View Full Version : Honda Civic / Del Sol (1992 - 2000)
- windshield washers for carbon hood
- 92-95 turn signals went out..all of em
- 95 del Sol -- Tach going crazy, any ideas? (VIDEO)
- CEL and car idle jumps from 800-1500 rpm
- Clunking noise from front side
- Have you purchase from rockauto.com?
- weird compression problem
- SiR Spoiler - What is it?
- 92 si too loud
- 99 Civic LX - skunk2 intake manifold needs a different IACV
- What distributor do I use for my 93 hatch
- D15Z1/D16Z6 mini me?
- which valves open at TDC?
- going b20 vtec any sugestions?
- 94 Civic CX Hatch Build Thread
- 1999 si loosing power
- missing 1st, 2nd, and reverse. HELP!
- Help: Should I keep my 95 Civic Ex?
- will 92-95 civic eg 4dr hood fit on 92-95 civic eg hatchback?
- 98 Civic EX - Cranks, fuel pump primes, no Spark, no Tach, and CEL code 0
- '00 Civic Sedan EX Fenderwell trim?
- 97 civic ex/00 gsr swap overheating sometimes
- Inexpensive Motor/Transmission Mounts
- 99 Civic EX - CEL code 20
- 95 ex w/ jdm b16b ? About tap noise
- 2000 Si with a B20 swap Starting problems
- B16a Timing belt flaps over 3k RPM
- OEM Springs for 94 Civic Coupe
- 1990 CRX parts on 1997 Civic??
- 90' CRX parts on 97' Civic??
- 95 Civic DX Clutch Chatter
- 93 Del sol si misfire problem.
- 93 del sol LEEEAAAKKKS
- LED Dash?
- 1999 Honda Civic Si Strange Fuel Pressure issue
- help
- can i use a zc block in replace of my oem d16y8 motor????
- 1993 Ej1 Budget Build
- A/C Idler pulley bearing is whining and no refrigerant in A/C system
- Can you modify a d16z6 pump to fit d16y7
- What hood would I need for a Del Sol with an eg front end conversion?
- Need help identifying Civic EJ8/EK D16y8 Header/exhaust parts
- Skunk2 shifter
- What car are these seats from?
- RSX Seats. EK. Not lining up.
- blower not working?
- help! pushing coolant into overflow tank 96 civic
- Where can I buy OEM fog lights for my 98 Civic?
- Cranking problem -- VERY ODD (solved)
- Is the fact that my EK Amber Clock always on normal?
- Will front knuckles from 98 civic ex bolt directly onto 92 civic dx hatch?
- '97 Civic LX Auto (D16Y7) surging idle. CEL: P0505. IACV and TB cleaned already.
- 1995 Honda Civic Oil Light Flashing
- Mild b16 eg hatch build
- Loud bang = handling issue?
- 2000 Civic Si/EM1 smells like burnt (oil?) after hitting v-tec
- Where to get a good copy type r lip?
- Will a tow hook look right where this cutout is? Or do I need new bumper?
- Rear CTR Seats Direct Bolt in?
- 1999 em1 AC
- b16a vtec wont work in my 94 civic dx
- Crazy idling and overheating
- b16 No injector pulse
- 1999 Civic SI wont start after compression check. HELP!
- Problems with my D16Z6....bogging
- eg power steering pump in ek
- Bad radiator or headgasket?
- Where do I find parts for a D15B7?
- speedometer dont work
- Anyone know what this is called?
- Timing belt came loose during driving, car wont start after adjusting
- JDM D15B VTEC problems
- 93 del sol is sputtering at 1000 idle
- Rear trailing arm bushing question
- ek9 side skirt
- 94 Civic Bubble ECU HELP!!
- What wheels are these?? Top left..
- 95 Del Sol Brake problem
- 95 civic sedan - all guages not working on civic?? help
- D16z6 CV Axle Transmission Oil Seal Problems!
