View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Is there a seal on the spoiler?
- will 94 gsr springs fit a 95 ex coupe?
- backward batt
- Best place to find D15B7 usdm block?
- how to fix back drivers window?
- Mirror Stud Question
- Compression & Leak down test & Valve adjustment, how to???
- HX Auto Tranny Went BAD!.....Need Help...Please!
- question on a VX
- Attention moderator
- Need quick answer: JDM B16 SIR II oil pan same as LS oil pan?
- ignition wires question.... are manual and automatic wires interchangable?
- CAR STOLEN right outside my own house!
- Energy suspension shifter stablizer Bushings
- Rear Defroster doesnt work.....
- How to I change the inner tie rod on my 94 EX
- projector head lights
- Question about JDM EG6 Cluster
- How to ID brake port. valve?
- Integra cluster in EG
- btw
- HELP!!!! I hydrolocked my engine today :-(
- Oil presure sender installation EG-6
- d16y clutch fit a d16a8 (zc) g/box?
- different fronts on the ek civics
- Just need a little bit of advice on CEL code and o2 sensor replacement.
- Side marker help
- Swapping Jdm B16a
- snapped bolt that held the cam cover, what can i do?
- what would be a better eibach spring to get?
- ebay lowering springs
- anyone tried this ebay brace?
- Failed Smog No Communication to the ECM
- DA Seats in EG sliders/rails?
- help me
- need help!
- best swaps for a eg ??
- ecu problems
- water in my oil?
- Skid plate/heat shield for jdm 4-1 header???
- a brake setup on my civic
- Smallest rim size on a EJ coupe?
- Is this a CX or Si eg?
- tranny question??
- 2000 civic ex gauge cluster light code?
- D16Y8 Intake Manifold.........Has anyone actually dynoed?
- Help wtih O2 Sensor on 2000 Si
- SI seats the same as Integra seats?
- NEW VIS CF HOOD DOESN'T FIT?
- Pulleys?
- Need Help With Del Sol Ignitor Install
- Swaps!!
- Big fuel leak ...Need help ASAP!!
- honda civic hatchback 94 dx headlight
- how do i fix LAF - lean air fuel sensor
- just bought a distributor from sylvain (distributo king)
- Screwed up civic
- Fuse box diagram
- Quick question about new shocks..(Koni Yellows)
- Spark plug choice.....
- rear bolt size for rear camber DIY washer style???
- code check for 94 civic
- have tranny 1 inch seperated from block but it wont move any farther need help and pics asap
- Where can i get a lower control arm?
- B18C Gsr Build Up question
- Megan Gauges.. what ones are available.
- gionanyone know anybody who will do engine swaps?
- new paint!
- Another CHECK ENGINE post
- 97 B18B EG Swap
- Will an input shaft bearing make a clanking noise?
- JDM dc header and USDM dc header?!?!?
- power door in my dx
- 98 civic ex rear speaker deminsions
- need some help in utah
- s2k cluster on eg
- Civics' offsets reference??
- 93 lx ?'s
- Need casting #s for trannys
- new car lots of smoke
- will 90-93 da seats fit in my 97 ek hatch with stock sliders?
- one eyed monster....my civic
- remove these seat beats...? (pics)
- Carbon Fiber Spoiler for my EG
- Teg Rear Seats into 96 Hatch
- Does the distributor install one way only ?? need quick answer thanks
- V-Tec problem
- SORRY FOR THE POST HERE BUT I NEED HELP!!
- Bad fuel economy on my d16z6
- top speed in your civics
- obd2b... obd2a...
- Problem w/ my old engine!!!
- Fix'n to fix the hoopty, seat belts, and things
- New del Sol owner...
- Honda Fuel-Pressure Regulator Mod
- Puting on eg6(Si) doors on my Honda Civic Cx
- quick rear wiper question
- vortec FMU on a returnless system
- 97-01 Prelude seats into a 5th gen coupe????
- Egged car, what to do?
- which oil to use in b16 sir II tranny
- Cheap place to get NGK wires for b16a2????
- H&R or Eibach Pro kit for Daily driving
- rear seat question!
- is JDM becoming RICE?
- Fake VISION = Real Vision?
- 92 civic hatch lowered on coilovers. what kind of tool do i need to adjust?
- b series rings (Hastings)
- Lots of oil on my oil pan.
- Suspension Set-ups!
- headlight problems....
- 2000 Integra Type R 5 lug conversion itr 5-lug conversion - $1500
- Complete list of CTR parts?
- Will D16 parts fit my ZC motor?
- Need help on control arms bushings? please
- Windshield wipers not working!!
- Cost of used transmission?
- GSR swap in EK??
- need an opinion
- inverted shocks
- Blue SCS connector? Need to check Timing..........
- Sweet tool for gasket scraping/sound deadening removal
- Redline transmission fluid b series trans
- Need a quick answer from the civic gods! Please help!
