View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 600lbs front and rear springs...
- spoon rear strut fitment, need urgent answer ?
- where to get cams
- does anyone know where i can have bottom end built in Nc
- vss check engine light WHY ?
- what the hell's a PR3?
- (too LOw ?) slicing tires...
- Anyone have info on thos abs and traction control system?
- front strut bar............
- ******************EVERY EG**********************
- Coilovers and Struts
- Metal Scraping Noise During Right Turns
- shifter bushings on new linkage
- Anyone ever bought/sold with I Have An STD?
- suspension
- HELP: Stolen Civic at WSU (michigan)
- Cel code 38
- NooB
- Need help finding a thread
- honda parts
- spark plugs
- Messed up Civic
- si brake install so cal ??????
- thermostat
- need help buying a car
- do they make a Ran air funnel type thing to replace EG head lights?
- Need to resurface rotor?
- Need help Installing Auto meter Water temp guage (searched)
- Type-R sway bars on my EJ coupe 1995 ??? Take a look please !
- springs on integra work on civics?
- swapping a stock b16 need a clutch and flywheel combo
- They stole my car..................
- Are there any del Sol chin spoilers?
- wiring gti-r sr20det into ek
- del sol seat covers?
- Civic Wheel Bearings
- Guys running Skunk2 IM for their B18C
- 94 green cx hatch for sale
- 94 coupe fender...will hatch fender work?
- will a 99 gsr motor fit in a 95 civic ex
- civic d15, wont start times two!
- Problems with LS/vtec
- fields vtec controller
- i need a JDM ITR B18C red valve cover
- oil pan gasket question
- Anyone Ref/Smog with OBD2 Carsound cat CARB legal????
- What ECU can I run a 96-98 H22 head w/ on EG
- Gasket/seal Question
- Short Ram Air Intake for Honda Civic EX 2004
- Steering wheel install.................
- i want to take the srs steering wheel out
- HOW DO I REATTACH MY OBD2 to OBD1 HARNESS?
- An h22 swap into an EK Civic
- NEX coilover kit?
- what are some sites that sell motors?
- wiring my 2-step module! help please (searched)
- CR-Vtec Is it worth the time and effort, If you have one please post.
- h&r springs with 17inch rims on eg hatch?
- 92-95 differences in 2 door to 4 door question
- WTB does anyone have a 1999 red front end for a civic hx two door?
- I need your guys opinion please, yea i know i write a lot lol
- Cleaning surface around water pump
- Looking for intake review. Not the Great intake review.
- What is the best header for B16A2 ?
- grinding noise when leting clutch out.
- What EG models came w/ what options? HELP
- need wiring diagram for jdm power folding mirrors EK only please!
- need help!!!!!!
- Will CTR center caps fit SI wheels?
- Jdm d15b questions
- NEED TORQUE specs for a 98 civic EX LCA and STRUT bolts.
- Need Help Please!!! Manual steering rack noise
- Anybody know where I can get this piece?
- Should I trade for a GSR swapped hatch?
- power to manual mirror question
- Engines for a 95 1.6 vtec civic
- where is it? help with install(s)
- how to tell the difference between alternators
- Type Arrrr head
- questions about eg w/ h22/turbo swap!! help
- Oil In Gas. Help With B16 Fuel Pressure.. -searched-
- HID people i need help
- oil leak from manual tranny
- wtb 99-00 gsr head
- air / water IC setup in a daily driver... opinions?
- VIS vspec II coilover install quesion
- Clutch or clutch pedal is messed up NEED HELP ASAP
- civic hood
- replacing the faces on EK cluster
- I NEED HELP! my GSR in my EG is throwin codes. PLZ READ
- 88 civic hb engine swap?
- problem with ls/vtec in del sol.
- 99 hatch LCA / Sway Question.....
- Rotors on 96-98 Civics
- 94 GSR Holley throttle body on type R mani and head?
- Venom Intake Manifolds
- dc header?
- 99-00 Ex had ABS option but Si didnt
- Witch motors will fit.
- ticking valves?
- Megan Racing adjustable springs??
- What mid-pipe for EG?
- clutches for sale
- which carsound cat?
- need help with gsr, JDM ecu or USDM?
- short shifter making noise
- PLEASE I NEED A VIN # CARFAX! Please help me, i beg you guys
- 96 civic ex with a b16? running a p72?
- p28 ecu wiring diagrams
- fuel pump wire
- Bad Road
- collector and downpipe gasket for DC header
- Where do i put this coin pocket?? JDM
- NEED HELP ASAP
- type R pistons
- v-tech controler
- Will 00 si sideskirts fit on my EG?
- jdm parts
- HELP..push brake pedal, every running light and interior light comes on?
- Stolen crx in nova reward!!!!!
- clutch help
- Turbo sound on my STOCK D16Z6?!
