View Full Version : Honda Civic / Del Sol (1992 - 2000)
- AC HELP!
- A few suspension questions.
- eg benen b-pillar in a 99 ek?!?!?
- please help a noob
- Really Odd Brake/Idle Problem
- Help identify to wires under dash in 97 hatch
- How to install a genuine Mugen Wing on a Del Sol ?
- Guess my HP!! I'm too poor to Dyno it:[ help me out
- Leaking on passenger side floor
- New B18b swap in my eg what to do??
- d16 timing belt on d15?
- not having credit sucks!! motor swap loan not approved..
- auto to manual B18C1 swap question
- B20/VTEC, what timing belt to use? Need quick answer
- Need Advise on Injector size ls-vtec??
- auto trans shifting @ 6500
- Can EK axles fit my EG?
- Engine Temp needle not working!
- ek gas tank
- Weather Stripping Question?
- Crap fuel economy
- 1997 Honda Civic EX Help
- Someone plz help with my koniY/GC!!
- !!!!!!!!! Stolen Hatch Omaha Area
- If your EG (or whatever) gets jacked, here's how to NOT get screwed by insurance...
- fried ecu
- Suspension need help
- VIPER ALARM KILL SWITCH PROBLEM
- Car cutting out at 5500+
- Tightning up Suspension
- First time swap
- Vtec won't kick in help!
- 96 Del Sol springs on 97 Civic?
- Can you block the Fitv on a 95 civic?
- 1997 civic w/ 1999 civic climate control
- AUTO radioator on MANUAL car?
- urgent help need
- Need Opinions Might Buy My First Civic
- Wiring questions
- where is ignition switch connector
- wiring diagram
- Compatability of EG and EK Front LCA's?
- b18 in civic suspension question
- spoiler for ek sedan
- HELP!!! my cluster stopped working.. 98 civic dx
- A/C compressor smoking and A/C not getting cold.
- true or not???
- Quite possibly the most annoying idle problem evar.
- blowen motor
- SMOG ISSUES
- Colors for an EG hatch?
- help with passing emissions
- b18 ls problems
- How much
- URGENT Please help - working on 1998 SOHC civic this weekend
- Rota concaved grids
- Thrust washers on a D16Z6
- My New Bubble!!
- Recurring CEL 1998 Hx
- Z6 timing cover problem.
- wiring harness issue, need help!
- OEM spring Rates?
- Civic HX Blown Headgasket
- shakey while braking
- Radiator Hose Pressure?
- Best shocks for OEM replacement??
- What Cams for my N/A motor
- O2 Sensor
- Solid Rear Lower Tie Bar?
- Motor swap advice
- Help Please Motor Problems!!!!!!!!!!!!!
- Help Idle Problems!!!!!!!!!!!!!!!!
- $1600 to spend in EM1!!!!!!
- smog check
- Need Help!!!
- problems with my em1
- need help rear bracket issue.
- What do I need?
- Engine automatic shut-off when it hot...???
- Problem with Clutch pedal / getting into gear
- Which stock suspension for my EM1
- Just replaced head gasket, now hesitates in 3rd at 3000rpms
- ebay EK4 / SiR lip review
- 2.75 inch filter with a 3 inch intake pipe?
- Weird Noises... chirping and whining
- [DIY] OEM 92-95 Honda Civic Lights-On Chime Retrofit (no RadioShack crap here, folks)
- d16 zc trans swap help!!!!!
- Y8 trans swap
- Need help with replacing my windshield
- Have Anyone Heard Of Yonaka Motorsports Coilovers
- no hoist... advice plz
- tire and rim question
- eg rear disc brakes on ek
- Got tuned yesterday. Kinda
- 6.5 or 6" speakers on front Panel 96' Civic???
- 4dr eg head light fits hatch,?
- Differences in oxygen sensors
- honda cancer/srs light/Chicago meet
- Ignition timing drops?
- Wheel Spacers on Diamon Racing wheels?
- can't rev past 4000 rpm, limp mode???
- sticky throttle?
- New Potential Honda Owner, 1998 Civic advice?
- Camber Question
- Floor Board Leak problem HELP!!!
- 2000 Honda Civic HX Automatic = Broken CVT Tranny
- how to replace a flywheel
- CRANKS BUT NO START! HELP!!
- Fuel Pump
- Del Sol Running Like Crap NEED HELP
- HELP!!! Cranks But Won't Start, No Relay Click, Or Fuel Pump, CEL
- CEL am I reading this right?
- D16y7 manifold to y8 manifold HELP ME!!
- K20 Eg CX
- Auto to manual conversion
- What now?
- How to remove the air conditioner?
- Strange ? Replace only 1 pistons rings and bearings
- Need help finding a part
- Weird noise comming from crank pulley?
- diffence in rsd and lsd rack and pinion bushings
- 95 eg cx - starting problem
- Best tire for stretch. 93 civic
- HID's with daytime running lights?
