View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 99-00 coupe rear bumper difference between 96-98?
- Fuel Pump/Fuse Box
- BOOSTED 2000 SI SPUTTERING/MISFIRING
- swapping seat rails
- 2000 civic ex D16Y8 into a 1998 civic ex.
- EX engine harness 02 Wire colors
- 99 civic ex mini me swap starting problem
- ek4 b16a2 with chipped p06
- 1996 Civic wiper problem. possible fuse box issue?
- Help with removal of D16y8 valve cover bolt seals
- 97 hatch wipers don't work help
- 98 civic ex has no electrical power
- 94 dx E-Vtec not passing smog help please
- Thoughts on eBay parts
- 95 dx coupe tips?
- EM1 Sunroof Leaking, and trunk wet..
- Odd vibration
- my civic ex stalls and dies
- How to do 2000 front end conversion?
- cel 43 fuel supply system, dont know were to start, help?!
- EG CF duckbill not sitting flush - flipping brackets?
- In need of a source for Quarter Panels on a Del Sol
- 96 CIVIC ALTERNATOR PROBLEM
- question about wiring city/parking lights
- More aftermarket radiator dilema
- 96 civic engine kinda shut itself off while im driving
- Crank Pulley Bolt not coming out with Impact Gun
- High idle when IACV plugged in
- TPS calibration problem
- 94 civic 4 door having trouble starting, please help
- car has dead cyl when negative is connected
- i have no clue what i need for a b16a2 swap
- engine build suggestions ideas help
- ECU HARNESS CONVERSION????
- car gains tha same in 5th then if i down shift to 4th?
- Brake problems. Help before something happens..
- Dash Rattle and other parts of Eg
- dc sports gsr header
- Rear brakes always on. Dash light is off. Handle has no pressure on it? help please!
- What's the stock 98 LX Sedan Lug Pattern?
- At a loss, car won't start, tried everything it seems... PLEASE HELP!
- clutch line fitting and brake line fitting sizes? please help need to know quick
- quick headlight and rear brake conversion question on del sol.
- 97 civic Strange shudder
- 98 Honda Civic dies after coming to a stop
- Is there anything I should grease on my 2000 EM1?
- help! car overheating & fan not turning on
- please help me with radiator hoses
- Diagnosing back bumper oil staining
- Check engine light help
- 96 civic ex with dome light/electrical issue not working
- would a honda civic 2000 start without oil?
- Replacing HX flywheel
- will del sol rear disc work on 95 coupe?
- 92-95 Civic front bumper cover
- 96 Civic PRNDL turns off when i turn head lights on
- z6,with 2000 y8 mf turbo iddling problem help asap
- D15B7 wont rev past 3k rpms!! im stumped!
- Need more FB votes!
- ? no start ?
- solid mount help?
- SRS removal
- Honda Civic battery tray
- 92 Civic Hatch CX
- compression test issues - important
- obd2b harness question
- Brake issues on EK4 Please help.
- 93 hatch dash light issue. Help?
- Hood Alignment
- Threading of thermoswitch and heater hose connector
- b18b1 motor swap clutch pedal help
- 98 Honda Civic EX Lock up solenoid?? Help!
- 1992 hatchback SI - need input on mods
- need 95 5spd engine
- Del Sol - main bearing in S20 transmission going out
- Clutch problem
- New drums, shoes, springs - pedal pulsates when braking
- 2000 Civic Seatbelts question
- Normal readings for STFT and LTFT
- Picking up a B18b1 - what should I look for?
- BEST performance ecu for B16a2?
- which type of plastic is the 92-95 96-00 upper steering wheel column?
- Quiet time...options?
- What Clutch should i get for stock 1995 civic eg9
- which rear t bracket will fit jdm b16 on 93 del sol si?
- EK Sedan Lock Problems
- D16z6 mild turbo
- very soft brakes
- Intermitant rough idle with smoke
- EG Coupe w/ B16A throttle issue
- Need a flex pipe, have a couple questions.
- 1999 EX Cruise Control Sticking
- some pics of the ej7
- 2000 Civic SI loose O2 sensor ground wire?
- Piston/Rod combo - advice/opinions
- diy front lip for 96-98 civic?
- Civic shifter moves forward at WOT, clunk noise
- '92 Civic VX won't pass emissions - high HC reading and NOx
- Advice, Mini me & looking for a MN honda person
- Car idle high!!
- How to know if your clutch is going bad?
- EM1 Green dash plug next to ecu pin out
- 97 CX manual conversion/wiring
- Is the cold air intake illegal in CA?
- Heat is not working!!!!help
- Timing Belt Won't Turn? Tight and not snapped
- 98 ex d16y8 Wiring harness work in a 98 lx d16y7?
- Need help on z6 swap
- My 1997 Ex Turbo Build
- I NEED HELP BAD, SWAP GONE WRONG
- Cluster/Climate control wont light need help
- Electrical Load Detector Question
- Idle and Timing Issue -HELP- Lots of INFO
- 98 civic fuel pressure
- Bolivo's Build !
- start car and attempt to drive, but wheels don't move
- honda civic 2000 ex instrument panels shut down, engine does not start
- Rack & Pinion Power Steering Leak
- No spark b16 in 93 Si ***PLEASE HELP***
- Cai bypass valve question
- 94 Civic CX/d15b7/p06 ecu - cel code 7
- Trying to fix EM1 foglights.. Smh..
- The best oil and antifreeze for civic 98 195k
- Why does my car Idle such at a low rpm .5k rpm -.-
- Just bought '95 Del Sol, automatic transmission question
- Cel Code 4
- lost motion assembly pn's and compatability
- How to correctly troubleshoot your troublesome CODE 43
- 1993 Civic Si - Revving Issues at IDLE
- fenco new flywheels any good?
