Knock Sensor?????????
hello i need help i bought a engine wiring harness for my b16 and its for a single cam so it doesnt have a plug for a knock sensor it has a evap solinoid plug can i convert that to a knock plug or do i have to make a new one
Re: Knock Sensor?????????
Find a plug that fits the knock. There are alot of plugs that will fit including the one you mentioned even though there are two pins on that one, the knock only has one wire so plug it up to see which wire to use on that plug and wire it up. You can remove the pin that is not used in that plug.
Technical Hero
Plugs that will work with knock: Evap purge (OBD1), IACV, IAT (OBD1), ECT, Powersteering pressure switch, VTEC pressure switch, fan switch (OBD1/2) to name a few
yeah i know it fits up what do i do about the wiring at the cannon plug to the ecu can i just deppin and move them to the proper locations like corrisponding blanks in the cannon plugs
and to hmonguy918 i couldnt find a b16 wiring harness that didnt cost like 300 dollars
to letam06
i bought a engine wiring harness for my jdm b16a and the wiring harness is for a single over head camshaft or s.o.h.c. vtec engine like a d16z6
sorry that i didn't use proper punctuation so i revised it for you
to everyone else thanks for the advise
(JON)
12-03-2003 06:05 AM