- Help on adding a kill switch...
- Where is that post about "MAKING YOUR CAR JDM!" searched.....
- CF hood
- Rebuilt engine wont start
- 93 DX CIVIC AND 91 SI CIVIC ENGINE PARTS INTERCHANGABILITY AND RACE TUNING ADVICE
- Ls in EG (prolbems)
- Turbo Trouble
- Another iacv problem please help!
- Honda Civic 2004: whistling, whirring sound
- What parts do I need to fit a 99-00 Civic Si Vortech SC Kit on a B18C1 Civic?
- new trade sell site tradrsoup.com
- y8 with ITBs........S-AFC suitable for tuning??
- codes cylinder misfire and fuel system is to lean help?
- Question about the Apexi World Sport Exhaust....
- Sedan Trunk lid on my Coupe????
- DX How do i put a clock in my DX?
- Would a civic coupe door fit a hatchback?
- Oil Drain Bolt Question
- engine question please help
- What type of shiftlinkage would i need?
- guestion about eg h22 swap mounts
- best intake and lowering springs for del sol
- sorry for the n00b question. but need some advice
- Wiper Problem
- Wanting to BUY a Del Sol
- gsr set up
- Where to post
- 96-98 P2e ecu question
- 14" steelies over GSR brakes?
- ECVC
- n00bie, Civic VTi - 1997.
- 2001 civc SRS issue
- 93 honda cx head or engine trans swap
- Failed MD emissions today got a question?
- EG Frame Lock
- help
- piston slap versus a bad wrist pin, how to tell?
- vtec does not kick in
- All wheel Drive CIVIC OMFG
- Clutch Master Problem
- Let's have a moment of silence for a $465 K20A
- Timing Marks....
- :octane question??:
- driver side spindel
- NEED CRANK PULLEY
- vafc on my setup, will it help?
- Need HELP!!
- Racing Seats
- 96-00 Civic and 94-01 Integra (not R) hubs Interchangable?
- got my window smashed last nite
- Anybody have directions on installing a resistor box on a 00' Si
- ITR rear swaybar similar to SS techniques rear sway bar?
- compression ratios
- DIY ITB ????
- 99-00 b16 hydro tranny vs 99-00 gsr tranny???????????
- Is this turbo kit worth it??(had it in FI but no response)
- b16b vs b20b vs b20z
- b18 bare block?
- 99-00 foglight info
- Clutch squeaking in first
- 2004 civic LS.. 124hp
- Thieves scoping out my ride.....
- cat/test pipe
- Brake lights......help
- Gas Guage does not read full when full?? Only reads 3/4 full?
- are ABS poly plastic OEM bumpers good?
- Car shut off and now wont start. Need some advice
- question bout installing rotor
- poor mans type r
- Engine problem
- car trouble
- trunk release switch removel??
- cant get axle in all the way!!!
- EG coupe, hatchback bumpers the same?
- Would you trade for...
- CLUTCH SLAVE, NEED HELP ASAP!!!
- D16Y7 98 HB: My cat is clogged, what other options?
- Whats the size of the gas tank in a 94 coupe?
- 2000 sideskirt on 1994????
- R33/Skyline/Omega bumper 2 peice, where?
- weird smell coming from my engine
- Stereo, What stereo?
- stainless steel clutch lines
- B16A upgrades? Where is the best place to start the upgrades?
- P08 ECU
- Cold idle problem
- wiring issue for my del sol tach
- How to wire LED washer lights on hood???
- Lips for EG9
- Gas Light in EK
- EK's with weathertech wind deflectors
- oh god please help
- Integra Exaust?
- left front suspension problems....
- full exhaust help
- 1.5 Del Sol HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- CTR
- alternator on B16 in EK?
- can I turn this over?
- i got carfax
- any place with free engines? (socal)
- question for all the VSMers
- cam gear
- HELP! burning coolant, smoking radiator, bad idle, no overheating..*sigh*
- water pump question
- Any problems with KYB AGX on Skunk2 sleeves over time?
- z6 distributor on d16y7
- Intake for a 96 civic with a B18C
- mini me in a hatch
- 1 piece body kits
- does anyone know how to installing ctr mugen air box in my eg6
- LSD
- oil loss help??????//
- Oil Pan Bolts???
- how to get rid of SRS light on EK?
- exhaust system question - wanting to make a custom set-up...need help with parts needed.
- idle air control valve
- Sparco Pedal instalation, help plz!
- 97 civic ex coupe
- stock 94 cx with ex tranny vs del sol d16 vtec turned off...
- fuel hose for coolant?
- LS/Vtec Del Sol project
- strange smell from exhaust
- best headers for a b16a2
- Quick ?
- exhaust option for a del sol...
- WTB: 92-95 Honda Civic HB
- my cd player stopped working someone help?
