View Full Version : Honda Civic / Del Sol (1992 - 2000)
- i cleaned my engine bay and now my car is dead :(
- My opinion on rear disk
- stock spring rate on a 98 hatch
- NO POWER TO RADIO AND CLOCK????????
- ? about Brake boosters for rear brake conversion (Yes searched this is not covered)
- idle probs
- question for those using ITR springs on their EG's
- dropping it
- Replacement panel filters
- how do i take off honda leather steering wheel cover?
- broken a solanoid in a swap, what's it called
- anyone buy a used motor from importbuilders.com?
- NO-tec... LS vs B20
- GSR T/B
- RS front Brake Caliper and rotor info needed
- 92-95 knuckles the same?
- how is the visibility using fake or real spoon mirrors??
- Idea for a cheap wheel lock***
- Need Suggestions...
- boost a d15b7?
- Does anybody agree with what this guy has to say about an LS-VTEC setup?
- Help my Bumpy ride!!!
- How to install Spoon mirror on an EK?
- Spoon mirror????????
- SOHC Vtec bolt on . . . . what would be the most beneficial next?
- mini me swap
- What do you think?
- Hood Gauges
- ES oval
- H22A or turbo B16A
- heavy vibration after small accident
- getting a b18b1 put in, whast yur avg. et??
- Getting 16" rims for the EH2....suggestions???
- *** Clutch or Transmission problem
- urethane bushings for short shifters
- fuel injection cleaner
- pic of EG on 195/45/15s
- ff drift!!!!!!!!!!!
- Clock DimmeR???????????????????
- What to do before bar and no papers!?!
- Where can I find them Benen carbon fiber products for my EG??
- I am a newbie
- Update on my 92 hatch a few pics (56k maybe)
- i need a car tuner from ct
- Some Pictures of my 99 Coupe
- Tired of water in my rear window, how to solve this annoying problem?
- Power Window Convesion
- need diagram to install my alram in my 94 civic coupe
- 00' Si swap 30k, clutch slipping?!
- Anyone know how to smoke out the amber corners ???
- Importing a car to the U.S.
- Pooopy 1/4 time of 99 Civic EX
- new clutch? newb question
- hi i am a newbie here
- carpet q
- d16y8 ECU work on a d16y7 block and d16z6 head?
- Questions on Body kit
- anyone know anything about this turbo kit??
- sohc turbo pointless??
- Jdm ITR header
- Knock Sensor for 92-95 JDM b16a
- will car over-heat with H22?
- ** Cheapest Place To Buy OEM Parts **
- gsr master cyl. diff between abs and non?
- momo hub adapter compatibilities
- Just came back from the track
- More pic of my slow EK
- integra radiator into 92-95 civic
- first time posting my ride...
- brake upgrade
- Pics of my lil bucket Betsy......
- 97 LX catback?
- first time posting pics of the sol
- b16 wiring (P30 ECU) into 95 civic DX
- What to fill trunk spoiler holes with?
- Del Sol to EG front end conversion (What does it take)
- y8 manifold on a d15b
- What is the weight of a steelie rim?
- What Swap should i do for a eg6 civic
- here is my slow EK...
- dip stick questions
- Any of you put integra pistons in a d15
- How do i get to the rear speakers in my 94 hatch?
- SPOON Carbon Fiber front lip on a del sol?
- Any Marylanders able to swap a tranny?
- how much are 00 to 03 civic stock rims worth?????
- Side Skirts, Are EX and SI Sides the same?
- can you put a 2.25" header on the stock 99-00 Si cat?
- Lookin to go to the dark side . . .
- 99-00 brake rotors on a 92-95?
- delsol identification help.....
- engine swap questions
- rattling problem
- curiosity
- H22 engine drop on del sol....
- New pics of my car (plus the HID's in the euro headlights
- Car messed up!?!?!
- Might get a RHD del Sol, how hard is it to register???!
- N1 piping, hanging to low?
- del sol sway bars
- compression test results...
- JDM hatch with US license plate question.... 92-95 civic....
- Skunk2 Coilovers
- Question: If AC is removed, do you retain heat?
- Got Hit
- What do i need...Y7 intake mani to Y8 intake manifold
- Need help
- which short shifter to buy, fast reply
- does anyone know where i could get intercooler piping for a ex ?
- Yet another problem to add to the list
- Pulsates and Pulls to the left when I am accelerating
- Manual / Auto Dipstick the same? (ek)
- EG8 with JDM B16 *Question*
- Question about TOTAL LOSS cars...
- Jdm Headlights and tail lights
- Need suggestions for a camber correction kit!
- Need Opinion: apex`i world sport exhaust vs. rsr ex-mag exhaust
- Why do you need a brake kit
- d16y8 into an eg... need help.. :)
- need wiring diagram w/relay 4 eg6 pwrfolding mirrors
- Attn: Admin.
- 96-00 sohc vtec tranny in a 92-95??
- tools needed for changin rotors
- a/c in eg2 question?
- 92 cx stock power?
