View Full Version : Honda Civic / Del Sol (1992 - 2000)
- NE ONE FROM Seattle Area
- ilNE ONE FROM Seattle Area
- EG hood release?
- Reveiw:PasswordJDM 3 point strut tower bar\2 point rear strut tower bar
- Random Knock Sensor Code??
- Sending my fuel injectors to have em' professionally cleaned
- TODA B SPEC
- which tranny to buy for a b16a2 (p30) ???
- Question about advanced timing and its effect to VTEC
- .>- *Light*'ish damage to front end...Parts? Cost? -<.
- Needed: No start/no spark diagnosis for 92 Civic
- 96 Civic - Moisture in headlight
- Quick opinion appreciated
- What would one pay for a '92 si?
- d16y8 intake manifold question
- Easy Way To Remove Brake Line Fittings
- mini me in progress
- People with password power chamber intake
- strut bar question
- helping my friend lower his 2001 civic coupe this weekend?
- weight distribution
- SMOG
- 15x7 +38mm offset 205/50r15 on EK chassis
- OEM type r lip 99-00
- i need help for my mini-me!!
- advice needed on if i should get into hondas or not
- hey guys new here. just want everyone opinion............
- ebay clutch/flywheel question
- car program
- heater hose question???
- not starting....
- questions about jdm p30 ecu.
- Skunk2 Manifold VS Stock GSR...for daily driving?
- Mugen Body Kit for del sol
- How can I tell what year mt GSR engine is?
- ECU question.
- Q and A HELP I NEED TO KNOW
- Help
- Idle problems...
- Master Cylinder / Brake Booster
- Omni Master Cylinder Clutch!
- good tires?
- What happens if you crank clockwise?
- O2 sensor extending
- Idle Sound
- Idles high
- B18B WITH GSR TRANNY.. PROBLEM WITH MOUNTS IN 1993 CIVIC ?
- B16 non V-tec
- VSS + Code 17 = no vtec..
- Which Header for LS/VTEC???
- So many mods about to be put in how much hp gains?
- Anyone spoon lip sit hella low on their eg?
- engine harness question
- Gutted Interior Painting
- whats a better sohc vtec motor??
- Si hatch convo....come on in ITR guyz
- cam timing on a d16y8??
- JSpec h22....BLING
- Will a b18c1 wiring harness work with a b16a2 motor
- 50mm crankshaft pulley bolt holder?
- honda dealership cant help!!!can you???wheel sticking out
- <~~~STRAIGHT PIPE QUESTION~~~>
- Srr lower tie bar
- Skunk 2 or Spoon???
- EK jdm fog lights bulbs went out?
- Anyone running a Kteller bolt/weld up exhaust system
- injector resistor box
- obd0 motor in an obd2 car i have a couplequestions
- Engine whine
- Full size radiator in Civic hatch
- ek power window, power mirror, power locks, tweeter
- d16a1
- Anyone else have this car alarm?? Need help?
- cams
- prelude 4x114 conversion on eg?
- Finding TDC for each cylinder?
- Need B16 speedo ring gear around differential, questions...
- Should i change my gasket with a new valve cover
- o2 sim
- LCA Question
- i need the fuse box diagram for my 94 civic hatch please help
- Junkyard turbo...95 EX
- what is a GSR cable trans worth?
- LS/VTEC pinging noise
- sighting of a stolen 99 Si i think
- Ordered Legend 2 Piston Caliper But Got Single Piston?
- if yall remember my thread
- how hard is it to bar a jdm b16a in california
- STOLEN VEHICLE: Lowered 1999 Electron Blue Civic Si
- i need a ZC 5 speed cable transmission.
- JDM theme cars
- VSS in rainy weather
- 92 civic suspension in 91 integra????
- Florida heat killed my battery in two minutes.
- ebay clutches
- V-AFC
- got a voltometer??
- What are the differences in a 92-95 Si hatch and a EX coupe?
- JDMSHIT 98 civic foglights worth it?
- Obd1 engine in obd2 car
- My ass is saggy...
- n/a b16a dyno charts
- ***** RS*R GT-II and EK HELP!! *****
- To Carbon Fiber or not? Any Help or ideas?
- 95 civic ex..a few problems
- what affects gas mileage? and what to check?
- porting throttle bodies?
- y 92 VX hatch - possible shift light? or VTEC-E indicator?
- Clutch peddal sits low
- Anyone know a site that sells 92-95 civic trannys?
- 1992 Civic four door, whats it worth???
- grille
- How to test for engine mileage?
- HT members special on PasswordJDM Solid Tower bars
- need to borrow an JDM OBD1 ecu
- 1995 ex coupe wiring diagram?
- making automatic stronger!?!
- Car Trouble
- getting rid of those dealer decals?
- Why do you spend thousands upgrading your 4 cylinder car?
- Whay engine is in my 96 Civic Si
- Coolant lines to throttle body for d16y8 swap...
