View Full Version : Honda Civic / Del Sol (1992 - 2000)
- quick catback question.
- Will B16 Vtec Solenoid gasket work with GSR?
- deals that are "not what they seem" in the scene thread
- Password JDM
- Short Shifter Problem..
- brake elctrical
- Autozone spring compressors
- EK hatch exhaust HELP!!!
- What headers do i use for my b18 in my EK
- What should i do with my civic ex 99
- Engine torque specs
- ne 1 know the part number
- civic shocks? which one?
- CTR Cams
- hi oil pressure help
- DIY Extended Shifter- Somewhat ghetto style
- MY RHD EJ1 PICS
- What to use for turob/parts after mini-me swap?
- Power mirrors and locks tied together somehow?
- weird noise in the rear
- Need advise Ls vtec ???
- Si-99 Shifting Troubles
- Radiator brands? Ebay?
- tachometer help
- more power....
- ls/vtec ecu????
- Winding noise coming from engine bay......... Help
- asr brace
- help me decipher cel code
- skunk2 pro-series intake manifold on gsr in 94 civic si hatch smog?
- is this a good deal?
- y8 head
- b16 block with gsr head
- Quick question - did Honda discontinue 99-00 front bumpers?
- Where can i find This???/
- help plz timeing issuse i think
- Difference between EG6 and EG9?
- cylinder head P72
- Hmm Question?
- Aftermarket Cam Gears....
- how do you remove 96-00 civic rear seats?
- Leaky Oil Pan fast fix?
- My Civic 93' Sedan.
- High milage, what to look for?
- Help! WTF is up with my brake/tail lights!?!?!?!
- greddy turbo kit stock b16 safe?
- Are these EX or GSR LCAs?
- Header question
- 93 Hatch Vx.... wiring
- battery problems!?!?!
- b20 vtec injector help
- electrical
- Injectors
- car isnt priming
- Window won't close now...
- EX cluster in Si
- Maintenance Required?
- y7 help
- HELP PLEASE: Alt issues
- 97 to 00 front end conversion
- Fix for the Honda reverse gear sticking?
- CEL 22 LS?V in 94 civic
- del sol shift problem
- horn relay, sunroof switch and driver side window switch click
- Fat intake
- Turbo tunning Help.
- quick part question.. shared with?
- Drum to disk confussion... Eg disks onto my 00 ek hatch
- B18a1 into 94 Civic Hatchback
- 96 dx hatch exhaust question
- Can a 99-00 Si radio light up white without changing the bulbs????????????
- need help changing rotor insisw dizzy.
- CX transmission in Del Sol
- Radiator fan problem.........
- i cannot find this exhaust
- Del sol shifter questions
- Alarm Help
- '96 HX, bad gas mileage and getting only 5* advance at WOT???!!
- flywheel question
- Broken spark plug = Low Compression?
- got my shifter extender from circuit hero
- Tried searching, quick help
- any one know of a good shop in cali
- Aftermarket Steering Wheel Help!
- samco radiator hose problems
- crap guages ?
- Hello/Input Shaft Woes
- Need help on SOHC Turbo Kit
- couple of questions...
- 95 civic lx cv axles
- ACT clutch problem
- motor mounts???
- Wiring Schematics for a 93 Civic Hatchback
- engine bogging help help help!!!!!!!!!!!!!
- surging when...only anfter car is no longer in motion? why.
- hood not popping open
- b20/vtec vs. ls/vtec
- Header Question
- World's First - 11.1" REAR discs on a Civic with drum spindles...
- help here, what time 1/4m Coupe b20 vtec stock
- eg6 cluster needle not lighting up
- will 93-95 rear struts fit on 96-2000 civic
- water cooled turbo
- honda scene in oregon?
- Valve cover swapping!! PLEASE HELP
- 92-95 civic check engine light
- d15b ecu, cam, and headwork
- slight problem with my civic
- Car won't start! --94 Civic EX-- Throwing CELs 17 & 41
- 93 Ex tie rod end on a 94 dx spndle??? Need to know asap.....
- Good links or sights to JDM Products ?????? anyone
- desprate need of tranny help!!!
- nrg short hub+nrg slim QR on a 92 civic question.
- 93 civic cx brakes smaller than 95 civic cx?
- integra carpet in hatch
- D15 engine hooked to D16 Tranny
- Sensor Interchangability Between D and B series
- Does anybody have pictures of Rota C8's mounted?
- D series setup
- civic hood question
- 95 Del Sol worth $3000?
- Knocking? pinging? rattling?
- how does this sound!!
- Wierd .... Rev-limiter at 6600-6800 RPM
- 96-98 fog lights?
