View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Rear Seat Options For EG Civic Coupe
- What happen if a piece of medal came out.....
- Header Pipe nut frozen
- brake firmness issue
- 16x7.5 +43mm for civic.
- OBD communications
- S20 92-95 EX/Si or P20 96-00 EX Tranny?
- eg8's
- 8psi on ex motor and i dont know if 12:1 fmu will work or not
- obd1
- help for b16 sirII swap to eg
- Limp Mode but VTEC engages
- is this a good deal for gauges?
- Red/Clear Tail Lights
- gear problems??
- P28 ECU
- Jacks
- d15b not revving
- Swapping airbag to new steering wheel ring?
- Question about griding gears...
- lookin for a nice car... around 4k in pa/ny area
- parts for sale
- airbag question(they saved me!!)
- d16y8/b16a
- too much smoke?
- Realy long to warm up
- b18c1 specs
- governors got any?
- Map sensor and IACV
- mothers car please help!
- transmission or what? please help
- Transmission Replacement
- b16
- p28 ecu with uberdata
- 96-98 fuse box layout
- Would the jdm integra front conversion fit on a eg?
- moonroof scrapes against the roof.help.
- dx seats? does any one know what seats these are ?
- Question about intake..
- cat back exhaust VS Regular Exhaust
- HELP!
- B18b Oil Questions
- WTB: 98 ex engine harness
- Freakin window..
- Where can i get bseries synchros?
- 99-00 Si cluster gauge for sale cheap!!
- b16a2?
- D.O. 6?
- Whats better for inspection high or low octane??
- 89 Integra Fogs, On a 96 EK
- funny noise when i accelerate
- Cold Running Problem Jdm B18c hatch
- the truth about engine swaps
- what do i do!!
- MY BRAKES ARE SHOT!!!
- Couple of questions?
- advance timing
- b16 injector o-rings
- Bay area Shops
- Fittipaldi Rims??
- Good / Bad / Nothing To Worry About? (wheel well liners)
- Camber Help
- question about my dropped hatch
- car shakes
- Quick EK sideskirt question
- Turbo D15b7...
- CEL: ’99 Civic EX Autozone OBDII reader can't read code??
- 96 cx oxygen sensor primary vs seconday problem
- Feedback Needed: Is balancing crank a waste for my setup?
- cat question
- Sloppy short shifter
- failed emissions. help, have numbers
- 00 interior conversion
- Buying a new Civic ...NEED HELP BADLY!!
- Ro_ta rims
- hp question
- PLEASE HELP WITH EK9 IDLE
- removing window crank/door panel
- brake pedal goes to floor. HELP!
- need new suspension
- WTB in Miami area
- koni yellow question ... ?
- ej1 guage cluster...door ajar question
- Fidanza short shifters
- Del Sol Greddy SP2 Advice
- HELP! California Smog Legal Del Sol S Motor Swap Advice Needed
- Fitment/quality of replica spoilers
- GSR fuel filter on 93 Civic HB?
- B16 Vtec
- Injector Harness. Any order?
- Auto ecu to manual?
- Does any one know of any trick on taking off e-brake handle for eg civic, Wow im sweting here!
- JDM EG Headlights, What Bulbs to Use besides stockers? Need better output
- Exedy Stage 2
- Has anybody been able to contact anyone at ASR?
- Trans question
- rear disc brake conversion on 96-00 civic
- quick Maryland State Inspection ???
- Skunk2 Stage 2 Cams + Smog test = no good?
- Can anyone tell for what transmission this ignition switch is for??
- 93 del sol transmission
- ARC Airbox Specs
- rough idle
- Oil spraying everywhere in my bay. Could bad PCV valve be cause?
- D16Y8 IM on D15B7?
- b20/vtec?
- Part Number??
- oil pan fitment?? help please...
- NPT Fitting question
- a/c question
- Degraded antenna seal + rain = rust?!
- Car not heating up
- 99 civic si CD player code??
- radiator proble,
- where to get rims
- What should be next?
- B20 pulley/thermostat housing on a B16A2 ?
- Auto to Stick Swap
- Question on vehicle purchase
- Where is the cheapest place to buy a complete Comptech air intake for a 97 del sol?
- brakes loosing pressure when making a tight turn... master cylinder problem? or brake booster
- EG sidemarkers
- EG Civic hatch Stacker Placement?
- Question about cruise control and spedos
- Carbon Fiber hatch
- Tire Problem please come in everybody
- check engine code 6
- JDM Vtec Solenoid Vs US Vtec Solenoid
- dirrect swap for my civic
- Bent rack and pinion question ? how to fix ?
