View Full Version : Honda Civic / Del Sol (1992 - 2000)
- O2 sensor q's
- 4-2-1 exhaust and O2 sensor problem
- gauge cluster bezel removal 95 Civic..
- type r tranny is an si...
- 5 lug conversion vs. 4 lug (GSR suspension all around)
- 99-00 Si Lip Install.
- Valve Cover Fitament
- HELP Just tore up my GSR seats!!
- **Si Redline**
- Rota Circuit 10
- Third brake light
- how to remove lower center console (95 Civic)
- Head Bolt TRQ for 93 Civic Putting the head back on right now!
- integra muffler on 97 civic hatches...what need to be modified? if any......
- short shifter question
- Light weight pullies to improve torque
- best clutch
- Need paint opionions for the EH.
- chipped SOHC ECU...on a SOHC instead of a DOHC?
- JapanDomesticMotor.com possible scam...
- civic lugnut size????
- Acura El conversion
- re-installing a short shifter..
- Suspension components most likely to get bent?
- road hazards suck! **please read and advise**
- fuel presure
- Chipped ECU's? Yes or no?
- engine swap need help???
- JDM d15b ECU help....
- What axles for OBD-1 ZC tranny into 92 VX? I searched!
- how to lean it the a/f
- Window Tint / Body Shop in Tampa Area?
- how do you know if your ps is going bad??????
- can you fit a EX exhaust onto a dx?
- Tick Tick Tick from drivers side
- engine is feeling weak....HELP!!!
- Car Shops at the Philippines
- running rich?
- 98 hb dx help please
- shifter question?
- what's a cel 68?
- OT: Urgent question for Pasadena (or around the area) members
- Mini-me swap/upgrade
- Civic ECU location
- hey looking for EG6KEN
- so when do i get to start posting in the " no trail members allowed section "
- How much can I sell my EG h22 hatch for
- Help with 2000 Si bogging out
- Rusty Quarters
- enproblems with b16 in eg hatch
- what does si stand for?
- Wheels? Offset, backspacing, etc... Compatability.
- finsihed b20z swap, no cels, but not redlining? HELP!
- Problems with 22mm sway bar (Beak's Kit) on my 00 Si, endlink related
- quick ac question
- gsr tranny question
- b16c!?!?!?!?!
- clutch oh no
- need help....!!!!!
- How much would u pay ??
- Carpet...
- for all you guys with gsr swaps in an ek
- my hatch w/ siR oem airbox and new lip. power loss?
- Motor mount questions???
- 1998 civic question
- EK with JDM ITR swap ECU questions!!!
- ITR front LCAs and swaybar on EK.
- Painting Headlight Housing?
- wut spark plugs do u use?
- d15 tranny from 92 civ cx to 94 civ d16z6 motor
- Iridium spark plugs........
- anyone have a B20 (without Vtec) in an EK post times and exp.
- Help About a Civic Si 99-00
- picked up gsr swap in Montreal - observations...
- D15b vtec tranny question
- ANY1 RUN ME A CARFAX?
- goodbye rex, hello 99 ex
- Ebay Greddy SP???
- ecu
- Starting problems?
- camber washer trick
- 1990 civic si a/c needs to be recharged.
- Cam installed.
- Ultra Rare GAB wheels for sale
- salvage title?
- Del Sol vtec radiator cap, same as DA radiator cap?
- b16 head with LS manifold??? Help! Also a coupel LS/VTEC questions
- torque mount problem (help)
- milano red front end on my ek roma red! Will it be ghetto or i wont notice color difference
- price on a sub frame
- Problem to Choose MSD
- New forum for you guys who have Questions!
- Wiring vafc w/obd2 -obd 1 jumper and p28 ecu
- 96-00 civic center console into 92-95 civic.... Cant find the original thread
- swap question
- vtec= no oil pressure?
- Truck freight companies
- Parts List
- Help me find 2 more wheels like this!
- ECU pinout - A'PEXi S-AFC
- who sells shorter shocks
- new motor questions
- 02 simulator
- 99-00 si cd player fit in eg?
- Where to dispose of radiator fluid?
- Civic Si 99-00
- Can you recognize these ADR wheels??? (56K You'll be sorry)
- STOLEN: 97 SILVER CIVIC HATCH
- need some emergency help with changing my clutch M/C..kinda long story.
- whats wrong?
- Exedy clutch kit - $130 shipped BRAND NEW on ebay!
- FS: 1999 Honda Civic EX swap
- SD Girl Racers
- 96 Civic EX - Whats the stock tranny code?
- which FPR for a b16?
- Honda Meeting 2003 *Germany*
- axle problem need help!
- Quick emergency fuel cut off switch help!!!
- My EK after Meguair's 3 step! **** 56K BEWARE ****
- how much should i lower my car......
- Can someone please run a carfax....
- p28 Program?
- Radiator fan not activating
- Question about 92-95 Civic hb's
- XS Engineering HUGE intercooler
- I suck!
- How can I remove my inside side panel......
