View Full Version : Honda Civic / Del Sol (1992 - 2000)
- swap info?
- 0BD1 TO 0B0 BLOCK???
- si front control arms and swaybar
- bad alarm remote?
- Will Tower Bars from An EF fit an EG?
- Will Tokico Blue EF Suspension Fit An EG?
- civic 19 ex cam shaft
- will open end extended lugnuts rust?
- 94 ls odometer/trip gage not working
- auto/manuel axle question help
- 96 CIVIC H22 SWAP
- Went to the carwash...now I have no brake lights!
- eg ls swap
- 2000 Civic LX blower motor
- 93 civic AIR conditioning recharge question
- Before Buying a Civic - Questions About LS Swap
- DANGIT!!!! -- Broken Plug Wire Boot giving me FITS!!!
- how do i remove axles?
- 92 DX Breather
- Takata should pads new vs old?
- Service Manual For 92-98 Civic
- 96 civic upper control arm bushing
- civic valve adjustment
- replacing boots on a 1995 honda civic?
- type-R sideskirts
- Car will not move with clutch pedal depressed
- help, DA cluster (auto) into a 96 civic (stick)
- anyone ever use one of these before?
- o2 sensor?
- Tomorrow looks like it's gonna be a "Labor" day...
- 92 hatch with ls or 94 with b20 ls
- Im having a bad day.
- Burning oil? Help
- Sway Bar Q's
- Exterior trim replacement
- idling issue
- What type of freon does a 94 civic ex require?
- Warning lights on Jap Crx del sol
- are all VSS the same
- Dilema Civic 95 vs. Civic 92 - Help me i'm a nub
- 94 civic ex heater/air con turns off when hitting a bump in the street
- who has a garrett t3 60-1 turbo for sell?
- no fuel pump or spark
- is a k20a or k20a2 worth the money?
- Need Help
- Fresh New Motor Has Hard Time Cranking??
- d16 stock sleeves hp help
- will integra panels fit an eg hatch??
- Torque wrench guide
- tunning
- car shuts off, need help
- ::sigh:: im stuck, please help...
- Quick question about tps
- Blower motor is making noise
- 92 to 95 civic A/C parts fit a del sol?
- Integra DA Seats in EJ8 Civic?
- chip ecu question????
- How does "sponsorship" work? (Sport Compact Pro)
- fuel line leak
- Best headlight bulbs to put on an OEM headlight?
- Getting a Gen 6 - shopping tips?
- help my DEL SOL... PLZ...kicking problem
- whats wrong with my car or turbo????
- Best K Series motor to turbo?
- ez question
- 2000 Civic DX Stalls while driving
- i have a 2000 honda civic dx ac compressor
- Fuel Question
- 93 civic ex 1.6 what is the oil pressure suposed to be?????
- Check engine light on...i need help...don't know what's wrong
- help tire rub on my 92 civic lx
- wierd kick ...tranny?
- Main relay
- lip question
- Timing belt
- d series girdle removal question
- Need inspiration and help with rear disc conversion
- Thoughts on Oil Catch for Civic 98 Ex?
- 94 Civic Control Climate light problem
- D16Z6 engine code question
- hatch throwing codes...NEED HELP!!!
- anyone running ek P/S in a eg
- Code 16 car runs fine
- I know it's not hydrolock but is it ok?
- Stolen EG
- 96 civic ex charging problems
- Need help bad!!!
- where do i get these front bumpers
- b16a2 with itr cams
- aem cam gear
- LOWER CONTROL ARM
- 00 EX rear disc conversion - questions
- I need some help with my AC system
- GSR swap no VTEC and no Codes, solenoid seems to work, HELP! (ya I searched)
- new headliner for car with possible aftermarket sunroof?
- Increase gas mileage through add-ons
- New (to me) 97 LX...suggestions for tools?
- Hx transmission swap
- cam holders .... help pls
- quick and easy question.
- Gsr motor with B16 head Smoking out of every hole?
- 99 sedan doors onto 98 hatch?
- Where could i find them!!??
- quick resonator question
- ls/vtec turbo question
- how do I remove a head rest cover??
- how do i put on a tech on a 96 civic ex
- steering rack
- still ballin, I mean boggin
- what type of material is this ??
- 5 lug conversion problem
- Mind Me Help. Can' find thread i'm looking for.
- exhaust to loud!?!
- computer problem
- Interesting clutch problem.
- How do I remove the proportioning valve?
- 99' Civic factory alarm, how can I test to see if working
- too rich
- d16 plugs
- CEL after VSS disconected???
- ***Stealership? It's been a while... Input please?***
- Check engine light Obd2 P1259 Need Help!!
- Exhaust question for Sedan and Hatchback.
- ls turbo
- Unpin ECU-Plugs?
