View Full Version : Honda Civic / Del Sol (1992 - 2000)
- engine trouble
- d16 takes way too long to warm up, changed thermostat
- brake setup help
- Bad Master Cylinder or Booster??? Help please...
- Apexi N1 Turbo Silencer
- where to buy JDM d16z6
- ECU Code
- Ideling problems - 94 Honda Civic ex -Timing?
- One6 Motorsports - Chicago: Sold me a dummy tranny..
- To those with aftermarket steering wheels...
- 93 SI D16Z6 install
- pro-kit civic coupe 16" wheels anyone have a picture? pic request
- Can I use a '99 Si ECU in a '98 DX hatch?
- air conditioning just quit...help me trouble shoot
- swappin b16 into my del sol what else do i need?
- RPM redline and max boost on a boosted B16a2
- what would you check next? (running rough)
- jdm D16A question....
- BAR in CALI with JDM Type R (B18c)
- neuspeed or del sol vtec stock strut bar?
- Turbo kit parts "OR" Rota Wheels
- dual stage vtec????
- Mileage problem
- Squeek, when going in reverse, with wheel turned.
- Torque specs?
- ....QUESTION ABOUT HAVING 2 RESONATORS......
- starter wire
- Removing the A/C
- Hit and Run
- D16A question. which turbo will fit and which is good?
- Need assistance with HIDS immediately
- Eg hatch question
- Looking for a window Tint shop in the Palo Alto area, any help?
- Rods "shot peened" How do I benifit from it?
- 96 Civic EX head gasket in a 94 civic Dx
- water in taillights
- HELP WITH FOG LIGHTS...!!!
- The red rocket is no more...most likely!
- eg tranny question
- Are d16y8 vtec?
- Quick question about valve breather tube.
- trans ?s
- Fuel Pump?
- AEM Intake Question - please help
- 99 00 second o2 sensor wiring location
- Running rough on startup. Eventually evens out.
- D Series transmission help needed!
- Help with location of the transmission fluid dipstick! D15B7
- Is this OEM rear lip?
- type of distributor?
- 96 Civic EX Interior Harness Problem HELP!
- 92-95 hatch
- engine boring
- idle problem
- turbo?
- Wiring Question
- Need Help: Upper Control Arm Anchor
- What to look out for when buying a used civic.
- Nasty tune with78humongous injectors
- Turn Signal Bulb issue!
- oil in distributor
- is this cam at TDC? *pic included*
- Problem Installing Springs on Rear
- Steering Wheel Shaking Violently above 70 mph
- Speedometer with jumping needle problem
- need help tranny f8ck up
- Running EK with out P/S
- Lil help please??
- 97 IAC?
- wheels stock
- H.O.P. Audio Console
- Del So TRANSTOP Swap Information
- DIY Paint Headlight Question
- h22 in eg hatch
- how do you get these out?
- civic headlight warning indicator.
- turbo-d
- need tips on boosting d16z6
- Gapping
- need help with water in trunk.. 1996 civic hatch dx
- How do you get pics onto posts?
- del sol clutch tranny problem?
- Braided brake lines (searched)
- What's the best suspension?
- Removing rear fender..HELP! (92 4dr)
- Linkage Problem
- Gas mileage
- Tie Rod Bushing/Steering Gear Box Bushings Replacement and help
- Blown fuses ?
- b16a2 w/ 12:8:1 compression question
- Can you put a b head on a d bottom end
- tranny/clutch problem???
- Is this a good clutch & deal?
- At a Loss - Car is not going pat 6000 RPM
- crank sensor problem...
- good Alignment shop in East phoenix for lowered cars
- toe in alighnment question
- Dude, what's my speed?
- may have hydrolocked?
- EK9 side markers, question?
- HUGE CLUTCH/TRANNY PROBLEM!! What Could It Be?
- www.jdm-online.com
- Omni Power Full Coilover Ride Quality
- Will '05 Civic EX wheels and tires fit on a '99 Civic EX?
- just put in synchromesh today......
- Si suspension fit all years?
- fuel problem?
- 2000 front end on a 96 civic? will it bolt up?
- gsr P/S pump on Ek
- y8 dizzy
- D16 motor WTF?
- High vacuum normal? 26 in hg on a B16
- si tranny to non-si engine
- Lock broke, in process of fixing, need help!!!
- b18c5 in ej having vtec prob please help!!!!!
- D15B Vtech longblock for 95 civic?
- What engine management is recommended?
- advantages when using type r shocks
- Problem with new d16 engine and old d15 transmission
- del sol guys
- What year radios fit a 92 civic
- I'm Ordering a Hood and Spoiler Today
- 1996 integra rear sway bar for 96 civic 4dr!!!
- crower stg 2 help? d16y8
- I'm Ordering Azenis Today
- 99 Honda civic Si shell for sale
- Anyone got the hook-up on Exedy flywheels?
