View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Looks or performance?
- Honda Civic EX Brake Problem
- Trans Problem :( NEED HELP ASAP
- Del Sol Nose Mask Owner please Check out?
- power steering conversion help??
- how to route the intercooler piping
- how do you tell dohc vtec heads apart
- clock spring installation
- OBD2B b16a2 into OBD2A car
- Car is running weird
- possible suspension problem?? eg dx coupe
- D16Z6 performance camshaft questions
- DX come with power steering?
- 3-2 wire iacv
- valves?
- d16y8 valve adjustment
- HELP-ECU Question
- overheat alarm
- Apexi neo/safc/vafc wires to wire colors on ecu write up
- minime help needed
- Sand side skirts or buy new ones?
- SUp with my fuse box.......weird
- B16a2: Does anyone know what this is or where it goes?
- My b18b1 squeels
- my car blew up.
- motor swap question
- B16a idle problems.....just a quick refresh! where to get IACV?
- Obd1 motor in OBD2 civic. Help
- Will this exhaust piping fit??? help asap
- Mud Guard Question 99-00 civic
- will a skunk2 magnaflow fit?
- fuel gauge reading incorrect
- What are these sensors? taken off b16a2 head.
- Need some help with valve adjustment on 95 EX D16Z6
- ek hood bra, which one is it?
- Hello H-T
- Need help want to do away with key and make just push start
- Drove car through puddle now CEL on
- probs. wit my 94 cx
- information on soon to be new motor (jdm d15b)
- head studs
- honda 92 si around atl
- speedo acting funny...
- having a hard time deciding! what color??
- new motor, ecu question (p28 vs. p08 w/vtec controller )
- 93 del sol hood?
- IACV
- quick question about wheel speed senor...
- car won't move
- D15B7 Oil pressure switch DIY?
- NEED HELP WITH AIM & ADJUSTING SONAR PROJECTORS
- Car was stolen... feels like shit.
- F20b swapped eg Gas & Temp Gauge Dont Work
- h23 swap question
- Putting power steering in b16
- need your input
- How can I get a cable from the door into the car? EJ9
- EK smokes
- For sell 93si in Ga
- b16 need help
- advise
- FITV required for D16Y8?
- EG VIS Duckbill owners, is this one real?
- rear disk brake conversion questions please help...
- Quarter Panel and Trunk.
- what needs to be change to safely use E85 in my 95 civic??
- how to fix spun bearing in b20?
- What performance mods should I install next?
- RSX Type S Cluster Into 00 Civic Coupe Help
- Exhaust Manifold Studs Issue.
- any stock injectors from another line
- HELP! running wire from trunk of del sol to cabin. how?
- Crankcase breather systerm for B18c5
- Fuel rail for civic
- Will a cat from a 98 civic ex fit a 95 ex?
- jdm fog lights H3bulb?
- Mud guards for Ek hatch?
- 00 civic cx part number request
- d series shift linkage????
- What's needed to swap in a factory cruise in a 95 DX
- STARTER SHAKES!!!
- HELP!! Car wont SHUT OFF!!!
- my DelSol Vtec wont pass smog
- which is better ls-v or gsr?
- help - car cant reverse. back passenger side wheel not moving
- 96 civic wont start
- surging after swap.help
- y7 to y8 intake and exhaust manifold q's....
- lucas oil stabilizer in tranny
- mini me idea.
- swapping a y8 into ek 4door lx 98
- secondary o2 sensor bypass????
- B20 In EG Questions
- engine problem
- B series swap question
- Um... RE-intro
- 00' EK need to know what its worth
- time for new brake pads
- what head is this?
- blinkers and tail lights wont work !!help
- eg civic body coloured corner grills means prior body damage and dodgy respray?
- Question about stiff engine mounts.
- car keeps dying when engine is cold?
- 2000 civic has issues
- pic request: 92-95 civic h/b with greddy sp2
- Hello everyone...
- oil light comes on HELP!!!!!!
- Is this guy crazy? (he wants $3500 for this car)
- H22 wont start?
- d15 trouble
- Civic Light Problems??
- Discovered some previous body damage on my car...
- do any of you have act 6 puck?
- Motor help
- EK dash removal help!?!?! Climate control swap.
- CEL Code...HT need your Input please.
- ARP Head Bolts B16
- steering wheel
- Wheels
- Need Christmas Gift Ideas - '93 Si
- ls block question
- If I remove power steering... questions
- Trouble Starting 2000 Civic after 1/2 Tank
- which computer should i chip out
- WTF H-T
- A/C stuck on and Wipers Randomly Come on
- Da axles for bswapped eg hatch?
