View Full Version : Honda Civic / Del Sol (1992 - 2000)
- so how good is it really ?!?!?
- d16z6 power gain ?
- d16y8 obd2-obd1 swap help
- SRS light for pass airbag... But no airbag!(98 CX)
- Trying to gain power
- about a oil pump??
- gsr with ls internals.
- need new mounts? (searched)
- Got a '97 DX Hatch
- A/C and Heater
- calling all EK owners with apexi WS2
- mug guard solution plz HELP
- Rear Camber kit went from negative to positve 0_____0
- Ek Ctr Wing
- Delsol exhaust pipe fitment
- Optios for activating V-Tech solenoid?
- Car Shipping Companies?
- Car runs lean or rich when it wants too...
- help on my spoiler
- Need help on B18 turbo
- Jsrc on H22a type S??
- Lights pulsating and obd2 code p1298 (eld)
- Putting Idle Question!?!
- question about gas
- help..
- distributor o-ring help please
- One Wheel is sticking out.
- toe bar bolt stuck?
- removed pin - shift linkage stuck
- New Guy here
- Replacing rear trailing arm bushings without the special tool
- Brake cable question?
- need help on eg suspension
- Wierd noise please help!
- someone help please :( OBD? Injectors
- RPM Problems
- Replaced eg's front turn signal bulbs, all four are stuck on... any ideas?
- cam gear adjustments on b16a
- Halp! Rear Motor Mount Replacement EM1
- front bumper insert...
- type of bulb used in JDM del sol fog lights?
- threaded holes in the rotors?
- dx won't drive more than 1mph, please help
- Help with radio
- D-series engine weight?
- J-Series Swap!
- timing and valve lash issues
- 92 honda civic si engine code 43 & 15
- handbrake cable on caliper wont come off...?
- stuttering and stalling :(
- Gsr into ek swap
- Crazy question about motor (torque) mounts on EK
- Info about changing piston rings and cylinder head gasket
- Power doors & windows not working! plz help
- Motor Mount Issues
- I stripped my tensioner bolt...
- engine shut off on gsr swap into 99dx automatic
- Is my Sol's GSR Tranny F'd? =[
- 22 mpg in city - 35 on highway?
- Are 450cc injectors too large for a n/a b16?????
- catalytic converter flange? HELP!
- 15.8 mpg on my b16 drivin like a granny someone help me!!!
- Civic fuel gauge problem?
- Sloshing sound
- Can I take doors from 99 coupe and put on my 97 hatch?
- Civic Question!!!
- when cleaning iacv?
- aftermarket throttle body sizes
- stock sol exhaust
- bolts and washer
- any pls help
- Blox IM question and DC 4-1 header question...
- 2000 Civic CX hatch won't stay up
- 95 computer
- cruise control
- Will a gauge cluster from an ITR fit a 92 Civic?
- 1992 1995 civic hatch differences
- Know of any good forums on how to replace head gasket correctly????
- d series oe pistons
- Help me! Bad transmission maybe?
- A little motor trouble here...
- EG hatch not throwing codes..wtf!
- anyone have corner lights?????
- Acura for civic coil springs
- 92 civic lx rear brake disk conversion.
- Mugen lip emblem.
- b18c swap
- oil catch/reservoir can help...
- LCA question
- **CAR STOLEN*** in Akron OH: 94 honda SI, black
- hitting vtec then boggs down
- J series swap in an EG
- EM1 won't rev past 3500 RPMS (B16A2)
- *** do i need arp headstuds ***
- Alarm wiring guidiance
- 94 CIVIC-LX Distributor making grinding noise & Check Engine Light Need Help!
- Front brakes lock up, prelude/accord brake set up
- info. on whats needed for a ls/vtec swap
- New guy With 94 ex (my first car)
- how do I pop the hatch? ('00 civic)
- gsr / itr spark plug cover warped?
- ?about a honda civic rear transmission bracket ?
- bootleg si help.
- Custom Honda Del Sol Projector Headlights/Taillights? VIDEO!!!
- ek b16 top tranny bracket question???
- zeal spoiler 96-00 civic hatch
- please help , car wont start
- What did I just break here?
- Car wont start
- jdm and usdm heater core difference?
- B16 into del sol questions
- jdm Center Console?
- interchagabilty of springs/coilovers
- H-t you were right!!
- did my mechanic screw me??
- Adjustable Fuel Presure Regulator.
- Ctr exhaust b pipe
- correct z6/b7 cam gear
- Wierd kick in cluth...plz help
- what drive shafts fit?