- are all obd1 up tranny torque brakets the same??
- Car running lean - Very strange scenario - experts only
- Energy suspension motor mount inserts...
- random voltage drops
- Battery cleaning question + alternator test
- Solid CEL, but car still starts. Need some advice.
- Stupid shifting mistake, now car is running strange
- OBD2 to OBD1 conversion?
- 93 civic lx d15b7 - rpms jump around and stalls when i give it gas
- 95 cx - should I swap the engine or fix the head gasket?
- Would exhaust from an 02-05 civic si fit my 99-00 civic si?
- Please help with wiring for z6 swap into 96 ex coupe
- EM1 dash/sunroof question
- MSD set up help!!!
- What's a good diagnostic tool for a 92 Civic?
- Could I use my srt4 injectors on my honda (they're rc 750s)?
- Ground wire of 92 Civic door switch?
- Remote Start/keyless/alarm on Sol 93
- D or B tranny?
- d16y7/y8 crank sensor
- Sooooo... I pulled the valve cover on my new GSR swap......
- Kent, Washington -- Parts stolen off my Eg civic coupe!
- Has anyone ordered a swap from JSH Motors?
- Check engine light.
- Engine swap, or buy another Civic?
- Does anyone know of a good company that repairs ECU's?
- Quick Clifford G5 help
- Creaking noise in front and rear of Honda Civic
- What do u think of ACT?
- Can't get cruise control to work after reinstall
- em1 competition clutch problems/adjustment
- Ecu Shopping
- 1998 LX won't start - died at the light.
- Yakima roof rack making my door leak.
- NEED HELP! PA state EMISSIONS.
- engine stall when accelerating
- BAR'ing my GSR swap
- 00 si temperature needle
- 95 Fog Light Help.
- After clutch install, not shifting into ANY gear with engine on
- 96 D16Y7 swap into 00 civic - wiring problem
- Speedometer Stopped Working
- b/7z6 help. wont start after head swap
- new 96 civic ex with a speaker and shifter problems
- Problem after cleaning throttle body.
- Poly inserts = wicked vibration.
- Need mini me help
- P1456/P1457 Codes
- Need Help Please Car wont rev past 3k
- headlight/fuel sender problem '95 civic - schematics help?
- D16Z6 camshafts
- 93 Si vtec to non vtec, wiring issues?
- 93 del sol bushing kit
- Timing affect performance
- 98 Civic LX - nearly all brake parts replaced but pedal still falls to floor
- 00 Civic Si: Why do my Tail Lights have major stress cracks?
- Anyone know dimensions (length/diameter) for b-series alternator bolts?
- 1997 Civic Dx Hatch exhaust question
- Fuse 15 Keeps blowing civic LX 1997
- Mini me, Z6 head and Y8 manifold HELP!!
- Raising motor for more oil pan clearance?! help please!
- stripped headstud bolt!
- CEL code 9 help
- voltage regulator problem?
- p2p ecu K01 only one oxygen sensor? pics
- 96-98 climate control trouble
- GSR into cx hatch - EVAP system question
- 2000 civic starts then dies
- Moving ej6 around shop w/o spindle nuts and axles assembled
- 96 LX ignition issue, weak spark, tested and or replaced everything I can think of...
- PCV Question
- d16z6 dowel pins??
- Need some advice on quick struts, rotors etc..
- ek window visor installation
- HELPPP car wont start!!!!! :mad:
- EM1/built B16 -- Buzzing relay, car wont start
- Downstream o2 effect idle?
- Failed Smog Test. NoX Too High.
- CX Eg brake conversion
- Outer window molding issue 2000 Civic
- map sensor issue
- Any difference in a d16y7 engine harness between auto and MT??
- field coil or shim issue... Air Condition 94 EG
- h22 problem w/ fuel pump? and h2b questions
- JDM folding side mirrors on DX EG
- D15b7 Head Gasket replacement Qs (PICS)
- Ek wheel spacer problems!
- 97 STOCK DD AT DX- Rotational "friction" questions-issues...
- jdm d16a what crank sensor pulley
- H22 Civic Back To Stock ???
- 96 Civic DX hatch - Need help! Power window/power lock conversion in my hatch
- Civic SiR - HELP me identify what type of b16a I have!!
- Anybody know where to buy SIR bumpers?
- 94 civic spark plug Question
- 99 civic dx hatch brake light issue HELP
- o2 sensors
- Prepping for y7 head gasket change.
- 98 civic mini-me help
- Not Getting the Right Amount of MPG
- JDM headlight question
- '95 CX Firing(spark plug) Order ---possibly?
- Domani headlight swap - illegal?
- HELP sputtering lots of codes - map/tps/iacv all out
- Del Sol SI - need advice on replacing stolen seats, radiator, spare tire, and battery
- Can't find the oil leak.
- 1999 EM1/JDM B18C TYPE R (CEL 22) HELP!!
- D15b7 has exhaust leak between header and exhaust pipe A - okay to weld?
- 93 civic ex throtle body
- how much hp can oem ls clutch handle
- 92 Hatch Radiator fan issue..
- 92-95, 96-00 Civic interior sizes
- d15 damper bolt keeps backing out
- HELP! TB coolant bypass EM1
- Need honest opinion about high rpms and spinning a rod bearing
- Grooves in brand new brake rotors.
- Another turbo build, need answers
- ENGINE BUILD?????
- What is the bolt spacing on 6th gen Civic fuel rail
- b16a2 94 Hatch Broken Coolant Bleeder Valve
- 94 Civic Hatch - replacing complete subframe
