View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 2007 civic type r spy pics
- obd0 dizzy on obd1
- Obd2 to Obd1
- I need info on brake pads
- engine codes????
- CEL problems
- daily driven 98 hatch
- car overheating and idles drop.
- 92 eg b16a2 swapped V-tec doesn't work
- what sensor is this?
- serious problem with brake pedal pressure before and after upgrade
- Need Help Please Car will not start!!!!!!!
- code 24???
- Antenna removal on 2000 Civic DX
- b-16 swap running bad
- NOW WTH IS GOIN ON WITH MY CAR?!! HELP!!
- check engine code 1128, 1106 help!
- Piston rings?
- D16Y8 manifold
- Tranny Mount Bracket
- sputtering problem please help!!!
- How to Remove Stickers/Decals?
- approx what will my civic weigh?qq
- ls swap into eg axle problems
- Gauge cluster works fine, but no tach. already searched
- So wtf, are my brand new axles bad??
- d16y7 20mpg wtf?
- Code 9 cylinder sensor
- Milano Red R-81
- first honda project
- brake lines for inegra system?
- could a bad axle cause a front end vibration?
- Honda Civic 95 Dx sedan problem help please ASAP..
- Is this worth it?
- 92 jdm b16 head
- rebuilt motor i think machine shop screwed me over
- how do you guys mount the licence plate on the side of a front bumper
- making your doors lighter?
- shaved side moldings.. (need advice what to do)...
- Taillight Conversion
- Will low coolant affect idle ??
- b16a swap into 92 civic
- +++++POWER WINDOW CONVERSION ON EK HELP++++
- Resistance of O2 sensor
- 95 gsr head into 93 gsr
- knock sensor
- Emanage wiring... <--Lost
- headlight problem!!!
- Tail lights not working?...
- Need help with OBDII
- 5 LUG Suspension
- help misfiring!!!!!
- Saturated or Hold and Peak?
- BANJO FITTINGS FOR WIRE TUCK...
- I'm trying to put an OBD1 B18a1 into my 93 civic dx should I a B18A1 or B18B intake manifold
- Was the 5th gen civic hatchback ever sold in South America?
- code 14 IACV can't get it to go away
- ek civic lca question plz help
- Sun Visor in car
- check engine
- wideband o2 sensor
- will a b16a drop right into a 92 SI?
- Cold Air vs Short Ram
- Faulty wiring harness: cause of inoperative power windows
- B16A2 Vibrant J-spec header question
- car dies when i turn on head light
- hot tank my b16a head ?
- Conventional/Synthetic Motor oil. Step Inside Please!
- auto to manual swap on a civic just a few questions.
- will 96-00 lowering springs work on eg
- headlight questions. please help.
- Difference between EM1 and regular 6th gen (suspension)?
- b16b with buddy club spec iv cams
- wing question
- throttle body cleaning
- non vtec d series?
- I dont understand why it gave me a cel?
- VERY small leak in factory steel brake line - what should I do?
- b-serries type r or k20r??
- 1987 civic hatch swap
- bmw HID's in a EG
- Integra dash and door panes in an EG
- Weird noise comming from my engine bay
- cd player relocation...
- EP3 into EG
- Need some info on swaybars for 92-95ex coupe
- (HOW-TO) a nice HID BALLAST mounting location EK
- I can't take a bolt off!!! header cover
- a/c fan is acting up!!!!
- if 2nd gear tops out at 30mph on my tranny, will 2nd gear still top out at 30mph on boost?
- I'm thinking about paying less tax to the DMV but...
- Intega Type R pistons in a B18c1 block w/B16 head.
- timing belt change part numbers
- d15 with a d16 head?
- Ksports interchangeable between EG-EK?
- reputable shop in SOCAL.
- CarFax Report please!
- is my b16 done ?
- help???
- Need a carfax report for this car please!
- car wont start afte.......HELP
- I need some help with some things
- bad fuel pump or distributor?
- spark plugs
- eg sir cluster question
- ek dx cluster ? ABS ligth
- suspension help
- exhaust
- up grading brakes
- LCA
- Apexi axle backs interchangable?
- VIN on the block?
- civic 96 burning oil and white smoke
- Do you know????
- mini swap questions
- Y8 Oil Pan on a Z6?
- A'pexi World Sport Rattle?
- My EH2
- IAC VALVE
- Coolant problem and sounds
- Motor swap wireing
- 1998 Civic Si taillights are the same as 1996 2dr dx coupe ... correct?
