- B16A2 Swap Into 92 Eg Hatch, Need Expert Help
- B16 swap in ej1 QUESTIONS
- primary o2 sensor wiring
- vtec not working on gsr in eg
- HMotors K20 into an EG Parts List
- need serious help
- changing out rack & pinion
- gsr and ls tranny specs
- Gauge Cluster/Climate Control Lighting
- Import Auto Pros
- 94 Sol Si, SRS Light on all the time!
- How to Identify OBD2 tranny
- what color wire?
- 1996 civic cx
- Engine Harness Problems
- stupid question
- 92 civic si owners help wanted:
- Close
- B20 into EG Anything im missing guys?
- b16a1 in ej1 smogable?
- Need engine swap suggestion for good mpg and performance
- Opinions on my upcoming build!... **CLICK**
- Wich Header and Exhaust?
- b series transmission
- eg dash trim removal damaged! help
- Function 7 sway bar bushings installed how?
- Cable Reel/Clock spring question
- Has anyone ran 100w bulbs in either Depo or Esuse foglights?
- 1995 Civic Si Rear Window Spoiler
- brake line tuck
- suede
- how to remove dash from 97 ek coupe
- post your race car picture and motor
- strange noise when braking
- door lock help
- integra tachometer problem
- anyone using block guard on b series?
- ** No clue what year transmission i have **
- ITR rear bottom cushion
- Is $2k realistic to build bottom end?
- weird idle problemo
- '94 Civic DX, taillights/gauge light problems
- 6spd swap into a B16
- Right section for a newbie ??
- too cheap to buy 2 itr cams.
- D16 not getting fuel.
- HELP!! No Vtec and No CEL
- 96 civic wont start
- Fulll Wire Tuck?
- dc an ek
- 99 civic dx idle issue
- oem honda & integra parts
- mini me starts, but wont stay running without gas
- 96 Dx to power window conversion
- BRAKE ROTORS????
- Main Cap Housing Bore? B20B
- ITR strut mounts on EG
- honda terms
- I need help drilling these 2 holes
- coupe exhaust on hatch
- Accurate info? H22 OBD1 to OBD2
- new to honda tech..
- starting problem
- PROBLEM WITH SWAP
- check out pic of my oil pan
- ek sideskirt on eg??
- quick eg ecu question
- Parts needed for B18c swap
- vision seat rails
- safe or not is the question
- Vtec problem
- Sunroof glass removal 98 civic ex
- lazy tachometer question
- winter rims for 96 honda civic si (canada) questions
- Different Trims
- driver side window help
- Front lip for 96-98?
- car won't start need help
- Overheating issue
- should i get this lip???
- Exedy Stage 1
- wanna go h-series on the ek
- D2 / Skunk2 Springs and Camber Kits
- HID question
- swap is done, now just have a huge problem!!!
- Need help!!auto to stick srry if wrong section
- engine sometimes wont turn over
- Wiring Diagram
- B16 map sensor
- d16z6 engine turns over but won't start
- GSR Tranny 5th Gear Problem
- y8 oil pan question
- My 1997 Midnight Purple Ek Hatch "Build Thread"/Project Stupid Kids
- Eg foglight problem. Please help.
- d16z6 into a 96 hatch
- VTEC Solenoid for F23A1
- how do i put power steering back into my 95 coupe
- Clicking sound when I open driver's door - what is it?
- 98 ek high idle
- Difference between 98 and 99 EK hatch rear interior harness
- eg ek
- how to make vx fit rear integra disks?
- CARBON FIBER......
- Does a 94 Integra swaybar fit on an EK?
- My true ek9 update
- Purple Ej1 please
- Build for my ek!!
- RHD conversion Questions
- 94 Civic hatchback will crank but not turn over
- track r/sir b16 swap
- missing reservoir question
- Radio volume goes crazy when raising or lowering it. Resolution?
- feeling the vibeee. please help.
- HELP WHAT K SWAP MOUNTS ARE THESE?
- P30 ECu Sell or Trade
- Honda Manual Transmission Oils
- My car eats batteries
- d15 non vtec to d16z6 please help!
- MY old civic EX
- Honda civic hatchback?
- 93 del sol body kit
- b16 wont turn over....
- GSR...need assistance..
- please please help me troubleshoot my engine cooling fan issue?
- which tranny is better?? LS Si or Gsr ??
- p75 or pr4
- Bouncy Idle
- Should I do this trade???
- H22 in EG/ H2B/ Axle allignment
- 99 Civic LX Radio Power Wire
- HELP Engine IDLE problem acting up sometimes
- am i screwed?
