTEC
- takin out my back seat. whats should i put?!
- GSR Fuel Rail Vs LS Fuel Rail..
- Who's got info on: 2002 HX (d17a6) Motor?
- Help me out plz!!
- already searched but no results.................
- help with my avatar
- anyone have jdm fogs for ek4 sir bumpers???
- Question for those that did a Swap and kept A/C
- Help Please !!
- LS Swap Main Fuel Hose Question?
- EK owners with type r 4 lug conversions
- Aftermarket Intake Manifolds for SOHC?
- WHo would win the race.....???
- roll cage
- Swap-able parts...differences between B16 to B18c5..... ??????
- azenis being street legal
- eg driver side glass
- si injectors size?
- brakes locking up after master cylindar/brake booster upgrade...did search
- will an Integra CD player wire into our cars?
- B16B Transmission
- Quick question about B16A3
- Civic Si e-brake arm question
- 1996 Civic engine swap
- Gauge Placements? Any ideas?
- Headers??
- K Series Motor Mounts?
- can't find a lip, what does everyone use?
- anybody in the tri-state area selling eg+hatch....?
- just picked up last week
- d16y8 oil pan on a d16z6?
- Did my fuel pump take a shit?
- CEL Question....Stupid, I know, but I need to know the answer
- New to the Forum...please help!
- rear toe adjustment. need answer quick.
- Smoking 92 Hatch
- Head Gasket Replacement, Should I do the bolts? Advise needed...
- tyc 1 piece headlights 92-95 civic
- Is my mechanic trying to sell me on something i dont need?
- Which ECU to use with JDM D15B with bolt ons?
- EG6 Sunroof Question?
- Potenza G009's or Potenza RE950's for my EK hatch in Rainy weather???
- 97 CX, DIY free CAI
- stock block ls/vtec opions wanted
- DIY gauge/accesory mounting tips here *pics*
