View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EK4 vs DC2 Knuckle height woes
- What Bolt goes in here! d16z6
- del Sol SIDE wing trim: how to remove, buy, fix???
- Hissing sound from throttle body area
- DIFFERENTIAL HELP?
- Vtec head is warped.. Can I modify another head to keep "vtec"?
- Anybody ever DIY low seat rails?
- 92 civic hatch Car creeps to H then drops down then Back to normal
- 92 civic h2b pressure plate bolts
- Skunk 2 Exhaust
- ignition switch panel
- Block Identification
- Y8 to Z6 transmission swap
- Upper ball joint removal
- Scraping noise coming from wheel
- looking for armrest for 97 civic
- How much oil for wet compreession test ?
- 99 civic fuel smell
- Aftermarket radio & Alarm, door lock problem
- Squeaking in brake area while turning
- Decent detachable steering wheel for 94 civic sedan ?
- 93 del sol condenser fan
- Timing Issues???
- MB6 Civic Vtec problem
- Distributor Timing Question
- The right one (SRS Wire)
- Timing belt burning?
- Tricky overheating problem
- Em1 start issue
- non-vtec to vtec can it be done?
- Sol tire issues '94
- fog light question
- Looking to build my D series for boost but cant find much aftermarket parts
- EK hatch wheel fitment question
- 99 Si or Clone?
- B16a build/turbo opinions
- What front lips are these EKs running?
- k series parts
- DA parts on EG
- TPS or Transmission issue?
- which clutch
- Gsr trans + b16?
- 2000 civic ex z6/y8 head?
- Do I need this? CONT AUTO CRU
- Smogging a car with a bent valve(s)
- P0420
- correct cv-shaft/intermediate shaft
- A/C button delete
- D15B8 in 1995 coupe
- Blown head gasket and then bad injector
- Locking the steering wheel, beforing applying Club lock.
- D-series Skunk2 Intake Manifold questions
- 5 speed conversion
- 99 civic ex
- hasport mounts causing vibration
- Help with steering wheel
- GSR head compatibility
- 93 civic 4door powe window/locks question
- Solid motor mounts suck what mounts should I get?
- Tree fell on my EM1 ... only 70K original miles. Must fix. Suggestions?
- t25 on d16y7
- help select balljoints/ front control arms
- I'm using a P75 ecu on Mini Me
- 1999 Civic LX Climate Control NO Power
- Question about seats in a bubble....
- Whats it wort lol
- Carbon fiber hood manufacturer
- Serpentine Belt Whines
- B16 crank cog removal.
- Vtec solenoid filter gasket & HBond
- 97 Civic Ex Build
- 350hp civic hatch handling
- obd2B d16y8 into obd2A EK
- Noob questions.
- question on engine swap wire harness
- 99 Si wont turn over?!?
- 99 civic harness question
- 98 civic shaking
- P28 AC question - pin A15
- Dumb quick question - OEM strut bar fitment on 6G D-series Civic
- D16y8 ECU questions
- D16y8 swap ecu question
- OBD1 to OBD2
- Car misfiring when idle
- Odd rattle/vibration
- Replacing only the tach in a gauge cluster
- 97 civic steering help
- Single din radio swap to a double din
- Reset ECU, New codes come up?
- Temperature Gage reading on my 95 Del Sol Si
- eg coupe exhaust question
- Complete EG hatchback front end on a sedan
- Radiator for jdm b16
- Do I have to bypass my ecu?
- Question about my b18c rebuild.
- B-series clutch issues after non use
- type r db8 seats in a 2000 civic si
- TPS issue*
- 2000 Honda Civic turns over but doesn't fire
- D16Z6 question?! - "Non"-VTEC head?
- How to get my cams to sound like this?
- EK rear disk conversion
- Help diagnosing a weak spark.
- Eg b18 to b16a swap help
- Grinding noise, Bearing? Tires? Other?
- 1995 honda civic eg hatch project
- lower strut bolt
- D15z1 missfires or pops till let off gas
- ls/vtec bogging
- Del sol wheel not center
- only start if i pushed the key ?
- First Civic - Feedback?
- K24 swap to a EG6
- D16z6 75.5 vitara Ring end gap?????
- B16a2 Rebuild - All Type R Internals *PICS*
- motor lags
- P1399
- Anti-Theft Idea
- smog help
- My 96 Hatch build. AKA The Brave Little Toaster
- Skunk 2 throttle body help !!!!
- Does your vtec kick in ?
- Quick question: Will B16A/B header fit on B20B swap into eg si?
- high pitch Noise from Transmission/clutch assembly until slightly pressing the clutch
- s2000 Cluster Conversion
- Oil leaking from head....is it possible?
- P0122
- help with low idle..
- Weird acceleration after swap
- My water pump seized!!
- Replace 94 cx brake light?