- B18C5 Supercharged !Comments Please!
- 99-00 OEM Front Bumper Or 99-00 Cwest Front Bumper
- valve cover
- EK Cluster 10K rpm, which?
- 99 Si factory fog light info needed.
- weird knock sensor problem...
- off subject... anyone?
- From the HT sponsor "wiredlab"
- what are all the factors that cause the annoying revving when the motor is cold?
- type r part #'s
- Ignition Help
- no vtec..any other options
- Silicone Grease
- Help me finnish ma swap. few questions.
- itr cluster in an eg?
- quick question about aebs power typhoon intake mani
- Tach Hookup in 93 cx
- CTR cluster dimmer not working...WTF?
- i cnat find my alarm box
- anyone here using these headlights?
- CEL CAME UP
- anyone able to vouch for this member??
- V2 Cold air intake on Auto
- Just wanting some info
- Do you need a Camber kit when replacing springs?
- rev limit on b20
- what fits the engine
- i need window help asap
- O2 (oxygen) sensor simulator HELP!!!
- help please!!!
- Aright, I have a true HID Predicament...
- Rev Limiter is too early
- DA teg seats into EK civic sedan?
- Question on Installing 6.5 in the front doors of my '95 civic
- New Starter Help
- AEM Cold Air Intake Cover? (Water)
- Whacked idle.
- Does anybody know the different between JDM EK hatch lights and USDM ones?
- Whats ur best 0-60?
- Friggin timing belt tensioner
- Intake just gotten, what next!!?
- will 13" steels fit on 96 civic ex sedan?
- P30 vs P72
- buying a del sol - what to look for?
- sparco hood pin thread?
- prob with gsr secondaries
- choke???
- Hi im new... Q: How much are ITR pistons worth
- Can someone tell me for sure????????????????
- Torque Specs on 98 EK w/Tokico HP's
- Shifters?
- Is my beam pattern a little off?
- how do you guys keep water off back window???
- Cluster/ECU question.
- Rear passengers lower car. Springs Help
- Heard about more car jackings (UCR people)
- swappin parts from a wrecked integra ls...
- After filling up a full tank of gas...
- Mugen MR5s
- weird single cam ZC motor obd2? hmmm
- Connecting iPod to Honda Civic
- things needed to go from d16y7 to jdm d15b. HELP!
- greddy header for 96-00 civic
- how much hp is my d16z6 giving
- Tach Reading right????
- H22a mounts
- Vtec cam shaft into a non vtec head?
- a question on the 1999-2000 civic SI
- Winter Tire questions ?????????????????? TIRE SIZE QUESTIONS
- 96-00 Tein S tech springs
- Weathertech and auto ventshade install the same?
- Anyone that needs a black teg dash already cut to fit your EG
- mini me
- noob question! sorry :(
- CAM install gone BAD! Need help/opnion on rocker PICS
- b16a
- Single Stage Paint Durability
- H22A SWAP IN 6TH GEN CIVIC
- How do I make a fuel cut off switch?
- CARFAX please
- How Crucial is getting your alignment done?
- ECU Alteration chips (and resistors)
- b16 ecu
- Water in the spark ports! fun stuff
- Do I Need A Camber Kit?
- Help Anyone?
- fno1r-c+kyokugen lugs?
- Del Sol SI Turbo / Swap Question
- FOR TRADE! : 97 Civic EX
- Lower control arm bushings? where to get?
- BackSeat Help
- Custom GC Rates for EG
- Header Question
- Looking for 4drs with fog lights? Pix?
- Armrest bracket(92-95)
- 5 inch tach tryin to mount it to a 92vx hatch with a full 2000 gsr swap??wiring Q??
- d16y7 to d16y8
- y1 jdm trans rebuild walkthrough
- hmm WEIGHT REDUCTION for civic, no forum!?
- How can i get the polish red look on polish rims?
- will BFG 225/50/15 drag radials fit on 99 SI wheels?
- Which head do I have???
- "Backfire" type noise once-in-a-while in exhaust when shifting....???
- D16 Distributor?
- Pics of my D15B swap
- symptoms of an a/c overcharge ?
- anyone have the rs-r exmag
- StockInteriors.com carpet?
- Looking for 96-98 Civic EX Stock Parts - So Cal
- What is good price for 99 Civic Si
- EG6?
- Passenger side airbag replacement help
- Question about Buddy Club Dampners...
- No Manual, need a couple specs for EX v-tech. Thanks.
- help!!!
- For EG hatchbacks..is there such as a......
- Blowing shocks. PLEASE HELP!!!!!!!!!!!!!!!
- harrassed by cops?!?
- Limited application for AEM V2?
- Question about gas...
- car is running sluggish at low RPM
- What injectors can I use in my Z6?
- Mini Me: Timing belt works its way off of cam gear :(
- WArm up question
- FOR SAlE?
- DIY Grounding kit
