View Full Version : Honda Civic / Del Sol (1992 - 2000)
- just wondering how much this car is worth
- D-Series Q's - Stroker kits? D17 crank in D16? I need some answers!
- Civic Type R rims
- Anyone had experience with Matrix HID kits?
- Swap is finally coming together.
- h22 swap.... gauges
- d15b and d16z6 guys read please!!!!!
- b18c5 o2 sensor wiring in CX
- HELP!!!!!!!!!!
- Washing seats Q?
- does tein ss suspension for dc5 fit eg?
- 99-00 Canadian SiR never existed!!!
- WHAT is the difference?!??!?!?!?
- Looking for SRR LCA's?
- Wanted: H22 Facts
- Part Number# for JDM 99-00 CTR headlamps with city lights?
- White 4 door Ferrio w/ exhaust in GLENDALE, CA area???
- exedy clutches
- 5th gen stock header
- 5/27/03 Bolsa Chica Photoshoot *56k go take a dump*
- can someone post a pic of there AEM short or cold air intake(92-95 civic)
- How Much For B16A
- B18c5 in EG question
- if you were to start all over, what platform would you start with?
- speedometer/odometer problems
- On the topic of lips!
- JDM ITR non-airbag wheel illegal?
- smells like burnt oil
- car looks "lifted" after rear swaybar install
- AEM Rail - 99 Si Fuel feed!?!
- Headlight Alignment Question
- Need opinion on DYNOMAX Ultru Flow Exhaust
- What's the best bulb "TYPE"?
- little black hatch vid...
- 1/4 mile time =| whatever dude
- how can u tell the year of your engine?
- What fuel pump 4 B16a
- real quick question....
- 2dr/hatch and 4door fenders are different, correct??
- Spark plugs
- High Compression Pistons
- Worth it?
- Havent posted pics of the ride in a while
- es oval / magnaflow oval, what piping?
- anyone has a KOSEI RIMS??
- anyone looking for a 2000 civic dx INJEN intake??
- anyone looking for a d16y7 ???
- 2000 DX with pic
- Quick question about stuck coolant drain plug
- Anyone in this forum have sounds wavs of exhaust systems?
- Pics of eg hatch with mugen front lip?
- Rebuilding rear gsr caliper?
- help with ek hatch
- reverse light fuse?
- help, axles for h22.
- My power lock RATTLES!!! How do i fix it??? HELP ME!!!!!!
- My srs light is on? How do i fix it??? HELP ME!!!!!!
- My horn stopped working? How do i fix it??? HELP ME!!!!!!
- RS Grill for EK?
- Sticking rear gsr Caliper on hatch?
- n00b intro with pics and questions
- Anyone have a Supercharged D16Y8?
- Brake swap EJ to Integra - instructions?
- Ok fuq it im stumped. GURUS please. Timing question
- Sparco Sprints
- EP3 CTR Steering Wheel: Do they fit 96-00 Civics, would cruise control work?
- car got broken into at WORK!
- personal exp. with OBX cat-backs???
- Power Steering Question
- Eg6 lca'a???????????
- Short Shifter On Si
- Tech: Apexi WS Exhaust (I'm on 56k)
- Question??
- Would you buy, Prefab AWD kit for 96-00 hatch? Just wondering
- Injen heat shield
- Might be doing a STi review compare to my EG just like the Evo.........
- removing bumper supports
- peak HP for stock fuel pump?
- Offset question?
- H02 Sensor ?s
- Need Muffler Help.
- Some tech that might apply here
- I passed smog at the callifornia smog ref w/ my 99 jdm b16 in my eg
- 2000 civic flushmount wing..pics anyone?
- D16y8 or b16a
- How much for an Apexi WS exhaust?
- carfax?
- z6 y8
- Questions on D series
- readers rides...
- pics request: 92-95 hatches with lips...
- Question on 98civic front ends...
- Need a favor. Please look.
- no spark, need help
- 95 GSR Rear Seats in 98 HB
- D series calculator..If this is accurate the Y8 with A1 pistons= 13.1:1 comp
- What do you know about these?
- Making my own 3 in Downpipe and full exhuast, What bends do i need??
- how long an i a trial user for??
- AEM, Gude, DPR or JG for NA Y8 work...
- want to make a ignition cut off switch were do i splice?
- need help with build up
- Headers? '97 Del Sol SI
- Cheapest Rotas???
- motor swap
- B16Bin a 95 civic?
- Comptech Icebox Which filter??
- 96 4-door Civic for Sale!
- RADIATOR FAN alternative
- What sidemarker is this??
- Radio relocation Kits for EK...where can I find one?
- Aftermarket Down Pipe?
- Need to know what OEM Shocks/Springs fit a 1994 civic ex coupe for going back to stock?
- Different makes with same bolt pattern ?
- swap Question?
- Ground Control Spring Rate
- 99-00 Si rear calipers the same as DC2 Integra's?
