- serious oil burning help!!
- Any write up on installing the ASR brace on the EK?
- d16y8 into dx hatch with d167y7 question
- Proper tension/torqueon e brake nut
- Anyone try EG lca Bushings In EK Lca??
- Column / key hole light install help. Did a search found nothing
- tire Question.
- 97 Prelude stock spoiler fit on a 97 civic? How about seats?
- Clutches interchangeable?
- quick exhaust manifold question
- How many ppl not rockin Innerfenders?
- honda wont crank or turn over
- VTEC spool solenoid valve cel 21
- ek rear lip
- dash piece removal!!!
- need help with LAF sensor!
- HELP! - Civic hatch stolen in San Antonio, TX
- EJ coupe dies out
- idling a bit high?
- Steering Wheel Slipping WTF!!
- finally purchasing my ls motor.. what sort of paperwork should i look for?
- Major D-series troubles
- ITR sway bar on del sol DOHC VTEC?
- HELP instructions for jdm civic window visors
- no power to coil
- h22a in Eg shifter question
- HELP WITH MOUNT CUT FOR H22
- f1spec or hytech replica header?
- E-brake loose
- pcv valve question
- 95 Civic Del Sol VTEC Sluggish when accelerating
- curb weight of 92' -95' Civic lx 4door
- del sol questin????????????
- Cracking cam gear bolts.
- WHY SHOULD I BUY A ALUMINUM EXTRA CAPACITY OIL PAN?
- tranny help!!!!!
- compression test results...
- What year motor is this?
- Custom manifold for turbo? Anyone know where to get one made?
- awd conversion???
- LSD???
- Engine Problems while driving
- k20 or b20?
- cel p0420 (i think i know)
- Honda Civic Auto Tranny
- Does anyone or EBAY sell EG Headlights but with a clear or plastic covers like a EK Headlight cover?
- What sensor is this? **PIC**
- b20 v-tec vs ls v-tec
- Civic Tune up guide.
- eg camber on ek?
- Help Please
- Does anybody a website where I can buy honda parts?
- Questions on lube...
- BPi stack fitment issues in EM1 with short ram
- crank fluctuation sensor on '00 b16a2 on 96 civic running obd1
- lsd question
- turbo or itb's?
- problem two with shifter
- Need 99-00 Civic SI mirrors diagram !!
- timing
- Tachometer shows 10 mph when stopped
- Throttle cable question.
- Buddy Club N+ Spec Damper ENG Instructions
- Map sensor on the firewall..
- turbo or all motor
- Purge control solenoid valve
- 00 civic ac evacuation question
- hardcore idle surge
- what will it take?
- ***WANTED*** B SERIES DEL SOL SHIFT LINKAGE***
- does any body know if !??????
- New cd player
- Interior ?
- o2 sensor wiring question
- Clifford Alarm matrix 3.5 remote has no power
- B18B Swap into 96 Civic DX Coupe
- cel 13 BARO
- hooking up a hitch????
- DTC Code P0501 Help
- CTR vs. GSR
- difference between......
- 95 integra o2 help please!!
- RHD Civic Wipers
- Sputtering?
- gsr swap fun
- Fuel pressure regulator
- B18B1 into a '93 civic si...hopefully the last post to get it finished
- side skirts
- A question about brakes
- switching a 1992 dx 1.5 non v-tec wo a 1.5 v-tec
- EK acting like a pussy... cat that is.
- Buying a skunk2 intake manifold for my b16a
- Heater core broke. Coolant on carpet
- h2b swap. need some help!!!
- strut bars!!!
- Does gas effect vtec?
- stuck with a d16z6...... what to do....
- will a jdm domani front end fit a eg?
- d15 b vtec swap help
- hows it sound?
- dumb question
- D16 v-tech swap in to a 94 Civic DX
- b20vtec turbo?
- OBD harness Conversion?????
- crank sensor ?
- turbo pluse vtec...good? or bad? do they mix
- strange engine nosie
- gold line springs?
- Lost a nut for my head studs.
- What are the differences between the 92,93 Honda Civic Si (EH3/"EG") and the 94,95 model?
- SI rear sway bar question
- looking for engine builder in NJ/PA area
- weak clutch....new clutch
- What tranny for DOHC ZC
- ebay turbo kits?
- Rear LCA Question
- Vtec problems
- System not charging
- Q about a header?
- Axle question
- OBD0 DOHC ZC swap into EG
- what to do, fix problem or new shortblock?
- ***HELP*** Tuning a Jackson Racing Supercaharger for GSR***
- b16 throttle body size?