- DC5 Recaro seats in EK. Low rails?
- 2000 d16y7 hatch
- Enignes choices for '93 civic
- how do I convert Civic sedan interior from tan to black
- tps sensor not working?
- What I did to my Civic today - my build thread
- Help!! 93 Civic CX with B16 SirII swap into 93 Civic SI question
- Need some help w/ emission pls
- MY 94 Civ EX detonation Problem w/video
- How much PAG oil to add?
- honda civic d16y8 code91
- 94 civic cx/B18B1 swap - code 41 after new O2 sensor
- difference in valves, y5, y8, z6
- 97 civic bad rear mount
- b16a cut out
- Combustion Chamber Diagnosis
- What type of coolant do our cars use?
- 3rd Brake light
- Rod Bearings....
- Car was getting hot now wont start
- I can't start my 95 Civic
- 93 Del sol/gsr trans axle wont go in all the way
- 1994 Civic cold engine acceleration hesitation
- 95 Civic/B16a swap - 15A ECU fuse blowing
- Gauges behind cup holder
- cranks,but wont start
- Trick for removing axle from transmission?
- 1997 Civic HX clutch bleeding problem.
- Engine running a little hot 94 civic ex
- Need help w/ Firewall harness removal!
- Brake Light Issue
- 98 ---> 00 Civic Front and Rear End Conversions - please help
- E Brake button spring?
- Ek coupe motor swap
- Integra Type R oil pump on B16A2 timing cover issue
- intake manifold identification - pr3 and HF-4 stamps seen
- 98 civic thermostat
- set timing after head removal
- Fuse Box and battery relocation
- OBD2B to OBD1 Harness Problem - No Tach
- someone help solve the overheating in my 98 civic ex
- D16Z6 Head gasket...
- Weird ac noise and cycles often but still blows cold
- 93 del sol no pwer whatsoever
- OBD1 91 civic drag car - power loss and code 15
- 99 si with itr swap - delayed response from clutch pedal
- Part Number for Cylinder Head Bolts?
- 93 civic si - i'm starting to build up and need advice
- vtec-e sputter
- is there a diy converting door man to auto windows, locks etc.?
- 98 civic ex auto swap to b16a2 manual help?
- Car Tips On Buying A Used Civic
- d series timing belt tensioner
- 2000 Civic y8 to y7 downgrade Idle bounce/rough driving help and advice needed
- SRS light will not turn ON - Can't pass inspection
- Installed new rear hub assembly, normal for bearing to be stiff?
- engine oil dye safe for seals gaskets?
- 96 civic wont go into gear when engine is on but will when off
- Front Tire Wear and Bent Frame, Says Firestone
- 98 civic cooling fan relay
- 98 Civic radiator fan not working
- mini me opinion and fact...
- 2000 Si w/B18C swap just started idling at 1500 and sputters from 800-1500 in neutral
- Where is my brake fluid going?
- Rust spots on my Honda Civic
- 94 civic ex - hunting idle, smoking, and overheating
- 98 Civic HX - Long delay in fuel pump priming (solved)
- Clutch pedal sticking a little?
- 92 Civic: How do I remove a/c reciever/dryer?
- Which axle seal? B series transmission, 93 Del sol
- Switches for e-brake console
- Can anyone identify this cable? Under steering wheel
- swapping throttle bodies
- Just bought 97 Civic EX auto w/98K+miles - any concerns?
- Has anyone bought JDM Engine Corp?
- help oil leak changed oil pan gasket, rear main and clutch
- 00 Civic DX Exhaust length Question
- Changing Mileage on the Odometer
- need quick answer, 99-2000 civic interior pieces work in 96-98?
- help. del sol rear garnish removal.
- My fuel tank is rusted. Can I use one from any 96-00 Civic?
- Lights dimming/flickering while dimming... Sometimes?