- Stolen Items & Or Cars Forum
- What did this previous owner do????
- Weight of Del Sol vs Hatch
- Low Engine Temp.
- Head assembly problem for D16Z6
- idle issue
- engine rpm vs. road speed
- What's Next after IHE mods? - NEW Here!
- New here... here's ma sol!
- finding a short to fix my battery problem
- Custom vibrant exhaust?
- cel light is blinking and car is shaking
- coolant loss but not overheating
- smoke came out my vents
- front rotor question
- FS:Tokicos off a 1999 Civic EX
- Windshield washer fluid hose broke now fluttering with no power
- d16z6 to d15b help!!!
- Avid mounts vs Hasport mounts
- HELP HONDA TECH!!!!!!
- JDM b16 OBD0 swap into a 98 Civic.
- test pipe
- 94 civic ex window motors
- color for ls meshes?
- Question on CAI (cold air intake)
- Heater fan stops when car is warm!?!
- ebay spoon style mirrors vs jdmshit
- car overheats
- Sub Frame / Cross Member Questions??? NEED HELP PLEASE!!
- soon to order new motor, questions on which ecu to run...
- water/tapping problem
- FAST BLINKER
- NEW HERE =)
- which size Throttle body would be best for my d16z6? skunk2
- clutch and breaks gone
- does anyone know who i can pay to do a wire tuck on my ek
- some advice
- b series header on 93 civic ex! Will it work?
- b16 in eg9 ?
- Thinking about wich exhaust i should buy for My 2000 honda civic si
- Need help car wont start
- aamco paint job???
- How to stop Bouncing like crazy...
- New to honda 95 coupe
- how to wire in and autometer speedo??????
- Failing NO Emissions test
- vtec not working, any help
- B16/B18 turbo
- Spark plug heat range questions?
- is it safe to not use the brace under the intake manifold?
- eg hatch front passeger side issue need help
- Driver Window Messed up on Closing
- 02 sensors
- ls civic vs 09 accordv6
- GOOD TUNE SHOP IN DALLAS
- EGG in the RADIATOR????!!
- 95 honda civic...No Fire To Dist. Or Fuel Pump..NOTHING!!!!!
- Rattle/Flutter sound at WOT under hood
- Hard pull to right and clunking sound?
- oil pressure sensor on obd1?
- what should i do for advance timing on my sol?
- vx wiring harness
- EK Cargo Cover
- question about shocks and springs
- overheating
- need help!!!!!!!!! with oem window visor
- B20b swap
- parts
- What Seats for your EG?
- vtec issues
- quarter mile times for del sol
- obd2b to obd1 help plz
- 2 cat pass CA smog
- oil pan question
- cant get my C.E.L code..it wont let me.help
- All B series vtec thermostat housing's the same?
- T28 Turbo
- 92 civic hatch Vent Window Visor (door) fit coupe?
- climat control 99/00 onto a 96 ek plz help
- Window Problem
- Honda Del Sol starter problem.
- Honda Del Sol
- need help white smoke!!!
- handling problem
- location of b1s2 plug on ek '98
- need help with front lca ?
- ef coilovers onto eg???
- how many catalytic converters on 98 ek
- Which color: white or black?
- 1993 del sol b16a1 swap help!
- Bad gas mileage, no CEL, 95' Dx,auto
- Door Locks Stuck!?!?
- KMS Valvetrain?!?!
- Code 23: knock sensor after warmed up
- Will EK sedan carpet fit an EK hatch
- 15mpg LS/VTEC?
- Is my Oxygen sensor bad?
- JDM GSR+ jdm harness into eg civic
- D16Y8 Into 95 Ex
- Help with mini-me swap
- what should i do?
- EK Shut Off, Wont Start
- helpppppppppp!!!!!
- PIC REQUEST: EK Sedan Sideskirt On A EK Hatch/Coupe
- rebuilding process...
- Only #3 cylinder fires on B20 swap into EG
- New Distributor Not Working
- EK Gurus: What headlights these are?
- Can anyone identify this spolier?
- supercharge or turbo b18c
- 93' Civic DX, temp fix brake light in dash
- what kind of cams should i install in my all motor no vtec b20?
- civic trans what oil and how much
- stupid "changing side mirrors" question..
- stupid "cahnging side mirrors" question..
- Need Help, Code 9 on JDM ITR in 97 hatch
- Alternator disconnected but can't remove
- need a 2nd opinion to my diagnosis (fuel pump not priming, main relay or ign. switch?
- Aftermarket AUX lights for Del sol
- Im STUMPED!! B18b, replaced entire ignition system, still no spark!
- ECU question
- Ideas & Advice For my EG B18b
- How much should I buy this engine for?
