View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Okay Guys. Limp mode. Follow me on the journey.
- my eg wont start. help
- Si Guage faces on lx cluster
- what mods are there for a b18c1
- civic ex vtec D16y8 no power
- MY 92 EG WONT START
- Projector Headlights
- Would a Apex'i N1 muffler from a 99-00 Civic Si fit a 92-95 civic?
- Engine compartment cleaning question?
- Finally!!! How to Get Rid of Honda Theft!!!
- Help fixing rear window defroster
- color situation????
- b16 idle problem
- just did brakes, not a lot of pressure
- 00-si abs brakes
- Is an inductive timing light necessary?
- Recaro brackets for 95 Civic Coupe question
- DIY: Shifter Plate
- How is the Spoon shift knob with a Skunk2 Short Shifter?
- 92 vx D15Z1 swap in 92 cx hatch – need wiring help plz…
- High HP sohc clutch ??
- $50 for the answer!!!!
- JDMSH!T carbon fiber hood... good or not?
- quick pr4 rod?
- z6 or y8 intake mani swap on d15z1
- Need help taking off rotor ASAP!!!
- help me please
- oil temp..... help
- where to buy?
- Cluster not working and blinkers please help
- just bought a vx hatch with d15z1, whats this problem...
- can i use a ac comperssor and p/s pump on from a d16 on a b16a2?
- Amsoil MTF SAE5W30
- Unusual squeak from distributor?
- day time lights ...noy working
- Shot Syncros?
- Civic Si-V6
- del sol forums?
- What are signs of a bad water pump?
- d16 turbo
- EG 92-95 seats
- MINI ME swap questions!
- A/C blows warm air
- ITR rear seats?
- broken dx not as broken anymore
- problems starting ek please help!!!!
- Help on wiring up O2 Sensor
- code 57 on 98 civic ex
- air condition question
- FS: 15" Rota Slipstreams
- Is it possible to swap a b18c1 into an EK and keep the A/C?
- i have 93 civic ex wanna swap a b18 in it got some qustions
- sway & tie, can u have both?!?!
- how i chip my ecu?
- this is bahraini civic
- Power window malfunction. Please help.
- Stripped my interior....
- water pump question...already searched
- Question about LS-Vtec (California People)
- how much pressure is stock b-series fuel regulator set at?...how much D-series..thanks
- OBD1: need pinout for these engine harness plugs-C303,C304,C211-C214. Thanks. Pictures helps.
- H22 Wiring question.
- d16z6 vacuum diagram?
- 96-00 hood, front bumper, front fenders for sale :stock: :cheap:
- SOHC Turbo Fuel Problem.
- bolts and raddle!!
- fuse problems
- y7 to z6 manifold swap need help
- flywheel ? *searched
- JDM B16a SIR II
- checking dipstick oil
- RACE --Civic Si-R Type-VTEC VS mkiv super--
- Car wont crank... help!
- How much should I pay?
- eg hatch stripped thursday morning-chicago north side
- fuse blowin
- DIY Poor-Man's Turbo Kit
- SOHC Turbo project...injector size
- Head vs Head
- Header Issues. Loss of power.
- 1992 Honda Civic EX-V
- WTB: 97+ integra cluster or gsr cluster...ASAP.
- Where to get JDM tails online (besides ebay)? (93)
- EK distributor rotor
- need help with possible misfire problem
- 94 Del Sol - Need Driver Side Glass, 2 black door panels
- A/C unit fit into a 94 eg?
- wheel inchs for 95 dx coupe
- Honda Electrical Gremlins / Problems
- Engine Damper causes car to swerve
- ITR REAR SEAT
- . The problem was tClutch question
- Is an Aftermarket Clutch Kit Supposed to come with Mounting Bolts?
- Who has the best price for apexi exhausts
- how to replace h22 alternator??
- Anyone replace there window motors before? I don't have AC.
- Skunk2 cat to short
- I need some help guys... Car Started smoking
- y8 vtech wiring
- overheating
- Ex Tranny= Si tranny =Del sol tranny??
- Are civic mudflaps optional?
- Weird CEL occurance
- EG w/ gsr swap... What cat for eg w/ gsr swap w/ 95 gsr header and 92 si stock piping and exhuast
- tranny making noise
- need help
- 00 civic rear turn signal question...
- eg stolen Bay Area Richmond
- 98 civic hatch
- Wats up wit my speedometer??
- throttle body spacerttl
- NEED HEL ASAP!!!(clutch change)
- Timing belt tension
- HELP! : starting problems...questions about relay....
- Compression Ok?
- FIrst Tech Post: DIY HEADUNIT cooling.
- Whats "ND" stands for?
- Electrical Help
- Do I need a new axle or just a new CV boot?
- So i got this b16a2 from a junkyard (need help first engine)
- looking for some one to do my swap b16 in a 93 civic
- Rota users what lug nuts are you using
- Wheel Alignment question about after u lower ur car...