- Anyone do A6 block/Z6 head in 92-95 civic?
- Anyone have a stock cat for a 93-95 EX coupe lying around?
- Where can i find Stanley clear corners
- Pic Request: si rims on eg hatch
- Exedy Clutch with Zex kit????
- Which ECU will I need????
- How much room for a turbo?
- What do yall think
- zex cam
- 1997 Honda Civic LX 5sp tranny swap
- Skunk2 header info
- K-series on ek?
- Suspension Questions....
- Anyone install clear bra in Chicago?
- I just got a call from old dominion about my motor coming, 434 dollars?!?!?!?!?!
- ?TIRES?
- ?H.I.D.?
- EG Sedan Interior Question
- EG Vs EK
- H22A intake manifold from (STR)
- How to install lowering springs on an EK4
- What all should be changed w/ my timing belt?
- Suggestions on stripped valve cover bolts (threads in the head)
- Si underbumper spoiler, lip.
- I Have A Important Question About JDMSHIT.COM
- Wheel Max: good or bad company?
- Where to buy upper ball joints
- 92-95 CX stock motor?
- how do i remove rotor from distributor??
- Looking to buy an engine in Toronto....
- Custom Seat brackets???
- Flywheel problems?
- Detailing Products
- exhaust choices?
- simple question about oil feed on d16y8 head
- Type R interior in my EH.....
- Installing seats????
- New Custome Exhaust way to loud! What can i do?
- honda fest 2003
- i need a cable tranny
- Coil-Over owner's
- Top Speed Pro-1 Header
- how to fit exhaust from hatchback into a 4 dr eg?
- D15B + Zex 59300
- How do I wire my OBD2 plug to a OBD1 distributor?~SEARCHED
- Which coilovers???? Ground Control or DropZone???
- comptech intake/icebox question
- Which mounts do I need?
- Difference between an EG8 DX and an EG8 LX
- OBD1 motor in OBD2 car which O2 sensor to use??
- del sol electrical wiring
- 3' exhaust on dx
- b&m Shortshifter install help!!!
- how heavy are 99-00 civic Si headlights??
- 95 integra rear suspension in EK hatch???
- Looking for a how to, need help with an install?
- need help -spoon ecu
- B18C Project Motor Build Up
- What Civic did these come from? (wheels)
- 93 Civic Coupe w/ GSR swap $5200
- need steps on painting side moldings?
- Help on si hatchback... SPEAKER and TRIM
- 99-00 si OEM sideskirt fit on 98 EK hatch?
- Scraping like noise from under the hood
- civic hatch and coupe compatibility
- Which SS brake lines do I need after rear disc conversion?
- D16Z6 parts interchangeability (sp?) with other D16
- Cool Honda song...have you heard it?
- what kind of rims are these?
- Need alittle Help on deciding to get Motor Mounts or not (yes I searched, just look!)
- D-series Skunk2 IM vs Y8 IM
- 95 hb with 90 strut ???
- Adjustable FPR
- Right hand drive
- ok friends car wont start after gsr swap.. where can i start to look?
- brake help asap
- gf's car almost gets stolen...have a few questions..
- JDM(CTR) EK headlights? do they fog? discolor?
- strange rpm drop
- questions about ITR exhaust...
- how do i remove PINS from ecu connectors?
- Install Help: SRR Rear Sway Bar with Lower Arm Brace
- 93 Sohc Vtec Distributor does it work with a 92 cx ?
- check this out (just wanted to share)...
- GSR Dash Swap into EG
- Brembo blanks?
- ok i did the amber gauge cluster bulbs
- Will 95 4 Dr Civic Tail Lights fit a 92 CX Hatch?
- Dynoed my car for the hell of it... now what?
- B series TB on ex mani....
- JDM EK air vent and pocket?
- Which exhuast would you pick if you where going turbo???
- I'm Pissed
- Does anybody make after market Syncros???
- anyone selling jdm fogs?
- Spearco Intercooler and piping, 12" sub box
- a/c price question
- Pic Request - EBP 6th Gen HB's
- Need Radiator for my 95 civic
- My civic was stolen! right outa a church!
- I searched but couldnt find the thread - Where to buy JDM 95 coupe side molding?
- Thinking of selling my hatch...how much should I ask for?
- oil Question
- You guys with HX rims
- ITR calipers fit 15" Rota Circuit 8s??????????????
- how much is a d16z6 im worth?
- Fuel injectors
- spark plug question
- changing head gasket?
- code 10...changed sensor still code 10...
- Which Springs?
- DEL SOL DOME LIGHT & SHARP TURN
- CD Player
- How much do '00 Civic Si rims weigh?
- why skunk 2 short shifter instead of ebay shifters?
- OT: SoCal Alarm installers ?
- Tranny pops out of fifth gear?
- ECU help?
- sohc upgrade
- EBAY style points!! Check this out!
- Who makes aftermarket fans for stock EG radiator????
- Fuel Pressure Question
- Will this lip fit?