- EK hatch
- should i do b18c5 turbo or high compression
- swap or sell
- 11.3:1 CR and Turbo Charged
- vtec controller
- SMOG REF GONE, TIPS ON PASSING SMOG CHECK NOW
- B18 Afc Neo Installion help
- B18c1 bracket drivers side question in a 95 ex coupe
- Wheel bearings - Do they require any maintenance?
- ALREADY SEARCHED! d16z6 bottom end d16y8 head need help asap!!!
- question about k swap
- Do I have VTEC?
- Tein Basic
- My questions about a B18C5 swap in a 93 del sol
- ***DOHCIVIC re-build thread***
- having rbc trouble help needed!!
- buy new motor or rebuild my blown b16 type r
- integra sway bars in ek? & how to install bushing for shift linkage
- does anyone have instructions on how to pull a d16z6
- is this the new s2000 or del sol??
- Putting a Manual H22 into auto 95 civic
- 1996 honda civic stereo configuration
- Cleaning Help!
- EG6 B20vtec bad idling problem, TPS??
- Honda civic "performance chip"
- Opinions? VTEC quieter with S2 IM, CAI, Header, Catback????
- oil cooler
- accord ex injectors into a b16?
- amsoil????
- auto shift linkage
- Fuel pump
- CAR SHAKING!!!!
- THIN MOLDINGS FOR EK HATCH!!!!
- Idle Problem with **VIDEO**
- Starter problems.
- Civic not turning over?
- Check Engine Light?
- 1996 Civic DX A/C Question
- Plug Gap on boosted engines
- engine cranks but won't start after airbag deployment
- Have any opinions on what I should do to my car?
- EK rear brace removal?
- civic type r
- No Brakes..
- Spitting and Sputtering and CEL
- Timimg belt broke... can you recommend me an engine for my 93 del sol?
- NEED HELP!!! bumper PROBLEM!!!
- Did 99-00 civics come with a door lock control box?
- VTEC doesnt kick in til 6200???
- Need paint for touch up
- Body Kit
- chipped/unchipped ECU
- EG JDM Climate Control - Install???
- Car dies right after startup..96 civic
- Will ek spindle work on eg?
- I Need CV Axels (I Searched)
- fuel pump ?
- Check engine light on, but no codes showing
- Start up problem
- fuse broblem.. help!
- New to Honda-Tech! Greets from Germany
- Louder vtec
- 3-wire to 2-wire iacv problems d16y8 need help
- b16 problem
- ***EG Door Panles Write Up to Change Color!****** LOTS OF PICS!
- rear break lights dont turn on 96 ek hatch
- Question: My car is idling up and down. What can be the problem???
- What year/model cars use the same ignition switch as a 93 Civic?
- Distributor EJ8
- What are good xenon lights to get for 2000 civic si?
- what exhaust is this?
- D16Y Engine swap with D15B
- 97 civic dx issues.
- Smoking 99 Civic Taillights?
- HeadGasket ideas???(under Boost)
- SQUEAKY CLUTCH, already searched no HELP
- car wont start, solid CEL light, replaced ecu already!
- strut bar question
- Power reving please help!!!!
- Electrical problem
- will this prop valve work?
- can i swap a y7 head onto a y8 block?
- Auto Transmission help....Bad bearing?
- Temp gauge not working NEED ADVICE
- max tire sizing...SEARCHED
- Honda Ek question.
- H4H or H4
- A/C not working please read.
- 96 EK Cat-Back in a 96 CX
- Bad a/c compressor?
- VX/CX Input shaft Bearings Part numbers?
- EG rear sway bar
- Too Much Noise When Driving
- addin abs?
- p30 jdm ecu
- removing third brake light panel
- wtf!!!! is a.....
- Help
- Need help identifying if this is an OEM Honda axle or just an aftermarket axle.....
- Question about Catalytic/cat-backs??
- will single cam civic starter fit integra?
- Best Cold Air Intake Brand for Civic Ex 2000 (Opinions Needed)
- What do I need to change to swap an LS from an EG to an EK?? Help, please.
- b16 oil cooler, need water line part numbers
- ITR vs stock suspension
- i'ma noob with a question
- Simple Swap Question.
- living in MASS and trying to get inspection sticker!!!
- Canadian SiR or UK SiR Roofskin
- Help with code 13 BARO?
- Fried p30 ecu,need some help please
- Swap Question
- valves
- Oil light flickering
- will eg shocks and struts fit a crx?
- intake
- D15 With Z6 head?
- you dx guys are lucky!!
- NPR Piston rings?
- ETHOS???
- Stuck Axle Nut on a Honda Del Sol '93
- HONDA-TECH help needed.....2 years and still not fixed
- Window off track
- Exedy Oem Clutch
- lca, camber kit