- need help asap...car will not move out of first or reverse
- Shift problem ... sort of
- turbo ?
- Throttle body coolant bypass question
- Odometer fraud...How to tell actual milage?
- Motor swap shope
- AEM Cold Air Troubles...! ! !
- ALREADY POSTED IN SUSPENSION, NO HELP, PLEASE HELP!!!!!
- will a stock p28 work with a gm 3 bar map?
- A quick question..
- How much do the HX Wheels Weigh?
- GS-R swap...do i absolutely need bigger brakes?
- grey/whitish smoke from b16a3???
- Type R or Aftermarket?
- How to Foglights
- is this legal?
- Are all OEM B-series cambelts the same???
- EG Civic Hatch Duckbills!!!!
- liter/hp/torque conversion
- Skunk2 N1 Exhaust???
- differences between 99/00/01 Civic Si
- jdm ITR HEADERS......
- WTB Work Wheels
- code 14..........but
- EK anyone know how to remove the antenna cover
- 99 Si Help
- Brake wear indicator starting to squeal!
- DUCKBILL
- Need help im blind and tired.....fuel pump cut off switch FAQ
- EG Tanabe Hyper fitment?
- Need some help to get insurance
- Skunk 2 Stage 2s on GSRs
- where to get pistons bigger than 75.5 for d series?
- car starts up by it self
- swapping an B18B1 w/ gsr head into a civic 2000 ex
- what can I chip a jdm p30 to??
- TB gasket question
- just did timing how to do distributor
- engine swap
- Need help with checking a car...?
- New member to the EK and question about power windows
- Valve lash adjustment on 91 Honda Civic!!
- si idling problem
- looking for info on the B16Z series.
- 99-00 Si (SiR in Canada) Rear seats direct fit in EK Hatch? (searched)
- Is a 94 Civic EX prewired for keyless entry?
- bogging/hesitation prob.
- will aem itr cai from eg fit an ef
- failed inspection for lights/exhaust in NJ
- i need struts really bad for my 93 coupe
- in the market....again civic si or v-tec lude?
- 92-95 CAI fit 99 Si?
- Advice on buying 94DX. Owner says there is slow clutch fluid leak???
- help....bolt question
- valve adjustment specs for d16y5?
- Motor Pulsing
- need help electrical problem with 92 civic hatch!!!!!!!!!!!!!!!
- Spoon Sports Motor Mounts
- quick, trying to install part, but need help
- rear trailing arms for sale off integra will fit civic or crx
- Thanks HT!!!
- How 'bout them O2 Sensors?
- Setting stock timing on my B18B
- Need Some Help Fast!! about mounts.
- dimming headlights
- no headlights
- delsol rusted
- Code 41 fix
- projector headligts for del sol
- msd help please!
- Head Removal & Unknown Sensors
- anyone have a supercharged ls in there eg?
- 95 civic cx distributor
- si and ex springs
- new key, not working that great
- integra ls cluster in civic coupe
- Nother Headlight Problem....
- 98 civic dx
- B16 heads question please
- si doors on 96 EK hatch
- Weatherstripping Question.
- RSX Interior in a 94 Coupe ???
- Lift Points
- B16A Swap axle options.
- Temperature is high “cluster gauge, radiator, thermostat, or gasket” ADVICE ONLY
- how the hell do u run a gsr throttle body on a y8 motor?>!!
- dropped moter
- b20 engine mounts, help
- I need someone to do an engine swap will pay CASH.....
- ctr pistons on eg with gsr motor
- 99-00 FogLight Help (searched)
- What does a stock B16A2 put out, whp wise?
- help
- Axleback Exhaust
- what do i need for this swap???
- convert p30 to p75
- 1996 Coupe: Rear bumper cover sitting below white clips??
- LSD problems?
- quick release hubs
- H22 Swap Guide for the Civic EG
- Quick question: AEM cam gear
- pic of GT3 (black) on CW EK
- Question: swapping sedan front for coupe
- Cwest bodykits
- OBX intake manifolds
- sounds like theirs a bird in my car. wtf
- WTB! HX wheels with or wo tires ma,ct
- a few questions on changing oil..
- cel code questions...
- Steering wheel shaking.
- 92 VX -> obd1 GS-R swap. O2 sensor problem/possible fix?
- omg please help ASAP
- Do shortshifter have to brake in?
- Possible Problem with starting?
- Who says front lips aren't useful?
- WTF IS WRONG? ek with P28 ECU dies WITHOUT WARNING?!?
- D-series maniold question...
- 98 EK brake problems
- So. Calif
- Warped Wheel
- Swap questions ....help
- Rough idle while stopped in gear
- Question about spark plugs?
- Best hood to lower under hood temp
- Trailing Arm Problems!! HELP
- pictures of rear tranny bracket fpr h22 swap?
- turboimport.com? (rhee motorsports)
- should i get an ls swap?
