View Full Version : Honda Civic / Del Sol (1992 - 2000)
- is there a problem with the fuel injectors??
- what is limp mode?
- F#%ing cops gave me a ticket for a greddy exhaust
- b20 97EK
- need help with my rpm gauge
- Has anyone ever added side moldings to their hatches???
- 1998 Honda Civic EX P1337 Code
- Who has some pics of clean battery cable install.....
- car sounds like a wrx
- Z6 Head to Y7 block
- Problem with vtech
- Where do the oem emblems go on the 92 civic hatch?
- seems like i have 2 motors up in my hatch...
- o2 sensor help!!
- What are you guys using for roof racks?
- h22 balance shaft
- link and or websites for 92-95 si/ex standard trannies?
- I need help with a mini me swap into a 96 hatch
- Swapping a 95 LS into a 96 EK...???
- overheating problem!
- H22 VALVES
- WHAT SIZE ARE THESE RIM
- putting a h22a in a del sol?
- clutch question?
- Crank Sensor NEED HELP PLEASE!
- anyone have password rear disk conversion on eg?
- alignment issue maybe...
- Heat Coating + Other Questions
- b16 swap questions?
- OBD2 & OBD1 Can someone explain the difference?
- ? bout foglight bulbs
- D16- B20 HHHHEEEELLLLPPPP
- intercooler for del sol
- 2000 Civic Timing Belt Change
- 00 SI Rim Fitment
- P30 b16 ecu obd1
- How much
- Front Lip Question? (PICS)
- Squeeking brakes but goes away then I step on the brake pedal (not your average problem)
- Anyone have any experiance with Seibon CF coupe trunks?
- oil filter wont screw on
- dizzy question
- what sensor is this
- Re-checking timing marks
- Integra Front Disk Swap Question
- 97 CX Cat-in-mani exhaust question
- will a 92 Hatch stock exaust fit on a 92 sedan ?
- changing shocks
- Car doesnt want to start!
- 2000 civic Ex Problem
- P28 Ecu or VAFC II
- So I got my new gas tank today
- - What to do with this engine? Ways to make it better?? -
- 99 Civic Si Engine Replacement
- dumb exhaust question...
- Radiator Fan Doesnt Cycle On?! Bad ECT?
- how to ask for a 93si with no engine?
- Building engine
- Some del sol swap questions....even more confused now from 5 hours of searching
- obd2a 16a into obd2b 2000 acura el problems
- Too low
- I need some advice on how to diagnose my 95 civic.
- o2 sensor or ecu? help please
- spark plug cover?
- Common drop height for Ek's?
- Clutch or Tranny, what's gone out?
- can an axle causing a rubbing sound?
- how do i tell if a head was ported and polished????
- Civic type R brake Vs CIVIC SI : Axial Difference ?
- lug covers.....
- d16y7 catalytic
- Wiring in a Knock Sensor for a D16Y7/8 mini-me
- UBER-HIGH Idle after HG install?? Idling at 3.5k1?!
- crankshaft problem???
- crazy tach problem
- 94 civic 5 speed trans into a 98 civic will it fit?
- trany swap 94 civic 1.5 to 98 civic 1.6 non vtec will it fit
- Dropping a 93' Civic EX
- These ebay catalytic convertors....link
- Integra Brake Proportioning valve = MORE or LESS rear bias?
- WTF??!?! K&NGOLD Oil FIlter: SIEZED?!?!
- ITR Muffler on a 99 Civic Si
- Clutch question...Help me out b4 i waste some money
- How to fix heater core leak....?
- Driver Side window fell out of place!! Help did some searching.
- gear grinding sound
- some help on my 93 sol
- thin head gasket
- 92-95 civic timing prob.
- 00' si turbo kit
- H22 motors in hatches
- gauges and climate control ... where do i get...
- D15 vtec trouble
- A/C Compressor onto LS Swap
- 94 Civic LX 1.5L fuel injector size?
- excessive engine movement, help needed
- Pic Request...Gold EG/EH
- Pollished B16A2 turbo manifold/header
- 97 del sol front end - 93-95 front end?
- should i buy this sol?
- starting problems! but only in the morning?
- LS-VTEC vs GSR motor
- Looking for a place to buy some parts
- where can i buy rails for these seats?
- Lsvtec Help!!!
- I stripped 1 lug on each of my axles...how dangerous is it to drive with 3 lugs>?>?
- is the gas pedal adjustable? 99 civic si/sir
- anyone has a skunk2 manifold on their b16 civic si?
- 92-95 civic si tranny vs ex tranny
- considering an 99/00 Si or a 98+ GSR
- Exaust
- 92 LX four door:Power Window Problem
- QUESTION ABOUT DUCKBILL!!
- WILL BUDDY CLUB SIDE SKIRTS OFF A 96 CIVIC COUPE FIT MY 95 CIVIC COUPE??
- WTF is wrong with the site?
- installing my new steering whell
- Test pipe Horror stories anyone?