- Replace sump gasket??
- auto D15b engine problem help..
- cluster question
- Heater Hacked and Blower only Works With Radiator Fan
- OEM rear lips for 96-00 hatchback
- Transmission noise
- YOUR opinion on RHD conversion..post it
- Real EDM 145MPH LSi cluster, what is it worth?
- B16A idling issue and RSX type S seats!
- An idea to curb car theft
- Help re: transmission fluid
- need help on the removal and replacemont of A/C Pulley
- Going to pull engine; anything I should be looking at/for?
- GOOD DEAL?
- The starter motor works but the car won't crank
- 95 dx 4 door cooling fan not turning on
- THROWIN CEL 43
- Code 6, ect sensor/leaking oil pressure sending unit
- dsm injectr questions wit hacked afc2
- bestfriend's ek9 got jacked lastnight
- NEED HELP!!
- why do people
- Brake lights problem
- DC2 airbox on EK4
- Rear defrost not working. Switch light inversion.
- 95 civic ex - speedo flutters and doesn't show the right speed
- new in here
- BYS risers
- why am i burning oil???
- cheap keyless entry WITH aftermarket alarm?
- B16A2 V-Tec cuttin in and out!!!!!!!
- Exhaust Buying Help (D to H series eventually)
- "Red" connector for the air bag
- new problem with the 97 civic lx fan won't come on till 3/4 hot
- What's the best way to "clean the inside of the motor.....
- Need help with turbo for B18 engine
- Clutch Compatibility
- help: tranny question
- BISIMOTO STAGE 3 CAM VS CROWER STAGE 3 CAM? NEED HELP!!
- Integra dash and door panels onto eg???
- EP3 CLUSTER ON EG???
- need help with my exhaust set up
- turn signals not working properly
- CEL code 67
- CAR DIED! P0170 and P0171
- b20b in eg hatch
- Anybody running a Flowtech catback?
- !!no start no money!!
- will rims of a 2001 fit on my eg?
- Newly Bought 94 Eg Maint. Crank Pulley Holder
- noob question
- My introduction thread
- Need Help with 96 Civic Misfire
- Quick o2 Sensor question.
- will 2006 civic rims fit on my EG?
- Integra vs. EK Civic rear upper control arms
- skunk2 coilover sleeve with agx adjustable ?
- Fresh swap not running. updates and video!
- quick stock intake question
- b18b1 swap into a 99 ex questions
- ::..New Suspension setup..::
- JDM D15b swap questions 56k no no no no
- d16y7 cel code p0505. tricky one!!!!!
- PLEASE HELP!!!
- Ingtion timing problem i believe help please
- how do i take out the pass. air bag on a ek
- question
- turbo em1 Injector question
- f22b2 Shaking [Seems like car is slower]
- 2 Step Launch Control???
- Del sol brake problem
- exhaust manifold
- What Pistons Should I Use On My Mini - Me Swap?
- Tire spins in N on jack??
- SRS light on... need some help
- Bearing Clearances? (pics inside)
- FML Overheating. Searched....
- how do i check the transmission fluid level in a ex d series trans?
- Main Relay Question
- d16y7 intake mani.
- will rsx 5 lug work on eg
- Building of a B18.
- vtec popping
- this bar thing
- NEED HELP IDENTIFYING A SENSOR ON MY CONDENSOR 94 EG Si ASAP PLEASE!
- What is the next step?? Pretend like its your car!!
- si grill
- car turns on only jum starting it ..help
- obd1 pr4 or p75?
- Wanna go K20 in my 92 eg hatch but dont know where to start???
- Auto Vs Manual Engine
- D15B or D16z6
- dropzone gen 2 review
- Type S cluster into Ek
- Oil Pan Install Help
- idle issue
- REAR DISC CONVERSION QUESTIONS!!!!!
- Mini me using p28
- HELP! ASAP!
- Idling diagnostic? Help!
- keep bumping this to the top till its solved thanks?
- WHAT ARE GOOD MUFFLERS FOR EK's
- Front lower tie bar fit on my civic with h22a swap?
- JDM Headlights Bulb Replacement
- fuel injector q?
- swap swap swap
- 93 civic with b20 vtec dont satart
- cam gear
- Clear or Yellow fogs?
- trouble with D16Y8 mani swap
- Ebay For Parts? How Bad Is This?
- basic parts for my b18c swap in EG
- 89' integra pistons
- THE absolute most quiet exhaust
- what throttle cable to use?
- '97 HX Stalling at stoplight
- Can a 2000 Si run a +37 offset?
- 99 civic EX problem. not sure what.