- motor trouble NEED help FAST
- CAR BOGGING!!! getting on my nerves....
- type r oil pump leak
- Gauge mounting ideas.....
- Changing front wheel bearings, shop wants almost $100, rather DIY
- b18c5 block and tranny with gsr head
- Seriously need some B18C1 Help
- SRS and Fuse Question on 93 Hatch
- I Need help finding a specific Post...
- How Much is this Built Head Worth?
- NEED HELP ASAP
- Endlink installation....
- gas mileage
- radio and clock memory Question...
- Shift Linkage, 5th gear.
- grinding/scraping noise when braking
- hondata info?
- eg steering problem
- D15 noob question
- swapping out a blown d16 to a new one
- stupid me
- si tranny reverse gear problem
- integra rear disc, sway bar installation
- Turbo Mini Me
- Del Sol Trans Top (Transtop) in action...
- tanny dipstick?
- Base timing jumper location on '99 Civic?
- maintenance required?
- EG rear suspension ?
- 92-95 civic coupe skirt FIT HATCH
- WORK WHEEL DECALS
- Value of certain parts
- seat bracket for racing seats
- o2 sensor wiring on a 1998 hx
- Civic Exhaust compatibility
- OIl coming from exhaust....built high compression
- which is a better lip
- need help changing front axel!!! PLZ!!
- Door lock cylinder replacement
- Is my head gasket blown??? 96 civic dx
- the best engine cleaner...
- which torque mount?
- socketing a jdm p72.. anyone have a good diagram?
- Header Question
- rebuilding turbos
- Back in the Game
- please HELP!!! CEL is on
- Problem after Problem
- Info needed on relocating battery to front bumper? 92-95! Example pic inside!!
- New to the site...GoldEK (pics)
- whats the thread size of a ek shift knob?
- B16a Gen2 Swap
- Some hints/help at the engine rebuild
- Help with swap into del sol....I SEARCHED
- Help! driver side rim has brake dust, passenger side doesnt?
- noob shifting questions
- Speed sensor hooked up and working but throwing a code 17 for VSS???
- Honda del sol Rim Question
- J's Intake // Password Intake
- did OBD2 swap in ek but need a little more help
- Throwing Code 12 on P08
- intake sucking air but not going forward?
- D16 Headers and Intake
- Transmission Q's.
- short shifter
- HELP..dc headers installed
- wiring diagrams???
- Ok boys... Lets talk NUMBERS!!!!!
- What's the most comfortable seat?
- damn another problem
- so cali transmission mechanic?
- zc help
- Grinding Noise
- OBX or SKUNK2
- need help from a ek owner
- my first build, comments and suggestions?
- Installing Apex SAFC on a 95 D16......which wires to tap?
- 95 D16 timing belt and water pump help.
- Power folding mirrors?
- tensioner going bad??
- help please!!
- WHICH EXHAUSTS ON EK'S GO UNDER THE CONTROL ARM? ek9 buddy club apexi
- New Jersey Machine SHOPs?? Central and NORTH JERSEY??? anyone??
- Legit 5-lug?
- obd0 to obd1
- ??? about b18a
- civic brake lights
- 00 si
- What do i need to install with the new pistons
- Hood pop
- Will it Fit???
- j's racing intake
- Im thinking of sealing my car throw me a price
- Rear disk brakes? Did I get lucky?
- Tire Treads Messed Up
- 95 Civic EX Red Parting out..... $600 for whats left....
- Axle-back.
- Final Build,... Need Tech Advice
- my soon to be project car
- crx mounts and axles?
- K23A1 in civic hatch
- How to Stop my head lights from leakin water
- Simple question.
- 93 civic rear subframe
- Strut bars?
- climate control
- Tranny Issues....Calling all Tranny People!!
- replacing outside door handle, how to?
- white smoke???????????
- what do you think?
- cant rev pass 3500 rpm??? CKF???
- ek lca?
- WONT START!!!
- Motor mount question - Motor is rubbing/moving - ek
- limter 3k?!!? sometimes!! yea weird!!
- ls/vtec beast
- Does this look right to you?
- I have a GSR in EG, What fuel line, and rail do I need to fit properly???????????
- Anyone know where to get cheap Helm manual?
- Valve Problem....... White carb build up on valves, looking through exhaust port ? what this mean?
- how to make a "poor man's type R" motor?????
- Newbie to Hondas
- Suspension Assembly
- Injector Question... do you need a tune???
- 3 questions i need help with
- Bogging down or overloading
- d16y8 question
- Will LS header fit 00 si?