- my first car eg
- rsx muffler on ek
- overheating problem
- i got a question.
- battery loosing charge after installing foglights
- D16Z6 Check Engine Light (MAP Sensor?) and idling questions.
- quick question about intake mani..
- JDM mud guards???
- Power and Ground Reference for PLX wideband
- ls swap questions?
- How do you remove an ignition switch 92 civic cx?
- Clicking noise when car is moving and not in gear.
- rubbing noise from passenger side
- Hardware for JDM SIR LIP EG
- head swap help should I go gsr or type r
- 95 EG Hatch Brake Lights wont shut off
- engine pic
- 2000 Hood Rubber Seal
- arp headstud help
- When jacked up, tire easily moves left and right
- oxygen sensor problems. cel 41.
- bad cat?
- b18b what trans fits
- Is this mechanic correct?
- Need clutch kit!!!!
- Silly Mistakes!.. What's yours?
- RHD Engine Harness. Whats it to?? EK, EG, DC, or DA..........
- Skunk2 Products
- Buyers Beware
- Failed NJ emissions
- D16Z6
- Need some help on my gsr head.
- Hondata Gasket B16
- tranny question
- Cant select any gears?!
- D16Z6 Oil Pan question
- b16b going 60mph @4000rpm
- Distributer question
- need engine for 96 honda civic vtech
- 92 Civic Hatch rear disk question?
- LS Swap: For those of you who've done it, What did you forget?
- boosting
- Bypass Clutch Safety Switch
- Buddy Club coilvers good
- SPOON monoblock calipers on 15's, possible?
- Swaps
- Another Idle thread "sorry" :)
- new guy questions... need answers
- jdm s15b question
- A question?
- picking a new motor
- Good Idea or bad???? B.A.R.D My car???? you know what i mean... Please help
- does anyone here know a good tint shop in SF?
- h22 ek core support
- head gasket?
- JDM del SOL
- New Brake calipers not fitting 96 civic EX stock rotors
- 92 vx eg with 95 gsr motor swap
- best cam to run(single slammer)
- ZC crank sensor question
- QUESTION!!!! HELPP!
- Should I get new rims?
- NEeed help plz help me!! Car is acting up after a new battery change...
- D16Y7 Turbo Intake Manifold Swap
- Dual Colored HIDs
- How-To Install Honda Access Sedan Window Visors ok EK
- shifter problems... PLEASE HELP..
- aftermarket steering wheel
- 99 fogs help
- suspension...please help
- 1997 Civic LX switch front and rear o2 sensors?
- AIR BAGS!!!!!!!!!!!
- Can't shift into first gear at very low speed
- starter problem?
- Low Compression in Cylinder 1
- Will spoon clappers go over AEM big brake fronts?
- need help locateing some parts
- Civic Airbag Module
- h2b problem
- b16a2 or b18c1
- anyone who recently got their gsr or EM1 stolen???
- Code 14 - Idle is different then most, and after replacement...
- Brake Setup for 350hp in 1995 Civic DX coupe GSR brakes good enough?
- Wheel Bearing differences??? HELP
- Will 94-01 Integra struts/springs work on 97 Del Sol?
- audio console question.....
- 92 civic motor mount question
- i think i have a problem....
- Body Molding Question
- steering wheel hub adapter
- Can someone give me some advice on what do next?
- turbo parts needed for installation
- Cluster Bulbs Help.....
- Ksport coilovers
- Kill Switch HELP!
- AEM Short Ram Intake Question?
- manual rack
- Quick bulb Q
- power steering removal
- My car has a hesitation when I try to start it, 97 hx with gsr swap...
- WTB Roof Handle
- 1994 Civic DX hatchback won't crank
- wanting to boost my b18c1
- how good is stock flywheel?
- intake mani swap problem
- How to Remove Rear Quarter Trim Panel for Civic HB
- Just bought a 93 coupe, water leaks....
- 99 si need fuse help
- totally ODD problem when first stepping on gas after startup!!!???
- DASH SWAP ?'s
- ??????what tranny??????
- Conveting a hatch to an Si question
- right hand drive converison how hard
- My poor civic is freaking out
- Would a exhaust from a 95 automatic civic fit a manual?
- Cel and revving idle obd1 conversion
- SOMEBODY HELP!!!
- WHERE IS DA FUEL FILTER ON A HONDA DEL SOL HELPPPPPP
- competition clutch? any good?
- off subject
- Problem with fuses.
- Damn! I just busted my blower motor resistor [96 del sol] pics
- Shift Knob Creation Questions
- Question about my B&M short throw