- Experience with PW JDM Fenders???
- Engine automatic shut-off while driving...?
- wheel fitment NOT aesthetically appealing
- TypeR wing (Brakets)
- Need help diagnosing a phanton coolant/overheating problem?
- Y7 fuel rail on Y8 intake manifold?
- Battery terminals
- JDM bumper for 95 civic
- jdm bumper 95 civic?
- need oil dipstick
- Gas mileage
- TYC one piece projector headlights on Ebay. Fake?
- weird coolant leak with new hoses
- CP-F Help!!!!!!_______
- having issues with motor swap
- need help with tuning
- 99-00 Civic Climate Control conversion for 96-98
- knock sensor on the 98 coupe
- bought a 98 coupe about a month ago
- input shaft play, how much is acceptable?
- 96-98 civic half nose mask
- d16y7 to y8??
- whats the best oil??????????????????
- ebay steering wheel
- Should i paint my hood and trunk?
- Hit a bump, car wont start now, FML!!!
- help with b16a !! plz.
- JDM Fog Retrofit???
- 2000 Honda Civic DX SE Hatchback Body Type
- Best 195/55/15 Tires for the price?
- KNock sensor delete ?? ECU decision
- Exhaust manifold smoking help!
- No power to ECU
- will type r b pipe fit 95 Si hatchback?
- 91 starter in 92-95?
- skunk2 pro series coilovers---help
- Oil loss. No Leak. No Smoke.
- Wiring up Vtec to ECU help!
- 95 civic ex a/c clutch not engaging
- gsr swap
- looking for d16y8 cam
- re-painting my meshys, color opinions needed
- just a little somethin for the noobs...
- sedans and coupes
- ENGINE LIGHT ON PLEASE HELP
- Picked Up a 96 CX HATCH!!
- ek hatch lift trunk supports?
- cruise control on an DX/HX/CX
- sensor error
- Hard time finding 96-00 rear carbon fiber lip for 2dr/4dr civics
- Del Sol Auto/Manual Conversion
- K Series worth it?
- ObdII for Smog
- Sputtering and stalling out? What may be the problem?
- Tail Lights, Turn Signals and License Plate Light are out.
- How to pass inspection with a b18 swap
- EM1 need help finding side skirt and fender clip!
- would crx skunk shocks fit an eg?
- Shift Linkage Backwards? Clutch Problems?
- what should i get to tune up my suspension a bit
- alternator relocation for my civic...please help
- oil catch can????
- CEL light goes on and off?
- EG8 with straight Pipe
- D16Z6 Mounts
- Fog Light and A/c Light Fuse
- wreck or restore/project?
- boosting my y8
- solid check engine light
- HOW DIFFICULT IS TO DO A SWAP
- Hey guys. been awya a while. I need your help!
- h22a4 del sol help checking cel
- Swappn a d15b w/3 stage vtec into auto 98 civic dx
- How does the Timing go off? Dohc Vtec
- 97 civic ex coupe with a 99 B16a2
- Anyone ever ordered from LTB Autosports?
- Engine harness in RHD conversion
- quick alternator question
- Killed my B16A del sol, help?
- K20a2 sway bar clearance
- del sol bumpers
- Any Idea if this will fit the Del Sol?
- need help, on 97 civic B18a
- Civic Bra
- Stock EG Hatch ?'s
- Del Sol Top Down Bars Up...
- D15b going in 92 hatch...need swap info
- Difference between b20's p75-3 and p75-5
- ECU CODE 7
- 2000 si muffler help
- Help in choosing the correct gear ratio for 1/4 mile..
- idle problems!!!!!!!!!!!!!!
- b16a block and gsr head.
- WTB Complete b16 head
- 99-00 si spoiler fit on eg?...pics?
- HID's into an 99 ek coupe.
- h23 questions.
- asr subframe help
- what rims for a 1993 civic si hatch
- 96-00 civic side skirt options?
- inner tie rod boot hose?
- 97 civic ex gas milage question
- Which model
- damn thuggin thieves.
- Timing belt tensioner spring question?
- New honda guy
- Cluster Light Problem
- Ideal tire/wheel size for eg hatch, autocross
- Motor buy Yes or No ( please help guys quick )
- Repairing hard oem fuel filter line help
- K series
- d16z6 no low end!!!!!
- Civic VX Failed Smog Twice
- water on gsr?????
- opinons on the blox universal muffler?
- whats wrong? vtech not engaging...
- New Wiper help for my ride
- 95 honda civic dx blowing smoke!!!!
- D15B7 Wierd Hot Start Idle Problems
- Need Epic Help with Car Not Starting
- is this a high flow cat?
- What kind of grease under steering rack boots?
- Inner Axle Tulip?
- IAC motor question
- ecu help
- Lowering my car.