- Brake light coming on randomly
- Is this steering wheel fixable
- 2000civic with d16z6/y8head
- 97 ek d16y7 pronlems
- Alternator will b work for d series
- Moving to a county without emissions
- 2000 Civic Auto Randomely Won't Start
- No air flow comming out of dash vents
- B16a2 annoying sound above 2500rpm
- D15b v-tec exhaust
- 98 ex d16 y8
- Possible Oil Leak..?
- Power window's Issue - 1993 H Del Sol
- Car won't turn over?
- Plastic guard under front bumper
- Good old code 14 problem
- dx auto won't accelerate/high pitch whistle
- Just overheated, need help
- 94 del sol exhaust
- Shift Knob is stuck!
- HELP PLEASE!!! question about off set and all that stuff
- 1992 Civic no power to fuel pump new to Hondas Help
- d16y7 problems
- Engine Running Rough After Seafoam
- FULLY built 92 eg hatch idle dip thunk.. please help
- 98 civic ex ac problems
- what exhaust to get for my 2000 honda civic ex
- valve spring retainer snapped in half. what do i do?!
- eg floor repair
- Wiper Switch Assembly 98 Civic DX
- 99 civic d16y8 no vtec after running hard
- 99 DX no start after removing dizzy. worked fine before.
- Low mpg
- Eg Gsr not starting
- 99 Ballade/Civic sedan central locking
- D15b7 performance problem
- AfterMarket Stereo - Failing
- Gas flooding?
- RPMs bouncing at idle between 900 and 2100 (roughly).
- Replace shocks weird sound
- OBD-2 question.
- Stock D16y8 Overheating!
- need help quick with battery ground location?
- D15B7 Rebuild Burning Oil
- Suspension bushing recommendations
- P0138 code
- spindle
- 99 civic wont start
- Obd2b-obd2a harness
- 93 civic dx with da rear disc brakes, bleeding problem
- 95 ex cluster tech/temp gauge not working
- '98 Civic EX Build Thead
- 99 Civic Lx torque converter won't lock onto input shaft
- Jdm B16a oil change
- 200hp, 10,000+ rpm B-series. Am I insane?
- 1999 Civic Hatchback DX Seafoam oopsie?
- How to make d15b7 non Vtec to Vtec ?
- Swapped D16Y8 to D16A engine and now idle/coolant issues
- HELP: EG bad mpg and running rich
- 92 civic brakes
- My Eg Hatch transformation
- throttle cable okay??!?
- 1994 EG Hatchback Auto to Manual Swap Specific Questions
- 94 honda civic turn signals need help
- How do I remove bottom half of ac box under dash? 98 civic
- connecting rods
- Trouble starting 92 dx
- D16z6 - what could i do to increase horsepower?
- wooom woom noise
- 1998 honda civic ac expansion valve replacement
- Bad jerk while in higher rpms
- How hard is it to install Hasport mounts?
- civic starting problems and bogged and dies need HELP.
- roller rockers on a d16z6?
- Steering Wheel fitment help?
- Ej6 crank no start
- Lower control arm???
- Noise at 40+ MPH help?! (Exhaust sound)
- A few Concerns with my 98 Civic EX
- Installation of new motor: What should I ask the shop?
- Can the cam be 180 degrees out of time?
- hello, H-T... back with EK
- extra connector??
- Big Brakes with small MC/Brake booster
- CODE 14, 7, IDLE problem, shifting problems
- 93 civic DX starting issue.
- EJ6/B16 swap - transmission noise, CEL codes, and speedo issues
- 96 Honda Civic Odometer frozen
- '93 Civic DX hatchback 1.5l crank pulley replacement options
- 92-95 honda civic sedan trunk garnish fitting coupe trunk
- No start, no codes... No anything
- AC Compressor oil
- Where Can I Get These Del Sol Headlights???
- Random Plug
- 98 civic ex idle problem
- Intake manifolds, error codes, and headaches
- A Honda thing??
- Aftermarket Sway Bars for 98 Civic DX Hatch
- Buddy Club Racing Spec Condenser
- Manual rack urethane bushings
- Rpm bounces up and down at steady acceleration
- Hatch Shaking
- OBD1 scanner
- Question with fitting up an exhaust with my B18b swap
- Antenna Stuck..need help
- 95 Civic DX Front Brake Lines.
- air intake for honda civic 2000 si
- My 93 del sol si build :P
- belt squeak!
- low idle on my ls vtec
- 92 Civic Hatch Build
- Cel wont turn on!
- B series ek
- 1993 Del Sol SI needs transmission
- how to adjust where the clutch releases?
- Where is my adjustable (unclamped) test pipe split? (sound clip)
- quiet exhaust system for ek gsr swap
- Timing belt and Distributor
- Removed car alarm, car won't start.