- b16a to b16b?
- time to replace spark plugs and wires?
- hello i am looking for a one on one
- ek hatch: amber taillight bulbs and DIY amber climate control.
- headgasket problem
- Prothane MM inserts, What did i get??? Anyone with MM inserts, PLEASE LOOK!!!!!!
- torque wrench compared to ratchet
- TURBO LIST
- b16b swap
- WTB 99+ oem silver civic front end
- civic to integra cluster wiring help
- Putting a front lip on
- WTB: Gsr w/LSD or ITR Tranny
- HELP !!! w/ JDM Integra DC2 98 Spec. Type R 23mm Rear Sway Bar !
- 92 hatch.. cargo cover?
- looking for 94 dx head
- WHERE CAN I GET ENDLINKS FOR AN EM1 AND WHAT KIND?
- d15b2 - low power at low RPM when cold
- 99-00 climate control into 96-98 civic
- here my whip
- best spark plugs
- Ereubuni Rear Lip for del sol?
- b16 help!!!
- This a 99-00 grille? Pretty sure, but still.
- wheel studs : 98 civic
- turbo
- Street Driven Turbo Del Sol: 3 Inch Exhaust or 2.5 Inch with 3 inch cutout
- Spindle nut
- Just grabbed SCCA civic
- Omni vs Skunk 2 camber kit *HELP*
- can anyone run VIN numbers?? read why i need this
- SOHC motor tear down, need advice, suggestions before I do it!
- Hondata Heatshield
- help with swap info please
- what would the symptoms be of a messed up throw out bearing or a pilot bearing?
- Difference between ZFR6J-11 and ZFR7F-11
- Will these fit?
- Door Panel Schematic....
- quick..question
- bauley civcs car
- 96-00 Civic LX stock spring rates ?
- I need help
- engine build
- Axle Wear?
- LSVTEC help...
- Headlight problem in my 2000 civic, help please!
- Double check me please....4-wire O2 sensor wiring
- Exhaust Manifold for D16Z6 just 1 o2 sensor? 94 SI is OBD1?
- Greddy oil filter relocation ?
- please help
- H22 Timing belt tensioner question
- 16 inch rims
- vtec question
- My Del Sol Interior Transformation "56k will die"
- D16Z6 ON D16Y7
- FI Question
- d series sites
- srs light
- PasswordJDM........got their intake? me too, quick question
- quick clutch question
- Supercharger application question..
- 99SI......tranny
- exhaust help. BUZZZZ
- vtec does not work sometimes
- 90-93 integra fron disk on 98 hatch?
- How much power will i get?
- CEL Help
- Newb Question About JDM R in an EK
- I WANT TO BUY...1993-96 CIVIC HB WITH B18 MOTOR FOR CHEAP
- Question about suspension
- speedometer not working, please help
- Need to buy axles/mount... have some questions.
- Will a EG HB exhaust fit on an EK HB?
- 97 HX throwing code 67.....???
- Starter question: 98 Honda civic EX
- b18c1 in my ek
- automatic to a manual question
- chappy idle
- Tach. is off after swap.....?
- Anti theft thingamajig
- Would this fit on a 95 Civic coupe dx?
- P08 ECU HELP
- Signs of a dying Alternator???
- sad day for my friend
- 92 vx ls b18 swap wiring
- 99 Civic Ex rear disc conversion (searched)
- hid question
- Suggestions for a machine shop!
- Help Seperating the Front LCA from the Knuckle (99-00 Civic SI)
- My new eg setup...
- LS head on b16 block? vtec?
- n00b terms
- Hit and Run
- Need some with some info on ECU codes OBDII
- B16A2 Oil amount
- can't find a upper left motor mount?
- Trubo fitment?
- block off plate?
- Heat not blowing through air vents..What could it be?
- I love my Honda
- Aem hybrid intake and Si Rim for sale SOFLA!!!
- 96 civic d16y8
- 95 ls into 96 hatch cx, bogs and idles really bad.??
- What is this ripped belt?
- 1996 Civic Ex
- Clutch master cylinder bad???
- Fuel Gauge Problem
- Is it worth putting money in a d16 sohc vtec motor?
- Third brake light is out, how to replace bulb?
- is this spark plug wire normal?
- 00 Civic EX - Need to replace passenger door skin...Help!
- RPM flys everywhere! Check engine light flashes like crazy and the car dies...
- d16y8 vs d16z
- completely stock cx running rich?
- ATTN: D-Series 1.6L guys
- brake fluid for '96 civic
- transmission problem
- The New Guy
- Installed Russell fuel filter line, did I do it correct? Pic included
- Loud Noise
- can someone identify this cluster?
- Need help with 95 sol vtec PLEASE
- Need help asap v-tec question.
