View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Ok got a blown 00 LS motor What are some good ls motor parts can i swap on my d16?
- Engine swap question :D
- Fix the EGR problem on an HX
- How hard is it to swap a trans.
- need help on a b series head
- is this a good deal for b16
- Hondata Question
- Need a Rear Seat for a Civic Hatchback/CRX
- jdm itr rear seats in ek?
- sounds dumb but need a pic
- Whould you consider these rice???
- CF hatchback and handling
- EG Headlight bulbs
- hybrid h22 civic linkage
- RSR GT2 exhaust??
- will 205/50/15's rub???
- 99-00 obd2b civic cx/dx ecu pinouts
- finally.....pics of the hatch
- Autolock...feedback!!
- Skunk2 / ITR Shift Knob Dimensions
- vafc on obd2
- which settings...
- B18b into 93 hatch. Can I use integra mounts?
- Idle Problem
- part # for b series throttle cable
- New cams / Stock configurations....??
- HELP! ANYBODY? HELP!!!
- for u cali peeps has anyone ever refed an ls\vtec
- d15b7 2 d16y8
- OEM 99-00 Sir Bra Instructions?
- 92-95 civic hatch windshield....same as 4door?
- HELP!!!!!!
- distributor identification
- Integra air conditioning into EG/del Sol?
- DFW guys.... 5spd SWAP at MY house.... Food... BEER....Lets MAKE IT HAPPEN !!!
- anyone has apexi N1 damper coilovers in their EK's?
- d15 cams
- touch up paint, to primer or not
- >>>>GROUPBUY on Honda Access EK visors NOW IN EFFECT!!
- horn not werking!!!! please help
- I want to buy a cat back. RS-R EXMAG or Greddy SP2?
- gsr pricing
- WTB: Stock Del Sol Shifter.. let me know if you have one
- remove some paint.....
- AEM Fuel Rail Fitment Problem! Help
- FOR SALE!!
- y8 intake mani swap problems
- Spring Compatibility
- HELP!!!!!!
- state ref... I passed, got my sticker! woohoo
- JRSC Map Controller Help!
- header on a 97 dx????
- making myself at home
- Thin Side Molding
- Apexi N1 dampers coilovers
- need to know some specifics on valves into d16z6...
- fenders question
- Bent my volks! Can they be repaired??
- Best swap with the following parts
- how to install o2 simulator?
- Spoon: Pay the cash, get trash?
- USDM ITR final drive with JDM LSD
- Using a P28 ecu or P30 Ecu on a B18c? Why?
- Car wont crank till I let off the brake???
- p28 ecu
- need help
- water from exhaust?
- I'm Screwed!!! Front LCA bolt spinning in subframe
- I need help finding a vendor!!!
- nuespeed sports
- alternator removal question (92 civic si) searched
- MOST BOOST PRODUCED FROM A B-SERIES
- stock predule intake on civic?
- Does anyone know who makes sliding rag tops for civic hatch backs?
- Door Panel for a 93 COUPE!
- alternator or distributor problem?
- Are 9003 SilverStar's still pretty yellow?????
- weight reduction-what can i remove without sacrificing safety?
- would u say this is a good deal
- Removing side panels
- Eliminate my road noise!!!
- Uberdata?
- ! faint thumping coming from rear left tire !
- Will this work with my setup???
- Prelude seats in a 94 ex coupe???
- Rails for DC5 Recaros in an EK
- Where is that ITR rear sway bar parts list thread?
- Broken Lug Nut....help!
- My front end shakes when I hit the brakes.
- diference b16????
- Will a EG6 SiR Cluster
- d16z6 HELP!
- New Alternator??
- how to put on spoon styler mirrors
- Need some help...
- DOHC on a D series block?
- GSR Swapped Hatch....What do you think...
- Got my D15b from HMO! Also clutch/wheel install *pics*
- New here....Pics Of my EJ :)
- Sway bar + general suspension set up questions for 92 civic hatch
- exterior trim question
- jdm engines vs. usdm engines
- searched with no results.. exmag gtII exhaust on 96-98 coupe?
- What makes this happen?
- What do you guys do to clean your headlights>?
- about to buy something..need help
- EK Civic Type R conversion - who's done it? Pics?
- GSr or B20?
- Lambda-Sond EJ6
- Is this a good idea?? (READ)
- Mugen Lip and CTR Rear Lip.....
- factory fuel pumps
- Thinking of buying this del sol...
- Smog Professionals, Check out my Smog Test Results and PLEASE HELP!!!
- jdm D15 plugs, wires , cap question
- Turbochargers
- greddy evo
- My b18c1 keeps idling.........will replacing the o-ring on the IAC help????????
- DX stock fuel pressure
- Well guys the car is finally gone. New owner picked it up yesterday. I'll still be around.