- 1997 Civic HX swap
- Engine swap D16y to a d15b jdm
- d16z6 head d16y7 block idle problems!! 1000 to 2500 rpm
- CEL P0170 and P0172, Bank 1 Too Rich/Fuel Trim. NEED HELP PLEASE!
- ebay intake manifold
- 96 Civic: Need wire schematic for wiper/washer circuit
- 93 ex eg wont drive???
- Mini-me Del sol
- Ticking sound in D16 engine
- 98 Civic wont start - turn key and nothing happens (solved)
- Car wont start
- 96-00 Trunk lip spoiler options??
- B-Series Rebuild Bible??
- 95 LX won't turn over after disconnecting negative cable...
- Resurface, or new rotors?
- Brake Lights Won't Turn Off
- passenger side window not working.needhelp!
- 93' Honda Del Sol - rust, power window, and power steering questions!
- Civic doesnt roll like it should
- I have spark, and no CEL, but car won't start/stay running
- 99 EM1 - Wiring Help with Green Plug C131
- help picked up eg hatch but it stauls when i press the gas
- Engine Bogging/Smoking
- 1999 Ex Coupe MT Exploded...
- Oil in my radiator?
- car wont start sometimes. now not starting at all
- Brake pedal going to floor slowly. civic 1995 ex d16z6
- R12 to R134a conversion - need help with ac compressor change
- 1992 civic knock crack noise from front
- LS Swap/Eg-ATF line routing?
- D Series B7 and Y8 Compatability Question
- 96 civic ex keyless entry problem.
- Civic VX O2 sensor replacement
- need help!!
- b18b Eg just died; now ACG fuse keeps blowing
- 96 Civic Doesn't Start Replaced Many Parts
- 00' Civic A/C pressure builds, compressor stops
- Power steering fluid leaked on alternator
- General Bushings Advice
- 96 civic dx - Should I wire in secondary O2 sensor or convert to obd1 p28 computer?
- Install Extended Wheel Studs
- Re-wiring entire car
- ek civic engine vin location?
- What is my car worth? GSR swapped Hatch!
- Can not get my 99 civic ex with b20 to start. Reaching out for help!!!
- How can I get my cam timing top dead center?
- What else do I need for AC?
- 2000 civic door lock rattle help
- timing belt installation; skipping teeth
- 93 Civic turns over but fuel pump has no power
- 00 Civic DX has codes 8 & 9 - Need help with DIY Distributor replacement
- 6th gen hatch exhaust conversion
- rotor rust...
- '95 hatch stock replacement suspension
- 92 Civic Won't start - has spark and fuel pump primes
- Crank chipped at woodruff key
- high idle untill stopped
- EG Ferio different exhaust systems
- 96 Civic w/ B18C1 swap clutch master cylinder
- car wont start, dizzy issue?
- driver window issue
- Help!! B18C swap starting issue.
- car starts but wont stay on!! help plz
- 95 civic ex axle problems
- velocityshop.com reviews
- exhaust interchangability
- where can i find or order sir bumber
- REAR MAIN SEAL QUESTION. B16 99 EM1
- K-Tuned Traction Bar Del Sol
- Speed Tach Has A Tantrum
- Civic loses power after warmed up
- Steering Wheel horn button
- Fried ECM???
- Oil pan gasket change help
- sparkplug for honda civic d16y8
- Valve Lapping?
- 99 Ek wont start. Help plz
- d16z6 speed sensor
- 95 dx coupe mini me swap, connecting vtec
- got rear ended i need some advice please!
- 92 civic cx/B16 swap - Will a PR4 ecu work?
- 97 civic d16y8 throttle body
- Buying a car that needs an ecu...help?
- Need help with swapping D16Z6 into a 92 civic Si hatch
- Rattle sound at 2500 rpm in neutral and in gear
- Engine Warning Light, Limp Mode & Bluey Smoke!!!
- CLUTCH REPLACEMENT???
- Front Endliknks