- Anyone work at Acura/Honda? Trade in value im curious about :)
- frame damage?
- Which is this Mugen twinloop made for?
- engine prep for turbo?
- Some help with motor swap
- B18A/C valve cover interchangeable w/ B18B?
- Hello, please help me with this question
- 99 Civic CX SPECS?
- JDM ej2 sidemarker help?
- TEMP GAUGE QUESTION
- Light switch problem, wont switch off parking lights
- place to buy motors?
- civic swap w/ac? possible?
- still problems with new ecu.
- Which Wire Harness
- o2 sensor HELP
- any way to eliminate the evap system??
- What would you pay?
- CTR piston setup
- quick question on b20
- Coolant problems OH MY HELP
- which radiator hoses for b16 eg swap
- Short Throw Shifter question and clutch acting funny
- Quick Oil Pan Question
- Computer Swap?
- another cat question
- how to ship civic seats
- CR-V Seats in EG???? Will It Work
- comptech Icebox in 99/00 si
- Ek, Kosei wheel offset question?(I searched)
- will a b18c1 flywheel work with a b16a2 tranny?
- Honda vs. DSM
- for sale ctr
- Random misfire question???
- How to take off cluster glass/Or how did you put in your bezel??
- BODYKIT ? anyone interested
- Cluster Help
- vx 02 sensor
- help finding thread, one that shows plug in block that has to be removed 4 vtec
- DSMS
- cluster question?
- non oem front bumper fitment???
- WEIRD OIL LEAK UNDERNEATH TRANNY?
- lagging problem with acceleration
- wiring diagram
- SI Tranny With Vin Tag??
- EG's with password JDM front lip
- Alternator question 96 DX hatch
- Shop for Turbo who ships to Germany ?
- Engine start ?'s
- Camber Kit help!
- does anyone have experience with this set up?
- swap
- 99 civic with a M2B4 tranny...what axles fit...?
- overheating
- what ecu?
- oil spewing out
- installing grille and bumper
- D15b VTEC wiring???
- check engine light CODE 43 on my honda civic!!!!need help!!!
- 94 civic dx What's the best way to get more power?
- AIR FILTER QUESTION!
- ek dash harness + CEL
- 93 eg dx w/ b16 cel any one know what it could be
- cruise control into dx eg
- Scammer alert: JDMCARBOY
- tokico blue struts and stock springs....?
- Which radiators fit the 99-00 EX coupe?
- **Help**, Looking for DIY link to make my "Si" emblem in the gauge cluster light up.....**
- Will H&R Sport Springs fit stock shocks?
- nub question
- d16z6 vtec intake mannifold on a d15b vtec
- ROSS pistons??
- Crx si seats in eg...
- Need help with Speed sensor..Changing trans fluid.
- NYS OBD2 emissions....swap???
- how to quiet exhaust?
- throwing a 73 code on a del sol
- For the people who had to put a new headliner and Interior in, I need some part numbers!
- O2 simulator
- remove stock airbox¿
- Help Air/Fuel Gauge install
- Water pumps
- making way for turbo D... pics
- Short shifter installation on '96 Civic hatchback
- p28 tuning
- AEM vs. INJEN???
- how do fix gas leak on my I/M ?
- anyone done this swap?
- ECU in safety mode
- B18 going into EG, what power steering bracket needed to run power steering pump?
- Looking for a 92-95 Civic SI emissions control system diagram
- wth is grinding when i turn left?
- will tail lights from an EG coupe fit an EG hatch?
- bad 02 sensor
- motor 4 my eg coupe..b20B
- help on jdm b16a starter ASAP!!
- driver side shock tower wire diagram?
- Help! Someone tried to steal my car and....
- d16y7 intake manifold
- How To: Auto->Manual conversion on an EK4
- 96-98 vtec engine harness
- Tranny grinds
- help d15b not reving after swap need help asap!!!
- HELP: with my steering wheel height adjustment
- looking for b motor?
- I finished my Clutch and Flywheel job.... I wanna say thanks to everyone here on HT !
- d16y8 blocks
- wiring tuck for 92-05 civic hatchback
- 2000 EX h22a swap help
- Oil pressure Problem EK9
- Another rear quarter panel rust thread
- Ep3 wheel fittment?
- Check Engine lights suck
- what is this piece called?
- Stupid question obd1 or obd2
- Need a torque spec.
- 99 si engine problems?? help me out
- performance cam
- Wiper Question