- Del Sol seat question
- Sparco Harness bar for EG civic-anyone got pics?
- b16 engine sound
- Stolen Hatch - SD Mission Beach Area
- gimme all the shit you want its all in fun ill give it right back
- Need help with lip installtion
- supercharge or turbo?????? on the track??? any engine??
- checking p28 ecu
- question on exhaust on rebel 250
- im new here and i like what i see
- Difference in oxygen sensors
- Help with ITR rear seats into EK hatch
- 1993 Civic coupe for sale
- honda civic "check engine light"
- Cat-Converter help
- code 22. what do i do now?
- Mini me
- 95 CIVIC hatch VX Brake Conversion
- del sol and 96-00 civic question
- Confused about B18A1
- window off track, need help.
- Civic VX wiring
- PLZ HELP>>> MY 94 Si IS TOO BOUNCY AFTER MY COILOVERS!!!
- intercooler piping, fmu, and bov ???
- My $500 SiR (Donor Car)
- Y8 Dist. wiring help
- HONDA CIVIC 92 TIRE SIZE ?
- air box help?!?!?
- Review: Jim Fab lower mounts installed
- annoying rattle at idle
- Anyone from seattle!
- Good deal on these konig/kumho tires or not??
- 72mm throttle body to big ls/vtec n/a?
- ECU Code 43 What Do I Fix???
- ANY BODY HAVE WIRING DIAGRAM FOR 94 civic ex power window setup
- size pulley do i need to get more boost off supercharger
- 100psi of fuel pressure problem help please
- auto to man conversion
- CRX motor into a EG. Plug-n-play?
- stutter while driving
- :: Serious Help Please :: Engine Bogging Badly ::
- EK door seal :::::::::::::::::: HELP!!!!!
- what size spacer is safe with stock studs?
- suspension for my 1995 honda civic
- No cel at all (tried different ecu)
- Will Denso spark plugs be too much
- Is this 10 or 12 Psi worthy?
- axel help
- b16a vs b16a2
- i need del sol seats now!!!!!
- Valve lash for Y8 head
- 95 dx oem cat for b16...work?
- ****B series Hydro tranny clutch problem!!need help!!
- Taking apart aftermarket Tails...
- p30 ecu
- Finally got the Sol looking good.....
- a/c for DOHC swap?
- h22 and b18c5
- WTB 99-00 Civic SI harness
- moderator???
- 96-00 Hatchback tail light bulb Question
- functional duckbill
- Who makes a electric window kits for 92-95 dx?
- Starter compatibility on my z6 swap
- grindin goin into 3rd
- Cooling Fan not coming on, this is weird, checked everything
- needle replacment problem??
- Vtec Controller installation please help
- Painting / Refreshing your Molding done right!
- d15b?
- B16 thinks oil is beer!
- how do i take apart the autometer gauge...
- california motor swap laws
- reverse lights problems HELP!!
- '98 civic hatch bucking -- engine mount?
- o2 sensor question
- Fuel Pump question on stock car
- trailing arm swap
- GSR NEEDLES ON A 93 CIVIC EX CLUSTER...
- d17a2 Swaps for an ej8?
- Bouncy ass suspension... What's going on?
- Best Engine for a civic hatch?
- brake booster
- civic injectors
- d-series manifold?
- Ecu difference
- Pulling off the 'cluster trim' ? (quick answer if possible, easy question)
- B16 LSD
- size question between the hatch and the coupe 92-00
- 1997 Dx engine reliability
- Question on wiring up VTEC for minime swap!!!!
- What tranny do i have?
- 12v Switched Source In Fuse Box for Secondaries
- Nitrous???
- Prelude Type S motor into EG
- throttle body help
- EK rear disc conversion
- computer question?
- jdm power folding ek
- Car Settings!!!
- d16y7 in 92 civic hatch
- pcv valve on honda civic dx 1997
- Intake problem...
- 2001 Civic. Where can I jump it to figure CEL codes
- Where to get my 2000 Civic Si Engine Rebuilt, OR buy another engine?
- code 54! Crank fluctuation sensor
- removing role pin
- Engine is lagging
- Need help with full d16z6 swap into 96 dx hatch
- programing keyless entry for 02 civic
- 92-95 rear seat carpet?
- New guy with Honda issues.
- DUCKBILL, abs plastic
- failed emissions... high HC levels...
- Replacment fenders?
- Selling a 96-98 Carbon Fiber Front Lip for Stock bumper
- 1999 Civic HX Transmission Problems
- loosing oil some how
- d15b wiring
- Question about Exhaust fitment.
- Recomended oil for JDM B16
- dangers/side effects of a turbo?
- Reliability of B20vtec in EM1
- AC question on an eg (searched)
- Is there any way these front brakes be fixed easily/cheap?
- CRX Engine set up..Ever Been Done?