- Miracle X bar
- HOW TO make antihijack use by ECU??
- Anyone ever read this article.....
- help with this please
- 94 civic lx question
- Question on p28 ecu's and vtec
- What are some good Aftermarket Seat brands besides Bride, Sparco & Corbeau?
- Interchangable VSS?
- Anyone know the part number for this...
- Help on installing pads for my brakes.
- Piston Rings Won't Fit
- delsol third brake light question
- A little help with dx to ex wiring.
- code 9
- Crank Pully
- What size bolt on back of d16 head to attach hoist to?
- KYB GR-2 shocks any good?
- Considering Purchasing 1997 Civic EX.. Few Questions!?!?!
- weight theoretical question
- d16y7 hesitates and is running rich on fuel?
- A question for you D-Series guys. Quick and simple question, looking for a simple answer...
- Probably a newb ass question but here goes. Secondary o2 sensor.
- idle problem and new dizzy
- I have a cell 21 code. any help please
- Wiring Issues..HELP!
- gm iat in d15bvtec
- what exhaust is this?
- Need some help deciding which catback to go with?
- hard to shift to 3rd gear
- P0505 indle air control system malfunction code
- Axleback Exhaust
- Which would you get?
- Morning chill weather affect the engine wokring temperature
- Grinding Noise.
- side skirts question
- liquid from muffler
- WIRE HARNESS?
- Hmmm tps sensor?
- del sol speaker
- bests cams for a b18c5
- average rpm's at 60-70mph
- PRIMARY SENSOR 41
- Need Help On GSR stock manifold
- HELP WITH WIRING DEFROST, 3rd BRAKE LIGHT, & WIPERS
- change front calipers
- PW JDM solid tower bars?
- ***NEED HELP -WHAT SHIFT LINKAGE TO USE IN 93' 4 DOOR CIVIC WITH DEL SOL SI MOTOR N TRANNY***
- converting from ODB1 to ODB2
- Manually close power windows?
- ARP Studs VS OEM head bolt
- B series starter HELP...
- help.. will sparco sliders or universal sliders work with recaro srd seats
- help with map sensor
- MANUAL TO POWER STEERING SWAP - need help
- what is this noise?
- Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods....
- custom engine or engine rebuild
- change chip or change headers?
- System too rich?
- Civic vs Civic
- need to convert obd2 distributor plug to obd1
- air/fuel and ecu questions
- Z6 Boost Setup
- swaybar dilemma
- silencer
- N00b hear with a tranny problem
- what stage cams?
- No Brake Light+Horn in 96-00civic
- Cx Header/catalytic converter on ex Question
- engine problem... help? VIDEO inside
- 92 Si, Speedometer not working
- WS2 w/ turbo??
- major transmission problem - need help
- code 1/14/41/43
- FS: jdm b16 tranny
- what is it and where does this go to??
- ACK! need some assistance
- Integra lip!
- muffler question
- swapping motor - cannot remove spring pin on shift linkage - Advice?
- full-race traction bars?
- seriously for the people that talk shit about hondas
- 99' Civic Custom Headlight Woes
- Exhaust Question
- b16 tranny
- VAFC Problem (yes i searched)
- Thinking of a possible new project...
- Will these rings fit?
- Say it ain't so...(d16y7 timing belt off one tooth)
- throttle problem? dead battery? help please.
- Gsr swap running lean
- eg sir cluster
- right ECU for motor swap
- ECU harness Conversion for B16???
- Headlights not working!!
- Y7 AT into a 95 LX
- need to run my gsr ob2 vtec into eg ..
- help me out
- 88-91 civic 13's on a 94 civic ex coupe????
- h22 in 98 civic ex??
- my speedometer is not working and niether is the light
- seats
- apex vtec controller?
- Broke my key. No spare. What to do ?
- Piston install problems.
- stubborn door
- skunk2 short shifter
- EJ Civic Washer assembly Fluid Question
- black urathen rear lip?
- After market exhaust
- will a 92 GSR OBD-1 dizzy fit on a b16/ type r head with no problems??
- piston slap...
- vtec not working please help
- vacuum leak?
- 2000 Si Intake Choice
- cams and springs install
- CTR compression height
- Radio/clock wont power on.. help
- Alternator or battery
- Civic Engine to Del Sol shell
- 99 civic y7 motor
- Are eg and ek cope exhausts the same?
- b16 swap in 97 civic ex
- 92-95 Civic with chevy small block 350
- 349 DOLLAR O2 sensor!?!?!!?! WTFFF!!!
- 2 questions...maybe 3 or 4