- What Magnaflow fits?
- :Project Journal: 99 Ek
- NEW KID
- fiberglassor carbon hatches for ek
- what should i get? i have....
- comp test numbers b18b
- 96-98 to 99-00 frontend conversion
- Mini-me gone bad...engine doesnt start...help ASAP....
- carsound cat or magnaflow?
- CEL & Speedometer Not Working
- D-Series Exhaust Manifolds
- *d15 turbo* Automatic is it possible ?
- Best place to buy brakes????
- Crower cams
- Sir brakes = broken axles?
- kind of a dumb ?? but??
- ---===why would my transmission do this?----
- Keep stock internals or no?
- Looking for some lightweight rims
- cf hood
- interior removal
- My new car
- ZEEKIN.........
- J's Rear C Pillar?
- which is the p08
- Push button Ignition ?????
- 2ooo Honda Civic Si Probs - HELP
- B series transmisions
- For those who ordered a rechipped ECU from Kenji
- Lots of carbon build up on my rear end, whats causing it?
- H-T gurus....whats the difference b/t obd2a and obd2b?
- Interior lighting problem!
- Str throttle body question???
- where can i buy turbo compressors and accesories in minniapolis?
- gsr sway bar will it fit a 94 ex coupe????
- distributor questoin
- where can i buy exhaust for my hatch hks or apex n1
- Cost of a paint job???
- How do I lower my eg???
- Just bought new greddy exaust
- I know what the problem is..
- would a 93 sol heater core fit into my 93 CX...?
- WTF??? window wont move
- 01 ex civic swap suggestions?
- Car wont start... alarm?
- Fuel pump or main relay?
- IACV?
- b20vtec
- tools needed for ex brake swap to dx
- Quick throttle body question Need quick response.
- New member question on a '95 Civic
- heater blowin cold air
- WOOHOO GOT SUM NEW STUFF FOR MY EJ...
- How many horsepower can a stock fuel rail support on a 95 civic ex w/ turbo?
- Vtec crossover point
- itr rear sway bar applications?
- Hondata - Romeditor ?
- 02 sensor
- Overheating problem.... did search already
- obd2-obd1 harness
- car keeps over heating.. help
- quick camshaft question
- Will springs from an EG fit on a 97 civic?
- Cable and Hydro Trannies - Diff/Final Drives Interchangable?
- another o2 sensor question?
- RS*R ex-mag
- gsr cluster plugs
- Qucik question-spoon mirrors
- C-Pillar pix??
- VAFC settings
- si cluster in 93 dx ??
- FREE carfax boys and girls
- dash lights
- rear sway bar for del sol si with SRR tie bar
- difference between EG and EG6 siRII tail lights?
- POST PICS OF NEW GREDDY HEADERS!!
- JDMSHIT Front Lip fitment?!
- what would you pair your h&r sport springs with?
- vtec controller diagrams???
- CARFAX....please
- Need help quick! Please look...
- Iceman CAI for 92-95?
- QUICK answer plz ok to drive with no gas cap?
- a website that i can go that sells cheap oem parts
- ANODIZING???
- ECU
- si brake swap question
- Help, lost radio code!!!
- fuel system help
- Yellow EK Chicago
- free carfax
- weight of B16 with all internals including 4 quarts of oil
- needs help installing apexi n1 exhaust on civichatch
- Need Help Please!!! 92 CX Hatchcrap!
- cel light wont stop blinking
- Get my clutch master and slave cylinder fixed and get a new tranny?
- Side markers
- h&r cup kit, any info?
- Del Sol Dash Into EH Hatch??? (searched)
- Adjusting coilovers?
- Whitest and brightest?
- Need bump stop for shocks. where to get?
- TIE RODS.....and BOOTS...
- web site to see wheels
- 88-91 header on 92-95?? Will it fit??
- mounting VAFC
- Fed ex came today....lip kit is here, ?'s on rear lip install
- fitment issues on wheels*16x8 with 45 offset*
- anybody knows a website for cheap oem parts?
- New guy here... My hatch
- oh es oval question?
- where can i find an ex cat?
- Fitting Tein SS EK on EG
- Has anyone done this? ITB
- WTH is a trail user?
- Picking up a D16Y8 tranny for $100 tonight. To good to be true?
- clutch to use with jdm D15b vtec???
- my friend wants to trade his b20b for my b16a3
- A few start up questions
- Opinions needed... exhaust and header match
- bolting frame to seat help ?
- Vadalism**** My hatch was broken into last night!!!
- My motor is leaking oil, why?????
- hood latch
- What could prevent VTEC from engaging?
- Does anyone know where I can find some oem honda foglights for my 94' hatch
- ignition problem?
- what pistons to use on my b18 w/ b16 head?
- gauge needles