- ecu in new swap
- SRR Suspension
- How's fitment on aftermarket polyurethane bushings?
- 94 civic DX question.
- How long does trail user take? CANT POST
- 95 4 door exhaust
- Ingalls camber kit install on 96 coupe.
- wiring CTR power folding mirror's(searched)
- need help with my turbo EG LS setup
- Removed cylinder head rust on cylinder walls need advice?
- Track times w/auto tranny
- anyone with a hatch have the WW rear?
- Spoon Stuff
- Looking for a certain style rear bumper.
- Decisions decisions........what to do?
- Wheel Recommendation (newbie)
- does anyone know if this brake combo will work?????help
- oil pressure sensor switch?!
- big dillemma, should i sell my ek hatch for a right hand drive integra
- So I Had To Settle For These Wheels....
- ANYONE near Md/Va/Dc wanna make some $$$???
- Swap question about purge tank
- Tough Decisions, Tough Decisions...
- outy dings...on a ek
- EG Owners with Stock Honda CD Players
- in car race video
- Why am I blowing out the clutch master cylinder?
- 1996 Civic CX
- thinking about getting rid of my EK
- b16a2(nashville tn)
- FI or NA on H22A
- Tein S-tech Springs
- air conditioning re-install
- 98 dx sedan with EX Head what do I need
- anyone run a Bseries AC bracket with a D series compressor?
- Complete LS into a 94 DX swap guide
- Is this a good deal for a 92-95 Civic turbo kit?
- ek years front bumpers fitting and stuff
- Air Condition Problem
- What Axles???
- anyone using a insight steering wheel
- Thermal Exhaust and a Del Sol???
- did swap need help!!!!!
- What's this worth?
- Got Hit and ran =( poor little hatcie
- pictures of my 2000 civic Si
- good place to buy b16 transmisson?
- my car pic
- i need the facts about the h22 swap into a 93 cx
- i got the obd2 blues...
- Dying interior plastic panels
- F the Ref and the Manager at the dealer......
- B-Series
- integra type r engine into eg hatch
- jump your ECU
- Visa tires???? Need more info & help
- Stop and go Problems
- Daily driver....is it worth it??
- I just got a apexi N1 exhaust
- which brake m/s and p/p valve
- Pic Request: EK Sedan Red/Clear
- All Motor B20 owners......
- same CR, ctr pistons or endyn with eagle rods?
- Best size tires for 14x6 rims. 185/65 or 195/65
- HELP!!! w/ JDM gsr b18c in 93 civic
- how much for a rebuild on a h22?
- Pulley?
- Need some wholsale companies that are reputable. Can't find that post fro ma while ago.
- Hercules G5000Z tires... LOL
- auto-manual -searched-
- Spark plug cross threaded and stuck.
- air/fuel guage..working half ass...
- swap question.
- timing belt on my b20vtec.. help..
- HELP: b16 rev problem
- Do these rear LCA's look straight to you?
- Anyone scan 96 civic 3 door helms?
- 95 Civic DX needs a new cluster...
- CF hood weight
- will D series engine fit on 85 civic?
- a/f to ecu?
- 00 B18C1 shortblock
- LSD in gearbox!
- should i make more of these?
- question on h&r springs..
- inspection sticker question
- Ground Zero Motorsports Pics...
- Which shift linkage for swap?
- Turn Signal lights not flashing??
- Trunk Lock
- vtec solenoid
- cheap ways to make an EK fast????
- Carfax request
- Catalytic Converter question on swap.
- quick question: 96 civic coupe......
- will 99-00 si steel brake lines work on a 96-00 civic ex
- Exhaust help needed
- Transmission Ratio
- Carbon Fiber
- 98 civic problems with header
- Will stock 99 Integra shocks fit on a 97 Civic?
- OBD II to OBD I conversion..whats needed???
- valve clearance
- Tires for my SI
- totalled front end
- Pictures of my 95 Civic VX Hatchback!
- How to tell if you have factory keyless entry???
- b16B to B18C
- Gauge Cluster
- Considering Spoon n1 axle back, what b pipe for EG with itr swap?
- Wheel alignment for the street?
- quick question, does 93 delsol si come with stock front sway bar, also general suspension questions?
- Spoon Rear Strut Tower Bar - Does it require modifications beyond cutting cargo lining?
- engine check light (help)!!
- dc5r brakes on 01 civic??
- how to ad a/c to my 00 hatchback.
- my D16 went kaboom!!!!
- headgasket question
- Weird CEL's ..Help Im confused!!
- turbine size
- ITR Brake upgrade on an EK HELP
- Help b16a1 swap to 92' civic hatch
- wiring my o2 sensor directly to my ecu?
- Whats thes best 2.5'' exhaust?
- What exhaust should i get? (I can't decide)
- Carfax History
- ALT 210 15x6.5 13.3lbs?
- my history of cars *i'm bored* no 56k
- what the hell is this?