- Just picked up a 97 ek ex and a H22 swap and got some questions?
- Windshield wiper issue.......
- DA parts on EG, interchangability questions.
- Refilling bseries coolant? How much? "Honda Type 2"?
- b16 and ls parts for sale
- H22A4 EG Axle Hybrid ????
- How do you install a tachometer on a 92 CIVIC DX? -----Help----
- Tein SS with pillow mounts and EDFC
- Does a GSR intake fit a GSR motor EG?
- which suspension?
- So many problems! Suggestions!
- Just installed OEM Power Window...Passanger window goes up Slow???
- WTF is this and where does it go?
- p28 ecu for sale
- Need help again on a aem part
- Need help on a apexi V-AFC
- 2006 Civic Si
- EK9 sussy on EG. Quick re-assurance thanks !!!
- Header question??????
- B20 Swap in my 98 EK
- Weird Squeaking noise at idle, and when doors close.
- 98 EK, need help
- civic prices
- b16A..just a question...
- D15
- wont start
- throw out bearing
- spoon calipers w/ spare tire
- Best Type of Bulb to use in Projector Headlights?
- SHould i post up my How TO power window, door lock, and mirror conversion?
- Airbag deployment?
- which transmission come with the d16y8?
- Difference in 2/3dr front and......
- Questions: D16y7 block/ D16z6 head
- d16z6 cam gear
- Speedometer Problems
- b16 del sol
- PLEASE! some1 that knows engines HELP!
- where to get foglight TRIM only?
- How do I tension the timing belt???
- stock springs new shocks?
- lookin for a tranny
- HELP!!! ZC bottom, Z6 top into a 94 del sol...HELP!!!!
- Loud, not constant, thumping noise when braking
- i'm screwed- rounded off head bolt
- Help with my wheels
- help about my eg hood?!?!?!
- type r steering wheel in ej "horn"
- Need install help in Columbia, SC.
- k20 swap
- Water leak
- Passing State Inspection + Winshield Resevoir Washer Tank
- carbon fiber roof
- If you think you have low RPMS LOOK AT THIS!!!
- Stickers?
- Air conditioning removal and questions~!
- low rpms...need help
- torque specs for b16 head
- Intake manifold problem after disassembling
- transaxle oil. need real quick help.
- transmission problems
- JDM d15 that's NOT vtec. Any specs?
- Rear upper control arm installation
- Spark Plug Tube R&R?
- B20 Vtec head gasket????
- AHHH. Blown Motor
- help with new civic!!
- Nashville Tennessee November 13th PICS
- MUGEN B SERIES VALVE COVER is it baffled?
- exhaust help on my ek hatch with d16y7 mini-me to y8
- B16 Build
- front bumper kit
- what motor mounts
- Can anybody help me out with the gap I have with my rear bumper!
- cruise control question
- Aluminum vs CF hood, fenders, trunk...
- cleaned out my blower motor
- Where? is the sale forums?
- I have a center cap, that will fit Del Sols, and Civics
- knock sensor question... search is down.
- Exhaust resonator modding
- engine overheating?
- 96-98 AC/Heater control. Will it work in a 92-95 civic???
- Cold Start Injector Question (Please Help)
- Horn relay?
- Low RPMs at idle on 97 Civic
- GS-R to EJ Seat Swap
- planning to get rims, need advice and opinons
- Question: Real JDM HEADLIGHT BULBS!
- How do I....
- please help "HIT N RUN"
- snapped off a suspention bolt in the bushing in the LCA
- buddyclub v-con install question.
- rhd eg2 del sol front clip
- 95 civic ex d16z6
- help, my engine effed all up 100 miles away from home.
- 99-00 Si cluster into EG9
- K20 swap ?
- EK b16 ecu help!
- any b16 cable tranny in 1994??????????
- Quick n00b question.
- H22 eg's
- Stock GSR map on Uberdata runs rich?
- which is better? z6 or y8 head?
- Where can I go to get my exhaust put together? Bay Area, CA
- Is this lca bent?
- Skunk 2 Stage 1 or Stage 2
- so how do i correctly install seats?
- how to set timing?
- Check engine light is on but flashes no codes...
- No Gas
- Removing paint and clear coat from plastic
- cant get off rusted bolts..
- Omni Quicklutch Clutch Master Cylinder - in winter
- my car has an OEM shift light
- Who has an Autometer mini shift light?
- scammer located in washington state
- 98 Civic Stereo
- another quick question on manual conversions
- how to advance timing
- Replacing heater core, how to take apart the whole plastic surround? Which screws?
- HELP NO SPEEDO....
- civic mudgaurd question?.././>/.
- Cleaning carbon buildup with pistons in engine?
- Eg hatch exaust fit on a Ek hatch?
- is it true b16 swap?
- Constant 12 Volt source for 96 Civic DX?
- quick question about SI seats...
- Need D16Y8 shortblock
- b16 Check Engine 45 plus 73 misfire WHATTT?
- about my idle, need help
- suspension??
- VTEC question