- my 95 eg sputters when vtec hits ?
- Velocity stack.
- Help me with this situation..
- Gsr ITR internals what ECU?
- type R motor issues!!!!!!
- got a quick qestion!!!!!
- Rev problem help
- Weird problem with throttle/clutch?
- Let's play another round of, NAME THAT BOLT!!!. Lots of PIX inside
- Im stuck what do i do. ?????
- stage 3 cams in b16, wont stay running
- Integra Door Panels in my Civic
- d-series engine bay post
- Need a photoshop please!
- trying to change cluth w/ motor pulled out?
- Anyone know where to get valve guides
- anyone kno where this connect to?
- Window problems.
- need help with my new dizzy
- ITR Exhaust on an ek??
- Help with Heater Core
- b16a3 Del Sol...Worth Swapping b18c1 ???
- hugh engine or tranny problem
- AEM bypass Valve... yes or no??
- 92 civic hatch
- HELP on my ls swap civic
- Power window - not seeing voltage
- Best head for B18b rebuild...?
- b16a redline?
- how do u take off the honda emblem
- Apexi N1 Axle back ?
- anyone else have a money pit civic!?
- will a 94 civic catback fit on a 94 integra?
- Rear Brake Cable
- How Much does An Engine Tune Up Cost For Honda civic 2000 DX
- d16z6
- fog light covers
- car will not start under about 25 degrees?
- honda part #91206
- finishing off b20 in ek list help!
- Rev high car goes into limp mode?
- Auto Swap Bseries
- E brake cable?
- Bouncy lights when the card is cold
- why do i have to press gas to start car???
- Which motor mounts?
- GSR swap in EJ2, battery not charging
- Help with wiring obd2a, IAT, IACV
- Need help with my b16a...throbbing...
- car dies on cold start ups
- power steering
- 2000 Civic Ex Carpet
- headers
- Carpet and Garnish
- rear disc swap with abs
- tsudo n1
- Civic Si still hestitating ???
- Gsr headers?
- ****--- stolen silver ej8 in chicagoland---***
- What injectors to use????
- Is this worth it?
- lowering an eg?? pics?
- How do i keep power steering (((searched)))
- Miata 90-93 alloys on 2000 Civic EX?
- d16y8 tranny problem!!!!
- Engine RPM Question
- water reservoir question
- how long do tokico blues last?
- Stock shocks/springs yet my car is dumped as hell
- Ballpark Compression Ratio of a B18C Type R
- d15b7 to b18 swap
- Connecting Vtec at the Solinoied.
- Speaker Size
- does canada carry ek9 ctr?
- Gas pedal height...Please Help
- did black interior ever come in 96-00 civics
- How to find Spring rate? Skunk 2 pro S 92-95 civic
- b20z non vtec question
- GSR b18 vs. CR-V b20??
- will aftermarket exhaust tip pass smog
- Which engine???
- do you have to drain trans oil to replace driver side axle
- questions about disk brake swap.
- bolts broke in block
- I bought a new lip!!!!
- Eg6 center console
- Car won't start
- reactive parts
- Hey everyone!
- d16y5 worth?
- 5500 rpm cut off
- Is this a good leakdown tester?
- is this worth it????
- 1995 EJ Coupe
- powers steering pump making noise
- gas gauge
- help and opinions on f20b swap into eg
- power loss QUESTION
- noob A/C ?
- help with engine swap
- EG Center Console Question.
- help 98 civic ex wiper issue
- Remove passenger side airbag...
- Help if you can!!!! 92-95 civic
- stock intake
- d16Y8 supertech titainiam valve springs and retainers..QuestioN..
- 00 civic si wont start!!! NO POWER
- Oil leak!!! HELP!!!!
- Power steering question
- EG6 Radio help( 94 civic dx)pics
- 1999 Honda Civic Sir, Brake line repair
- need help with ls swap
- Best b16 mod for $1500?
- how much would you pay for this 2000 civic ex?
- Proper Radiator Hoses for a 95 DX/ Type R Swap?
- CEL Issue
- Need help. Relocated battery.
- Will It Work
- general rim question
- reliable place to get smoked amber corner lights?
- help - gauge cluster, clock and turn signals quit working *92 civic hatch*
- How does the IACV work? B16A
- I need some Help on 94 civic t bracket issues
- OBD1 B18c - 96 Civic swap question
- No power when i turn the key???
- Del Sol Guru's.. New Owner with some questions!!
- One last step left - wheel studs
- Stripped head studs (block)
- Hard to start when the fuel is low.