- whump-whump-whump-whump noise on tire revolution (I guess)
- Just bought a 92 DX Hatch.. Motor wont start...
- Headlight wiring.
- pods!!! help
- 92-95 2dr EX exhaust to a 92-95 4dr LX?
- need help with me coupe suspension
- URGENT!!! Car doesn't start
- EK springs on EG, they will fit right?
- How do i tell if BRAKE proportion valve is ABS or not?
- Drum to Disc conversion
- got the swap done
- EG Stock Exhaust Question
- Dropped Redline AND Code 31?WTF?I'm confused...
- Apexi N1 fitment, EG vs EK
- New lower profile oil pan?
- dear God...Why!?!?!?
- IACV
- rims wanted
- Swap CX cluster for GSR cluster?
- New Exhaust System......................
- ITR suspension on Civic EJ
- ex 93 automatic cluster fit cx 93?
- oem fog question
- How to add HID to my EG?
- MASTER CYLINDER STOPPER
- A whirlllll noise
- 90-93 Integra Master Brake Cylinder fit a Civic???
- My new car after the theft of my Si...Woo hoo!!!
- BAR certified B20, is it possible ?
- throttle body problems
- Ignition diagrams
- GSR DASH ON A CIVIC HATCH please help me
- stipped brake (hard) lines nuts?
- Ride height law in AZ ?
- guys I slid into a wall(Pics inside!)need ideas!
- gsr brake conversion from cx eg brake lines?
- new suspension parts
- Del Sol power roof problem
- hey guys, just wanted to share something.
- d16y8 vacuum diagram
- 195/45/15 kumho ecstas....195/50 es100
- b16 swap into 95 dx question
- Stock EJ wing removal wiring.
- first time post pics, What you think.
- help on clickin sound when i shift
- skunk2 struts, rear sway, and rear lower tie?
- anyone dumped on tein SS coilovers?
- Idle on Civic revs high, then low...IAC?
- B16hf's EK :) (56k why the hell not!)
- what,s wrong with my car?
- How can I make sure it's JDM???
- Synthetic Oil in a 03 Civic EX?
- B16a2 Exhaust Cam Vs. B16B Exhaust Cam
- Shipping a motor?
- Will Eibach Pro kit springs fit on GC sleeves?
- need help with rear light wiring
- p/s removal trouble on a sohc
- TRANSMISSION SENSORS
- Where to find cheapest O2 Sensor
- wow swapping again... im gettign sick of this
- jdm eg9 seat question
- door insets.....
- O2 Sensor Wiring HELP!!!!!!!!!
- 1 piece header?
- battery light
- Help! IACV issue again
- Prototype carbon fiber lip for EG! original design
- Finally got a rear disk converison!! But ?'s about the ABS lines
- Problems with sideskirt.
- JDM Time in Georgia! Take 2!
- Pulling Check Engine Light codes on a 96 Civic (yes, i tried a search!!)
- Civic A/C mount, do I need one
- comptech rear tie bar?
- Possible Transmission problems??
- B-series rods on D-series crank?
- Crankshaft Pulley Holder tool 50mm HEX
- what mods for a 92 hb cx, just got 1
- Nitrous question
- ek srping rate
- anyone had a problem with AEM short ram cuasing a stall?
- replacing an oil pan
- CEL code 10 ..where is it?????
- anyone got the skunk2 ECU ?
- About the Sparco torino seats...
- looking for some wheels need help
- went to the track tonight and am pretty dissapointed
- Please Help Fast!! 93 rear disc bolt on 95 coupe?
- 94+ under dash harness w/ teg dash?
- Got a swap and took her to the track.
- Is this a good buy?
- HIgh CO count on cx emission test
- wat size bulbs light up gauge cluster?
- Hit the track tonight, sohc style
- Jackson Racing Vs. Vortech Based For B18C1 Hatch....
- best rear sway and tie bar for EG's???
- crower cam ?
- I think I have a short...
- AEM V2, no VTEC now?
- queston about skunk2 spring rates
- Oh my god!
- difference b/w new and rebuilt...
- Civic Headliner
- Selling A Set of Axis Touring Cup w/ Blue Center Caps for Civic, Integra, 240SX
- Selling A Pair of Used 96-98 Honda Civic Clear Corner Headlights
- Compression Numbers?
- CEL on my Civic??
- Recommendations on a good muffler?
- how do i take off my center console?
- intake mounts a problem..on a SOHC AC autotechnic
- I need to find this!!!
- idle prob on a y7... help
- APexi or greddy SOHC turbo kit on a d16y7....
- clutch
- Ground Control coilover problem
- do you need a spring compresser to change your shocks or struts?
- Spades "one time" picture post in the Civic forum.
- need opinions on my b18b
- newbie questions about hatchbacks
- kinda dumb, but do lighted flywheels help gain traction?
- before or after? what do you recomend?
- '99 Y8 IM into Z6 head ?!?! fitment? will it work?
- whats the best looking side and rear lips?
- Anyone with SRR Cup Kit coilovers?
- black housing
- hard time finding p54 bracket (aircon question)
